Текущее время: Ср июн 24, 2026 14:56
 Заголовок сообщения: DES-3526 IP MAC Port Binding ARP + ACL?
СообщениеДобавлено: Чт апр 29, 2010 23:03
Доброго времени суток.
Заметил вот такую чтуку
DES-3526:admin#show access_profile
Command: show access_profile
DES-3526:admin#config address_binding ip_mac ports 2 state enable
Command: config address_binding ip_mac ports 2 state enable
Success.
DES-3526:admin#
Access Profile Table
Access Profile ID : 1                                      Type : Packet Content
Owner    : Address_binding
Masks    :
Offset 16-31 : 0xffff0000 00000000 00000000 00000000
Offset 32-47 : 0x00000000 0000ffff 00000000 00000000
Access ID: 2              Mode: Lease_renew
Port     : 2
Offset 16-31 : 0x08000000 00000000 00000000 00000000
Offset 32-47 : 0x00000000 00000044 00000000 00000000
ACL Free: System : 799, Port 1-8  : 199, Port 9-16 : 200, Port 17-24: 200
         Port 25 : 100, Port 26   : 100
Total Access Entries : 1
DES-3526:admin#config address_binding ip_mac ports 2 state disable
Command: config address_binding ip_mac ports 2 state disable
Success.
DES-3526:admin#show firmware information
Command: show firmware information
ID  Version   Size(B)  Update Time          From                User
*1  6.00.B35  3387870  2010/03/19 23:58:31  172.21.203.1(T)     admin
 2  (Empty)
'*' means boot up section
(T) means firmware update through TELNET
(S) means firmware update through SNMP
(W) means firmware update through WEB
(SIM) means firmware update through Single IP Management
Free space: 4980736 bytes
DES-3526:admin#show address_binding ip_mac all
Command: show address_binding ip_mac all
IP Address      MAC Address       Ports                          Mode
172.21.100.2    00-04-61-1B-8A-6A 10                             ARP
172.21.100.3    00-04-61-2E-11-FE 10                             ARP
172.21.100.4    00-04-63-DF-FF-F7 10                             ARP
172.21.100.5    00-0C-1E-88-11-E0 10                             ARP
172.21.100.6    00-0F-EA-17-23-59 10                             ARP
172.21.100.7    00-13-71-AA-05-02 10                             ARP
172.21.100.8    00-14-81-DA-25-46 10                             ARP
172.21.100.9    00-16-11-B8-C3-01 10                             ARP
172.21.100.10   00-16-31-2E-67-8F 10                             ARP
172.21.100.11   00-1A-2D-57-AD-06 10                             ARP
172.21.100.12   00-1B-28-53-AE-D1 10                             ARP
172.21.100.13   00-2B-B9-B4-86-5A 10                             ARP
172.21.100.14   00-2B-B9-B8-7D-26 10                             ARP
172.21.100.15   00-2D-7D-D4-3B-61 10                             ARP
172.21.100.16   00-2F-D0-20-C0-3F 10                             ARP
172.21.100.17   00-1F-D1-41-59-03 10                             ARP
172.21.100.18   00-21-81-39-58-2A 10                             ARP
172.21.100.19   00-22-16-45-06-F1 10                             ARP
172.21.100.20   00-24-07-0F-76-3D 10                             ARP
172.21.100.21   00-22-12-9E-FD-29 10
Total entries : 190
DES-3526:admin#
ТОесть
по началу не имеем ни одного access профиля,
включаем биндинг на 2 порту и на порту появляется какое-то правило.
Как видно - овнер адресбиндинг.
Все связки создаются в арп режиме.
Как сделать так, чтобы не тратился акль? Что-то где-то включено? Никак не могу понять почему создается акль, хотя работа идет в арп-мод.
СообщениеДобавлено: Чт апр 29, 2010 23:39
если же включить биндинг на 1-19 то создаются 19 правил.
Далее отключаем биндинг и удаляем все связки
config address_binding ip_mac ports 1-24 state disable allow_zeroip disable forward_dhcppkt disable
delete address_binding ip_mac all
DES-3526:admin#show address_binding ports
Command: show address_binding ports
Port  State     Zero IP    DHCP Packet  Stop Learning
                                        Threshold/Mode
1     Disabled  Not Allow  Not Forward  no_limit/Normal
2     Disabled  Not Allow  Not Forward  no_limit/Normal
3     Disabled  Not Allow  Not Forward  no_limit/Normal
4     Disabled  Not Allow  Not Forward  no_limit/Normal
5     Disabled  Not Allow  Not Forward  no_limit/Normal
6     Disabled  Not Allow  Not Forward  no_limit/Normal
7     Disabled  Not Allow  Not Forward  no_limit/Normal
8     Disabled  Not Allow  Not Forward  no_limit/Normal
9     Disabled  Not Allow  Not Forward  no_limit/Normal
10    Disabled  Not Allow  Not Forward  no_limit/Normal
11    Disabled  Not Allow  Not Forward  no_limit/Normal
12    Disabled  Not Allow  Not Forward  no_limit/Normal
13    Disabled  Not Allow  Not Forward  no_limit/Normal
14    Disabled  Not Allow  Not Forward  no_limit/Normal
15    Disabled  Not Allow  Not Forward  no_limit/Normal
16    Disabled  Not Allow  Not Forward  no_limit/Normal
17    Disabled  Not Allow  Not Forward  no_limit/Normal
18    Disabled  Not Allow  Not Forward  no_limit/Normal
19    Disabled  Not Allow  Not Forward  no_limit/Normal
20    Disabled  Not Allow  Not Forward  no_limit/Normal
21    Disabled  Not Allow  Not Forward  no_limit/Normal
22    Disabled  Not Allow  Not Forward  no_limit/Normal
23    Disabled  Not Allow  Not Forward  no_limit/Normal
24    Disabled  Not Allow  Not Forward  no_limit/Normal
25    Disabled  Not Allow  Not Forward  no_limit/Normal
26    Disabled  Not Allow  Not Forward  no_limit/Normal
Masks    :
Port     : 2
Access ID: 4              Mode: Lease_renew
Port     : 4
ACL Free: System : 781, Port 1-8  : 195, Port 9-16 : 192, Port 17-24: 194
Total Access Entries : 19
ACL_mode          : Disabled
Trap/Log          : Enabled
DHCP_Snoop        : Disabled
Total entries : 0
Удалить эти акли невозможно, только ребут.
DES-3526:admin#delete access_profile profile_id 1
Command: delete access_profile profile_id 1
This entry was not created by ACL.
Fail!
Данные акли блокируют работу dhcp.
СообщениеДобавлено: Пт апр 30, 2010 09:44
Вам нужно сделать:
disable address_binding acl_mode
P.S. Можете также ознакомиться с презентацией: ftp://ftp.dlink.ru/pub/Trainings/D-Link_switches_and_network_technologies_Advanced.rar
СообщениеДобавлено: Пт апр 30, 2010 09:52
Так ведь
ACL_mode          : Disabled
Trap/Log          : Enabled
DES-3526:admin#disable address_binding acl_mode
Command: disable address_binding acl_mode
Success.
< вот в этот момент по снмп заливаем связки >
Masks    :
Port     : 2
Port     : 4
ACL Free: System : 792, Port 1-8  : 195, Port 9-16 : 197, Port 17-24: 200
Total Access Entries : 8
СообщениеДобавлено: Пт апр 30, 2010 10:24
А какими SNMP командами создаете связки?
СообщениеДобавлено: Пт апр 30, 2010 11:25
Для 3626 кусочек кода php
<?php
snmpset($host,$community,"1.3.6.1.4.1.171.11.64.1.2.7.2.1.3.$ip","i","4");
snmpset($host,$community,"1.3.6.1.4.1.171.11.64.1.2.7.2.1.4.$ip","x","$binport");
snmpset($host,$community,"1.3.6.1.4.1.171.11.64.1.2.7.2.1.2.$ip","x","$mac1");
snmpset($host,$community,"1.3.6.1.4.1.171.11.64.1.2.7.2.1.6.$ip","i","0");
СообщениеДобавлено: Пт апр 30, 2010 12:15
На тестовом стенде такая ситуация не подтверждается, после команд:
snmpset -v2c -c private 192.168.0.1 1.3.6.1.4.1.171.11.64.1.2.7.2.1.3.192.168.0.100 i 4
snmpset -v2c -c private 192.168.0.1 1.3.6.1.4.1.171.11.64.1.2.7.2.1.4.192.168.0.100 x 80000000
snmpset -v2c -c private 192.168.0.1 1.3.6.1.4.1.171.11.64.1.2.7.2.1.2.192.168.0.100 x 000102030405
snmpset -v2c -c private 192.168.0.1 1.3.6.1.4.1.171.11.64.1.2.7.2.1.6.192.168.0.100 i 0
В sh access_profile записей не появляется.
Попробуйте, пожалуйста, ситуацию с прошивкой, которую я Вам выслал. После обновления прошивки нужно осуществить сброс конфигурации устройства, и подгрузить конфигурационный файл.
СообщениеДобавлено: Пн май 03, 2010 21:24
Обновил прошивку - всё осталось неизменно.
Обнаружил команду после которой всё происходит.
snmpset -v2c -c private 172.21.204.2 1.3.6.1.4.1.171.11.64.1.2.7.1.1.2.4 i 2
т.е. я хочу сделать
config address_binding ip_mac ports 4 state enable
Согласно Примеры настройки функции IP-MAC-Port Binding по SNMP для серии DES-35XX имею коммутатор с заводскими настройками, настроен только системный интерфейс и маршрут по умолчанию. После вышеуказанной команды получаем запись в профиле доступа, однако, если дать локально через rs232 - то запись не появляется.
              DES-3526 Fast Ethernet Switch Command Line Interface
                            Firmware: Build 6.00.B37
            Copyright(C) 2008 D-Link Corporation. All rights reserved.
username:
password:
Total entries : 0
ACL_mode          : Disabled
Trap/Log          : Enabled
< вот в этот момент выполняем снмп-команду >
Masks    :
Port     : 4
                                        Threshold/Mode
1     Disabled  Not Allow  Forward      no_limit/Normal
2     Disabled  Not Allow  Forward      no_limit/Normal
3     Disabled  Not Allow  Forward      no_limit/Normal
4     Strict    Not Allow  Forward      no_limit/Normal
5     Disabled  Not Allow  Forward      no_limit/Normal
6     Disabled  Not Allow  Forward      no_limit/Normal
7     Disabled  Not Allow  Forward      no_limit/Normal
8     Disabled  Not Allow  Forward      no_limit/Normal
9     Disabled  Not Allow  Forward      no_limit/Normal
10    Disabled  Not Allow  Forward      no_limit/Normal
11    Disabled  Not Allow  Forward      no_limit/Normal
12    Disabled  Not Allow  Forward      no_limit/Normal
13    Disabled  Not Allow  Forward      no_limit/Normal
14    Disabled  Not Allow  Forward      no_limit/Normal
15    Disabled  Not Allow  Forward      no_limit/Normal
16    Disabled  Not Allow  Forward      no_limit/Normal
17    Disabled  Not Allow  Forward      no_limit/Normal
18    Disabled  Not Allow  Forward      no_limit/Normal
19    Disabled  Not Allow  Forward      no_limit/Normal
20    Disabled  Not Allow  Forward      no_limit/Normal
21    Disabled  Not Allow  Forward      no_limit/Normal
22    Disabled  Not Allow  Forward      no_limit/Normal
23    Disabled  Not Allow  Forward      no_limit/Normal
24    Disabled  Not Allow  Forward      no_limit/Normal
25    Disabled  Not Allow  Forward      no_limit/Normal
26    Disabled  Not Allow  Forward      no_limit/Normal
СообщениеДобавлено: Вт май 04, 2010 09:37
Пришлите мне, пожалуйста, на почту полный конфигурационный файл коммутатора для анализа.
СообщениеДобавлено: Ср май 12, 2010 12:18
Данную ситуацию планируется исправить в следующей версии программного обеспечения ориентировочно в первой половине июня.
СообщениеДобавлено: Пн май 31, 2010 13:57
Выслал Вам исправление на почту, проверьте пожалуйста и сообщите по результатам.
