Текущее время: Вс окт 04, 2026 13:38
 Заголовок сообщения: Проблема с DGS-3200-28
СообщениеДобавлено: Чт авг 12, 2010 16:51
Перестал отвечать коммутатор DGS-3200-28. Версия прошивки и boot-prom'а:
Boot PROM Version : Build 1.00.B003
Firmware Version : Build 1.21.B007
При подключении консолью выводил:
sysToMonitor
sysGetCountb86df53a
sysGetCompare959397c0
intCRGet00008428
ReadEPCb1181570
ReadBVA00000000
ReadERRPC00000000
vxSpGet84976010
SR = 0x10007c00
--- Stack Trace ---
FUNC = 0x80002160, PC = 0x800021b4 (0x800021b4), SP = 0x84976030
FUNC = 0x80188e0c, PC = 0x80188f40 (0x80188f40), SP = 0x84976048
FUNC = 0x801880e0, PC = 0x80188204 (0x80188204), SP = 0x849760b0
RA 0xb1151544 out of range
sysToMonitor
sysGetCountc98edfd6
intCRGet00008428
ReadEPCb1181570
ReadBVA00000000
ReadERRPC00000000
vxSpGet84975ed0
SR = 0x10007c00
--- Stack Trace ---
FUNC = 0x80002160, PC = 0x800021b4 (0x800021b4), SP = 0x84975ef0
FUNC = 0x80188e0c, PC = 0x80188f40 (0x80188f40), SP = 0x84975f08
FUNC = 0x801880e0, PC = 0x80188204 (0x80188204), SP = 0x84975f70
sysToMonitor
sysGetCountdaafca46
intCRGet00008428
ReadEPCb1181570
ReadBVA00000000
ReadERRPC00000000
vxSpGet84975d90
SR = 0x10007c00
--- Stack Trace ---
FUNC = 0x80002160, PC = 0x800021b4 (0x800021b4), SP = 0x84975db0
FUNC = 0x80188e0c, PC = 0x80188f40 (0x80188f40), SP = 0x84975dc8
FUNC = 0x801880e0, PC = 0x80188204 (0x80188204), SP = 0x84975e30
sysToMonitor
sysGetCountebd0b4c7
intCRGet00008428
ReadEPCb1181570
ReadBVA00000000
ReadERRPC00000000
vxSpGet84975c50
SR = 0x10007c00
--- Stack Trace ---
FUNC = 0x80002160, PC = 0x800021b4 (0x800021b4), SP = 0x84975c70
FUNC = 0x80188e0c, PC = 0x80188f40 (0x80188f40), SP = 0x84975c88
FUNC = 0x801880e0, PC = 0x80188204 (0x80188204), SP = 0x84975cf0
sysToMonitor
sysGetCountfcf19f51
intCRGet00008428
ReadEPCb1181570
ReadBVA00000000
ReadERRPC00000000
vxSpGet84975b10
SR = 0x10007c00
--- Stack Trace ---
FUNC = 0x80002160, PC = 0x800021b4 (0x800021b4), SP = 0x84975b30
FUNC = 0x80188e0c, PC = 0x80188f40 (0x80188f40), SP = 0x84975b48
FUNC = 0x801880e0, PC = 0x80188204 (0x80188204), SP = 0x84975bb0
sysToMonitor
sysGetCount0e1289d8
intCRGet00008428
ReadEPCb1181570
ReadBVA00000000
ReadERRPC00000000
vxSpGet849759d0
SR = 0x10007c00
--- Stack Trace ---
FUNC = 0x80002160, PC = 0x800021b4 (0x800021b4), SP = 0x849759f0
FUNC = 0x80188e0c, PC = 0x80188f40 (0x80188f40), SP = 0x84975a08
FUNC = 0x801880e0, PC = 0x80188204 (0x80188204), SP = 0x84975a70
sysToMonitor
sysGetCount1f33744b
intCRGet00008428
ReadEPCb1181570
ReadBVA00000000
ReadERRPC00000000
vxSpGet84975890
SR = 0x10007c00
--- Stack Trace ---
FUNC = 0x80002160, PC = 0x800021b4 (0x800021b4), SP = 0x849758b0
FUNC = 0x80188e0c, PC = 0x80188f40 (0x80188f40), SP = 0x849758c8
FUNC = 0x801880e0, PC = 0x80188204 (0x80188204), SP = 0x84975930
sysToMonitor
sysGetCount30545ecb
intCRGet00008428
ReadEPCb1181570
ReadBVA00000000
ReadERRPC00000000
vxSpGet84975750
SR = 0x10007c00
--- Stack Trace ---
FUNC = 0x80002160, PC = 0x800021b4 (0x800021b4), SP = 0x84975770
FUNC = 0x80188e0c, PC = 0x80188f40 (0x80188f40), SP = 0x84975788
FUNC = 0x801880e0, PC = 0x80188204 (0x80188204), SP = 0x849757f0
В чём может быть проблема и как её устранить?
СообщениеДобавлено: Пт авг 13, 2010 09:08
При включении питания коммутатора через консоль нажмите shift+3, вы попадёте в бутменю, через которое удалите образ прошивки и залейте ту, которую я Вам выслал.
СообщениеДобавлено: Пт авг 13, 2010 09:24
А заменить прошивку без удаления старой можно? И в каком порядке обновлять boot-prom?
СообщениеДобавлено: Пт авг 13, 2010 09:29
Через бутменю я Вам это делать не рекомендую.
Сначала замените прошивку и убедитесь в работоспособности коммутатора, затем тем же способом обновите пром.
СообщениеДобавлено: Пт авг 13, 2010 10:16
Спасибо, попробуем.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 62
