Текущее время: Чт авг 20, 2026 13:15
 Заголовок сообщения: [DIR-655] SIP ALG Rejected
СообщениеДобавлено: Вс фев 07, 2010 13:02
Здраствуйте, к роутеру подключен
телефон Siemens C470IP соединен с 4мя провайдерами sip
Порт SIP 5060
Порт RTP 5004-5020
Cоединение PPPoE
прошивка 1.31b11
в логах по стоянные rejected
[INFO]   Sun Feb 07 12:58:37 2010   SIP ALG rejected packet from 174.129.234.254:5060 to 79.139.146.188:5060
[INFO]   Sun Feb 07 12:58:34 2010   UPnP renew entry 255.255.255.255 <-> 79.139.146.188:65168 <-> 192.168.0.6:65168 UDP timeout:0 'Teredo'
[INFO]   Sun Feb 07 12:58:33 2010   SIP ALG rejected packet from 192.168.0.15:5060 to 174.129.234.254:5060
[INFO]   Sun Feb 07 12:58:32 2010   SIP ALG rejected packet from 192.168.0.15:5060 to 77.72.174.128:5060
[INFO]   Sun Feb 07 12:58:32 2010   SIP ALG rejected packet from 174.129.234.254:5060 to 79.139.146.188:5060
[INFO]   Sun Feb 07 12:58:27 2010   Above message repeated 1 times
[INFO]   Sun Feb 07 12:58:24 2010   Blocked outgoing TCP packet from 192.168.0.5:1234 to 91.121.21.27:42631 with unexpected acknowledgement 3582705751 (expected 3582720137 to 3582851192)
[INFO]   Sun Feb 07 12:58:22 2010   SIP ALG rejected packet from 174.129.234.254:5060 to 79.139.146.188:5060
[INFO]   Sun Feb 07 12:58:17 2010   Above message repeated 1 times
[INFO]   Sun Feb 07 12:58:13 2010   SIP ALG rejected packet from 192.168.0.15:5060 to 174.129.234.254:5060
[INFO]   Sun Feb 07 12:58:12 2010   SIP ALG rejected packet from 192.168.0.15:5060 to 77.72.174.128:5060
[INFO]   Sun Feb 07 12:58:12 2010   SIP ALG rejected packet from 174.129.234.254:5060 to 79.139.146.188:5060
[INFO]   Sun Feb 07 12:58:07 2010   Above message repeated 1 times
[INFO]   Sun Feb 07 12:58:03 2010   Blocked incoming TCP packet from 109.126.48.238:61069 to 79.139.146.188:1234 as FIN:ACK received but there is no active connection
[INFO]   Sun Feb 07 12:58:02 2010   Blocked outgoing TCP packet from 192.168.0.5:1234 to 91.121.21.27:42631 with unexpected acknowledgement 3579893958 (expected 3579902584 to 3580033639)
[INFO]   Sun Feb 07 12:58:02 2010   SIP ALG rejected packet from 174.129.234.254:5060 to 79.139.146.188:5060
[INFO]   Sun Feb 07 12:57:59 2010   Blocked outgoing TCP packet from 192.168.0.5:1234 to 91.121.21.27:42631 with unexpected acknowledgement 3579575269 (expected 3579644824 to 3579775879)
[INFO]   Sun Feb 07 12:57:57 2010   SIP ALG rejected packet from 174.129.234.254:5060 to 79.139.146.188:5060
[INFO]   Sun Feb 07 12:57:54 2010   UPnP renew entry 255.255.255.255 <-> 79.139.146.188:65168 <-> 192.168.0.6:65168 UDP timeout:0 'Teredo'
[INFO]   Sun Feb 07 12:57:53 2010   SIP ALG rejected packet from 192.168.0.15:5060 to 174.129.234.254:5060
[INFO]   Sun Feb 07 12:57:52 2010   SIP ALG rejected packet from 192.168.0.15:5060 to 77.72.174.128:5060
[INFO]   Sun Feb 07 12:57:52 2010   SIP ALG rejected packet from 174.129.234.254:5060 to 79.139.146.188:5060
[INFO]   Sun Feb 07 12:57:51 2010   Blocked incoming TCP packet from 109.126.48.238:61069 to 79.139.146.188:1234 as FIN:ACK received but there is no active connection
[INFO]   Sun Feb 07 12:57:47 2010   SIP ALG rejected packet from 174.129.234.254:5060 to 79.139.146.188:5060
[INFO]   Sun Feb 07 12:57:44 2010   Blocked outgoing TCP packet from 192.168.0.5:1234 to 91.121.21.27:42631 with unexpected acknowledgement 3577670840 (expected 3577841154 to 3577972209)
[INFO]   Sun Feb 07 12:57:42 2010   SIP ALG rejected packet from 174.129.234.254:5060 to 79.139.146.188:5060
[INFO]   Sun Feb 07 12:57:37 2010   Above message repeated 1 times
[INFO]   Sun Feb 07 12:57:36 2010   Blocked outgoing TCP packet from 192.168.0.5:1234 to 91.121.21.27:42631 with unexpected acknowledgement 3577081796 (expected 3577103289 to 3577234344)
[INFO]   Sun Feb 07 12:57:33 2010   SIP ALG rejected packet from 192.168.0.15:5060 to 174.129.234.254:5060
[INFO]   Sun Feb 07 12:57:32 2010   SIP ALG rejected packet from 192.168.0.15:5060 to 77.72.174.128:5060
[INFO]   Sun Feb 07 12:57:32 2010   SIP ALG rejected packet from 174.129.234.254:5060 to 79.139.146.188:5060
[INFO]   Sun Feb 07 12:57:17 2010   Above message repeated 3 times
[INFO]   Sun Feb 07 12:57:15 2010   UPnP renew entry 255.255.255.255 <-> 79.139.146.188:65168 <-> 192.168.0.6:65168 UDP timeout:0 'Teredo'
[INFO]   Sun Feb 07 12:56:58 2010   SIP ALG rejected packet from 192.168.0.15:5060 to 174.129.234.254:5060
[INFO]   Sun Feb 07 12:56:57 2010   SIP ALG rejected packet from 192.168.0.15:5060 to 77.72.174.128:5060
Как настроить чтобы sip alg работал
Последний раз редактировалось romuz Пн фев 08, 2010 12:53, всего редактировалось 1 раз.
СообщениеДобавлено: Вс фев 07, 2010 14:40
Advanced - Firewall Settings
внизу поставить галку SIP
DIR-655 и DWA-556
Мысли, написанные с грамматическими ошибками, невозможно воспринимать как умные 8)
СообщениеДобавлено: Вс фев 07, 2010 14:56
галка естественно установлена, иначе такие ошибки и быть не моглибы
СообщениеДобавлено: Чт фев 11, 2010 13:19
дополнительная инфа по результатам наблюдений.
После перезагрузки роутера подобных сообщений в логе нет и SIP ALG видимо работает правильно
Через неколько часов работы в лог непрерыно попадают сообщения как первом посте, а в таблицесоодинений появляется запись которой нет в настройках роутера (проброс портов итд ) отмеченная на картинке.
Подозреваю что изза нее и наблюдается проблема
PS Upnp отключен
[INFO]   Thu Feb 11 13:20:11 2010   SIP ALG rejected packet from 174.129.234.254:5060 to 79.139.146.167:5060
[INFO]   Thu Feb 11 13:20:11 2010   Allowed configuration authentication by IP address 192.168.0.5
[INFO]   Thu Feb 11 13:20:06 2010   SIP ALG rejected packet from 174.129.234.254:5060 to 79.139.146.167:5060
[INFO]   Thu Feb 11 13:20:05 2010   Blocked outgoing TCP packet from 192.168.0.5:20233 to 85.15.80.92:53833 with unexpected sequence 3101245512 (expected 1951649041 to 1951781395)
[INFO]   Thu Feb 11 13:20:01 2010   SIP ALG rejected packet from 174.129.234.254:5060 to 79.139.146.167:5060
[INFO]   Thu Feb 11 13:20:01 2010   SIP ALG rejected packet from 192.168.0.15:5060 to 174.129.234.254:5060
[WARN]   Thu Feb 11 13:20:01 2010   Failed configuration authentication attempt by IP address 192.168.0.5
[INFO]   Thu Feb 11 13:19:58 2010   Blocked outgoing TCP packet from 192.168.0.5:20233 to 85.15.80.92:53833 with unexpected sequence 3101245512 (expected 1951649041 to 1951781395)
[INFO]   Thu Feb 11 13:19:56 2010   SIP ALG rejected packet from 174.129.234.254:5060 to 79.139.146.167:5060
[INFO]   Thu Feb 11 13:19:56 2010   Blocked outgoing TCP packet from 192.168.0.5:20233 to 85.15.80.92:53833 with unexpected sequence 3101245512 (expected 1951649041 to 1951781395)
[INFO]   Thu Feb 11 13:19:51 2010   SIP ALG rejected packet from 174.129.234.254:5060 to 79.139.146.167:5060
[INFO]   Thu Feb 11 13:19:46 2010   Above message repeated 1 times
[INFO]   Thu Feb 11 13:19:41 2010   SIP ALG rejected packet from 192.168.0.15:5060 to 174.129.234.254:5060
[INFO]   Thu Feb 11 13:19:41 2010   SIP ALG rejected packet from 174.129.234.254:5060 to 79.139.146.167:5060
[INFO]   Thu Feb 11 13:19:26 2010   Above message repeated 3 times
[INFO]   Thu Feb 11 13:19:21 2010   SIP ALG rejected packet from 192.168.0.15:5060 to 174.129.234.254:5060
[INFO]   Thu Feb 11 13:19:21 2010   SIP ALG rejected packet from 174.129.234.254:5060 to 79.139.146.167:5060
[INFO]   Thu Feb 11 13:19:06 2010   Above message repeated 3 times
[INFO]   Thu Feb 11 13:18:46 2010   SIP ALG rejected packet from 192.168.0.15:5060 to 174.129.234.254:5060
[INFO]   Thu Feb 11 13:18:26 2010   Above message repeated 1 times
СообщениеДобавлено: Чт фев 11, 2010 18:49
У меня тоже самое в логах.
SIP ALG rejected packet from 70.42.62.159:5062 to 91.21.97.14:8222
SIP ALG rejected packet from 192.168.0.7:8222 to 70.42.62.159:5062
Тоже хотелось бы знать, почему такое происходит.
СообщениеДобавлено: Пт фев 12, 2010 11:40
Я создал правила в QoS Engine Rules для IP, с которого идут звонки через SIPNet , в логах пропали такие же строки. Сделал для теста несколько звонков, ничего в логах не появилось. До настройки этих правил было тоже самое.
СообщениеДобавлено: Вт фев 16, 2010 09:27
Мне ваш вариант не помог, через какоето время снова посыпались reject
Может поддержка что-нибудь посоветует???
СообщениеДобавлено: Чт фев 18, 2010 09:20
Все также спамит лог, никаких пробросов портов на сип-устройство и прочего в роутере не настроено,UPNP отключено однако в списке сессий появляется проброс и после этого постоянные ошибки в логе...
У поддержки идеи есть?
[INFO] Thu Feb 18 09:11:08 2010 SIP ALG rejected packet from 192.168.0.15:5060 to 174.129.236.7:5060
[INFO] Thu Feb 18 09:10:49 2010 Blocked incoming TCP packet from 95.25.30.191:60732 to 79.139.146.214:2946 as RST:ACK received but there is no active connection
[INFO] Thu Feb 18 09:10:49 2010 SIP ALG rejected packet from 192.168.0.15:5060 to 174.129.236.7:5060
[INFO] Thu Feb 18 09:10:43 2010 Blocked incoming TCP packet from 95.25.30.191:60732 to 79.139.146.214:2946 as SYN:ACK received but there is no active connection
[INFO] Thu Feb 18 09:10:40 2010 Blocked incoming TCP packet from 95.25.30.191:60732 to 79.139.146.214:2946 as RST:ACK received but there is no active connection
[INFO] Thu Feb 18 09:10:29 2010 SIP ALG rejected packet from 192.168.0.15:5060 to 174.129.236.7:5060
[INFO] Thu Feb 18 09:10:09 2010 Above message repeated 1 times
[INFO] Thu Feb 18 09:09:58 2010 Blocked incoming ICMP error message (ICMP type 3) from 109.254.20.7 to 79.139.146.214 as there is no UDP session active between 79.139.146.214:21234 and 192.168.1.2:35887
[INFO] Thu Feb 18 09:09:49 2010 SIP ALG rejected packet from 192.168.0.15:5060 to 174.129.236.7:5060
[INFO] Thu Feb 18 09:09:47 2010 Blocked incoming ICMP error message (ICMP type 3) from 109.254.20.7 to 79.139.146.214 as there is no UDP session active between 79.139.146.214:21234 and 192.168.1.2:35887
[INFO] Thu Feb 18 09:09:42 2010 Blocked incoming ICMP error message (ICMP type 3) from 89.110.55.119 to 79.139.146.214 as there is no UDP session active between 79.139.146.214:21234 and 192.168.111.20:22345
[INFO] Thu Feb 18 09:09:32 2010 Above message repeated 3 times
[INFO] Thu Feb 18 09:09:29 2010 SIP ALG rejected packet from 192.168.0.15:5060 to 174.129.236.7:5060
[INFO] Thu Feb 18 09:09:20 2010 Allowed configuration authentication by IP address 192.168.0.5
[INFO] Thu Feb 18 09:09:09 2010 SIP ALG rejected packet from 192.168.0.15:5060 to 174.129.236.7:5060
СообщениеДобавлено: Чт фев 18, 2010 11:19
А если отключить SIP настройках ALG ? Может в нем проблема? И проверить заработает ли связь. При этом проброс портов оставить и правила в QoS тоже. Выдержка из хелпа:"... If you are having trouble making VoIP calls, try turning this ALG off."
