Текущее время: Ср сен 30, 2026 02:14
СообщениеДобавлено: Вт мар 09, 2010 13:12
Здравствуйте.
Имеем такую схемку
DGS-3612G <---> FreeBSD
На фряхе запущен quagga ospf
cat /usr/local/etc/quagga/ospfd.conf
! Zebra configuration saved from vty
!   2010/03/09 12:44:23
hostname ospfd
password password
interface em0
interface em1
interface lo0
interface ng0
interface pflog0
interface vlan1202
router ospf
 ospf router-id 172.21.202.2
 redistribute kernel
 redistribute connected
 network 172.21.202.0/24 area 172.21.202.0
 area 172.21.202.0 range 172.21.202.0/24
 default-information originate always metric 10
line vty
Состояние DGS-3612G
DGS-3612G:5#show ospf
Command: show ospf
OSPF Router ID : 172.21.202.1
State          : Enabled
OSPF Interface Settings
Interface    IP Address         Area ID         State    Link      Metric
                                                         Status
System       10.90.90.90/24     172.21.202.0         Disabled Link DOWN 1
if6          172.21.1.1/24      172.21.202.0         Disabled Link Up   1
if10         172.21.2.1/24      172.21.202.0         Disabled Link Up   1
#Тут поскипано куча интерфейсов
if101        172.21.3.1/24      172.21.202.0        Disabled Link DOWN 1
if102        172.21.5.1/24      172.21.202.0         Disabled Link DOWN 1
if5          172.21.201.1/24    172.21.202.0         Disabled Link Up   1
dmz          172.21.202.1/24    172.21.202.0    Enabled  Link Up   1
if4021       192.168.68.68/24   172.21.202.0         Disabled Link DOWN 1
if1003       192.168.77.1/24    172.21.202.0         Disabled Link DOWN 1
if4013       192.168.88.8/24    172.21.202.0        Disabled Link DOWN 1
if_test      192.168.99.1/24    172.21.202.0    Disabled Link Up   1
Total Entries : 90
OSPF Area Settings
Area ID         Type   Stub Import Summary LSA Stub Default Cost Translate
0.0.0.0         Normal None                    None              None
172.21.202.0    Normal None                    None              None
Total Entries : 2
Virtual Interface Configuration
Transit         Virtual         Hello    Dead     Authentication Link
Area ID         Neighbor Router Interval Interval                Status
Total Entries : 0
OSPF Area Aggregation Settings
Area ID         Aggregated         LSDB     Advertise
                Network Address    Type
Total Entries : 0
OSPF Host Route Settings
Host Address    Metric Area ID
Total Entries : 0
show ospf neighbor
Command: show ospf neighbor
IP Address of   Router ID of    Neighbor Neighbor
Neighbor        Neighbor        Priority State
172.21.202.2    172.21.202.2    1        Full
Total Entries : 1
Все друг-друга видят, но не передаются маршруты с 3612
С фряхи всё передается, и локальные и вручную прописанные
а с коммутатора ничего не идет
И только при команде
config ospf ipif if7 state enable
начинается передоваться маршрут с if7
Как можно распредилить маршруты со всех интерфейсов не включая на них ospf?
СообщениеДобавлено: Вт мар 09, 2010 13:30
Если не хотите включать ospf на клиентских портах то сделайте redistribute
create route redistribute dst ospf src local mettype 2 metric 2
D-Link User: DGS-3120-24, DGS-3324SR, DGS-3627G, DGS-3612G, DGS-3312SR, DGS-3100-24TG, DGS-3200-10, DES-3200-26, DES-3200-28, DES-3200-18, DES-3528, DES-3526, DES-3028, DES-1228, DES-2108, DES-2110, DES-3326SR, DMC-920, DMC-810.
СообщениеДобавлено: Вт мар 09, 2010 13:35
Спасибо, всё заработало
Ещё в продолжении темы
Если маршрут статический Inactive то он не проанонсируется?
А он станет активным когда будет виден мак гейта?
Command: show iproute static                                  p
Routing Table
IP Address/Netmask  Gateway          Cost   Protocol  Backup    Weight  Status
0.0.0.0/0           192.168.7.1      1      Default   Primary   None    Inactive
10.0.0.0/24         10.50.0.1      1      Static    Primary   None    Inactive
192.168.5.4/32      172.21.202.2     1      Static    Primary   None    Active
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 62
