Текущее время: Сб авг 22, 2026 17:52
Начать новую тему Ответить на тему  [ Сообщений: 18 ]  На страницу Пред.  1, 2
СообщениеДобавлено: Вт сен 21, 2010 22:35
Какое-то странное "недопонимание" получилось... :(
Не пойму, на чьей стороне проблема.
Конфиг 3612:
sh sw
Command: show switch
Device Type       : DGS-3612G Gigabit Ethernet Switch
MAC Address       : 00-1E-XX-XX-XX-00
IP Address        : 192.168.4.254 (Manual)
VLAN Name         : management
Subnet Mask       : 255.255.252.0
Default Gateway   : 192.168.7.250
DGS-3612G:5#sh ipif
Command: show ipif
IP Interface                : System
Interface Admin state       : Enabled
IPv4 Address                : 192.168.4.254/22 (Manual)  Primary
IP Interface                : abon101
VLAN Name                   : druzba
IPv4 Address                : 10.0.192.1/22 (Manual)  Primary
IP Interface                : abon102
VLAN Name                   : orehova
IPv4 Address                : 10.0.196.1/22 (Manual)  Primary
IP Interface                : abon103
VLAN Name                   : libknehta
IPv4 Address                : 10.0.200.1/22 (Manual)  Primary
IP Interface                : abon104
VLAN Name                   : kalinina
IPv4 Address                : 10.0.204.1/22 (Manual)  Primary
IP Interface                : abon105
VLAN Name                   : proletarskaya
IPv4 Address                : 10.0.208.1/22 (Manual)  Primary
 Total Entries   : 6
DGS-3612G:5#sh dhcp_relay
Command: show dhcp_relay
DHCP/Bootp Relay Status         : Enabled
DHCP/Bootp Hops Count Limit     : 4
DHCP/Bootp Relay Time Threshold : 0
DHCP Relay Agent Information Option 82 State  : Enabled
DHCP Relay Agent Information Option 82 Check  : Disabled
DHCP Relay Agent Information Option 82 Policy : Replace
Interface    Server 1        Server 2        Server 3        Server 4
abon103      192.168.7.250
System       192.168.7.250
Конфиг роутера (он же DHCP сервер):
IP 192.168.7.250
ddns-update-style none;
        option ms-classless-static-routes code 249 = array of unsigned integer 8;
        option rfc3442-classless-static-routes code 121 = array of unsigned integer 8;
        log-facility local3;
if exists agent.circuit-id
log (
info, concat( " Lease for ",
binary-to-ascii (10, 8, ".", leased-address),
#" Swith port: ",
#binary-to-ascii (10, 8, ".", option agent.circuit-id),
" Relay MAC: ",
binary-to-ascii (16, 8, ":", suffix ( option agent.remote-id, 6)),
" Router IP: ",
binary-to-ascii(10, 8, ".", packet(24, 4)),
" VLAN: ",
binary-to-ascii (10, 16, "", substring( option agent.circuit-id, 2, 2)),
" MAC of subscriber: ",
binary-to-ascii (16, 8, ":", substring(hardware, 1, 7))
shared-network vlan103 {
subnet 10.0.200.0 netmask 255.255.252.0 {
class "match_vlan_103"
      match if ( binary-to-ascii(10, 16, "",  substring(option agent.circuit-id, 2, 2)) = "103");
    authoritative;
    deny unknown-clients;
    deny duplicates;
    option subnet-mask              255.255.252.0;
    option broadcast-address        10.0.203.255;
    option routers                  10.0.200.1;
    ddns-domainname                 "mynet.net";
    option domain-name-servers      XX.XX.XX.XX;
    option time-offset              14400;
    option time-servers             XX.XX.XX.XX;
    option ntp-servers              XX.XX.XX.XX;
    option ms-classless-static-routes       24, 10,254,213, 10,0,200,1, 22, 10,0,192, 10,0,200,1, 22, 10,0,204, 10,0,200,1, 22, 10,0
,196, 10,0,200,1, 22, 10,0,208, 10,0,200,1;
    option rfc3442-classless-static-routes  24, 10,254,213, 10,0,200,1, 22, 10,0,192, 10,0,200,1, 22, 10,0,204, 10,0,200,1, 22, 10,0
    option-82;
    boot-unknown-clients            false;
    default-lease-time 21600;
    max-lease-time 43200;
  pool {
    allow members of "match_vlan_103";
    range 10.0.200.2 10.0.203.254;
    include "/etc/dhcpd/vlan103.conf";
cat /etc/dhcpd/vlan103.conf
host user001 {
hardware ethernet 00:11:11:11:11:11;
next-server XX.XX.XX.XX;
fixed-address 10.0.200.18;
В итоге, host с МАС адресом 00:11:11:11:11:11 получает IP 10.0.200.18, НО! Маска подсети = 255.0.0.0, шлюз и DNS отсутствует.
Не понимаю, где затык... :cry:
СообщениеДобавлено: Пт сен 24, 2010 16:27
KovAl59 писал(а):
terrible писал(а):
Объясните идиоту: зачем на 3612 использовать otp 82?
Ну во-первых, на 3612 НЕ _opt 82_, а dhcp_relay option_82.
в контексте данного форума "Option 82" и "DHCP Relay Option 82" это практически синонимы ;)
KovAl59 писал(а):
А во-вторых, dhcp_relay option_82, для того чтобы объяснить dhcp серверу, из какой vlan припёрся данный МАС. Чтобы тот (dhcp сервер) выдал ему (клиенту) соотв. IP и отправил его в соотв. vlan.
Или все же кто-то из нас двоих перепутал тёплое с мягким? ;)
да, перепутал, и этот кто-то - Вы ;) на кой хрен, простите, Вам сдалась Option 82 если Вы по старинке хотите выдавать IP на МАС? Option 82 как раз нужна для того чтобы выдать IP на определенный порт/VLAN свича, т.к. она (опция) эту инфу и несет (DHCP Realy ЕМНИМС содержит в себе только инфу об IP свича через который прошел запрос), в противном случае, если действовать по старинке, ее можно и не использовать ...
BTW, DHCP сервер занимается только выдачей IP и "отправлением их в соответствующий VLAN", как Вы изволили выразиться, не занимается ;)
с уважением, БП
СообщениеДобавлено: Пн сен 27, 2010 15:16
Option82 содержит инфу о порте, вилане и свитче... а поскольку релей предполагается на агрегации, а не на доступе - Opt82 тут очень пригодится...
Это текст, который можно добавлять к размещаемым вами сообщениям. Длина его ограничена 255 символами.
