Текущее время: Сб июн 13, 2026 20:02
Начать новую тему Ответить на тему  [ Сообщений: 3714 ]  На страницу Пред.  1 ... 17, 18, 19, 20, 21, 22, 23 ... 248  След.
СообщениеДобавлено: Сб янв 30, 2010 09:55
Поддерживаю вопрос Driver64
ДИР-300 НРУ В1, прошивка рекомендованная Д-Линк. При резервировании ай пи по МАКу (для ноута, кот. цепляется к ДИРу по Вай Фай) в логах роутера такая картина: (снизу вверх)
"Jan 29 20:15:49 ","DHCP: Server sending NAK to 00:19:7d:87:79:10."
"Jan 29 20:15:49 ","DHCP: Server sending ACK to 192.168.0.110. (Lease time = -1)"
"Jan 29 20:15:49 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Jan 29 20:15:49 ","DHCP: Server sending OFFER of 192.168.0.110 for static DHCP client."
"Jan 29 20:15:49 ","DHCP: Server receive DISCOVER from 00:19:7d:87:79:10."
"Jan 29 20:15:05 ","DHCP: Server sending NAK to 00:19:7d:87:79:10."
"Jan 29 20:15:05 ","DHCP: Server sending ACK to 192.168.0.110. (Lease time = -1)"
"Jan 29 20:15:05 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Jan 29 20:15:05 ","DHCP: Server sending OFFER of 192.168.0.110 for static DHCP client."
"Jan 29 20:15:05 ","DHCP: Server receive DISCOVER from 00:19:7d:87:79:10."
"Jan 29 20:15:04 ","DHCP: Server sending NAK to 00:19:7d:87:79:10."
"Jan 29 20:15:04 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Jan 29 20:15:01 ","DHCP: Server sending NAK to 00:19:7d:87:79:10."
"Jan 29 20:15:01 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Jan 29 19:54:16 ","DHCP: Server sending NAK to 00:19:7d:87:79:10."
"Jan 29 19:54:16 ","DHCP: Server sending ACK to 192.168.0.110. (Lease time = -1)"
"Jan 29 19:54:16 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Jan 29 19:54:16 ","DHCP: Server sending OFFER of 192.168.0.110 for static DHCP client."
"Jan 29 19:54:16 ","DHCP: Server receive DISCOVER from 00:19:7d:87:79:10."
"Jan 29 19:54:15 ","DHCP: Server sending NAK to 00:19:7d:87:79:10."
"Jan 29 19:54:15 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Jan 29 19:00:43 ","DHCP: Server sending NAK to 00:19:7d:87:79:10."
"Jan 29 19:00:43 ","DHCP: Server sending ACK to 192.168.0.110. (Lease time = -1)"
"Jan 29 19:00:43 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Jan 29 19:00:43 ","DHCP: Server sending OFFER of 192.168.0.110 for static DHCP client."
"Jan 29 19:00:43 ","DHCP: Server receive DISCOVER from 00:19:7d:87:79:10."
"Jan 29 19:00:42 ","DHCP: Server sending NAK to 00:19:7d:87:79:10."
"Jan 29 19:00:42 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Jan 29 12:56:03 ","DHCP: Server sending ACK to 192.168.0.110. (Lease time = -1)"
"Jan 29 12:56:03 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Jan 29 12:28:47 ","DHCP: Server sending NAK to 00:19:7d:87:79:10."
"Jan 29 12:28:47 ","DHCP: Server sending ACK to 192.168.0.110. (Lease time = -1)"
"Jan 29 12:28:47 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Jan 29 12:28:47 ","DHCP: Server sending OFFER of 192.168.0.110 for static DHCP client."
"Jan 29 12:28:47 ","DHCP: Server receive DISCOVER from 00:19:7d:87:79:10."
"Jan 29 12:27:49 ","DHCP: Server sending NAK to 00:19:7d:87:79:10."
"Jan 29 12:27:49 ","DHCP: Server sending ACK to 192.168.0.110. (Lease time = -1)"
"Jan 29 12:27:49 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Jan 29 12:27:49 ","DHCP: Server sending OFFER of 192.168.0.110 for static DHCP client."
"Jan 29 12:27:49 ","DHCP: Server receive DISCOVER from 00:19:7d:87:79:10."
"Jan 29 12:27:48 ","DHCP: Server sending NAK to 00:19:7d:87:79:10."
"Jan 29 12:27:48 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
Отчего так?
СообщениеДобавлено: Сб янв 30, 2010 13:28
Есть ли в DIR-300N возможность настройки мощности излучения?
СообщениеДобавлено: Сб янв 30, 2010 14:06
да, есть.
расширенные настройки - расш.настр.беспроводной сети.- Мощность передатчика
работает или нет - не проверял.
по DHCP - в логах у меня подобное есть, но пользователи не жалуются на какие-либо проблемы, адрес вроде выдаётся каждый раз нормально...
(интерфейс русс, прошив - последняя).
полный кусок лога при разовой работе DHCP с одним клиентом:
Jan 30 12:58:10 DHCP: Server sending NAK to 00:18:de:78:b8:da.
Jan 30 12:58:10 DHCP: Server sending ACK to 192.168.5.101. (Lease time = -1)
Jan 30 12:58:10 DHCP: Server receive REQUEST from 00:18:de:78:b8:da.
Jan 30 12:58:09 DHCP: Server sending OFFER of 192.168.5.101 for static DHCP client.
Jan 30 12:58:09 DHCP: Server receive DISCOVER from 00:18:de:78:b8:da.
Jan 30 12:58:07 DHCP: Server sending NAK to 00:18:de:78:b8:da.
Jan 30 12:58:07 DHCP: Server receive REQUEST from 00:18:de:78:b8:da.
хз нормально это или нет))
Driver64
, м.б. сделана резервация по мак, но сам DHCP выключен?
и нет ли проблем со службой dhcp-клиент на ПК?
СообщениеДобавлено: Сб янв 30, 2010 19:21
Driver64, м.б. сделана резервация по мак, но сам DHCP выключен?
Всё включено, проблема решилась отключением NetworkManager и включением традиционного метода ifup. Пока вроде всё работает. Но родительский контроль так и не работает, если разрешаешь доступ к определённым сайтам, то блокируются все, а если запрещаешь доступ к определённым сайтам, то совсем ничего не блокируется.
СообщениеДобавлено: Вс янв 31, 2010 00:18
Такая проблемка, у меня городская локалка и инет ,так вот сайты внитрисетевые в том числе и страничка провайдера видятся только в том случае ,если в свойствах сетевого подключения на компьютере прописать вручную DNS-сервер , а не получать его автоматически как рекомендуется в настройках роутера, и еще роутер не пускает на внутрисетевой сервак игры COD 4 , на серваки через инет заходит без проблем,без роутера естественно все работает, помогите советом плиз!!!! Скрины настроек прилагаю.
 Заголовок сообщения: Re: DIR-300/NRU
СообщениеДобавлено: Вс янв 31, 2010 14:59
Коллеги, не пинайте ногами, но я прочитал всю тему и так и не увидел ответа на вот этот вопрос:
sh@man писал(а):
...В софте полная преемственность с DIR-300..? :)
т.е. можно ли на DIR-300 залить прошивку от DIR-300 NRU?
СообщениеДобавлено: Вс янв 31, 2010 15:02
Доброго времени суток.
с горем пополам настроил это роутер (dir-300)...работает от шнурка на комп и на нетбук samsung n310...работает инет без проблем и одновременно и по отдельности от шнурка...а вот wi fi (ту ды его в качель) нет...ну не видит сети нетбук...пишет что их нет...при чем на роуте и значок wi fi моргает и в статусе пишет что фурычит...
как быть???????? я купил этот е@#чий роутер ради wi fi ...
пы сы нетбук проверен во множестве wi fi сетей - все ок
СообщениеДобавлено: Вс янв 31, 2010 15:07
Peka пишет:
На нетбуке не пробывал, а смартфон нормально сеть подхватывает, и логи говорят, что сеть видна и к ней пытаются подключиться.
Какая прошивка? Не стоит ли галочка в настройках беспроводной сети: Включить Hidden Wireless, если стоит, то её надо снять, что сделает сеть видимой.
СообщениеДобавлено: Вс янв 31, 2010 15:29
Driver64 писал(а):
Peka пишет:
у меня русский интерфейс...если речь идет о "Включить Hidden Wireless : (Другое название - SSID Broadcast)"
то тут галки нет и не было...
СообщениеДобавлено: Вс янв 31, 2010 15:58
2 Peka:
Ещё можно попробывать обновить драйвер на Вай Фай карточку в нетбуке.
СообщениеДобавлено: Вс янв 31, 2010 19:18
Собираюсь его брать, интересует, совместимость с виндой семёркой,со старой и последней обновлённой прошивками?
СообщениеДобавлено: Вс янв 31, 2010 19:19
работает на ура ноут MSI
DIR-300 DIR-100(VLAN) DVG-2101S DNS-323
СообщениеДобавлено: Вс янв 31, 2010 19:22
Vista compatible, так что не думаю, что с 7-кой будут проблемы.
СообщениеДобавлено: Вс янв 31, 2010 19:26
Просто какой то чел мне сказал что проблема именно с последней обновлённой прошивкой при использовании седьмой винде... Значит всё окей?
СообщениеДобавлено: Вс янв 31, 2010 20:31
все окей
