Текущее время: Пн сен 14, 2026 12:22
СообщениеДобавлено: Чт май 06, 2010 23:23
Кусок лога со стороны провайдера:
21:31:11.281930 arp who-has 10.14.0.1 (ff:ff:ff:ff:ff:ff) tell <my_IP>
21:31:11.282419 arp reply 10.14.0.1 is-at 00:e0:81:79:dc:e8
21:31:19.370111 arp who-has 193.151.59.59 (ff:ff:ff:ff:ff:ff) tell <my_IP>
21:31:19.370121 arp reply 193.151.59.59 is-at 00:e0:81:79:dc:e8
21:31:20.362037 arp who-has 193.151.59.157 (ff:ff:ff:ff:ff:ff) tell <my_IP>
21:31:20.362050 arp reply 193.151.59.157 is-at 00:e0:81:79:dc:e8
21:31:20.455161 arp who-has 193.151.59.249 (ff:ff:ff:ff:ff:ff) tell <my_IP>
21:31:26.426317 arp who-has 193.151.59.1 (ff:ff:ff:ff:ff:ff) tell <my_IP>
21:31:26.426326 arp reply 193.151.59.1 is-at 00:e0:81:79:dc:e8
21:31:33.841542 arp who-has 193.151.59.51 (ff:ff:ff:ff:ff:ff) tell <my_IP>
21:31:33.841557 arp reply 193.151.59.51 is-at 00:e0:81:79:dc:e8
21:31:34.099633 arp who-has 193.151.59.17 (ff:ff:ff:ff:ff:ff) tell <my_IP>
21:31:34.099645 arp reply 193.151.59.17 is-at 00:e0:81:79:dc:e8
21:31:34.922693 arp who-has 193.151.59.188 (ff:ff:ff:ff:ff:ff) tell <my_IP>
21:31:34.922704 arp reply 193.151.59.188 is-at 00:e0:81:79:dc:e8
21:31:34.966627 arp who-has 193.151.57.87 (ff:ff:ff:ff:ff:ff) tell <my_IP>
21:31:38.863751 arp who-has 193.151.59.24 (ff:ff:ff:ff:ff:ff) tell <my_IP>
21:31:38.863762 arp reply 193.151.59.24 is-at 00:e0:81:79:dc:e8
21:32:01.056578 arp who-has 193.151.59.15 (ff:ff:ff:ff:ff:ff) tell <my_IP>
21:32:01.056590 arp reply 193.151.59.15 is-at 00:e0:81:79:dc:e8
21:32:02.459626 arp who-has 193.151.59.233 (ff:ff:ff:ff:ff:ff) tell <my_IP>
21:32:02.459642 arp reply 193.151.59.233 is-at 00:e0:81:79:dc:e8
21:32:02.678619 arp who-has 193.151.59.6 (ff:ff:ff:ff:ff:ff) tell <my_IP>
21:32:02.678630 arp reply 193.151.59.6 is-at 00:e0:81:79:dc:e8
21:32:05.290716 arp who-has 193.151.59.148 (ff:ff:ff:ff:ff:ff) tell <my_IP>
Current Firmware Version : 1.21WW
Current Firmware Date : 2008/12/26
Он шлет это наружу даже в полном одиночестве, т.е. когда к нему ничего не подключено.
Перерыл англоязычный инет - ничего, нашел на вашем форуме единственную ветку viewtopic.php?t=57127&postdays=0&postorder=asc&highlight=ARP+WHO&start=15 но там немного не то.
Поможите это побороть? А то пров грозиться вырубить, дескать перегружаю им маршрутизатор :(
СообщениеДобавлено: Пт май 07, 2010 15:51
Ну для начала обновить ПО, сбросить его кнопкой и посмотреть, что получится.
СообщениеДобавлено: Пт май 07, 2010 15:53
Попробуйте обновить прошивку до последней версии: http://ftp.dlink.ru/pub/Router/DIR-655/ ... 1WWB04.bin
Инструкция по прошивке: http://dlink.ru/ru/faq/68/274.html
СообщениеДобавлено: Пт май 07, 2010 16:58
Общая идея ясна. Спасибо. А вот бету ставить не стремно? Как я почитал, откатить назад будет уже нельзя :(
Как распаковать gateway_settings.gws? Не переписывать же руками МАС адреса всех интерфейсов своих компов и настроенные порты в НАТ-е.... (
СообщениеДобавлено: Вт май 11, 2010 11:32
Откатить можно будет.
При прошивке распаковывать ничего не надо.
СообщениеДобавлено: Вт май 11, 2010 14:07
а 1.31-я прошивка захавает gateway_settings.gws от 1.21? Или мне на бумажечку все переписывать придеться? И ткните, плз, в ссылку или ФАК по процедуре отката на 1.21, а то мало ли чего..... он еще гарантийный ;)
СообщениеДобавлено: Вт май 11, 2010 14:24
Настройки после прошивки прописывайте вручную.
Сейчас этот форум просматривают: Google [Bot] и гости: 149
