Текущее время: Сб авг 22, 2026 07:08
 Заголовок сообщения: DIR-300 traffic shaping. Баг или не баг?
СообщениеДобавлено: Вс апр 25, 2010 02:42
D-Link wireless 150 router
Hardware Version : B1 Firmware Version : 2.01 (качал отсюда http://forum.dlink.ru/viewtopic.php?t=11222)
Беда в следующем: от роутера мне требуется в том числе функция traffic shaping на движке QoS. В мануале написано что есть,
QoS Engine
The QoS Engine feature helps improve your network performance by prioritizing applications.
QoS Engine Setup
Enable QoS Engine - Enable this option for better performance and experience with online games and other interactive applications, such as VoIP.
Enable Traffic Shaping - When this option is enabled, the router restricts the flow of outbound traffic so as not to exceed the WAN uplink bandwidth.
Automatic Uplink Speed - When enabled, this option causes the router to automatically measure the useful uplink bandwidth each time the WAN interface is re-established (after a reboot, for example).
Measured Uplink Speed - This is the uplink speed measured when the WAN interface was last re-established. The value may be lower than that reported by your ISP as it does not include all of the network protocol overheads associated with your ISP's network. Typically, this figure will be between 87% and 91% of the stated uplink speed for xDSL connections and around 5 kbps lower for cable network connections.
Manual Uplink Speed - If Automatic Uplink Speed is disabled, this option allows you to set the uplink speed manually. Uplink speed is the speed at which data can be transferred from the router to your ISP. This is determined by your ISP. ISPs often specify speed as a downlink/uplink pair; for example, 1.5Mbps/284kbps. For this example, you would enter "284". Alternatively you can test your uplink speed with a service such as www.dslreports.com. Note however that sites such as DSL Reports, because they do not consider as many network protocol overheads, will generally note speeds slightly lower than the Measured Uplink Speed or the ISP rated speed.
Connection Type - By default, the router automatically determines whether the underlying connection is an xDSL/Frame-relay network or some other connection type (such as cable modem or Ethernet), and it displays the result as Detected xDSL or Frame Relay Network. If you have an unusual network connection in which you are actually connected via xDSL but for which you configure either "Static" or "DHCP" in the WAN settings, setting this option to xDSL or Other Frame Relay Network ensures that the router will recognize that it needs to shape traffic slightly differently in order to give the best performance. Choosing xDSL or Other Frame Relay Network causes the measured uplink speed to be reported slightly lower than before on such connections, but gives much better results.
Detected xDSL or Frame Relay Network - When Connection Type is set to Auto-detect, the automatically detected connection type is displayed here.
а на деле нет.
Может я чего то не допонял :? прошу дать ответ.
D-Link Wireless 150 Router DIR-320
СообщениеДобавлено: Вс апр 25, 2010 12:50
На данной прошивке Traffic shaping еще не реализован разработчиком.
СообщениеДобавлено: Вс апр 25, 2010 16:44
Отписал в ПМ.
СообщениеДобавлено: Пн апр 26, 2010 13:07
Ммм, можно ли узнать как скоро будет реализован трафик шейпинг на данном роутере, на сколько процентов так сказать, и какие есть альтернативы к данному роутеру? Мне шейпинг необходим для урезки торент юзеров - они забивают канал, заставляя остальных пользователей курить бамбук... Может есть способ по другому раздать всем по ровну,никого не обидив..
СообщениеДобавлено: Пн апр 26, 2010 14:04
DFL умеют шейпер, но они не сопоставимы с DI по ценам
Хотите считать с него трафик?
СообщениеДобавлено: Пн апр 26, 2010 14:23
эт точно... хотелось бы вариант по дешевше...
СообщениеДобавлено: Пн апр 26, 2010 14:49
viewtopic.php?t=121446 п.11
СообщениеДобавлено: Вт апр 27, 2010 06:10
почитал про bandwidth control и понял что, что тот факт, что я почти не спал последние трое суток очень плохо отразился на вникании во всякого рода новые вещи...
Вот эмуль 330-го
http://support.dlink.com/Emulators/dir3 ... index.html
Вот 130-го
http://www.support.dlink.com/emulators/ ... index.html
как тут настроить то О_о
_________________________________
viewtopic.php?t=119176&highlight=BANDWIDTH
судя по этой теме есть трафик шейпинг в 320-м,
ftp://files.dlink.com.au/products/DIR-3 ... _v1.00.pdf
судя по этому мануалу тут есть и bandwidth control (но нету трафик шейпинга, что, похоже, исправляется свежей прошивкой)
так что же выбрать все таки для решение задачи с параметрами
cheap/traffic shaping(bandwidth)?
соответственно варианты ответа
1) DIR-130
2) DIR-320
3) DIR-330
4) автор дибил и нифига не шарит - здесь нет правильного ответа
СообщениеДобавлено: Вт апр 27, 2010 09:43
Вот эмуль 330-го
Вот 130-го
В эмуляторах нет данного функционала, могу прислать необходимые скрины с описанием.
В DIR-320 traffic shaping работает на гарантированную полосу пропускания и только тогда, когда канал полностью загружен и необходимо выделить гарантированную полосу пропускания.
1) DIR-130
2) DIR-320
3) DIR-330
Выбирайте исходя из стоимости и функционала, на беспроводной сети bandwidth control не работает, т.к. беспроводная сеть очень специфическая среда передачи данных.
СообщениеДобавлено: Вт апр 27, 2010 12:22
жду скринов=)
Беспроводную среду можно пока что опустить
5 постоянно работающих торент-юзеров могут обеспечить полный загруз канала на 3 мб инете? (я думаю могут)
поменял сегодня DIR-300 на DIR-320/
прошил его вот этим: http://ftp.dlink.ru/pub/Router/DIR-320/ ... -rc110.bin
офигенно, но видимо когда это писали не сильно задумывались над реализацией PPPoE. не могу подключить О_о (может быть опять же я дурак, но там нету никаких иных настроек, окромя выбора сетевого адаптера..)
СообщениеДобавлено: Вт апр 27, 2010 14:55
Rai[er писал(а):
жду скринов=)
Пожалуйста, вот пример реализации Bandwidth control на DIR-130:
ограничиваем Download (по аналогии можно и Upload) для IP адреса 192.168.0.100 до 512 кбит/с
А зачем вы взяли прошивку для Yota?
Для PPPoE вполне подойдет и родная прошивка: http://ftp.dlink.ru/pub/Router/DIR-320/ ... 1_a3ia.bin
СообщениеДобавлено: Чт апр 29, 2010 06:23
на 320 м есть что то подобное)
но торрент, я так понял просто забивает канал полностью, не важно какая у канала скорость, и не дает пробиться всем остальным. над как то очередь организовать, чтобы всем был мир
СообщениеДобавлено: Чт апр 29, 2010 11:42
Попробуйте настроить Управление трафиком на DIR-320 для выделения гарантированной полосы пропускания для конкретного IP адреса, тогда торрент не будет занимать весь канал.
СообщениеДобавлено: Чт апр 29, 2010 17:15
вот простейшая схема моей сети:
если просто серфит пользователь 1, то у остальных качает со скоростью 3-5 к/б.
СообщениеДобавлено: Пт апр 30, 2010 13:14
Ну так зарезервируйте канал для 2 и 3 пользователя по IP адресу.
