Текущее время: Ср сен 23, 2026 15:24
 Заголовок сообщения: Loopback Detection 3612G
СообщениеДобавлено: Чт апр 08, 2010 17:57
Здравствуйте!!!
Возникла проблема с 3612G.
замкнулось кольцо Loopback Detection не сработал легла сеть
вот логи
10997 2010-04-07, 12:30:50 Unauthenticated IP-MAC address and discarded by ip mac port binding(IP:<10.111.40.21>, MAC:<00-1D-7E-BD-39-2C>, Port<3>)
10996 2010-04-07, 12:30:50 Unauthenticated IP-MAC address and discarded by ip mac port binding(IP:<10.111.40.36>, MAC:<00-17-31-7F-4A-63>, Port<3>)
10995 2010-04-07, 12:30:50 Unauthenticated IP-MAC address and discarded by ip mac port binding(IP:<10.61.70.254>, MAC:<00-1B-11-5B-19-11>, Port<3>)
10994 2010-04-07, 12:30:50 Unauthenticated IP-MAC address and discarded by ip mac port binding(IP:<10.111.10.254>, MAC:<00-1C-F0-6D-4B-30>, Port<3>)
10993 2010-04-07, 12:30:50 Unauthenticated IP-MAC address and discarded by ip mac port binding(IP:<10.111.10.254>, MAC:<00-1C-F0-6D-4B-30>, Port<3>)
10992 2010-04-07, 12:30:50 Port <4> IMPB stop learning state
10991 2010-04-07, 12:30:50 Unauthenticated IP-MAC address and discarded by ip mac port binding(IP:<10.61.70.254>, MAC:<00-1B-11-5B-19-11>, Port<4>)
10990 2010-04-07, 12:30:50 Unauthenticated IP-MAC address and discarded by ip mac port binding(IP:<10.61.70.254>, MAC:<00-1B-11-5B-19-11>, Port<3>)
10989 2010-04-07, 12:30:50 Unauthenticated IP-MAC address and discarded by ip mac port binding(IP:<10.61.150.1>, MAC:<00-1A-92-33-26-67>, Port<4>)
10988 2010-04-07, 12:30:50 Unauthenticated IP-MAC address and discarded by ip mac port binding(IP:<10.61.150.1>, MAC:<00-1A-92-33-26-67>, Port<3>)
10987 2010-04-07, 12:30:50 Unauthenticated IP-MAC address and discarded by ip mac port binding(IP:<10.111.110.9>, MAC:<00-01-4A-06-B6-CA>, Port<4>)
10986 2010-04-07, 12:30:50 Unauthenticated IP-MAC address and discarded by ip mac port binding(IP:<10.111.110.9>, MAC:<00-01-4A-06-B6-CA>, Port<3>)
10985 2010-04-07, 12:30:50 Unauthenticated IP-MAC address and discarded by ip mac port binding(IP:<10.61.0.6>, MAC:<00-19-CB-8D-83-20>, Port<4>)
10984 2010-04-07, 12:30:50 Unauthenticated IP-MAC address and discarded by ip mac port binding(IP:<10.61.0.6>, MAC:<00-19-CB-8D-83-20>, Port<3>)
Loopback Detection Port Based Table
Port Loopdetect State Loop Status
1 Enabled Normal
2 Enabled Normal
3 Enabled Normal
4 Enabled Normal
5 Enabled Normal
6 Enabled Normal
7 Enabled Normal
8 Enabled Normal
9 Disabled Normal
10 Enabled Normal
11 Enabled Normal
12 Enabled Normal
Чем это может быть вызвано?
СообщениеДобавлено: Пт апр 09, 2010 00:39
Версия прошивки? А это петля между двумя портами или за одним?
СообщениеДобавлено: Пт апр 09, 2010 09:30
прошивка 2.51.B23 .Петля между 2-мя портами.
СообщениеДобавлено: Пт апр 09, 2010 09:47
LBD работает только с порта на порт. Для решения данной задачи Вам нужно использовать STP LBD.
Бигаров Руслан.
СообщениеДобавлено: Пт апр 09, 2010 13:12
как правильно настроить STP LBD?
СообщениеДобавлено: Вс апр 11, 2010 21:12
Вот так:
config stp ports 1-12 externalCost auto edge false p2p auto state enable lbd enable.
СообщениеДобавлено: Чт апр 15, 2010 15:11
Спасибо!!!
СообщениеДобавлено: Вт апр 20, 2010 00:05
Пожалуйста!
СообщениеДобавлено: Вт апр 20, 2010 07:37
разве для предотвращения кольца между двумя портами нужен loopdetect? вроде это решается только средствами STP и lbd можно делать disable... при том, что STP положит весь порт (рассматриваем STP и RSTP), loopdetect, который вынесен можно настроить vlan-based и будет положен только закольцованный vlan.
СообщениеДобавлено: Вт апр 20, 2010 19:57
STP и соответственно STP LBD отлавливает петли между портами, а LBD в пределах одного порта. Если нужно отлавливать и то и то то нужно включать STP и LBD независимый от STP.
