Текущее время: Вс июн 21, 2026 19:18
Начать новую тему Ответить на тему  [ Сообщений: 87 ]  На страницу Пред.  1, 2, 3, 4, 5, 6  След.
СообщениеДобавлено: Вс июл 18, 2010 16:47
вот backup.conf:
<psitree>
<AtmCfg>
<initCfg structureId="2" threadPriority="25" freeCellQSize="10" freePktQSize="200" freePktQBufSize="1600" freePktQBufOffset="32" rxCellQSize="10" rxPktQSize="200" txFifoPriority="64" aal5MaxSduLen="64" aal2MaxSduLen="0"/>
</AtmCfg>
<AtmCfgTd>
<td1 cat="UBR" PCR="0" SCR="0" MBS="0"/>
</AtmCfgTd>
<SecCfg>
<qosMgmtCfg enableQos="enable" defaultDSCPMark="-1" defaultQueue="-1"/>
<srvCtrlList ftp="lan" http="lan" icmp="enable" ssh="lan" telnet="lan" tftp="lan"/>
</SecCfg>
<Lan>
<entry9999 address="1.1.1.1" mask="255.255.255.0" dhcpServer="disable" confDhcpSrv="disable" leasedTime="0" startAddr="0.0.0.0" endAddr="0.0.0.0" subnetMask="0.0.0.0" instanceId="1509949443"/>
<entry1 address="192.168.1.1" mask="255.255.255.0" dhcpServer="enable" confDhcpSrv="enable" leasedTime="24" startAddr="192.168.1.2" endAddr="192.168.1.254" subnetMask="255.255.255.0" instanceId="1509949442"/>
</Lan>
<SystemInfo>
<sysLog state="disable" displayLevel="ERR" logLevel="DEBUG" option="local" serverIP="0.0.0.0" serverPort="514"/>
<protocol autoScan="enable" igmpSnp ="disable" igmpMode ="disable" macFilterPolicy="forward" encodePassword="enable" fltin="block" fltout="forward"/>
<sysUserName value="admin"/>
</SystemInfo>
<ADSL/>
<AtmCfgVcc>
<vccId9999 portId="0" vpi="0" vci="65534" tdId="0" aalType="AAL2" adminStatus="down" encap="unknown" qos="disable" instanceId="1509949441"/>
<vccId1 portId="0" vpi="8" vci="35" tdId="1" aalType="AAL5" adminStatus="up" encap="llc" qos="disable" instanceId="1509949441"/>
</AtmCfgVcc>
<StaticIpCfg/>
<PMapCfg>
<pmap tableSize="1">
<pmapEntry id="1" groupName="Default" groupKey="1" groupStatus="1" ifList="eth0:1|nas_0_8_35:2" vendorid0="" vendorid1="" vendorid2="" vendorid3="" vendorid4=""/>
</pmap>
<pmapFlt tableSize="2">
<pmapFltEntry id="1" instance="1" status="enable" bridgeRef="1" interfaceRef="eth0"/>
<pmapFltEntry id="2" instance="2" status="enable" bridgeRef="1" interfaceRef="nas_0_8_35"/>
</pmapFlt>
</PMapCfg>
<RouteCfg>
</RouteCfg>
<SNTPCfg/>
<ToDCfg/>
<ToDUrlFilter/>
<EngDbgCfg/>
<wan_0_8_35>
<entry1 vccId="1" vlanMuxId="-1" conId="1" name="br_0_8_35" protocol="BRIDGE" encap="LLC" firewall="disable" nat="disable" fullcone="enable" igmp="disable" vlanId="-1" service="enable" instanceId="1509949443"/>
</wan_0_8_35>
</psitree>
СообщениеДобавлено: Вс июл 18, 2010 16:58
нет, не то, бридж я знаю как настроен, да и он работает...
нужен конфиг с MER
СообщениеДобавлено: Вс июл 18, 2010 17:08
ну там же только это
СообщениеДобавлено: Вс июл 18, 2010 17:15
понятно, я и предлагаю:
1) сбросить модем к дефолтным заводским настройкам (Management/Settings/Restore Default)
2) создать в Advanced Setup/WAN одно соединение типа MER, перезагрузить
3) посмотреть, что работает, что нет
4) сохранить в Management/Settings/Backup и прислать файл
5) восстановить Bridge из сохранённого ранее файла (Management/Settings/Update)
СообщениеДобавлено: Вс июл 18, 2010 17:17
понял, скоро отвечу
СообщениеДобавлено: Вс июл 18, 2010 18:34
вот:
<psitree>
<AtmCfg>
<initCfg structureId="2" threadPriority="25" freeCellQSize="10" freePktQSize="200" freePktQBufSize="1600" freePktQBufOffset="32" rxCellQSize="10" rxPktQSize="200" txFifoPriority="64" aal5MaxSduLen="64" aal2MaxSduLen="13568"/>
</AtmCfg>
<AtmCfgTd>
</AtmCfgTd>
<AtmCfgVcc>
</AtmCfgVcc>
<SecCfg>
<srvCtrlList ftp="lan" http="lan" icmp="lan" ssh="lan" telnet="lan" tftp="lan"/>
</SecCfg>
<Lan>
<entry9999 address="1.1.1.1" mask="255.255.255.0" dhcpServer="disable" confDhcpSrv="disable" leasedTime="0" startAddr="0.0.0.0" endAddr="0.0.0.0" subnetMask="0.0.0.0" instanceId="1509949442"/>
<entry1 address="192.168.1.1" mask="255.255.255.0" dhcpServer="enable" confDhcpSrv="enable" leasedTime="24" startAddr="192.168.1.2" endAddr="192.168.1.254" subnetMask="255.255.255.0" instanceId="1509949441"/>
</Lan>
<SystemInfo>
<sysLog state="enable" displayLevel="ERR" logLevel="DEBUG" option="local" serverIP="0.0.0.0" serverPort="514"/>
<defaultGateway enblGwAutoAssign="disable" ifName="" ipAddr="10.35.17.254"/>
<dns dynamic="disable" primary="80.73.64.251" secondary="255.255.255.255" domain="Home" host="Broadcom"/>
</SystemInfo>
<Global>
<pptpcfg pptpstate="disable" Pptpname="" defaultroute="disable" serverip="0.0.0.0" pptpusername="" pptppassword="" peerip="0.0.0.0" peermask="0.0.0.0" pptpalive="1"/>
</Global>
<ipsrv_0_8_35>
<dhcpc_conId1 state="disable" wanAddress="10.35.16.12" wanMask="255.255.254.0" />
</ipsrv_0_8_35>
<wan_0_8_35>
<entry1 vccId="1" vlanMuxId="-1" conId="1" name="mer_0_8_35" protocol="MER" encap="LLC" firewall="enable" nat="enable" fullcone="disable" igmp="disable" vlanId="-1" service="enable" instanceId="1509949442"/>
</wan_0_8_35>
<ADSL/>
<StaticIpCfg/>
<PMapCfg/>
<RouteCfg>
</RouteCfg>
<DDNSCfg/>
<SNTPCfg/>
<ToDCfg/>
<ToDUrlFilter/>
<EngDbgCfg/>
</psitree>
СообщениеДобавлено: Вс июл 18, 2010 19:01
ну что ж, всё верно, только ip-адрес вы раньше говорили 10.35.16.15, а тут 10.35.16.12, и второй dns не написан
и что, это совсем не работает? default gw у компьютеров при этом 192.168.1.1? добавленные ранее маршруты на 10.35.16.0 не забыли убрать?
СообщениеДобавлено: Вс июл 18, 2010 19:07
ну я просто в другом доме. здесь тоже адсл. второй днс? альтернативный? зачем он? какие ранее добавленные маршруты? я же ребут модема сделал. а где посмотреть default gw?
СообщениеДобавлено: Вс июл 18, 2010 19:14
default gw на сетевых картах на компах, в статусе соединения, или из командной строки 'route print', там и маршруты, которые могли добавлять 'route add'
хотя, маршрут через 10.35.17.254 и так тоже должен работать...
главное, комп переводить при этом либо в получение по dhcp, либо вручную 192.168.1.XXX/255.255.255.0 gw 192.168.1.1
чтобы там 10-я сеть нигде не осталась
СообщениеДобавлено: Вс июл 18, 2010 19:23
вот route print:
Microsoft Windows [Version 6.1.7600]
(c) Корпорация Майкрософт (Microsoft Corp.), 2009. Все права защищены.
C:\Users\JohanK>route print
Список интерфейсов
14...00 1c 26 ee db 9b ......Устройства Bluetooth (личной сети)
12...00 13 e8 cf f2 5b ......Intel(R) Wireless WiFi Link 4965AGN
11...00 1b 38 62 49 58 ......Broadcom NetLink (TM) Gigabit Ethernet
1...........................Software Loopback Interface 1
24...00 00 00 00 00 00 00 e0 Адаптер Microsoft 6to4 #6
15...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
16...00 00 00 00 00 00 00 e0 Адаптер Microsoft 6to4
22...00 00 00 00 00 00 00 e0 Адаптер Microsoft ISATAP #4
19...00 00 00 00 00 00 00 e0 Адаптер Microsoft 6to4 #2
23...00 00 00 00 00 00 00 e0 Адаптер Microsoft 6to4 #5
20...00 00 00 00 00 00 00 e0 Адаптер Microsoft 6to4 #3
21...00 00 00 00 00 00 00 e0 Адаптер Microsoft 6to4 #4
25...00 00 00 00 00 00 00 e0 Адаптер Microsoft ISATAP #3
26...00 00 00 00 00 00 00 e0 Адаптер Microsoft ISATAP #5
IPv4 таблица маршрута
Активные маршруты:
Сетевой адрес Маска сети Адрес шлюза Интерфейс Метрика
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.2 20
10.35.16.0 255.255.254.0 10.35.17.254 192.168.1.2 21
10.35.16.0 255.255.255.0 10.35.17.254 192.168.1.2 21
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
169.254.0.0 255.255.0.0 On-link 192.168.1.2 296
169.254.255.255 255.255.255.255 On-link 192.168.1.2 276
192.168.1.0 255.255.255.0 On-link 192.168.1.2 276
192.168.1.2 255.255.255.255 On-link 192.168.1.2 276
192.168.1.255 255.255.255.255 On-link 192.168.1.2 276
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.1.2 276
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.1.2 276
Постоянные маршруты:
Сетевой адрес Маска Адрес шлюза Метрика
0.0.0.0 0.0.0.0 5.0.0.1 По умолчанию
IPv6 таблица маршрута
Активные маршруты:
Метрика Сетевой адрес Шлюз
15 58 ::/0 On-link
1 306 ::1/128 On-link
15 58 2001::/32 On-link
15 306 2001:0:5ef5:73bc:1456:286c:3f57:fefd/128
On-link
15 306 fe80::/64 On-link
15 306 fe80::1456:286c:3f57:fefd/128
On-link
1 306 ff00::/8 On-link
15 306 ff00::/8 On-link
Отсутствует
СообщениеДобавлено: Вс июл 18, 2010 19:35
в варианте с MER-конфигурацией попробовать комп перевести на dhcp и убрать всё это:
route delete 10.35.16.0 mask 255.255.254.0
route delete 10.35.16.0 mask 255.255.255.0
что, даже интернет не работает так?
Последний раз редактировалось ergot Вс июл 18, 2010 19:37, всего редактировалось 1 раз.
СообщениеДобавлено: Вс июл 18, 2010 19:37
Сведения о сетевом подключении
Адрес IPv4: 192.168.1.2
Маска: 255.255.255.0
Шлюз: 192.168.1.1
DHCP-сервер: 192.168.1.1
DNS-сервер: 192.168.1.1
СообщениеДобавлено: Вс июл 18, 2010 19:44
ну я же много раз говорил, что интернет работает, домашняя сеть работает, но НЕ пингует ADSL пользователей в режиме MER!
СообщениеДобавлено: Вс июл 18, 2010 20:22
ага, прошу прощения, вот теперь начинаю понимать :) действительно, так и выходит, кривовато
у adsl-пользователей какие адреса? все на 10.35.16.XXX? тогда можно попробовать добавить к MER в Advanced Sеtup/Routing/Static Route 10.35.16.0 255.255.255.0 gw 10.35.17.254
СообщениеДобавлено: Вс июл 18, 2010 20:39
или ещё такой вариант, наверно даже получше, изменить в WAN/MER:
10.35.16.15/255.255.254.0 на 10.35.16.15/255.255.255.255, чтобы эта сеть была недоступна, как, в общем, и есть на самом деле
10.35.17.254 оставить как default gw
а маршрут к нему добавить в Static Route: 10.35.17.254/255.255.255.255 Use Interface: mer_0_8_35
Сейчас этот форум просматривают: Baidu [Spider] и гости: 14
