Текущее время: Сб сен 26, 2026 10:07
 Заголовок сообщения: Dir-320 пропадает сеть
СообщениеДобавлено: Вт мар 23, 2010 00:18
Переодически пропадает сеть
"Mar 22 07:40:31  ","Time synchronized"
"Mar 22 07:40:21  ","WAN connected (PPTP)."
"Mar 22 07:40:13  ","Access Control disabled."
"Mar 22 07:40:13  ","Remote management is disabled."
"Mar 22 07:40:13  ","Block WAN PING is disabled."
"Mar 22 07:40:12  ","DMZ disabled."
"Mar 22 07:40:12  ","VPN (RTSP) Pass-Through enabled."
"Mar 22 07:40:12  ","VPN (L2TP) Pass-Through enabled."
"Mar 22 07:40:12  ","VPN (IPSec) Pass-Through enabled."
"Mar 22 07:40:12  ","VPN (PPTP) Pass-Through enabled."
"Mar 22 07:40:12  ","Domain blocking disabled."
"Mar 22 07:40:12  ","URL blocking disabled."
"Mar 22 07:40:12  ","MAC filter disabled."
"Mar 22 07:40:10  ","IPCP: primary DNS address 10.1.1.1."
"Mar 22 07:40:10  ","IPCP: remote IP address 192.168.24.2."
"Mar 22 07:40:10  ","IPCP: local IP address 193.107.80.129."
"Mar 22 07:40:10  ","CHAP authentication succeeded."
"Mar 22 07:36:50  ","PPP: Connection terminated."
"Mar 22 07:36:48  ","PPP: Connection terminated."
"Mar 22 07:36:45  ","WAN disconnected (PPTP)."
"Mar 22 07:34:12  ","Time synchronized"
"Mar 22 07:34:02  ","WAN connected (PPTP)."
"Mar 22 07:33:54  ","Access Control disabled."
"Mar 22 07:33:53  ","Remote management is disabled."
"Mar 22 07:33:53  ","Block WAN PING is disabled."
"Mar 22 07:33:53  ","DMZ disabled."
"Mar 22 07:33:53  ","VPN (RTSP) Pass-Through enabled."
"Mar 22 07:33:53  ","VPN (L2TP) Pass-Through enabled."
"Mar 22 07:33:53  ","VPN (IPSec) Pass-Through enabled."
"Mar 22 07:33:53  ","VPN (PPTP) Pass-Through enabled."
"Mar 22 07:33:53  ","Domain blocking disabled."
"Mar 22 07:33:53  ","URL blocking disabled."
"Mar 22 07:33:53  ","MAC filter disabled."
"Mar 22 07:33:51  ","IPCP: primary DNS address 10.1.1.1."
"Mar 22 07:33:51  ","IPCP: remote IP address 192.168.24.2."
"Mar 22 07:33:51  ","IPCP: local IP address 193.107.80.129."
"Mar 22 07:33:51  ","CHAP authentication succeeded."
"Mar 22 07:30:10  ","PPP: Connection terminated."
"Mar 22 07:30:09  ","PPP: Connection terminated."
"Mar 22 07:30:06  ","WAN disconnected (PPTP)."
"Mar 22 07:28:52  ","WAN connected (PPTP)."
"Mar 22 07:28:44  ","Access Control disabled."
"Mar 22 07:28:44  ","Remote management is disabled."
"Mar 22 07:28:44  ","Block WAN PING is disabled."
"Mar 22 07:28:44  ","DMZ disabled."
"Mar 22 07:28:44  ","VPN (RTSP) Pass-Through enabled."
"Mar 22 07:28:44  ","VPN (L2TP) Pass-Through enabled."
"Mar 22 07:28:44  ","VPN (IPSec) Pass-Through enabled."
"Mar 22 07:28:44  ","VPN (PPTP) Pass-Through enabled."
"Mar 22 07:28:44  ","Domain blocking disabled."
"Mar 22 07:28:44  ","URL blocking disabled."
"Mar 22 07:28:44  ","MAC filter disabled."
"Mar 22 07:28:42  ","IPCP: primary DNS address 10.1.1.1."
"Mar 22 07:28:42  ","IPCP: remote IP address 192.168.24.2."
"Mar 22 07:28:42  ","IPCP: local IP address 193.107.80.129."
"Mar 22 07:28:42  ","CHAP authentication succeeded."
"Mar 22 07:28:14  ","PPP: Connection terminated."
"Mar 22 07:28:14  ","WAN disconnected (PPTP)."
"Mar 22 07:15:10  ","Time synchronized"
сеть 10.0.0.0 маска 255.0.0.0 шлюз 10.1.1.1
настройки роутера
IP адрес выданный провайдером 10.х.х.х
маска подсети 255.0.0.0
шлюз 10.1.1.1
Сеть за роутером состоит из двух компьютеров, при запущеном торренте сеть и интернет отваливаются.
Dir-100 при запущеном торренте работал нормально 320 работать нормально не хочет подскажите где копать?
СообщениеДобавлено: Вт мар 23, 2010 15:47
viewtopic.php?t=110340
СообщениеДобавлено: Вт мар 23, 2010 19:48
Читал я тот топик и поиском пользовался ответа на свой вопрос я так и не нашел.
Прошивка стоит последняя dir320_v1.21_97hb настройки до заводских сбрасывал не однократно, без запущенного торрента работает роутер нормально как только запускаю uTorrent как сразу начинает отваливаться сеть и интернет.
В сети IP адрес статический с привязкой по МАКадресу за роутером тоже статический IP адрес
СообщениеДобавлено: Вт мар 23, 2010 20:29
Попробуй отключить DHT в торрент-клиенте.
Ваш IP: Изображение
СообщениеДобавлено: Вт мар 23, 2010 21:31
Про бывал отключать DHT создавал правила для торрена в роутере не помогает.
СообщениеДобавлено: Ср мар 24, 2010 16:37
В торрент-клиенте помимо DHT нужно ограничивать число потоков до минимума.
СообщениеДобавлено: Пт мар 26, 2010 00:08
Ограничить до скольки? с этими настройками которые сейчас в торренте стоят у меня DIR-100 качал без проблем.
Здесь я так понял меня блокирует ДНС сервер сети на короткое время какбы подмена ИП адреса сетевого на интернетовский как мне сказал админ сети при общении.
СообщениеДобавлено: Пт мар 26, 2010 00:13
Локальный адрес у меня примерно такой 10.х.х.х почему в логах проскакивает локальный 193.107.80.129 если это ИП адрес интернета?
СообщениеДобавлено: Сб мар 27, 2010 18:44
Может кто нибудь сталкивался с такой проблемой?
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 43
