Текущее время: Пн авг 10, 2026 15:39
СообщениеДобавлено: Ср июн 23, 2010 09:12
Здраствуйте,
Роутер DIR-655 A3 1.34b2
Подключение PPPoE Russia Dual 12Mb/s
Trafic Shaping, Qos, WISH Выключено
WIFI:
g only
Выбор канала-вручную
Speed 54 Mb/s only
WPA2-PSK AES
Роутер под нагрузкой торентами перезагружается при включении WIFI по расписанию.
Лог:
<110>Wed Jun 23 06:59:40 2010 Router System Log: Blocked incoming UDP packet from 24.147.129.74:63121 to 95.221.211.169:35917
<110>Wed Jun 23 06:59:44 2010 Router System Log: Blocked incoming UDP packet from 24.147.129.74:63121 to 95.221.211.169:35917
<108>Wed Jun 23 07:00:01 2010 Router System Log: : Wireless schedule start
<108>Tue Jun 22 09:52:36 2010 Router System Log: Wireless schedule init
<110>Tue Jun 22 09:52:36 2010 Router System Log: Wireless link is up
<110>Tue Jun 22 09:52:36 2010 Router System Log: Device initialized
<110>Tue Jun 22 09:52:37 2010 Router System Log: LAN Ethernet Carrier Detected
<110>Tue Jun 22 09:52:37 2010 Router System Log: LAN interface is up
<110>Tue Jun 22 09:52:38 2010 Router System Log: WAN interface cable has been connected
<110>Tue Jun 22 09:52:38 2010 Router System Log: Bringing up WAN using Russia PPPoE
<110>Tue Jun 22 09:52:38 2010 Router System Log: Attempting to start always-on WAN connection
<110>Tue Jun 22 09:52:39 2010 Router System Log: Russia DHCP Options 121 created !!
<110>Tue Jun 22 09:52:39 2010 Router System Log: Obtained IP Address using DHCP. IP address is 10.16.160.79
<110>Tue Jun 22 09:52:40 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:21234 to 178.92.111.175:2290 as ACK received but there is no active connection
<110>Tue Jun 22 09:52:41 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:1127 to 91.211.117.113:4000 as PSH:ACK received but there is no active connection
<110>Tue Jun 22 09:52:44 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:21234 to 178.187.58.89:4459 as ACK received but there is no active connection
<110>Tue Jun 22 09:52:44 2010 Router System Log: Time server ntp1.dlink.com is at IP address 207.232.83.70
<110>Tue Jun 22 09:52:44 2010 Router System Log: Requesting time from 207.232.83.70
<110>Tue Jun 22 09:52:44 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:21234 to 78.85.180.88:55176 as ACK received but there is no active connection
<110>Tue Jun 22 09:52:45 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:21234 to 79.104.202.105:64127 as ACK received but there is no active connection
<110>Tue Jun 22 09:52:45 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:1383 to 178.122.21.39:57944 as ACK received but there is no active connection
<110>Tue Jun 22 09:52:45 2010 Router System Log: Starting DHCP server
<110>Tue Jun 22 09:52:46 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:21234 to 93.84.130.176:11306 as ACK received but there is no active connection
<110>Tue Jun 22 09:52:46 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:21234 to 41.230.216.193:51847 as ACK received but there is no active connection
<110>Tue Jun 22 09:52:46 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:3484 to 89.112.47.190:50001 as FIN:ACK received but there is no active connection
<110>Tue Jun 22 09:52:47 2010 Router System Log: Time synchronization failed (status 2)
<110>Tue Jun 22 09:52:47 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:21234 to 95.188.150.198:4769 as ACK received but there is no active connection
<110>Tue Jun 22 09:52:47 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:21234 to 109.73.192.82:1705 as ACK received but there is no active connection
<110>Tue Jun 22 09:52:47 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:21234 to 219.146.73.5:27217 as ACK received but there is no active connection
<110>Tue Jun 22 09:52:48 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:21234 to 183.2.237.104:14782 as ACK received but there is no active connection
<110>Tue Jun 22 09:52:48 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:21234 to 94.51.180.174:19224 as ACK received but there is no active connection
<110>Tue Jun 22 09:52:48 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:21234 to 92.43.185.40:2675 as ACK received but there is no active connection
<110>Tue Jun 22 09:52:49 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:21234 to 78.57.6.60:51141 as ACK received but there is no active connection
<110>Tue Jun 22 09:52:49 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:21234 to 123.17.128.111:16497 as ACK received but there is no active connection
<110>Tue Jun 22 09:53:08 2010 Router System Log: Trying to establish INTERNET PPPoE connection
<110>Tue Jun 22 09:53:08 2010 Router System Log: Discovering PPPoE servers for INTERNET PPPoE Session
<110>Tue Jun 22 09:53:08 2010 Router System Log: Offer of service [any] accepted for INTERNET PPPoE Session
<110>Tue Jun 22 09:53:08 2010 Router System Log: Issuing request for offer for INTERNET PPPoE Session
<110>Tue Jun 22 09:53:08 2010 Router System Log: Established INTERNET PPPoE connection, session id 19645
<110>Tue Jun 22 09:53:08 2010 Router System Log: LCP sets remote options: ACCM: FFFFFFFF, ACFC: 1, PFC: 0, MRU: 1492
<110>Tue Jun 22 09:53:08 2010 Router System Log: LCP sets remote auth: C223
<110>Tue Jun 22 09:53:08 2010 Router System Log: LCP sets local options: ACCM: 00000000, ACFC: 1, PFC: 0, MRU: 1492
<110>Tue Jun 22 09:53:08 2010 Router System Log: MSCHAPv1 authentication challenge received from peer.
<110>Tue Jun 22 09:53:08 2010 Router System Log: MSCHAPv1 authentication details were sent to authenticator.
<110>Tue Jun 22 09:53:08 2010 Router System Log: MSCHAPv1 authentication successful.
<110>Tue Jun 22 09:53:08 2010 Router System Log: PPP network up with IP Address 95.221.220.49
<110>Tue Jun 22 09:53:08 2010 Router System Log: WAN IP changed to 95.221.220.49, updating to dynamic DNS provider
<110>Tue Jun 22 09:53:08 2010 Router System Log: Dropped packet from 95.221.220.49 to 212.1.224.53 (IP protocol 17) as unable to create new session
<110>Tue Jun 22 09:53:08 2010 Router System Log: DNS relay ALG rejected packet from 95.221.220.49:4099 to 212.1.224.53:53
<110>Tue Jun 22 09:53:08 2010 Router System Log: Successfully updated dynamic DNS entry for *** good 95.221.220.49
<110>Tue Jun 22 09:53:08 2010 Router System Log: DNS relay ALG rejected packet from 95.221.220.49:4101 to 212.1.224.53:53
<110>Tue Jun 22 09:53:10 2010 Router System Log: Stored configuration to non-volatile memory
<110>Tue Jun 22 09:53:10 2010 Router System Log: Next dynamic DNS update scheduled for Fri Jul 16 09:53:08 2010
<110>Tue Jun 22 09:53:10 2010 Router System Log: Dropped packet from 95.221.220.49 to 239.192.152.143 (IP protocol 2) as unable to create new session
<110>Tue Jun 22 09:53:47 2010 Router System Log: Requesting time from 207.232.83.70
<110>Wed Jun 23 07:01:11 2010 Router System Log: Time synchronized
<110>Wed Jun 23 07:01:13 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:3169 to 95.70.119.195:53238 as ACK received but there is no active connection
<110>Wed Jun 23 07:01:15 2010 Router System Log: Blocked incoming TCP connection request from 91.206.15.79:61355 to 95.221.220.49:60109
Последний раз редактировалось romuz Чт июн 24, 2010 08:34, всего редактировалось 1 раз.
СообщениеДобавлено: Чт июн 24, 2010 08:32
Свежий лог, ситуация стабильно повторяется :(
<110>Thu Jun 24 06:59:10 2010 Router System Log: Blocked incoming TCP connection request from 95.221.140.176:4526 to 95.221.220.49:445
<108>Thu Jun 24 07:00:04 2010 Router System Log: : Wireless schedule start
<110>Tue Jun 22 09:52:38 2010 Router System Log: Russia DHCP Options 121 created !!
<110>Tue Jun 22 09:52:38 2010 Router System Log: Obtained IP Address using DHCP. IP address is 10.16.160.79
<110>Tue Jun 22 09:52:40 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:21234 to 201.75.16.184:49793 as ACK received but there is no active connection
<110>Tue Jun 22 09:52:43 2010 Router System Log: Time server ntp1.dlink.com is at IP address 207.232.83.70
<110>Tue Jun 22 09:52:43 2010 Router System Log: Requesting time from 207.232.83.70
<110>Tue Jun 22 09:52:43 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:21234 to 91.212.239.7:65166 as ACK received but there is no active connection
<110>Tue Jun 22 09:52:46 2010 Router System Log: Time synchronization failed (status 2)
<110>Tue Jun 22 09:53:05 2010 Router System Log: Blocked outgoing TCP packet from 192.168.0.5:21234 to 112.92.171.164:50142 as FIN:ACK received but there is no active connection
<110>Tue Jun 22 09:53:06 2010 Router System Log: Blocked incoming TCP packet from 79.120.45.128:4996 to 10.16.160.79:21234 as PSH:ACK received but there is no active connection
<110>Tue Jun 22 09:53:08 2010 Router System Log: Established INTERNET PPPoE connection, session id 31732
<110>Tue Jun 22 09:53:08 2010 Router System Log: PPP network up with IP Address 95.221.214.249
<110>Tue Jun 22 09:53:08 2010 Router System Log: WAN IP changed to 95.221.214.249, updating to dynamic DNS provider
<110>Tue Jun 22 09:53:08 2010 Router System Log: Dropped packet from 95.221.214.249 to 212.1.224.34 (IP protocol 17) as unable to create new session
<110>Tue Jun 22 09:53:08 2010 Router System Log: DNS relay ALG rejected packet from 95.221.214.249:4099 to 212.1.224.34:53
<110>Tue Jun 22 09:53:08 2010 Router System Log: Successfully updated dynamic DNS entry for *** good 95.221.214.249
<110>Tue Jun 22 09:53:08 2010 Router System Log: Dropped packet from 95.221.214.249 to 212.1.230.111 (IP protocol 17) as unable to create new session
<110>Tue Jun 22 09:53:08 2010 Router System Log: DNS relay ALG rejected packet from 95.221.214.249:4101 to 212.1.230.111:53
<110>Tue Jun 22 09:53:46 2010 Router System Log: Requesting time from 207.232.83.70
<110>Thu Jun 24 07:01:18 2010 Router System Log: Time synchronized
СообщениеДобавлено: Чт июн 24, 2010 08:46
romuz писал(а):
Здраствуйте,
На предыдущей бете было так же?
СообщениеДобавлено: Чт июн 24, 2010 09:04
VadimI писал(а):
romuz писал(а):
Здраствуйте,
Тоже самое... даже на 1.21 насколько я помню перезагружался... Видимо памяти не хватает для запуска.
А у вас с этим проблемы нет, или не пользуетесь?
СообщениеДобавлено: Чт июн 24, 2010 10:57
romuz писал(а):
VadimI писал(а):
romuz писал(а):
Здраствуйте,
Не пользуюсь, но попробую для интересу.
СообщениеДобавлено: Чт июн 24, 2010 15:41
Конфиг прислать сввой для анализа можете мне? У меня такая проблема на тестовом стенде не подтверждается.
СообщениеДобавлено: Пт июн 25, 2010 07:17
Отправил конфиг на vkorkunov@dlink.ru
Но повторюсь, проблема возникает после длительной работы роутера с торрентами.
Если перед включением по расписанию, скажем минут за 10, я перезагружу роутер то включение сработает как и должено, а если через сутки то с перезагрузкой.
СообщениеДобавлено: Пт июн 25, 2010 08:14
Подобную проблему не могу подтвердить. WiFi включается и выключается стабильно, торренты раздаются постоянно, роутер не перегружается уже несколько дней.
ps Прошивка последняя, обновлял сбросом к заводским настройкам и вбитием настроек по новой.
СообщениеДобавлено: Пт июн 25, 2010 10:36
romuz писал(а):
О
Если у вас торрент клиент utorrent 2.0 и старше, в дополнительных настройках сделайте параметр bt.transp.disposition поменьше, а лучше равным 5.
СообщениеДобавлено: Пт июн 25, 2010 12:58
VadimI писал(а):
romuz писал(а):
О
Именно так... uTP у меня отключен совсем.
