Текущее время: Чт авг 20, 2026 21:35
 Заголовок сообщения: DGS-3610-26 LACP Link Aggregation
СообщениеДобавлено: Пт апр 30, 2010 00:38
Имеется 2 шт DGS-3610-26 между ними настроено по 2 портах Link Aggregation по LACP
Первый коммутатор
DGS-3610#sh aggregatePort load-balance
Load-balance : Source MAC and Destination MAC
DGS-3610#sh int Aggregateport 1
Index(dec):27 (hex):1b
AggregatePort 1 is UP , line protocol is UP
Hardware is Broadcom 5464 AggregatePort
Description: to_3610_2
Interface address is: no ip address
MTU 1500 bytes, BW 2000000 Kbit
Encapsulation protocol is Bridge, loopback not set
Keepalive interval is 10 sec , set
Carrier delay is 2 sec
RXload is 38 ,Txload is 169
Queueing strategy: FIFO
Output queue 0/0, 0 drops;
Input queue 0/75, 0 drops
Switchport attributes:
interface's description:"to_3610_on_M52"
medium-type is copper
lastchange time:0 Day: 0 Hour: 0 Minute:52 Second
Priority is 0
admin duplex mode is AUTO, oper duplex is Full
admin speed is AUTO, oper speed is 1000M
flow control admin status is OFF,flow control oper status is OFF
broadcast Storm Control is OFF,multicast Storm Control is OFF,unicast Storm Control is OFF
Aggregate Port Informations:
Aggregate Number: 1
Refs: 2
Members: (count=2)
GigabitEthernet 0/22 Link Status: Up
GigabitEthernet 0/23 Link Status: Up
DGS-3610#sh lacp summary
System Id:32768, 0021.91c7.d71b
Flags: S - Device is sending Slow LACPDUs F - Device is sending fast LACPDUs.
A - Device is in active mode. P - Device is in passive mode.
Aggregate port 1:
Local information:
LACP port Oper Port Port
Port Flags State Priority Key Number State
Gi0/22 SA bndl 32768 0x1 0x16 0x3d
Gi0/23 SA bndl 32768 0x1 0x17 0x3d
Partner information:
Port Flags Priority Dev ID Key Number State
Gi0/22 SA 32768 0021.91c7.d713 0x1 0x16 0x3d
Gi0/23 SA 32768 0021.91c7.d713 0x1 0x17 0x3d
Второй коммутатор
DGS-3610#sh AggregatePort load-balance
Index(dec):28 (hex):1c
Description: to_3610_on_tr2
RXload is 163 ,Txload is 37
interface's description:"to_3610_on_tr2"
lastchange time:26 Day: 8 Hour:53 Minute:59 Second
Priority is 0
Aggregate Number: 1
Refs: 2
Members: (count=2)
System Id:32768, 0021.91c7.d713
Aggregate port 1:
Local information:
Gi0/22 SA 32768 0021.91c7.d71b 0x1 0x16 0x3d
Gi0/23 SA 32768 0021.91c7.d71b 0x1 0x17 0x3d
Вопрос:
Выглядит так что хоть и задействовано 2 гиговых порта и настроена балансировка - больше одного гига продавить не получается через агрегацию.....
СообщениеДобавлено: Пт апр 30, 2010 13:18
никто ничего не может сказать о том почему 1 Гб ?
СообщениеДобавлено: Пт апр 30, 2010 14:19
Как проверяете?
СообщениеДобавлено: Пт апр 30, 2010 14:41
Он в нас стоит под нагрузкой и снимаем статистику с него...
синтетических тестов не делали
Трафик идёт по двум портах и в точке 1Гб (понятно что на портах распеределён этот Гиг ) на портах физических до гига есть куда ещё лезть в принципе!
а должно быть по идее 2 ? или этого никто не знает ;) сколько должно быть при агрегации с балансировкой двух гиговых портов ....
больше всего не нравится вот это
СообщениеДобавлено: Вт май 04, 2010 11:14
А какая нагрузка на 22 и 23 портах?
СообщениеДобавлено: Ср май 05, 2010 02:03
Сейчас на графиках нет нагрузки больше гига.
демонстрирую чтобы было видно как распределяется траффик между портами в канале.
Но бывают моменты когда на агрегированном канале в гиг впираемся а на портах ёмкость ещё есть. Постараюсь такой момент позже продемонстрировать когда будет загрузка...
Агрегированный
22
23
Ну и вопрос всё таки oper speed 1000M - что это значит? и на какой всё таки скорости должен работать канал ? по идее, я так понимаю, должно быть 2Гига
СообщениеДобавлено: Ср май 05, 2010 09:11
Скорость аггрегированого интерфейса берётся по среде. А вот что касается общей скорости в 1Гб с учётом трафика с двух портов. Это странно.
Запрошу разработчиков, скиньте пожалуйста в почту версию прошивки и конфиги обоих устройств.
СообщениеДобавлено: Ср май 12, 2010 04:21
подгрузили больше канал - протестировали, порог в гиг перешли - на первый взгляд всё работает!
Спасибо за консультации!
Сейчас этот форум просматривают: Bing [Bot] и гости: 14
