Текущее время: Пт авг 14, 2026 09:28
 Заголовок сообщения: DES-3828 IP-MAC Binding, DHCP/BOOTP Relay
СообщениеДобавлено: Ср авг 11, 2010 05:49
Конфигурация:
VID : 1 VLAN Name : default
VLAN TYPE : static Advertisement : Enabled
Member ports : 1
Static ports : 1
Current Tagged ports :
Current Untagged ports : 1
Static Tagged ports :
Static Untagged ports : 1
Forbidden ports :
VID : 2 VLAN Name : V_1(Servers)
Member ports : 2-18,25
Static ports : 2-18,25
Current Tagged ports : 18,25
Current Untagged ports : 2-17
Static Tagged ports : 18,25
Static Untagged ports : 2-17
Forbidden ports :
VID : 4 VLAN Name : V_3(Avers_Multi)
Member ports : 27-28
Static ports : 27-28
Current Untagged ports : 27-28
Static Untagged ports : 27-28
Forbidden ports :
VID : 5 VLAN Name : V_5(Switch)
Member ports : 15,18,25
Static ports : 15,18,25
Current Tagged ports : 15,18,25
Static Tagged ports : 15,18,25
Forbidden ports :
VID : 6 VLAN Name : V_7(DMZ)
Member ports : 19-23
Static ports : 19-23
Current Untagged ports : 19-23
Static Untagged ports : 19-23
Forbidden ports :
VID : 7 VLAN Name : V_100
Member ports : 15,26
Static ports : 15,26
Current Untagged ports : 26
Static Untagged ports : 26
Forbidden ports :
VID : 401 VLAN Name : V_6(Avers_Alukom)
Member ports : 24-25
Static ports : 24-25
Current Tagged ports : 24-25
Static Tagged ports : 24-25
Forbidden ports :
Total Entries : 7
IP Interface Settings
Interface Name : System
IP Address : 10.90.90.1 (MANUAL)
Secondary : FALSE
Subnet Mask : 255.255.255.0
Admin. State : Enabled
Proxy ARP : Disabled
Link Status : Link UP
Member Ports : 15,18,25
Interface Name : net_0/24
IP Address : 192.168.0.1 (MANUAL)
Secondary : FALSE
Member Ports : 2-18,25
Interface Name : net_100/24
IP Address : 192.168.100.1 (MANUAL)
Secondary : FALSE
VLAN Name : V_100
Member Ports : 15,26
Total Entries : 3
OSPF ECMP : Disabled
Routing Table
IP Address/Netmask Gateway Interface Hops Protocol
10.90.90.0/24 0.0.0.0 System 1 Local
192.168.0.0/24 0.0.0.0 net_0/24 1 Local
192.168.100.0/24 0.0.0.0 net_100/24 1 Local
Total Entries : 3
DHCP/BOOTP Relay Status : Enabled
DHCP/BOOTP Hops Count Limit : 4
DHCP/BOOTP Relay Time Threshold : 0
DHCP Relay Agent Information Option 82 State : Disabled
DHCP Relay Agent Information Option 82 Check : Disabled
DHCP Relay Agent Information Option 82 Policy : Replace
Interface Server 1 Server 2 Server 3 Server 4
net_100/24 192.168.0.9
ACL_mode : Disabled
Trap/Log : Disabled
Enabled ports : 26
Enabled ports (Loose) :
Enabled allow_zeroip ports : 26
Enabled forward_DHCPpkt ports: 1-28
Command: show address_binding dhcp_snoop
DHCP_Snoop : Enabled
Теперь о сути самой проблемы.
Клиент получил ип адрес из подсети 192.168.100.0/24 все отлично.
Работает маршрутизация, работает DHCP.
Включаем IP-MAC Binding, видим мак в таблице маков. Видим режим AUTO.
В блок листе его нет.
Проходит 5 минут и у человека куда-то мистически пропадает сеть. Он просто обновляет настройки сети посредством клавиши исправить, и сеть появляется. Проходит 3 – 4 минуты и снова те же грабли.
В общем, помогите разобраться, в чем дело.
СообщениеДобавлено: Ср авг 11, 2010 09:11
Укажите версию прошивки, после включения/выключения функций пробовали перезагружать коммутатор?
СообщениеДобавлено: Ср авг 11, 2010 09:45
Build 4.50.B27
Пробовал не однократно.
Да и его шибко не по перезагружаешь.
Через него сеть в 300 машин смотрит в интернет.
СообщениеДобавлено: Ср авг 11, 2010 09:52
Попробуйте прошивку которую я я Вам выслал и напишите по результатам.
СообщениеДобавлено: Ср авг 11, 2010 14:10
Хм.. стало еще хуже.
Тепер после включения опции по привязке падает DHCP reley.
Чтото как то совсем плохо...
СообщениеДобавлено: Ср авг 11, 2010 14:14
Укажите версию прошивки, которую Вы установили?
Build 4.50.B37
СообщениеДобавлено: Ср авг 11, 2010 14:21
Установите пожалуйста 4.61-В20
СообщениеДобавлено: Ср авг 11, 2010 14:23
А вот тут загвоздка...
Я администрирую в любом интерфейсе, но напарник (девушка) она с юникс подобными не умеет обращатся, мало того еще 2 человека глядят в веб на нем..
Этот вариант отпадает, так как в ней нет WebUi
Внимание!
В des3828r46_4.61.had отсутствует WebUI!
Есть еще идеи?
СообщениеДобавлено: Ср авг 11, 2010 14:33
Что в логах DHCP сервера? Вы используете option 82?
СообщениеДобавлено: Ср авг 11, 2010 14:36
WIn2003 srv
Адрес получает, после включения опции IP-MAC Binding
сеть работает спустя 3 минуты падает на машине, отключаю опцию все равно машина пролезть не куда не может, хотя на порте есть активность.
Перегружаю свитч, опция 82 начинает работатьь хоть час хоть два.
СообщениеДобавлено: Ср авг 11, 2010 16:25
Похоже дело не в бабине.
Все перепробовал.
Как аказалось это проблемма только на комбо портах....
26-27
Переделал vlan, сделал 2ой порт все работает и прошивку вернул старую.
:oops:
Помоему вам необходимо протестировать тчательно эту модель.
Проверил на двух DES-3828
Могу сказать серийные номера.
На втором тотже баг.
