Текущее время: Пт окт 02, 2026 20:20
СообщениеДобавлено: Вт мар 30, 2010 12:03
взял за основу: http://www.dlink.ru/ru/faq/62/243.html
пункт №2
взял два DES3200-10
На обоих Коммутаторах:
VID : 2 VLAN Name : VLAN2
VLAN Type : Static Advertisement : Disabled
Member Ports : 1-4,9-10
Static Ports : 1-4,9-10
Current Tagged Ports : 9-10
Current Untagged Ports : 1-4
Static Tagged Ports : 9-10
Static Untagged Ports : 1-4
Forbidden Ports :
VID : 3 VLAN Name : VLAN3
Member Ports : 5-10
Static Ports : 5-10
Current Untagged Ports : 5-8
Static Untagged Ports : 5-8
Forbidden Ports :
DES-3200-10:4#show stp
Command: show stp
STP Bridge Global Settings
STP Status : Enabled
STP Version : MSTP
Max Age : 20
Forward Delay : 15
Max Hops : 20
TX Hold Count : 6
Forwarding BPDU : Enabled
DES-3200-10:4#show stp mst_config_id
Command: show stp mst_config_id
Current MST Configuration Identification
Configuration Name : abc Revision Level :1
MSTI ID VID List
CIST 1,4-4094
2 2
3 3
Коммутатор А:
DES-3200-10:4#show stp ports 9
Command: show stp ports 9
MSTP Port Information
Port Index : 9 , Hello Time: 2 /2 , Port STP Enabled ,
Restricted role : False, Restricted TCN : False
External PathCost : Auto/20000 , Edge Port : True /No , P2P : Auto /Yes
Port Forward BPDU : Enabled
MSTI Designated Bridge Internal PathCost Prio Status Role
0 1000/00265A1E4818 20000 128 Forwarding Designated
2 1002/00265A1E4818 20000 96 Forwarding Designated
3 1003/00265A1E4818 20000 128 Forwarding Designated
DES-3200-10:4#show stp ports 10
Command: show stp ports 10
Port Index : 10 , Hello Time: 2 /2 , Port STP Enabled ,
2 1002/00265A1E4818 20000 128 Forwarding Designated
3 1003/00265A1E4818 20000 96 Forwarding Designated
на коммутаторе B:
0 1000/00265A1E4818 20000 128 Forwarding Root
2 1002/00265A1E4884 20000 128 Forwarding Master
3 1003/00265A1E4884 20000 128 Forwarding Master
0 1000/00265A1E4818 20000 128 Discarding Alternate
2 100/00265A1E4884 20000 128 Discarding Alternate
3 1003/00265A1E4884 20000 128 Discarding Alternate
Коммутаторы связываю между собой 9порт в 9 10-10
Если вынимаю кабель из 9 все начинает работать по 10. Т.е. в принцепи работает, но при этом не работает балансировка.
Как я понял Vlan 2 у меня должен рабтать через порт 9 , а vlan 3 через 10 ый, но что-то так не получается.
Какие выводы еще показать?
СообщениеДобавлено: Вт мар 30, 2010 16:00
У меня был создан vlan 4. На одном был этот vlan на другом его не было.
Убил vlan 4 и все заработало так как хотелось.
СообщениеДобавлено: Ср мар 31, 2010 00:11
Это логично.
СообщениеДобавлено: Ср фев 08, 2012 11:54
У меня тоже проблема.
Схема почти такая же.
Два этих же коммутатора. прошивки на обоих 1.52.B003
Балансировка работает.
Но оба коммутатора в логах пишут
Topology changed (Instance:3 port:8)
Topology changed (Instance:2 port:1)
Topology changed (Instance:0 port:1)
Topology changed (Instance:3 port:1)
при этом периодически отваливается не рутовый коммутатор (В)
корневой коммутатор (А)
stp настроено на 1 и 8 порту
Command: show vlan ports 1
Port 1
VLAN ID Untagged Tagged Forbidden Dynamic
14 - X - -
900 X - - -
1490 - X - -
Command: show vlan ports 8
Port 8
14 - X - -
900 X - - -
1490 - X - -
коммутатор (В)
stp настроено на 15,16 порту
Command: show vlan ports 15
Port 15
14 - X - -
900 X - - -
1490 - X - -
Command: show vlan ports 16
Port 16
14 - X - -
900 X - - -
1490 - X - -
СообщениеДобавлено: Ср фев 08, 2012 13:55
Приведите настройки STP с обоих коммутаторов
СообщениеДобавлено: Ср фев 08, 2012 15:40
это с корневого коммутатора A
Command: show stp
STP Version : MSTP
Max Age : 20
Forward Delay : 15
Max Hops : 20
TX Hold Count : 6
Port Index : 1 , Hello Time: 2 /2 , Port STP Enabled ,
External PathCost : Auto/200000 , Edge Port : Auto /No , P2P : Auto /Yes
0 1000/F07D68A6C97C 200000 128 Forwarding Designated
2 1002/F07D68A6C97C 200000 96 Forwarding Designated
3 1003/F07D68A6C97C 200000 128 Forwarding Designated
Command: show stp ports 8
Port Index : 8 , Hello Time: 2 /2 , Port STP Enabled ,
2 1002/F07D68A6C97C 200000 128 Forwarding Designated
3 1003/F07D68A6C97C 200000 96 Forwarding Designated
Со второго коммутатора
Command: show stp
STP Version : MSTP
Max Age : 20
Forward Delay : 15
Max Hops : 20
TX Hold Count : 6
Command: show stp ports 15
Port Index : 15 , Hello Time: 2 /2 , Port STP Enabled ,
0 1000/F07D68A6C97C 200000 128 Forwarding Root
2 1002/F07D68A6C97C 200000 128 Forwarding Root
3 1003/F07D68A6C97C 200000 128 Discarding Alternate
Command: show stp ports 16
Port Index : 16 , Hello Time: 2 /2 , Port STP Enabled ,
0 1000/F07D68A6C97C 200000 128 Discarding Alternate
2 1002/F07D68A6C97C 200000 128 Discarding Alternate
3 1003/F07D68A6C97C 200000 128 Forwarding Root
на всех остальных портах включено stp.
СообщениеДобавлено: Ср фев 08, 2012 15:55
Отключите stp на клиентских портах.
СообщениеДобавлено: Чт фев 09, 2012 08:53
я описался на все остальных портах stp выключено
СообщениеДобавлено: Чт фев 09, 2012 09:08
Тогда приводите вырезки из конфига.
СообщениеДобавлено: Пт фев 10, 2012 07:55
Коммутатор А
# VLAN
disable asymmetric_vlan
enable pvid auto_assign
config vlan default delete 1-10
config vlan default advertisement enable
create vlan vlan14 tag 14
config vlan vlan14 add tagged 1,8-9
create vlan vlan35 tag 35
config vlan vlan35 add tagged 9-10
create vlan vlan900 tag 900
config vlan vlan900 add tagged 9-10
config vlan vlan900 add untagged 1-6,8
create vlan service tag 901
config vlan service add tagged 9-10
create vlan voip tag 990
config vlan voip add tagged 7,9-10
create vlan vlan1490 tag 1490
config vlan vlan1490 add tagged 1,8-9
disable qinq
disable gvrp
config qinq ports 1-10 role nni outer_tpid 0x88A8 trust_cvid disable vlan_translation disable
config gvrp 1-6,8 state disable ingress_checking disable acceptable_frame admit_all pvid 900
config gvrp 7,9-10 state disable ingress_checking disable acceptable_frame admit_all pvid 1
# STP
config stp version mstp
config stp maxage 20 maxhops 20 forwarddelay 15 txholdcount 6 fbpdu enable
config stp priority 4096 instance_id 0
create stp instance_id 2
config stp instance_id 2 add_vlan 14
config stp priority 4096 instance_id 2
create stp instance_id 3
config stp instance_id 3 add_vlan 900,1490
config stp priority 4096 instance_id 3
config stp mst_config_id name abcabc revision_level 111
config stp ports 1,8 externalCost auto hellotime 2 edge auto p2p auto state enable
config stp ports 1-10 hellotime 2
config stp mst_ports 1-10 instance_id 0 internalCost auto priority 128
config stp ports 1-10 fbpdu enable
config stp ports 1-10 restricted_role false
config stp ports 1-10 restricted_tcn false
config stp ports 2-7,9-10 externalCost auto hellotime 2 edge true p2p auto state disable
config stp mst_ports 1 instance_id 2 internalCost auto priority 96
config stp mst_ports 2-10 instance_id 2 internalCost auto priority 128
config stp mst_ports 1-7,9-10 instance_id 3 internalCost auto priority 128
config stp mst_ports 8 instance_id 3 internalCost auto priority 96
enable stp
Коммутатор В
# VLAN
config vlan default delete 1-18
config vlan vlan14 add tagged 15-17
config vlan vlan900 add untagged 15-16
create vlan service tag 1401
config vlan service add tagged 17
create vlan vlan1404 tag 1404
config vlan vlan1404 add tagged 17
config vlan vlan1404 add untagged 1-10
config vlan vlan1490 add tagged 15-17
disable qinq
disable gvrp
config qinq ports 1-18 role nni outer_tpid 0x88A8 trust_cvid disable vlan_translation disable
config gvrp 1-10 state disable ingress_checking enable acceptable_frame admit_all pvid 1404
config gvrp 11-14,17-18 state disable ingress_checking enable acceptable_frame admit_all pvid 1
config gvrp 15-16 state disable ingress_checking enable acceptable_frame admit_all pvid 900
# STP
config stp priority 32768 instance_id 0
config stp priority 32768 instance_id 2
config stp priority 32768 instance_id 3
config stp ports 1-14 externalCost auto hellotime 2 edge true p2p auto state disable
config stp ports 1-18 hellotime 2
config stp mst_ports 1-18 instance_id 0 internalCost auto priority 128
config stp ports 1-18 fbpdu enable
config stp ports 1-18 restricted_role false
config stp ports 1-18 restricted_tcn false
config stp ports 15-16 externalCost auto hellotime 2 edge auto p2p auto state enable
config stp ports 17-18 externalCost auto hellotime 2 edge auto p2p auto state disable
config stp mst_ports 1-18 instance_id 2 internalCost auto priority 128
config stp mst_ports 1-18 instance_id 3 internalCost auto priority 128
enable stp
СообщениеДобавлено: Пт фев 10, 2012 13:08
C виду все верно. Соответственно, если коммутатор говорит что топология менялась - можно сделать вывод, что линк все-таки моргал.
И еще вопрос. Если у вас только два линка и нужна балансировка - не проще ли поднять lacp, чем заморачиваться с mstp?
СообщениеДобавлено: Пт фев 10, 2012 14:03
оба эти линка радиоканалы. Поэтому не lacp не настроить.
СообщениеДобавлено: Пт фев 10, 2012 14:50
Значит у вас теряются bpdu в радиоканале и он периодически отваливается.
Ищите проблему не в коммутаторах
СообщениеДобавлено: Пн фев 13, 2012 09:05
потерь в обоих радиоканалах нет.
Могу только предположить, что истекает время ожидания bpdu пакета и коммутатор начинает перестраивать кольцо.
Можно ли это время ожидания увеличить?
СообщениеДобавлено: Пн фев 13, 2012 09:26
Редактируйте параметр maxage
Сейчас этот форум просматривают: Google [Bot] и гости: 21
