Текущее время: Вт сен 15, 2026 17:03
 Заголовок сообщения: DIR-300 DIR-320 DIR-130 + pppoe (MikroTik RouterOS 4.2)
СообщениеДобавлено: Пн апр 12, 2010 15:54
Здраствуйте. Не первую неделю мучаюсь! понять не могу в чём проблема. Просьба обьяснить почему не работает у данных ротеров этот режим.
1. На дир 100 всё работает на ура всегда и его FW не обновляли.
2. DIR 300 обновлял как положенно со скидыванием конфигов и пошаговым обновлением до последней прошивки.dir300_v1.05_a319.bin.
Сесию то он цепляет авторизует но трафик не ходит вообще но на серваке логи пишут как опбычно мол зацепился и никакого отличая от других сессий.
Логи дира
"Jan  1 00:10:58  ","Access Control disabled."
"Jan  1 00:10:58  ","Remote management is disabled."
"Jan  1 00:10:58  ","Block WAN PING is disabled."
"Jan  1 00:10:57  ","DMZ disabled."
"Jan  1 00:10:57  ","VPN (RTSP) Pass-Through enabled."
"Jan  1 00:10:57  ","VPN (L2TP) Pass-Through enabled."
"Jan  1 00:10:57  ","VPN (IPSec) Pass-Through enabled."
"Jan  1 00:10:57  ","VPN (PPTP) Pass-Through enabled."
"Jan  1 00:10:57  ","Domain blocking disabled."
"Jan  1 00:10:57  ","URL blocking disabled."
"Jan  1 00:10:57  ","MAC filter disabled."
"Jan  1 00:10:55  ","PPPoE: Sending PADT for session1. (Session ID: f5)"
"Jan  1 00:10:54  ","PPP: Connection terminated."
"Jan  1 00:10:49  ","PPP: Terminating connection due to lack of activity."
"Jan  1 00:05:52  ","Access Control disabled."
"Jan  1 00:05:52  ","Remote management is disabled."
"Jan  1 00:05:52  ","Block WAN PING is disabled."
"Jan  1 00:05:51  ","DMZ disabled."
"Jan  1 00:05:51  ","VPN (RTSP) Pass-Through enabled."
"Jan  1 00:05:51  ","VPN (L2TP) Pass-Through enabled."
"Jan  1 00:05:51  ","VPN (IPSec) Pass-Through enabled."
"Jan  1 00:05:51  ","VPN (PPTP) Pass-Through enabled."
"Jan  1 00:05:51  ","Domain blocking disabled."
"Jan  1 00:05:51  ","URL blocking disabled."
"Jan  1 00:05:51  ","MAC filter disabled."
"Jan  1 00:05:49  ","CHAP authentication succeeded."
"Jan  1 00:05:49  ","PPPoE: Received PADS for session1. (Session ID: f5)"
"Jan  1 00:05:49  ","PPPoE: Sending PADR for session1."
"Jan  1 00:05:49  ","PPPoE: Received PADO for session1, from: 00:0c:42:20:89:b0"
"Jan  1 00:05:49  ","PPPoE: Sending PADI for session1."
"Jan  1 00:05:47  ","Access Control disabled."
"Jan  1 00:05:47  ","Remote management is disabled."
"Jan  1 00:05:47  ","Block WAN PING is disabled."
"Jan  1 00:05:47  ","DMZ disabled."
"Jan  1 00:05:46  ","VPN (RTSP) Pass-Through enabled."
"Jan  1 00:05:46  ","VPN (L2TP) Pass-Through enabled."
"Jan  1 00:05:46  ","VPN (IPSec) Pass-Through enabled."
"Jan  1 00:05:46  ","VPN (PPTP) Pass-Through enabled."
"Jan  1 00:05:46  ","Domain blocking disabled."
"Jan  1 00:05:46  ","URL blocking disabled."
"Jan  1 00:05:46  ","MAC filter disabled."
"Jan  1 00:05:40  ","PPPoE: Sending PADT for session1. (Session ID: f4)"
"Jan  1 00:05:39  ","PPP: Connection terminated."
"Jan 1 00:03:43  ","Log message was cleared."
уже пробывал и mschap (1/2) и chap и pap и всё безтолку (MikroTik RouterOS 4.2) . Обьясните как это поправить может ктото сталкивался с такой проблемой?
СообщениеДобавлено: Пн апр 26, 2010 05:57
Решение найдено. проблема в локальных ипшниках и в ипшниках шлюза установленных на микротике. они не должны совпадать.(у dir 100 в силу его топорности всё работало нормально). А товарищам длинкам низачёт ни одного поста по определению проблемы.
Сейчас этот форум просматривают: Google [Bot] и гости: 45
