Текущее время: Вт фев 17, 2026 05:02
 Заголовок сообщения: DES-7210 - CPU utilization: 100%
СообщениеДобавлено: Чт фев 25, 2010 16:59
Всем привет!
Есть DES-7210.
Все модули прошиты v10.3.00(3b12), Release(40793) .
Имеем вот такую картину:
DES-7210#sh cp
     CPU Using Rate Information
CPU utilization in five seconds: 100%
CPU utilization in one minute  : 100%
CPU utilization in five minutes: 100%
  NO   5Sec   1Min   5Min   Process
  0     0%     0%     0%    LISR INT
  1     0%     0%     0%    HISR INT
  2     0%     0%     0%    ktimer
113     0%     0%     0%    chkpnt_task
114     0%     0%     0%    lcdm_print
115    100%   100%   100%    rl_ssh_1
DES-7210#
все было бы понятно, но перед этим специально было сделано:
DES-7210(config)#no enable ser ssh
и за компанию
DES-7210(config)#no enable ser w
в логах - ничего подозрительного:
*Feb 25 2010 19:00:04: DES-7210 %PARAM-6-CONFIG_SYNC: The startup configuration has been successfully synchronized to the standby supervisor.
*Feb 25 2010 19:04:12: DES-7210 %SYS-5-CONFIG_I: Configured from console by valera on vty1(10.25.0.115)
*Feb 25 2010 19:04:12: DES-7210 %PARAM-6-CONFIG_SYNC: Sync'ing the startup configuration to the standby supervisor.
*Feb 25 2010 19:04:12: DES-7210 %PARAM-6-CONFIG_SYNC: The startup configuration has been successfully synchronized to the standby supervisor.
*Feb 25 2010 19:05:01: DES-7210 %SYS-5-CONFIG_I: Configured from console by valera on vty1(10.25.0.115)
*Feb 25 2010 19:05:01: DES-7210 %PARAM-6-CONFIG_SYNC: Sync'ing the startup configuration to the standby supervisor.
*Feb 25 2010 19:05:01: DES-7210 %PARAM-6-CONFIG_SYNC: The startup configuration has been successfully synchronized to the standby supervisor.
*Feb 25 2010 19:05:38: DES-7210 %SYS-5-CONFIG_I: Configured from console by alex on vty3(10.25.0.10)
*Feb 25 2010 19:05:38: DES-7210 %PARAM-6-CONFIG_SYNC: Sync'ing the startup configuration to the standby supervisor.
*Feb 25 2010 19:05:38: DES-7210 %PARAM-6-CONFIG_SYNC: The startup configuration has been successfully synchronized to the standby supervisor.
*Feb 25 2010 19:06:40: DES-7210 %SYS-5-CONFIG_I: Configured from console by valera on vty1(10.25.0.115)
*Feb 25 2010 19:06:40: DES-7210 %PARAM-6-CONFIG_SYNC: Sync'ing the startup configuration to the standby supervisor.
*Feb 25 2010 19:06:40: DES-7210 %PARAM-6-CONFIG_SYNC: The startup configuration has been successfully synchronized to the standby supervisor.
и т.д.
Короче, при чем тут ssh? Мы им не пользуемся.
P.S. А может это коварный uTP (торрентовский протокол) таким макаром проявляется? Просто его мы еще не успели хлопнуть
P.P.S. Еще одну штуку заметил - когда я первые N раз для верности вырубил сервис ssh, загрузка проца упала где-то до 60%, побыла такой может секунд 10-15 и опять вернулась к 100%.
не важно, из какого места растут золотые руки
СообщениеДобавлено: Чт фев 25, 2010 19:10
Нужно обновляться до последнего релиза. В 40793 версии были проблемы с Telnet/SSH
СообщениеДобавлено: Пт фев 26, 2010 06:38
Новую прошивку заказал.
Пока загрузка ЦПУ так и есть 100%
СообщениеДобавлено: Вс фев 28, 2010 22:33
Обновились?
СообщениеДобавлено: Пн мар 01, 2010 07:29
Нет, Иван, не обновились. Вопросы появились по обновлению.
Итак, имеем:
DES-7210#sh ver
System description      : DES-7210 Modular Layer 3 Chassis Ethernet Switch
System start time       : 2010-3-1 8:53:40
System uptime           : 0:0:36:12
System hardware version : A1.01
System software version : v10.3.00(3b12), Release(40793)
System boot version     : 10.3.40793
System CTRL version     : 10.3.40793
System serial number    : 1234942570002
Module information:
  Slot-1 : 7200-24G
    Hardware version : A1.0
    Software version : v10.3.00(3b12), Release(40793)
    BOOT version     : 10.3.40793
  Slot-7 : 7200-2XG
  Slot-8 : 7200-24G
  Slot-M1 : 7200-CM4
  Slot-M2 : 7200-CM4
DES-7210#
т.е. двухпроцессорный девайс.
Прошивку взял отсюда
Хочу уточнить, так ли процедура апгрейда будет выглядеть в моем случае. Внятной инструкции не нашел, только тут ftp://ftp.dlink.ru/pub/Switch/DES-7200%20Series/Firmware/v10.3_5/Release_Notes.txt описана процедура, но невнятно. Итак:
0. Логинюсь через TELNET
1. Загружаем прошивку на свич и убеждаемся, что все в порядке:
Switch#copy tftp://<tftp_server_ip>/V10.3(5)_R70398_CM3_4.bin flash:firmware.bin
Accessing tftp://<tftp_server_ip>/V10.3(5)_R70398_CM3_4.bin
Transmission finished, file length 18708320
THE PROGRAM VERSION: Firmware 10.3.*, Release(4862)
Download executable file [V10.3(5)_R70398_CM3_4.bin] to file system is OK.
Switch#ls
DES-7210#ls
    Mode Link      Size               MTime Name
   <DIR>    1         0 1970-01-01 06:00:00 dev/
   <DIR>    2         0 2008-07-17 11:38:29 mnt/
   <DIR>    1         0 2010-03-01 08:51:04 ram/
   <DIR>    2         0 2010-03-01 08:51:23 tmp/
   <DIR>    7         0 1970-01-01 06:00:00 proc/
            1      1408 2010-03-01 08:10:42 index_persist
            1   2870496 2008-07-08 16:02:42 install_lc_200e0020.bin
            1   4021152 2008-07-08 16:02:47 install_lc_200e0030.bin
            1   8630592 2010-03-01 08:41:35 Firmware_for_CMII.bin_.copy
            1   8630592 2008-07-08 16:02:40 Firmware_for_CMII.bin_
            1       424 2009-09-14 17:29:03 rsa_private.bin
            1  18708320 2010-03-01 08:42:13 firmware.bin             <-----вот прошивка (убедились)
            1   3445184 2008-07-08 16:02:50 install_lc_20070010.bin
            1   2873696 2008-07-08 16:02:44 install_lc_20070020.bin
            1       952 2010-03-01 08:49:41 bin_info.txt
            1     10843 2010-03-01 08:10:41 config.text
            1       424 2009-09-14 17:29:03 rsa1_private.bin
            1  18708320 2010-03-01 08:40:21 000.txt
13 Files (Total size 67902403 Bytes), 5 Directories.
Total 536346624 bytes (511MB) in this device, 452096000 bytes (431MB) available.
Switch#
2. Далее пишем команду
Switch#redundancy forceswitch
Proceed with switchover to standby PRE? [N/y]y
System bootstrap ...
И свич ребутится.
А вот дальше начались определенные непонятки. Прошу помочь.
3. Хватаем нотку и консольный шнурок и идем уже непосредственно к свичу. Втыкаюсь (в SLAVE-модуль?), вижу в терминале....
Nor Flash ID: 0x00010049, SIZE: 2097152Byte
Press Ctrl+B to enter Boot Menu ......
и давлю Ctrl+B
Из консоли выполняю команду
4. Ребучу свич (
reload
) - или как раз ребутиться не нужно?
5. Втыкаюсь в MASTER-модуль и опять из консоли выполняю команду
И что дальше? Я жду 4 минуты и появляется фраза
Installation process finished successfully ...
HAL-5-SYS_RESTART: System restarting, for reason 'Upgrade product !'.
? Или я какую команду синхронизации запускаю?
Короче, слишком много вопросов появилось, без ответа на которые БОЯЗНО производить действия над этим девайсом.
А может есть еще какая-то инструкция, где все просто и понятно описано?
P.S. Кстати, никакого файла firmware.bin у моего 7210 нет, есть только Firmware_for_CMII.bin_. Вот содержимое флешки свича:
DES-7210#ls /
   <DIR>    2         0 2008-07-17 11:46:30 mnt/
   <DIR>    1         0 2010-03-01 08:59:07 ram/
   <DIR>    2         0 2008-07-08 14:41:38 tmp/
            1   2870496 2008-07-08 14:47:29 install_lc_200e0020.bin
            1   4021152 2008-07-08 14:47:34 install_lc_200e0030.bin
            1   8630592 2008-07-08 14:47:27 Firmware_for_CMII.bin_
            1   3445184 2008-07-08 14:47:36 install_lc_20070010.bin
            1   2873696 2008-07-08 14:47:31 install_lc_20070020.bin
            1       952 2008-07-17 11:42:56 bin_info.txt
            1     10843 2010-03-01 08:14:17 config.text
7 Files (Total size 21852915 Bytes), 5 Directories.
Total 536346624 bytes (511MB) in this device, 501764096 bytes (478MB) available.
DES-7210#
Тогда в какой их этих двоих файлов копировать новый файл - в firmware.bin или в Firmware_for_CMII.bin_?
СообщениеДобавлено: Пн мар 01, 2010 09:03
только сейчас увидел - оказывается, загрузка процессора теперь вполне в норме:
DES-7210#sh cpu
CPU utilization in five seconds: 0%
CPU utilization in one minute  : 3%
CPU utilization in five minutes: 12%
  0     0%     0%     0%    LISR INT
  1     0%     0%     0%    HISR INT
  2     0%     0%     0%    ktimer
  3     0%     0%     0%    atimer
  4     0%     0%     0%    printk_task
  5     0%     0%     0%    waitqueue_process
  6     0%     0%     0%    tasklet_task
  7     0%     0%     0%    kevents
  8     0%     3%    12%    snmpd
  9     0%     0%     0%    snmp_trapd
111     0%     0%     0%    RDNDFCLT
112     0%     0%     0%    autoupgd
115     0%     0%     0%    rl_vty_1
116   100%    97%    88%    idle
DES-7210#
Никакого ssh в процессах не присутствует. может, сыграло то, что я сервис ssh остановил, да проребутил?
А загрузка snmpd - это я snmpwalk-ом прошелся по свичу.
Но апгрейдить софт по-любому придется
СообщениеДобавлено: Пн мар 01, 2010 11:18
ответил в почту
СообщениеДобавлено: Пн мар 01, 2010 11:54
Станислав, повторите пожалуйста по адресу, который в моем профиле.
Что-то я пока ничего не получил
СообщениеДобавлено: Ср мар 03, 2010 15:09
Обновился!
Теперь
DES-7210#sh ver
System start time       : 2010-03-03 17:15:22
System uptime           : 0:0:53:16
System software version : v10.3(5), Release(70398)
System BOOT version     : 10.3.70398
System CTRL version     : 10.3.70398
Module information:
  Slot-1 : 7200-24G
    Software version : v10.3(5), Release(70398)
  Slot-7 : 7200-2XG
  Slot-8 : 7200-24G
  Slot-M1 : 7200-CM4
  Slot-M2 : 7200-CM4
DES-7210#
СообщениеДобавлено: Ср мар 03, 2010 19:51
И!? Проблема осталась?
Бигаров Руслан.
СообщениеДобавлено: Чт мар 04, 2010 07:45
на время апгрейда пришлось его из сети выключить
мы его вернем в сеть в начале след недели, тогда результат станет виден.
а мне понравилось, что прошивку на него можно самой обычной флешкой доставлять (а то я уже прикидывал, сколько времени 18 мегов будет через zmodem качаться, пусть даже со скоростью 115 кбит/с)! сам ее увидел, сам примонтировал. КРАСОТА!
Одного не понял, как воспользоваться менеджмент-портом на процессорном модуле. Как и чем только не втыкался, линк не поднимается. Порт явно не выключен. Вообще, зачем он нужен? И как правильно им пользоваться?
СообщениеДобавлено: Чт мар 25, 2010 07:00
Приношу кучу пардонов за задержку в ответе!
Конечно свич уже в работе - через пару-тройку дней после предыдущего поста его вернули в сеть. Полет нормальный - загрузка проца 2-4%.
Сейчас разбираюсь с его мониторингом через SNMP.
Т.е. все замечательно работает.
СообщениеДобавлено: Пт мар 26, 2010 00:24
Рад слышать!
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 72
