Текущее время: Вс сен 27, 2026 19:27
СообщениеДобавлено: Ср сен 01, 2010 13:47
Доброго времени!
Столкнулись с тем, что свитч на прошивках старше 2.52.b03 не получает адрес по DHCP после команды config ipif system dhcp.
софт 2.52.b03:
#tcpdump -vvv  -i eth0 ether src 1c:af:f7:79:f3:f3
12:00:08.831088 IP (tos 0x0, ttl 30, id 2, offset 0, flags [none], proto UDP (17), length 328) 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 1c:af:f7:79:f3:f3 (oui Unknown), length 300, xid 0x1d001d, Flags [Broadcast] (0x8000)
          Client-Ethernet-Address 1c:af:f7:79:f3:f3 (oui Unknown) [|bootp]
12:00:09.008755 arp who-has 172.16.2.215 tell 172.16.2.215
12:00:09.009055 arp who-has 172.16.2.215 tell 172.16.2.215
12:00:14.009674 IP (tos 0x0, ttl 30, id 4, offset 0, flags [none], proto UDP (17), length 328) 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 1c:af:f7:79:f3:f3 (oui Unknown), length 300, xid 0x1d001d, Flags [Broadcast] (0x8000)
12:00:14.030441 arp who-has 172.16.0.1 tell 172.16.2.215
12:00:14.030741 arp who-has 172.16.0.1 tell 172.16.2.215
софт 2.53.b04:
11:51:43.244462 IP (tos 0x0, ttl 30, id 4, offset 0, flags [none], proto UDP (17), length 328) 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 1c:af:f7:79:f3:f3 (oui Unknown), length 300, xid 0x5b005b, Flags [Broadcast] (0x8000)
11:51:51.244255 IP (tos 0x0, ttl 30, id 6, offset 0, flags [none], proto UDP (17), length 328) 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 1c:af:f7:79:f3:f3 (oui Unknown), length 300, xid 0x5b005b, Flags [Broadcast] (0x8000)
11:52:03.244166 IP (tos 0x0, ttl 30, id 8, offset 0, flags [none], proto UDP (17), length 328) 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 1c:af:f7:79:f3:f3 (oui Unknown), length 300, xid 0x5b005b, Flags [Broadcast] (0x8000)
11:52:16.243673 IP (tos 0x0, ttl 30, id 10, offset 0, flags [none], proto UDP (17), length 328) 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 1c:af:f7:79:f3:f3 (oui Unknown), length 300, xid 0x5b005b, Flags [Broadcast] (0x8000)
и так до бесконечности...
СообщениеДобавлено: Ср сен 01, 2010 17:25
Я проверю по Вашему описанию и напишу Вам по результатам.
СообщениеДобавлено: Чт сен 02, 2010 09:28
Похоже на правду. Не получает.
СообщениеДобавлено: Чт сен 02, 2010 10:20
На тестовом стенде проблема подтвердилась, я написал в ШК по этому вопросу.Как только появятся новости я Вам сообщу.
СообщениеДобавлено: Пн сен 06, 2010 03:21
На 2.53.B03 работает, вроде. Прошил большое количество коммутаторов, все работают без проблем уже две недели.
СообщениеДобавлено: Пн сен 06, 2010 08:14
ТС пишет что если прошивка выше чем указанная, тогда не получает.)
СообщениеДобавлено: Пн сен 06, 2010 08:21
Я писал, что если версия выше 2.52.b03. Да и Victor Soloviev подтверждает.
СообщениеДобавлено: Вт сен 07, 2010 02:03
Проблема возникла еще в ветке 2,52. в 10 билде, по-моему или около того, я написал о проблеме. В ветке 2,53 версии 3 поправили, в 4 судя по всему опять поломали.
СообщениеДобавлено: Ср сен 08, 2010 09:19
Прошивка, исправляющая данную проблему, появится в середине сентября.
СообщениеДобавлено: Чт сен 09, 2010 16:58
Прошивка вышла.Автору топика выслал.Остальным просьба запрашивать в соответствующей теме.
