Текущее время: Ср сен 30, 2026 13:08
 Заголовок сообщения: DES3200-28F address-binding
СообщениеДобавлено: Пт сен 17, 2010 12:11
Проблема в следующем.
Имеем три dhcp binding'a (время лиза 300сек):
show address_binding dhcp_snoop binding_entry
Command: show address_binding dhcp_snoop binding_entry
IP Address      MAC Address       Lease Time (secs) Port  Status
10.93.4.24      00-24-54-AA-9D-C4 290               9     Active
10.93.4.28      00-1E-8C-1A-F4-86 294               12    Active
10.93.4.77      00-24-54-08-E9-60 295               13    Active
Total Entries : 3
При достижении 150 сек(и соответственно DHCP request'a) ситуация меняется:
10.93.4.24      00-24-54-AA-9D-C4 296               9     Active
10.93.4.28      00-1E-8C-1A-F4-86 300               [b]13[/b]    Active
10.93.4.77      00-24-54-08-E9-60 294               13    Active
Конфиг address-binding'a:
enable address_binding dhcp_snoop
enable address_binding trap_log
disable address_binding arp_inspection
config address_binding ip_mac ports 1 state disable allow_zeroip enable forward_dhcppkt enable
config address_binding ip_mac ports 1-24 mode acl stop_learning_threshold 500
config address_binding dhcp_snoop max_entry ports 1-24 limit 5
config address_binding ip_mac ports 2-24 state enable strict allow_zeroip enable forward_dhcppkt enable
config address_binding ip_mac ports 25-28 state disable allow_zeroip disable forward_dhcppkt enable
config address_binding ip_mac ports 25-28 mode arp stop_learning_threshold 500
config address_binding dhcp_snoop max_entry ports 25-28 limit no_limit
disable dhcp_relay
config dhcp_relay hops 4 time 0
config dhcp_relay option_82 state disable
config dhcp_relay option_82 check disable
config dhcp_relay option_82 policy replace
config dhcp_relay option_82 remote_id default
enable dhcp_local_relay
config dhcp_local_relay option_82 remote_id default
config dhcp_local_relay vlan vlanid 3001 state enable
config dhcp_local_relay option_82 ports 1-24 policy replace
config dhcp_local_relay option_82 ports 25-28 policy keep
СообщениеДобавлено: Пт сен 17, 2010 12:13
show switch
Command: show switch
Device Type        : DES-3200-28F Fast Ethernet Switch
MAC Address        : 00-1E-58-6E-D5-C0
IP Address         : 172.16.1.16 (Manual)
VLAN Name          : mgmt
Subnet Mask        : 255.255.252.0
Default Gateway    : 172.16.0.1
Boot PROM Version  : Build 1.00.B003
Firmware Version   : Build 1.33.B002
Hardware Version   : A1
Serial Number      : P4NQ198000024
System Location    :
System Uptime      : 0 days, 21 hours, 57 minutes, 17 seconds
System Contact     :
Spanning Tree      : Disabled
GVRP               : Disabled
IGMP Snooping      : Disabled
VLAN Trunk         : Disabled
802.1X             : Disabled
Telnet             : Enabled (TCP 23)
Web                : Disabled
RMON               : Disabled
SSH                : Disabled
SSL                : Disabled
CLI Paging         : Enabled
Syslog Global State: Enabled
Dual Image         : Supported
Password Encryption Status : Disabled
СообщениеДобавлено: Пн сен 20, 2010 10:51
Что, никто с этим не сталкивался?
СообщениеДобавлено: Пн сен 20, 2010 13:28
Проблема проявляется на одном коммутаторе или на нескольких? Проблема всегда с одним клиентом или может случаться с любым? STP используете? Может просто топология перестроилась?
СообщениеДобавлено: Пн сен 20, 2010 13:34
Пришлите пожалуйста мне на почту полностью выгруженный конфигурационный файл со ссылкой на форум.Я проверю по Вашему описанию.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 95
