Текущее время: Вт ноя 10, 2026 18:20
СообщениеДобавлено: Ср июл 21, 2010 03:44
Настроил роутер Dlink dir 300 под свою локальную сеть Next-one Волгоград! Наконец то через месяц он задышал... но не на долго! Как то странно он работает: работает интернет минуты 2 и выключаеться минут на 10 - 15 патом снова!
Помогите пожалуйста! Прошивка стоит:
Hardware Version : B1 Firmware Version : 2.05
Вот лог:
Jan 1 00:05:43    Drop TCP packet from N/A (src:83.167.65.7:45233, dst:10.208.58.10:80) by default rule.
Jan 1 00:05:40    Drop TCP packet from N/A (src:83.167.65.7:45233, dst:10.208.58.10:80) by default rule.
Jan 1 00:02:47    WAN connected (L2TP).
Jan 1 00:02:44    Remote management is disabled.
Jan 1 00:02:44    Block WAN PING is enabled.
Jan 1 00:02:44    DMZ disabled.
Jan 1 00:02:44    VPN (L2TP) Pass-Through enabled.
Jan 1 00:02:44    VPN (IPSec) Pass-Through enabled.
Jan 1 00:02:44    VPN (PPTP) Pass-Through enabled.
Jan 1 00:02:44    Domain blocking disabled.
Jan 1 00:02:44    URL blocking disabled.
Jan 1 00:02:44    MAC filter disabled.
Jan 1 00:02:43    IPCP: secondary DNS address 83.167.66.166.
Jan 1 00:02:43    IPCP: primary DNS address 83.167.65.2.
Jan 1 00:02:43    IPCP: remote IP address 10.64.64.64.
Jan 1 00:02:43    IPCP: local IP address 83.167.93.35.
Jan 1 00:02:43    CHAP authentication succeeded.
Jan 1 00:02:41    DHCP: Client receive ACK from 83.167.66.94, IP=10.208.58.10, Lease time=28800.
Jan 1 00:02:39    DHCP: Client send REQUEST to server 83.167.66.94, request IP=10.208.58.10.
Jan 1 00:02:39    DHCP: Client receive OFFER from 83.167.66.94.
Jan 1 00:02:39    DHCP: Client send DISCOVER.
Jan 1 00:02:05    DHCP: Client send REQUEST to server 83.167.66.94, request IP=10.208.58.10.
Jan 1 00:01:49    DHCP: Client send REQUEST to server 83.167.66.94, request IP=10.208.58.10.
Jan 1 00:01:41    DHCP: Client send REQUEST to server 83.167.66.94, request IP=10.208.58.10.
Jan 1 00:01:37    DHCP: Client send REQUEST to server 83.167.66.94, request IP=10.208.58.10.
Jan 1 00:01:35    DHCP: Client send REQUEST to server 83.167.66.94, request IP=10.208.58.10.
Jan 1 00:01:35    DHCP: Client performing a DHCP renew.
Jan 1 00:01:34    PPP: Connection terminated.
Jan 1 00:01:34    CHAP authentication failed.
Jan 1 00:01:33    DHCP: Client receive ACK from 83.167.66.94, IP=10.208.58.10, Lease time=28800.
Jan 1 00:01:30    DHCP: Client send REQUEST to server 83.167.66.94, request IP=10.208.58.10.
Jan 1 00:01:30    DHCP: Client receive OFFER from 83.167.66.94.
Jan 1 00:01:30    DHCP: Client send DISCOVER.
Jan 1 00:00:56    DHCP: Client send REQUEST to server 83.167.66.94, request IP=10.208.58.10.
Jan 1 00:00:40    DHCP: Client send REQUEST to server 83.167.66.94, request IP=10.208.58.10.
Jan 1 00:00:32    DHCP: Client send REQUEST to server 83.167.66.94, request IP=10.208.58.10.
Jan 1 00:00:28    DHCP: Client send REQUEST to server 83.167.66.94, request IP=10.208.58.10.
Jan 1 00:00:26    DHCP: Client send REQUEST to server 83.167.66.94, request IP=10.208.58.10.
Jan 1 00:00:26    DHCP: Client performing a DHCP renew.
Jan 1 00:00:25    PPP: Connection terminated.
Jan 1 00:00:24    CHAP authentication failed.
Jan 1 00:00:23    DHCP: Client receive ACK from 83.167.66.94, IP=10.208.58.10, Lease time=28800.
Jan 1 00:00:21    DHCP: Client send REQUEST to server 83.167.66.94, request IP=10.208.58.10.
Jan 1 00:00:21    DHCP: Client receive OFFER from 83.167.66.94.
Jan 1 00:00:21    DHCP: Client send DISCOVER.
Jan 1 00:00:19    DHCP: Client send DISCOVER.
Jan 1 00:00:14    DHCP: Server sending NAK to 00:1a:4d:4a:c8:1f.
Jan 1 00:00:13    DHCP: Server sending ACK to 192.168.0.100. (Lease time = -1)
Jan 1 00:00:13    DHCP: Server receive REQUEST from 00:1a:4d:4a:c8:1f.
Jan 1 00:00:13    DHCP: Server sending OFFER of 192.168.0.100 for static DHCP client.
Jan 1 00:00:13    DHCP: Server receive DISCOVER from 00:1a:4d:4a:c8:1f.
Jan 1 00:00:13    VPN (L2TP) Pass-Through enabled.
Jan 1 00:00:13    VPN (IPSec) Pass-Through enabled.
Jan 1 00:00:13    VPN (PPTP) Pass-Through enabled.
Jan 1 00:00:13    Domain blocking disabled.
Jan 1 00:00:13    URL blocking disabled.
Jan 1 00:00:13    MAC filter disabled.
Jan 1 00:00:12    DHCP: Server sending NAK to 00:1a:4d:4a:c8:1f.
Jan 1 00:00:12    DHCP: Server receive REQUEST from 00:1a:4d:4a:c8:1f.
Jan 1 00:00:12    DHCP: Server sending NAK to 00:1d:60:36:c3:63.
Jan 1 00:00:12    DHCP: Server sending ACK to 192.168.0.101. (Lease time = -1)
Jan 1 00:00:12    DHCP: Server receive REQUEST from 00:1d:60:36:c3:63.
Jan 1 00:00:12    DHCP: Server sending OFFER of 192.168.0.101 for static DHCP client.
Jan 1 00:00:12    DHCP: Server receive DISCOVER from 00:1d:60:36:c3:63.
Jan 1 00:00:11    DHCP: Server sending NAK to 00:1d:60:36:c3:63.
Jan 1 00:00:11    DHCP: Server receive REQUEST from 00:1d:60:36:c3:63.
Jan 1 00:00:04    System started.
[/code]
СообщениеДобавлено: Ср июл 21, 2010 12:12
Вот продолжение лога после чего Интернет и сеть отрубаються... Но как не странно на роуторе всё горит зелёным!
Jan 1 00:06:50    DHCP: Server sending NAK to 00:1d:60:36:c3:63.
Jan 1 00:06:50    DHCP: Server sending ACK to 192.168.0.101. (Lease time = -1)
Jan 1 00:06:50    DHCP: Server receive REQUEST from 00:1d:60:36:c3:63.
Jan 1 00:06:50    DHCP: Server sending OFFER of 192.168.0.101 for static DHCP client.
Jan 1 00:06:50    DHCP: Server receive DISCOVER from 00:1d:60:36:c3:63.
Jan 1 00:06:28    Drop PING request from WAN (ip:87.103.161.94).
Jan 1 00:06:23    PING-FLOODING flooding attack from N/A (ip:83.167.66.16) detected.
Jan 1 00:06:17    PING-FLOODING flooding attack from N/A (ip:10.208.58.1) detected.
Jan 1 00:03:51    Drop TCP packet from N/A (src:83.167.65.7:56269, dst:10.208.58.10:80) by default rule.
Jan 1 00:03:48    Drop TCP packet from N/A (src:83.167.65.7:56269, dst:10.208.58.10:80) by default rule.
СообщениеДобавлено: Чт июл 22, 2010 02:58
Извините я ошибся думал у меня dir 300 (так на коробке написано) а на самом деле у меня dir 300/NRU
Может быть с этой информацией вы сможете мне чем нибудь помочь!
СообщениеДобавлено: Пт июл 23, 2010 17:33
Кароче как я понел пока я дождусь ответа я уже успею и мастера вызвать и в офис Длинка съездитьи уже роутер успеет сломать и я куплю новый, только после этого я дождусь ответа????
СообщениеДобавлено: Ср июл 28, 2010 15:18
После прошивки осуществляли сброс роутера на заводские настройки и настраивали его заново вручную?
Настройки подключения опубликуйте, пожалуйста.
