Текущее время: Вс июн 28, 2026 01:12
 Заголовок сообщения: DES-3526 calble_diag problem
СообщениеДобавлено: Вт июн 29, 2010 11:36
Доброго времени суток.
Недавно обнаружил, что команда cable_diag перестала работать:
DES-3526:admin#cable_diag ports all
Command: cable_diag ports all
 Perform Cable Diagnostics ...
 Port   Type    Link Status            Test Result           Cable Length (M)
  1     FE      Link Down      The PHY can't support Cable Diagnostic
  2     FE      Link Down      The PHY can't support Cable Diagnostic
  3     FE      Link Down      The PHY can't support Cable Diagnostic
  4     FE      Link Up        The PHY can't support Cable Diagnostic
  5     FE      Link Down      The PHY can't support Cable Diagnostic
  6     FE      Link Down      The PHY can't support Cable Diagnostic
  7     FE      Link Down      The PHY can't support Cable Diagnostic
  8     FE      Link Down      The PHY can't support Cable Diagnostic
  9     FE      Link Down      The PHY can't support Cable Diagnostic
  10    FE      Link Down      The PHY can't support Cable Diagnostic
  11    FE      Link Down      The PHY can't support Cable Diagnostic
  12    FE      Link Down      The PHY can't support Cable Diagnostic
  13    FE      Link Down      The PHY can't support Cable Diagnostic
  14    FE      Link Down      The PHY can't support Cable Diagnostic
  15    FE      Link Down      The PHY can't support Cable Diagnostic
  16    FE      Link Down      The PHY can't support Cable Diagnostic
  17    FE      Link Down      The PHY can't support Cable Diagnostic
  18    FE      Link Down      The PHY can't support Cable Diagnostic
  19    FE      Link Down      The PHY can't support Cable Diagnostic
  20    FE      Link Down      The PHY can't support Cable Diagnostic
  21    FE      Link Down      The PHY can't support Cable Diagnostic
  22    FE      Link Up        The PHY can't support Cable Diagnostic
  23    FE      Link Up        The PHY can't support Cable Diagnostic
  24    FE      Link Up        The PHY can't support Cable Diagnostic
  25    GE      Link Down      The PHY can't support Cable Diagnostic
  26    GE      Link Up        The PHY can't support Cable Diagnostic
DES-3526:admin#show switch
Command: show switch
Device Type       : DES-3526 Fast-Ethernet Switch
Combo Port Type   : 1000Base-T + 1000Base-T
Boot PROM Version : Build 5.00.009
Firmware Version  : Build 6.00.B38
Hardware Version  : 3A1
DES-3526:admin#
С чем это может быть связано?
PS Другой коммутатор с той же прошивкой и идентичным конфигом - работает исправно.
PPS С момента, когда команда работала, изменения в конфиг вносились только в разделе SNMP (добавили r-w комьюнити, и все)
СообщениеДобавлено: Вт июн 29, 2010 12:14
А точно ли она работала раньше, просто ревизия у свитча старая вроде как. По крайней мере у меня 0A3G пишет.
LiveComm
СообщениеДобавлено: Вт июн 29, 2010 12:29
Да, точно - специально проверяли.
СообщениеДобавлено: Вт июн 29, 2010 14:20
Cable diag поддерживается только на аппаратных версиях A3 A4 A5.
СообщениеДобавлено: Вт июн 29, 2010 14:40
Прошу прощения, действительно, пока меня не было, коллеги поменяли коммутатор.
