Текущее время: Чт авг 27, 2026 01:18
Начать новую тему Ответить на тему  [ Сообщений: 384 ]  На страницу Пред.  1 ... 18, 19, 20, 21, 22, 23, 24 ... 26  След.
СообщениеДобавлено: Вс авг 01, 2010 13:21
Лог с модема в студию.
DSL-2500U/BRU/D. Fw 1.58.
СообщениеДобавлено: Вс авг 01, 2010 13:33
Date/Time Facility Severity Message
Aug 1 11:51:47 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=109.165.106.62 DST=109.165.81.164 LEN=48 TOS=0x00 PREC=0x00 TTL=125 ID=2012 DF PROTO=TCP SPT=3975 DPT=1433 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 1 12:04:31 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=178.88.47.12 DST=109.165.81.164 LEN=48 TOS=0x00 PREC=0x00 TTL=115 ID=4807 DF PROTO=TCP SPT=9460 DPT=6881 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 1 12:17:06 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=109.165.30.190 DST=109.165.81.164 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=34069 DF PROTO=TCP SPT=3174 DPT=445 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 1 12:21:50 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=188.134.40.136 DST=109.165.81.164 LEN=48 TOS=0x00 PREC=0x00 TTL=114 ID=63827 DF PROTO=TCP SPT=4474 DPT=6881 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 1 12:35:06 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=188.134.40.136 DST=109.165.81.164 LEN=48 TOS=0x00 PREC=0x00 TTL=114 ID=53339 DF PROTO=TCP SPT=1956 DPT=6881 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 1 12:42:55 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=174.17.133.30 DST=109.165.81.164 LEN=48 TOS=0x00 PREC=0x00 TTL=113 ID=7553 DF PROTO=TCP SPT=1090 DPT=445 WINDOW=16384 RES=0x00 SYN URGP=0
Aug 1 12:55:03 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=109.165.103.185 DST=109.165.81.164 LEN=48 TOS=0x00 PREC=0x00 TTL=125 ID=17192 DF PROTO=TCP SPT=4565 DPT=445 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 1 13:01:30 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=188.134.40.136 DST=109.165.81.164 LEN=48 TOS=0x00 PREC=0x00 TTL=114 ID=35567 DF PROTO=TCP SPT=4432 DPT=6881 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 1 13:13:31 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=95.78.89.195 DST=109.165.81.164 LEN=48 TOS=0x00 PREC=0x00 TTL=241 ID=44264 DF PROTO=TCP SPT=2898 DPT=6881 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 1 13:27:59 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=188.134.40.136 DST=109.165.81.164 LEN=48 TOS=0x00 PREC=0x00 TTL=114 ID=45258 DF PROTO=TCP SPT=3147 DPT=6881 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 1 13:40:50 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=109.165.123.93 DST=109.165.81.164 LEN=64 TOS=0x00 PREC=0x00 TTL=125 ID=15180 DF PROTO=TCP SPT=4115 DPT=445 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 1 13:41:10 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=188.134.40.136 DST=109.165.81.164 LEN=48 TOS=0x00 PREC=0x00 TTL=114 ID=18945 DF PROTO=TCP SPT=4329 DPT=6881 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 1 13:54:24 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=188.134.40.136 DST=109.165.81.164 LEN=48 TOS=0x00 PREC=0x00 TTL=114 ID=10695 DF PROTO=TCP SPT=1944 DPT=6881 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 1 14:07:35 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=188.134.40.136 DST=109.165.81.164 LEN=48 TOS=0x00 PREC=0x00 TTL=114 ID=51036 DF PROTO=TCP SPT=3215 DPT=6881 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 1 14:11:16 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=109.165.7.221 DST=109.165.81.164 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=47692 DF PROTO=TCP SPT=1898 DPT=1433 WINDOW=65535 RES=0x00 SYN URGP=0
наверное это...настроил в режим дебага.
СообщениеДобавлено: Вс авг 01, 2010 13:38
Это мало, нужен весь.
СообщениеДобавлено: Вс авг 01, 2010 13:54
ок... тогда пусть с часик модем поработает и я выложу
СообщениеДобавлено: Вс авг 01, 2010 14:03
нужен лог модема в момент возникновения проблемы, т.е. в течении 5-10 минут послу дисконекта, когда модем сам не переподключается
лучше всего поставить на комп программу для сбора логов
СообщениеДобавлено: Вс авг 01, 2010 14:11
хорошо. в постах выше где-то видел. так и поступлю.
СообщениеДобавлено: Вс авг 01, 2010 20:54
вот смотрите :
Здесь глюкнуло электричество и связь оборвалась. Реконект так и не наступил!
192.168.1.1,08/01/10 21:14:54,08/01/10 21:14:54,,user-level,Critical,kernel,,"ADSL G.992 channel analysis"
192.168.1.1,08/01/10 21:15:00,08/01/10 21:15:00,,user-level,Critical,kernel,,"ADSL link up, interleaved, us=637, ds=6143"
192.168.1.1,08/01/10 21:15:00,08/01/10 21:15:00,,user-level,Warning,kernel,,"ADSL2/ADSL2+ connection"
192.168.1.1,08/01/10 21:15:00,08/01/10 21:15:00,,user-level,Warning,kernel,,"ATM Soft SAR: ATM link connected."
192.168.1.1,08/01/10 21:15:02,08/01/10 21:15:02,,user-level,Debug,syslog,,"iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107"
192.168.1.1,08/01/10 21:15:03,08/01/10 21:15:03,,system,Info,pppd[346],,"Using interface ppp0_0_35_1"
192.168.1.1,08/01/10 21:15:03,08/01/10 21:15:03,,system,Notice,pppd[346],,"Connect: ppp_0_0_35_1 <--> 0.0.35"
192.168.1.1,08/01/10 21:15:04,08/01/10 21:15:04,,system,Info,pppd[346],,"LCP terminated by peer"
192.168.1.1,08/01/10 21:15:07,08/01/10 21:15:07,,system,Notice,pppd[346],,"Connection terminated...."
192.168.1.1,08/01/10 21:15:37,08/01/10 21:15:37,,system,Info,pppd[346],,"Using interface ppp0_0_35_1"
192.168.1.1,08/01/10 21:15:37,08/01/10 21:15:37,,system,Notice,pppd[346],,"Connect: ppp_0_0_35_1 <--> 0.0.35"
192.168.1.1,08/01/10 21:16:07,08/01/10 21:16:07,,system,Warning,pppd[346],,"LCP: timeout sending Config-Requests "
192.168.1.1,08/01/10 21:16:07,08/01/10 21:16:07,,system,Notice,pppd[346],,"Connection terminated...."
192.168.1.1,08/01/10 21:16:07,08/01/10 21:16:07,,system,Info,pppd[346],,"Exit."
Здесь после ресета кнопкой восстановилась связь.
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,syslogd,Emergency,,,"BCM96345 started: BusyBox v1.00 (2010.04.27-07:21+0000)"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Notice,kernel,,"klogd started: BusyBox v1.00 (2010.04.27-07:21+0000)"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Debug,syslog,,"sntp -s clock.fmt.he.net -s none -t ""Moscow, St. Petersburg, Volgograd"" &"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"Linux version 2.6.8.1 (joan@BB3) (gcc version 3.4.2) #1 Tue Apr 27 15:19:05 CST 2010"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"Serial flash device: name S25FL016A, id 0x0114, size 2048KB"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"96332 prom init"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"CPU revision is: 00029010"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"Determined physical RAM map:"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"memory: 007a0000 @ 00000000 (usable)"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Debug,kernel,,"On node 0 totalpages: 1952"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Debug,kernel,,"DMA zone: 1952 pages, LIFO batch:1"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Debug,kernel,,"Normal zone: 0 pages, LIFO batch:1"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Debug,kernel,,"HighMem zone: 0 pages, LIFO batch:1"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"Built 1 zonelists"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"Kernel command line: root=31:0 ro noinitrd console=ttyS0,115200"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"brcm mips: enabling icache and dcache..."
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"Primary instruction cache 16kB, physically tagged, 2-way, linesize 16 bytes."
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"Primary data cache 8kB 2-way, linesize 16 bytes."
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"PID hash table entries: 32 (order 5: 256 bytes)"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"Using 120.000 MHz high precision timer."
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"Memory: 6024k/7808k available (1287k kernel code, 1764k reserved, 184k data, 64k init, 0k highmem)"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"Calibrating delay loop... 239.20 BogoMIPS"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"Mount-cache hash table entries: 512 (order: 0, 4096 bytes)"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"Checking for 'wait' instruction... unavailable."
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"NET: Registered protocol family 16"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"Total Flash size: 2048K with 32 sectors"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"File system address: 0xbfc10100"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"Can't analyze prologue code at 801506c4"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"PPP generic driver version 2.4.2"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"NET: Registered protocol family 24"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"Using noop io scheduler"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"bcm963xx_mtd driver v1.0"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"brcmboard: brcm_board_init entry"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,""
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"======= GPIO CONFIG_BCM96338 inited ========"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"Serial: BCM63XX driver $Revision: 3.00 $"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"ttyS0 at MMIO 0xfffe0300 (irq = 10) is a BCM63XX"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"NET: Registered protocol family 2"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"IP: routing cache hash table of 512 buckets, 4Kbytes"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"TCP: Hash tables configured (established 512 bind 1024)"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"NET: Registered protocol family 1"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"NET: Registered protocol family 17"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Notice,kernel,,"Ebtables v2.0 registered"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"NET: Registered protocol family 8"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"NET: Registered protocol family 20"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"All bugs added by David S. Miller <davem@redhat.com>"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"VFS: Mounted root (squashfs filesystem) readonly."
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"Freeing unused kernel memory: 64k freed"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"Algorithmics/MIPS FPU Emulator v1.5"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"atmapi: module license 'Proprietary' taints kernel."
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"adsl: adsl_init entry"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"blaadd: blaa_detect entry"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"Broadcom BCMPROCFS v1.0 initialized"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"Broadcom BCM6338A2 Ethernet Network Device v0.3 Apr 27 2010 15:17:46"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"Config Internal PHY Through MDIO"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"BCM63xx_ENET: 100 MB Full-Duplex (auto-neg)"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"eth0: MAC Address: 00:21:91:94:C4:98"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Critical,kernel,,"eth0 Link UP."
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"BcmAdsl_Initialize=0xC0068A48, g_pFnNotifyCallback=0xC0081784"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"AnnexCParam=0x7FFF7EB8 AnnexAParam=0x00000980 adsl2=0x00000000"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"pSdramPHY=0xA07FFFF8, 0x9E7B78BE 0x7DB9FFF3"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"AdslCoreHwReset: AdslOemDataAddr = 0xA07EF96C"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"DoInitialize: do kerSysRegisterDyingGaspHandler"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"dgasp: kerSysRegisterDyingGaspHandler: dsl0 registered "
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"DoInitialize: do put_user"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"DoInitialize: do kerSysLedCtrl"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"ATM proc init !!!"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Critical,kernel,,"ADSL G.994 training"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"ip_tables: (C) 2000-2002 Netfilter core team"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"ip_conntrack version 2.1 (61 buckets, 0 max) - 376 bytes per conntrack"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"ip_conntrack_pptp version 2.1 loaded"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"ip_nat_pptp version 2.0 loaded"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"ip_conntrack_rtsp v0.01 loading"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"ip_nat_rtsp v0.01 loading"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Warning,kernel,,"unregistering helper for port 5060"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"device eth0 entered promiscuous mode"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"br0: port 1(eth0) entering learning state"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"br0: topology change detected, propagating"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"br0: port 1(eth0) entering forwarding state"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"device nas_0_0_38 entered promiscuous mode"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"br0: port 2(nas_0_0_38) entering learning state"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"br0: port 2(nas_0_0_38) entering forwarding state"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"device eth0 left promiscuous mode"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"br0: port 1(eth0) entering disabled state"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"device nas_0_0_38 left promiscuous mode"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"br0: port 2(nas_0_0_38) entering disabled state"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Info,kernel,,"cted, propagating"
192.168.1.1,08/01/10 21:19:35,08/01/10 21:19:35,,user-level,Debug,syslog,,"echo > /var/snmpd.conf"
192.168.1.1,08/01/10 21:19:46,08/01/10 21:19:46,,user-level,Critical,kernel,,"ADSL G.992 channel analysis"
192.168.1.1,08/01/10 21:19:53,08/01/10 21:19:53,,user-level,Critical,kernel,,"ADSL link up, interleaved, us=637, ds=6143"
192.168.1.1,08/01/10 21:19:53,08/01/10 21:19:53,,user-level,Warning,kernel,,"ADSL2/ADSL2+ connection"
192.168.1.1,08/01/10 21:19:53,08/01/10 21:19:53,,user-level,Warning,kernel,,"ATM Soft SAR: ATM link connected."
192.168.1.1,08/01/10 21:19:54,08/01/10 21:19:54,,user-level,Debug,syslog,,"iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107"
192.168.1.1,08/01/10 21:19:56,08/01/10 21:19:56,,system,Info,pppd[332],,"Using interface ppp0_0_35_1"
192.168.1.1,08/01/10 21:19:56,08/01/10 21:19:56,,system,Notice,pppd[332],,"Connect: ppp_0_0_35_1 <--> 0.0.35"
192.168.1.1,08/01/10 21:20:05,08/01/10 21:20:05,,system,Notice,pppd[332],,"PAP authentication succeeded"
192.168.1.1,08/01/10 21:20:06,08/01/10 21:20:06,,system,Notice,pppd[332],,"local IP address 87.117.59.107"
192.168.1.1,08/01/10 21:20:06,08/01/10 21:20:06,,system,Notice,pppd[332],,"remote IP address 83.221.214.195"
192.168.1.1,08/01/10 21:20:06,08/01/10 21:20:06,,system,Notice,pppd[332],,"primary DNS address 80.254.111.13"
192.168.1.1,08/01/10 21:20:06,08/01/10 21:20:06,,system,Notice,pppd[332],,"secondary DNS address 83.221.202.254"
192.168.1.1,08/01/10 21:20:07,08/01/10 21:20:07,,user-level,Debug,syslog,,"route add default gw 83.221.214.195 2>/dev/null"
192.168.1.1,08/01/10 21:20:07,08/01/10 21:20:07,,user-level,Debug,syslog,,"iptables -A FORWARD -o ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu"
192.168.1.1,08/01/10 21:20:08,08/01/10 21:20:08,,user-level,Debug,syslog,,"iptables -A FORWARD -i ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu"
192.168.1.1,08/01/10 21:20:08,08/01/10 21:20:08,,user-level,Debug,syslog,,"echo > /proc/net/ip_conntrack"
192.168.1.1,08/01/10 21:20:08,08/01/10 21:20:08,,user-level,Debug,syslog,,"echo ""600"" > /proc/sys/net/ipv4/ip_conntrack_max"
192.168.1.1,08/01/10 21:20:08,08/01/10 21:20:08,,user-level,Debug,syslog,,"echo 2000 > /proc/sys/net/ipv4/netfilter/ip_conntrack_generic_timeout"
192.168.1.1,08/01/10 21:20:08,08/01/10 21:20:08,,user-level,Debug,syslog,,"echo 600 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_established"
192.168.1.1,08/01/10 21:20:08,08/01/10 21:20:08,,user-level,Debug,syslog,,"echo 1400 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_fin_wait"
192.168.1.1,08/01/10 21:20:08,08/01/10 21:20:08,,user-level,Debug,syslog,,"echo 120 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_time_wait"
192.168.1.1,08/01/10 21:20:08,08/01/10 21:20:08,,user-level,Debug,syslog,,"echo 4096 > /proc/sys/net/ipv4/ipfrag_high_thresh"
192.168.1.1,08/01/10 21:20:08,08/01/10 21:20:08,,user-level,Debug,syslog,,"echo 1024 > /proc/sys/net/ipv4/ipfrag_low_thresh"
192.168.1.1,08/01/10 21:20:08,08/01/10 21:20:08,,user-level,Debug,syslog,,"echo 5 > /proc/sys/net/ipv4/ipfrag_time"
192.168.1.1,08/01/10 21:20:08,08/01/10 21:20:08,,user-level,Debug,syslog,,"iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null"
192.168.1.1,08/01/10 21:20:08,08/01/10 21:20:08,,user-level,Debug,syslog,,"iptables -t nat -D POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null"
192.168.1.1,08/01/10 21:20:08,08/01/10 21:20:08,,user-level,Debug,syslog,,"iptables -t nat -A POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE"
192.168.1.1,08/01/10 21:20:08,08/01/10 21:20:08,,user-level,Debug,syslog,,"iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 80.254.111.13 2>/dev/null"
192.168.1.1,08/01/10 21:20:08,08/01/10 21:20:08,,user-level,Debug,syslog,,"iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 80.254.111.13"
192.168.1.1,08/01/10 21:20:08,08/01/10 21:20:08,,user-level,Debug,syslog,,"/bin/dnsprobe &"
192.168.1.1,08/01/10 21:20:09,08/01/10 21:20:09,,user-level,Notice,dnsprobe[559],,"dnsprobe started! "
192.168.1.1,08/01/10 21:20:10,08/01/10 21:20:10,,user-level,Debug,syslog,,"echo 4096 > /proc/sys/net/ipv4/ipfrag_high_thresh"
192.168.1.1,08/01/10 21:20:10,08/01/10 21:20:10,,user-level,Debug,syslog,,"echo 1024 > /proc/sys/net/ipv4/ipfrag_low_thresh"
192.168.1.1,08/01/10 21:20:10,08/01/10 21:20:10,,user-level,Debug,syslog,,"echo 5 > /proc/sys/net/ipv4/ipfrag_time"
нифига в этом не понимаю. помогите пожалуйста.
СообщениеДобавлено: Вс авг 01, 2010 21:19
А до строчек
в логе что?
Выложи лог с момента разрыва + 10 попыток переподключения
На первый взгляд похоже, что какие-то глюки у провайдера.
СообщениеДобавлено: Пн авг 02, 2010 06:09
Magnitudo писал(а):
А до строчек
в логе что?
Ну до того момента все работало нормально. И как я сказал, глюкнуло электричество и модем стал перезагружаться. Как видно в логе попыток последующего подключения было всего 3 :shock: . После чего сессия была закрыта, а новую так и не открыли.
СообщениеДобавлено: Пн авг 02, 2010 07:32
Процесс завершен. Никаких соединений не будет.
После прошивки 2640u/bru/c1 версией 1.24 получил такой же результат - завершение pppd про реконнекте. С версией 1.23 и 2500u/bru/d3 (1.54) такой проблемы нет. Также помогает включение "Bridge PPPoE Frames Between WAN and Local Ports".
СообщениеДобавлено: Пн авг 02, 2010 07:33
По приведенному куску лога непонятно почему произошел разрыв.
По приведенному куску лога видно, что модему не удалось отправить один из контрольных запросов.
Интересно именно почему происходит разрыв и как модем на него реагирует! Из лога нужен момент разрыва и лог модема в течении 10-15 минут попыток подключения.
А если у Вас электричество глючит несколько раз в день, то сразу рекомендую посадить модем на UPS, т.к. глюки могут быть и из-за помех по электропитанию.
СообщениеДобавлено: Пн авг 02, 2010 19:02
Дело в том, что у меня интернет через PPPOA, то есть через АТС. И опции у меня такой нет.
Повторяюсь опять. Сама по себе сессия не рвется. Коннект стабильный! НО, стоит глюкнуть электричеству, ресетнуть модем из браузера или иногда даже просто его включить, не коннекта не реконекта нет. Раньше такой проблемы у меня не было. Я точно знал что модем в любом случае приконектиться. Помогает только кнопка ресет на модеме.
P.S. У меня есть подробный лог с того момента как я пришел домой и включил сеть для компа и всего что с ним связанно. Ниже приведу.
Вот, смотрите господа. Это я просто пришел домой и включил пилот общий для всего компьютерного у меня.
"192.168.1.1,08/02/10 18:56:24,08/02/10 18:56:24,,system,Notice,pppd[346],,""Connection terminated...."""
"192.168.1.1,08/02/10 18:56:24,08/02/10 18:56:24,,system,Warning,pppd[346],,""LCP: timeout sending Config-Requests """
"192.168.1.1,08/02/10 18:56:24,08/02/10 18:56:24,,system,Info,pppd[346],,""Exit."""
Далее жму ресет на модеме когда увидел что он так и не приконектился.
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,syslogd,Emergency,,,""BCM96345 started: BusyBox v1.00 (2010.04.27-07:21+0000)"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Critical,kernel,,""eth0 Link UP."""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Critical,kernel,,""ADSL G.994 training"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Critical,kernel,,""ADSL G.992 started"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Critical,kernel,,""ADSL link down"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Notice,kernel,,""klogd started: BusyBox v1.00 (2010.04.27-07:21+0000)"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Notice,kernel,,""Ebtables v2.0 registered"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""Linux version 2.6.8.1 (joan@BB3) (gcc version 3.4.2) #1 Tue Apr 27 15:19:05 CST 2010"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""Serial flash device: name S25FL016A, id 0x0114, size 2048KB"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""96332 prom init"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""Memory: 6024k/7808k available (1287k kernel code, 1764k reserved, 184k data, 64k init, 0k highmem)"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""CPU revision is: 00029010"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""NET: Registered protocol family 16"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""Determined physical RAM map:"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Debug,kernel,,""On node 0 totalpages: 1952"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""PPP generic driver version 2.4.2"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""memory: 007a0000 @ 00000000 (usable)"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Debug,syslog,,""sntp -s clock.fmt.he.net -s none -t """"Moscow, St. Petersburg, Volgograd"""" &"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""NET: Registered protocol family 24"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Debug,kernel,,""DMA zone: 1952 pages, LIFO batch:1"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""Built 1 zonelists"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""Serial: BCM63XX driver $Revision: 3.00 $"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Debug,kernel,,""Normal zone: 0 pages, LIFO batch:1"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""Kernel command line: root=31:0 ro noinitrd console=ttyS0,115200"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""NET: Registered protocol family 2"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Debug,kernel,,""HighMem zone: 0 pages, LIFO batch:1"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""brcm mips: enabling icache and dcache..."""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""IP: routing cache hash table of 512 buckets, 4Kbytes"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""Primary instruction cache 16kB, physically tagged, 2-way, linesize 16 bytes."""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""TCP: Hash tables configured (established 512 bind 1024)"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""Primary data cache 8kB 2-way, linesize 16 bytes."""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""NET: Registered protocol family 1"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""PID hash table entries: 32 (order 5: 256 bytes)"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""NET: Registered protocol family 17"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""Using 120.000 MHz high precision timer."""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""NET: Registered protocol family 8"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""NET: Registered protocol family 20"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""Calibrating delay loop... 239.20 BogoMIPS"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""All bugs added by David S. Miller <davem@redhat.com>"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""Mount-cache hash table entries: 512 (order: 0, 4096 bytes)"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""Freeing unused kernel memory: 64k freed"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""Checking for 'wait' instruction... unavailable."""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""Broadcom BCMPROCFS v1.0 initialized"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""Total Flash size: 2048K with 32 sectors"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""BCM63xx_ENET: 100 MB Full-Duplex (auto-neg)"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""File system address: 0xbfc10100"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""device eth0 entered promiscuous mode"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""Can't analyze prologue code at 801506c4"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""br0: port 1(eth0) entering learning state"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""Using noop io scheduler"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""br0: topology change detected, propagating"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""bcm963xx_mtd driver v1.0"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""br0: port 1(eth0) entering forwarding state"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""brcmboard: brcm_board_init entry"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""device nas_0_0_38 entered promiscuous mode"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,"""""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""br0: port 2(nas_0_0_38) entering learning state"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""======= GPIO CONFIG_BCM96338 inited ========"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""ttyS0 at MMIO 0xfffe0300 (irq = 10) is a BCM63XX"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""br0: port 2(nas_0_0_38) entering forwarding state"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""VFS: Mounted root (squashfs filesystem) readonly."""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""device eth0 left promiscuous mode"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""Algorithmics/MIPS FPU Emulator v1.5"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""br0: port 1(eth0) entering disabled state"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""atmapi: module license 'Proprietary' taints kernel."""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""device nas_0_0_38 left promiscuous mode"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""adsl: adsl_init entry"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""br0: port 2(nas_0_0_38) entering disabled state"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""blaadd: blaa_detect entry"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""Broadcom BCM6338A2 Ethernet Network Device v0.3 Apr 27 2010 15:17:46"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Info,kernel,,""ning state"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""Config Internal PHY Through MDIO"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""eth0: MAC Address: 00:21:91:94:C4:98"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""BcmAdsl_Initialize=0xC0068A48, g_pFnNotifyCallback=0xC0081784"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""AnnexCParam=0x7FFF7EB8 AnnexAParam=0x00000980 adsl2=0x00000000"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""pSdramPHY=0xA07FFFF8, 0x4099C73 0xDFADBEEF"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""AdslCoreHwReset: AdslOemDataAddr = 0xA07EF96C"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""DoInitialize: do kerSysRegisterDyingGaspHandler"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""dgasp: kerSysRegisterDyingGaspHandler: dsl0 registered """
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""DoInitialize: do put_user"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""DoInitialize: do kerSysLedCtrl"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""ATM proc init !!!"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""ip_tables: (C) 2000-2002 Netfilter core team"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""ip_conntrack version 2.1 (61 buckets, 0 max) - 376 bytes per conntrack"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""ip_conntrack_pptp version 2.1 loaded"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""ip_nat_pptp version 2.0 loaded"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""ip_conntrack_rtsp v0.01 loading"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""ip_nat_rtsp v0.01 loading"""
"192.168.1.1,08/02/10 19:05:09,08/02/10 19:05:09,,user-level,Warning,kernel,,""unregistering helper for port 5060"""
"192.168.1.1,08/02/10 19:05:10,08/02/10 19:05:10,,user-level,Critical,kernel,,""ADSL G.994 training"""
"192.168.1.1,08/02/10 19:05:10,08/02/10 19:05:10,,user-level,Debug,syslog,,""echo > /var/snmpd.conf"""
"192.168.1.1,08/02/10 19:05:11,08/02/10 19:05:11,,user-level,Debug,syslog,,""pppd plugin pppoa 0.0.35 user 'i12790' password ********** interface_name 0_0_35_1 usepeerdns refuse-eap persist vc-encaps nomppc nomppe mtu 1492 &"""
"192.168.1.1,08/02/10 19:05:14,08/02/10 19:05:14,,system,Notice,pppd[346],,""pppd 2.4.3 started by admin, uid 0"""
"192.168.1.1,08/02/10 19:05:14,08/02/10 19:05:14,,system,Info,pppd[317],,""Plugin pppoa loaded."""
"192.168.1.1,08/02/10 19:05:14,08/02/10 19:05:14,,system,Info,pppd[317],,""PPPoATM plugin_init"""
"192.168.1.1,08/02/10 19:05:14,08/02/10 19:05:14,,system,Info,pppd[317],,""Plugin pppoa called."""
"192.168.1.1,08/02/10 19:05:14,08/02/10 19:05:14,,system,Info,pppd[317],,""PPPoATM setdevname_pppoatm - SUCCESS:0.0.35"""
"192.168.1.1,08/02/10 19:05:29,08/02/10 19:05:29,,user-level,Critical,kernel,,""ADSL G.992 started"""
"192.168.1.1,08/02/10 19:05:34,08/02/10 19:05:34,,user-level,Critical,kernel,,""ADSL G.992 channel analysis"""
"192.168.1.1,08/02/10 19:05:40,08/02/10 19:05:40,,user-level,Critical,kernel,,""ADSL G.992 message exchange"""
"192.168.1.1,08/02/10 19:05:40,08/02/10 19:05:40,,user-level,Critical,kernel,,""ADSL link up, interleaved, us=637, ds=6143"""
"192.168.1.1,08/02/10 19:05:40,08/02/10 19:05:40,,user-level,Warning,kernel,,""ADSL2/ADSL2+ connection"""
"192.168.1.1,08/02/10 19:05:40,08/02/10 19:05:40,,user-level,Warning,kernel,,""ATM Soft SAR: ATM link connected."""
"192.168.1.1,08/02/10 19:05:41,08/02/10 19:05:41,,user-level,Debug,syslog,,""iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107"""
"192.168.1.1,08/02/10 19:05:43,08/02/10 19:05:43,,system,Notice,pppd[346],,""Connect: ppp_0_0_35_1 <--> 0.0.35"""
"192.168.1.1,08/02/10 19:05:43,08/02/10 19:05:43,,system,Info,pppd[346],,""Using interface ppp0_0_35_1"""
"192.168.1.1,08/02/10 19:06:10,08/02/10 19:06:10,,system,Notice,pppd[346],,""PAP authentication succeeded"""
"192.168.1.1,08/02/10 19:06:11,08/02/10 19:06:11,,system,Notice,pppd[346],,""local IP address 87.117.49.159"""
"192.168.1.1,08/02/10 19:06:11,08/02/10 19:06:11,,system,Notice,pppd[346],,""remote IP address 83.221.214.195"""
"192.168.1.1,08/02/10 19:06:11,08/02/10 19:06:11,,system,Notice,pppd[346],,""primary DNS address 80.254.111.13"""
"192.168.1.1,08/02/10 19:06:11,08/02/10 19:06:11,,system,Notice,pppd[346],,""secondary DNS address 83.221.202.254"""
"192.168.1.1,08/02/10 19:06:12,08/02/10 19:06:12,,user-level,Debug,syslog,,""route add default gw 83.221.214.195 2>/dev/null"""
"192.168.1.1,08/02/10 19:06:12,08/02/10 19:06:12,,user-level,Debug,syslog,,""iptables -A FORWARD -o ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu"""
"192.168.1.1,08/02/10 19:06:12,08/02/10 19:06:12,,user-level,Debug,syslog,,""iptables -A FORWARD -i ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu"""
"192.168.1.1,08/02/10 19:06:12,08/02/10 19:06:12,,user-level,Debug,syslog,,""echo > /proc/net/ip_conntrack"""
"192.168.1.1,08/02/10 19:06:12,08/02/10 19:06:12,,user-level,Debug,syslog,,""echo """"600"""" > /proc/sys/net/ipv4/ip_conntrack_max"""
"192.168.1.1,08/02/10 19:06:12,08/02/10 19:06:12,,user-level,Debug,syslog,,""echo 2000 > /proc/sys/net/ipv4/netfilter/ip_conntrack_generic_timeout"""
"192.168.1.1,08/02/10 19:06:12,08/02/10 19:06:12,,user-level,Debug,syslog,,""echo 600 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_established"""
"192.168.1.1,08/02/10 19:06:13,08/02/10 19:06:13,,user-level,Notice,dnsprobe[577],,""dnsprobe started! """
"192.168.1.1,08/02/10 19:06:13,08/02/10 19:06:13,,user-level,Debug,syslog,,""echo 1400 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_fin_wait"""
"192.168.1.1,08/02/10 19:06:13,08/02/10 19:06:13,,user-level,Debug,syslog,,""echo 120 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_time_wait"""
"192.168.1.1,08/02/10 19:06:13,08/02/10 19:06:13,,user-level,Debug,syslog,,""echo 4096 > /proc/sys/net/ipv4/ipfrag_high_thresh"""
"192.168.1.1,08/02/10 19:06:13,08/02/10 19:06:13,,user-level,Debug,syslog,,""echo 1024 > /proc/sys/net/ipv4/ipfrag_low_thresh"""
"192.168.1.1,08/02/10 19:06:13,08/02/10 19:06:13,,user-level,Debug,syslog,,""echo 5 > /proc/sys/net/ipv4/ipfrag_time"""
"192.168.1.1,08/02/10 19:06:13,08/02/10 19:06:13,,user-level,Debug,syslog,,""iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null"""
"192.168.1.1,08/02/10 19:06:13,08/02/10 19:06:13,,user-level,Debug,syslog,,""iptables -t nat -D POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null"""
"192.168.1.1,08/02/10 19:06:13,08/02/10 19:06:13,,user-level,Debug,syslog,,""iptables -t nat -A POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE"""
"192.168.1.1,08/02/10 19:06:13,08/02/10 19:06:13,,user-level,Debug,syslog,,""iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 80.254.111.13 2>/dev/null"""
"192.168.1.1,08/02/10 19:06:13,08/02/10 19:06:13,,user-level,Debug,syslog,,""iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 80.254.111.13"""
"192.168.1.1,08/02/10 19:06:13,08/02/10 19:06:13,,user-level,Debug,syslog,,""/bin/dnsprobe &"""
"192.168.1.1,08/02/10 19:06:14,08/02/10 19:06:14,,user-level,Debug,syslog,,""echo 4096 > /proc/sys/net/ipv4/ipfrag_high_thresh"""
"192.168.1.1,08/02/10 19:06:14,08/02/10 19:06:14,,user-level,Debug,syslog,,""echo 1024 > /proc/sys/net/ipv4/ipfrag_low_thresh"""
"192.168.1.1,08/02/10 19:06:14,08/02/10 19:06:14,,user-level,Debug,syslog,,""echo 5 > /proc/sys/net/ipv4/ipfrag_time"""
"192.168.1.1,08/02/10 19:07:14,08/02/10 19:07:14,,user-level,Alert,kernel,,""Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=62.16.58.153 DST=87.117.49.159 LEN=64 TOS=0x00 PREC=0x00 TTL=38 ID=45799 DF PROTO=TCP SPT=1590 DPT=17053 WINDOW=65535 RES=0x00 SYN URGP=0 """
"192.168.1.1,08/02/10 19:07:17,08/02/10 19:07:17,,user-level,Alert,kernel,,""Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=62.16.58.153 DST=87.117.49.159 LEN=64 TOS=0x00 PREC=0x00 TTL=38 ID=46003 DF PROTO=TCP SPT=1590 DPT=17053 WINDOW=65535 RES=0x00 SYN URGP=0 """
"192.168.1.1,08/02/10 19:07:19,08/02/10 19:07:19,,user-level,Alert,kernel,,""Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=92.246.168.15 DST=87.117.49.159 LEN=48 TOS=0x00 PREC=0x00 TTL=242 ID=31292 DF PROTO=TCP SPT=3273 DPT=17053 WINDOW=65535 RES=0x00 SYN URGP=0 """
"192.168.1.1,08/02/10 19:07:22,08/02/10 19:07:22,,user-level,Alert,kernel,,""Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=92.246.168.15 DST=87.117.49.159 LEN=48 TOS=0x00 PREC=0x00 TTL=242 ID=32869 DF PROTO=TCP SPT=3273 DPT=17053 WINDOW=65535 RES=0x00 SYN URGP=0 """
"192.168.1.1,08/02/10 19:07:23,08/02/10 19:07:23,,user-level,Alert,kernel,,""Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=62.16.58.153 DST=87.117.49.159 LEN=64 TOS=0x00 PREC=0x00 TTL=38 ID=46260 DF PROTO=TCP SPT=1590 DPT=17053 WINDOW=65535 RES=0x00 SYN URGP=0 """
"192.168.1.1,08/02/10 19:12:01,08/02/10 19:12:01,,user-level,Debug,syslog,,""echo 0 > /var/isdft_cfg"""
"192.168.1.1,08/02/10 19:12:08,08/02/10 19:12:08,,user-level,Debug,syslog,,""echo 0 > /var/isdft_cfg"""
"192.168.1.1,08/02/10 19:12:12,08/02/10 19:12:12,,user-level,Debug,syslog,,""cat /var/pslist"""
"192.168.1.1,08/02/10 19:12:12,08/02/10 19:12:12,,user-level,Debug,syslog,,""sysinfo"""
"192.168.1.1,08/02/10 19:12:12,08/02/10 19:12:12,,user-level,Debug,syslog,,""kill -9 298"""
"192.168.1.1,08/02/10 19:12:12,08/02/10 19:12:12,,user-level,Debug,syslog,,""kill -9 291"""
"192.168.1.1,08/02/10 19:12:12,08/02/10 19:12:12,,user-level,Debug,syslog,,""kill -9 289"""
"192.168.1.1,08/02/10 19:12:12,08/02/10 19:12:12,,user-level,Debug,syslog,,""kill -9 286"""
"192.168.1.1,08/02/10 19:12:48,08/02/10 19:12:48,,syslogd,Emergency,,,""BCM96345 started: BusyBox v1.00 (2010.04.27-07:21+0000)"""
"192.168.1.1,08/02/10 19:12:48,08/02/10 19:12:48,,user-level,Debug,syslog,,""sntp -s clock.fmt.he.net -s none -t """"Moscow, St. Petersburg, Volgograd"""" &"""
"192.168.1.1,08/02/10 19:12:55,08/02/10 19:12:55,,system,Notice,pppd[362],,""pppd 2.4.3 started by admin, uid 0"""
"192.168.1.1,08/02/10 19:12:55,08/02/10 19:12:55,,system,Notice,pppd[362],,""local IP address 10.64.68.161"""
"192.168.1.1,08/02/10 19:12:55,08/02/10 19:12:55,,system,Notice,pppd[362],,""remote IP address 10.112.116.209"""
"192.168.1.1,08/02/10 19:12:55,08/02/10 19:12:55,,system,Info,pppd[319],,""PPPoATM plugin_init"""
"192.168.1.1,08/02/10 19:12:55,08/02/10 19:12:55,,system,Info,pppd[319],,""Plugin pppoa called."""
"192.168.1.1,08/02/10 19:12:55,08/02/10 19:12:55,,system,Info,pppd[319],,""PPPoATM setdevname_pppoatm - SUCCESS:0.0.35"""
"192.168.1.1,08/02/10 19:12:55,08/02/10 19:12:55,,system,Info,pppd[362],,""Using interface ppp0_0_35_1"""
"192.168.1.1,08/02/10 19:12:57,08/02/10 19:12:57,,user-level,Critical,kernel,,""ADSL G.992 started"""
"192.168.1.1,08/02/10 19:13:01,08/02/10 19:13:01,,user-level,Critical,kernel,,""ADSL G.992 channel analysis"""
"192.168.1.1,08/02/10 19:13:07,08/02/10 19:13:07,,user-level,Critical,kernel,,""ADSL G.992 message exchange"""
"192.168.1.1,08/02/10 19:13:08,08/02/10 19:13:08,,user-level,Critical,kernel,,""ADSL link up, interleaved, us=634, ds=6143"""
"192.168.1.1,08/02/10 19:13:08,08/02/10 19:13:08,,user-level,Warning,kernel,,""ADSL2/ADSL2+ connection"""
"192.168.1.1,08/02/10 19:13:08,08/02/10 19:13:08,,user-level,Warning,kernel,,""ATM Soft SAR: ATM link connected."""
"192.168.1.1,08/02/10 19:13:09,08/02/10 19:13:09,,user-level,Debug,syslog,,""iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107"""
"192.168.1.1,08/02/10 19:13:10,08/02/10 19:13:10,,user-level,Debug,syslog,,""iptables -t nat -A POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE"""
"192.168.1.1,08/02/10 19:13:10,08/02/10 19:13:10,,user-level,Debug,syslog,,""route add default dev ppp_0_0_35_1 2>/dev/null"""
Внимание сюда. Тут я поменял настройку : Dial on demand (with idle timeout timer), которая, как я понял заставит модем автоматически подключаться. Выставил 2 минуты.
Естественно save & reboot. Результат внизу. Sessions limit exceeded - это что за бред? Количество сессий закончилось ? :)
"192.168.1.1,08/02/10 19:13:16,08/02/10 19:13:16,,system,Notice,pppd[362],,""Connect: ppp_0_0_35_1 <--> 0.0.35"""
"192.168.1.1,08/02/10 19:13:16,08/02/10 19:13:16,,system,Info,pppd[362],,""Starting link"""
"192.168.1.1,08/02/10 19:13:16,08/02/10 19:13:16,,system,Info,pppd[362],,""LCP terminated by peer"""
"192.168.1.1,08/02/10 19:13:19,08/02/10 19:13:19,,system,Notice,pppd[362],,""Connection terminated...."""
"192.168.1.1,08/02/10 19:13:50,08/02/10 19:13:50,,system,Notice,pppd[362],,""Connect: ppp_0_0_35_1 <--> 0.0.35"""
"192.168.1.1,08/02/10 19:13:50,08/02/10 19:13:50,,system,Info,pppd[362],,""Starting link"""
"192.168.1.1,08/02/10 19:14:13,08/02/10 19:14:13,,system,Error,pppd[362],,""PAP authentication failed"""
"192.168.1.1,08/02/10 19:14:13,08/02/10 19:14:13,,system,Info,pppd[362],,""Remote message: % Sessions limit exceeded."""
"192.168.1.1,08/02/10 19:14:19,08/02/10 19:14:19,,system,Notice,pppd[362],,""Connection terminated...."""
"192.168.1.1,08/02/10 19:14:19,08/02/10 19:14:19,,system,Info,pppd[362],,""Exit."""
Ну опять ресет кнопкой на модеме.
"192.168.1.1,08/02/10 19:17:17,08/02/10 19:17:17,,system,Notice,pppd[344],,""pppd 2.4.3 started by admin, uid 0"""
"192.168.1.1,08/02/10 19:17:17,08/02/10 19:17:17,,system,Notice,pppd[344],,""local IP address 10.64.68.161"""
"192.168.1.1,08/02/10 19:17:17,08/02/10 19:17:17,,system,Notice,pppd[344],,""remote IP address 10.112.116.209"""
"192.168.1.1,08/02/10 19:17:17,08/02/10 19:17:17,,system,Info,pppd[317],,""PPPoATM plugin_init"""
"192.168.1.1,08/02/10 19:17:17,08/02/10 19:17:17,,system,Info,pppd[317],,""Plugin pppoa called."""
"192.168.1.1,08/02/10 19:17:17,08/02/10 19:17:17,,system,Info,pppd[317],,""PPPoATM setdevname_pppoatm - SUCCESS:0.0.35"""
"192.168.1.1,08/02/10 19:17:17,08/02/10 19:17:17,,system,Info,pppd[344],,""Using interface ppp0_0_35_1"""
"192.168.1.1,08/02/10 19:17:19,08/02/10 19:17:19,,user-level,Critical,kernel,,""ADSL G.992 started"""
"192.168.1.1,08/02/10 19:17:24,08/02/10 19:17:24,,user-level,Critical,kernel,,""ADSL G.992 channel analysis"""
"192.168.1.1,08/02/10 19:17:30,08/02/10 19:17:30,,user-level,Critical,kernel,,""ADSL G.992 message exchange"""
"192.168.1.1,08/02/10 19:17:30,08/02/10 19:17:30,,user-level,Critical,kernel,,""ADSL link up, interleaved, us=637, ds=6143"""
"192.168.1.1,08/02/10 19:17:30,08/02/10 19:17:30,,user-level,Warning,kernel,,""ADSL2/ADSL2+ connection"""
"192.168.1.1,08/02/10 19:17:30,08/02/10 19:17:30,,user-level,Warning,kernel,,""ATM Soft SAR: ATM link connected."""
"192.168.1.1,08/02/10 19:17:32,08/02/10 19:17:32,,user-level,Debug,syslog,,""iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107"""
"192.168.1.1,08/02/10 19:17:32,08/02/10 19:17:32,,user-level,Debug,syslog,,""iptables -t nat -A POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE"""
"192.168.1.1,08/02/10 19:17:32,08/02/10 19:17:32,,user-level,Debug,syslog,,""route add default dev ppp_0_0_35_1 2>/dev/null"""
"192.168.1.1,08/02/10 19:17:41,08/02/10 19:17:41,,system,Notice,pppd[344],,""Connect: ppp_0_0_35_1 <--> 0.0.35"""
"192.168.1.1,08/02/10 19:17:41,08/02/10 19:17:41,,system,Info,pppd[344],,""Starting link"""
"192.168.1.1,08/02/10 19:18:11,08/02/10 19:18:11,,system,Notice,pppd[344],,""Connection terminated...."""
"192.168.1.1,08/02/10 19:18:11,08/02/10 19:18:11,,system,Warning,pppd[344],,""LCP: timeout sending Config-Requests """
"192.168.1.1,08/02/10 19:18:50,08/02/10 19:18:50,,system,Notice,pppd[344],,""Connect: ppp_0_0_35_1 <--> 0.0.35"""
"192.168.1.1,08/02/10 19:18:50,08/02/10 19:18:50,,system,Info,pppd[344],,""Starting link"""
"192.168.1.1,08/02/10 19:18:54,08/02/10 19:18:54,,system,Notice,pppd[344],,""PAP authentication succeeded"""
"192.168.1.1,08/02/10 19:18:54,08/02/10 19:18:54,,system,Warning,pppd[344],,""Local IP address changed to 109.165.8.237"""
"192.168.1.1,08/02/10 19:18:54,08/02/10 19:18:54,,system,Warning,pppd[344],,""Remote IP address changed to 83.221.214.195"""
"192.168.1.1,08/02/10 19:18:56,08/02/10 19:18:56,,user-level,Debug,syslog,,""route add default gw 83.221.214.195 2>/dev/null"""
"192.168.1.1,08/02/10 19:18:56,08/02/10 19:18:56,,user-level,Debug,syslog,,""iptables -A FORWARD -o ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu"""
"192.168.1.1,08/02/10 19:18:56,08/02/10 19:18:56,,user-level,Debug,syslog,,""iptables -A FORWARD -i ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu"""
"192.168.1.1,08/02/10 19:18:56,08/02/10 19:18:56,,user-level,Debug,syslog,,""echo > /proc/net/ip_conntrack"""
"192.168.1.1,08/02/10 19:18:56,08/02/10 19:18:56,,user-level,Debug,syslog,,""echo """"600"""" > /proc/sys/net/ipv4/ip_conntrack_max"""
"192.168.1.1,08/02/10 19:18:56,08/02/10 19:18:56,,user-level,Debug,syslog,,""echo 2000 > /proc/sys/net/ipv4/netfilter/ip_conntrack_generic_timeout"""
"192.168.1.1,08/02/10 19:18:56,08/02/10 19:18:56,,user-level,Debug,syslog,,""echo 600 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_established"""
"192.168.1.1,08/02/10 19:18:56,08/02/10 19:18:56,,user-level,Debug,syslog,,""echo 1400 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_fin_wait"""
"192.168.1.1,08/02/10 19:18:56,08/02/10 19:18:56,,user-level,Debug,syslog,,""echo 120 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_time_wait"""
"192.168.1.1,08/02/10 19:18:56,08/02/10 19:18:56,,user-level,Debug,syslog,,""echo 4096 > /proc/sys/net/ipv4/ipfrag_high_thresh"""
"192.168.1.1,08/02/10 19:18:56,08/02/10 19:18:56,,user-level,Debug,syslog,,""echo 1024 > /proc/sys/net/ipv4/ipfrag_low_thresh"""
"192.168.1.1,08/02/10 19:18:56,08/02/10 19:18:56,,user-level,Debug,syslog,,""echo 5 > /proc/sys/net/ipv4/ipfrag_time"""
"192.168.1.1,08/02/10 19:18:56,08/02/10 19:18:56,,user-level,Debug,syslog,,""iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null"""
"192.168.1.1,08/02/10 19:18:56,08/02/10 19:18:56,,user-level,Debug,syslog,,""iptables -t nat -D POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null"""
"192.168.1.1,08/02/10 19:18:56,08/02/10 19:18:56,,user-level,Debug,syslog,,""iptables -t nat -A POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE"""
"192.168.1.1,08/02/10 19:18:57,08/02/10 19:18:57,,user-level,Notice,dnsprobe[567],,""dnsprobe started! """
"192.168.1.1,08/02/10 19:18:57,08/02/10 19:18:57,,user-level,Debug,syslog,,""iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 80.254.111.13 2>/dev/null"""
"192.168.1.1,08/02/10 19:18:57,08/02/10 19:18:57,,user-level,Debug,syslog,,""iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 80.254.111.13"""
"192.168.1.1,08/02/10 19:18:57,08/02/10 19:18:57,,user-level,Debug,syslog,,""/bin/dnsprobe &"""
"192.168.1.1,08/02/10 19:18:58,08/02/10 19:18:58,,user-level,Debug,syslog,,""echo 4096 > /proc/sys/net/ipv4/ipfrag_high_thresh"""
"192.168.1.1,08/02/10 19:18:58,08/02/10 19:18:58,,user-level,Debug,syslog,,""echo 1024 > /proc/sys/net/ipv4/ipfrag_low_thresh"""
"192.168.1.1,08/02/10 19:18:58,08/02/10 19:18:58,,user-level,Debug,syslog,,""echo 5 > /proc/sys/net/ipv4/ipfrag_time"""
И последнее. Как только появился коннект сразу посыпались сообщения о вторжении. Разъясните пожалуйста что это.
"192.168.1.1,08/02/10 19:19:34,08/02/10 19:19:34,,user-level,Alert,kernel,,""Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=94.231.64.156 DST=109.165.8.237 LEN=52 TOS=0x00 PREC=0x00 TTL=116 ID=10686 DF PROTO=TCP SPT=55299 DPT=45445 WINDOW=8192 RES=0x00 SYN URGP=0 """
"192.168.1.1,08/02/10 19:19:37,08/02/10 19:19:37,,user-level,Alert,kernel,,""Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=94.231.64.156 DST=109.165.8.237 LEN=52 TOS=0x00 PREC=0x00 TTL=116 ID=10772 DF PROTO=TCP SPT=55299 DPT=45445 WINDOW=8192 RES=0x00 SYN URGP=0 """
"192.168.1.1,08/02/10 19:19:43,08/02/10 19:19:43,,user-level,Alert,kernel,,""Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=94.231.64.156 DST=109.165.8.237 LEN=48 TOS=0x00 PREC=0x00 TTL=116 ID=10961 DF PROTO=TCP SPT=55299 DPT=45445 WINDOW=8192 RES=0x00 SYN URGP=0 """
"192.168.1.1,08/02/10 19:19:50,08/02/10 19:19:50,,user-level,Alert,kernel,,""Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=62.209.132.46 DST=109.165.8.237 LEN=52 TOS=0x00 PREC=0x00 TTL=116 ID=2478 PROTO=TCP SPT=9628 DPT=58340 WINDOW=8192 RES=0x00 SYN URGP=0 """
"192.168.1.1,08/02/10 19:19:52,08/02/10 19:19:52,,user-level,Alert,kernel,,""Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=62.209.132.46 DST=109.165.8.237 LEN=52 TOS=0x00 PREC=0x00 TTL=116 ID=2603 PROTO=TCP SPT=9628 DPT=58340 WINDOW=8192 RES=0x00 SYN URGP=0 """
:lol:
СообщениеДобавлено: Пн авг 02, 2010 19:15
Опять самого главного нет: полного лога в случае, когда модем не подключается.
А по поводу "Sessions limit exceeded", оборудование на стороне провайдера думает, что одно подключение уже есть (ещё не оборвалось по таймауту), а в настройках у него стоит не более 1 подключения для 1 пользователя (например). И опять же, в этом случае тоже не видно, что там было до этого, почему оно так думает.
СообщениеДобавлено: Пн авг 02, 2010 19:22
За разъяснение спасибо по поводу "Sessions limit exceeded". А вот там где после глюка модем не подключился самые первые строки предыдущего лога. Как я понял после появления линка 3 раза попытался подключиться и провайдер обрубил линию.
СообщениеДобавлено: Пн авг 02, 2010 19:32
Если под этим подразумеваются первые три красные строчки, то я там не вижу трёх попыток подключения.
Ладно, расскажу, как надо было собирать логи в случае неподключающегося модема, а то, чую, так разбирательство затянется. Глюкнуло электричество -> ни модем, ни комп не включены (насколько я понял) -> выдёргиваем БП модема, чтобы он не включился -> включаем "пилот" -> ждём, когда комп загрузится полностью -> втыкаем БП модема назад -> на компе будет полный лог с момента включения модема.
Сейчас этот форум просматривают: Baidu [Spider] и гости: 6
