Текущее время: Пт сен 11, 2026 06:21
СообщениеДобавлено: Ср янв 27, 2010 18:43
Вчера купил DIR 655, поменял прошивку на DIR655Ax_FW131RUB11, поставил дефолтные настройки и настроил Dual access L2TP (Провайдер корбина)
В процессе настройки роутер пару раз отваливался и зависал, пару раз пришлось сделать ресет.
К роутеру через вайфай 11n подключены 2 компа.
Сейчас роутер каждые пару часов подвисает, а в логах творится вот что:
[INFO] Sat Jan 31 21:57:00 2004 Blocked incoming TCP connection request from 193.22.84.18:50700 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:59 2004 Blocked incoming TCP connection request from 84.228.105.242:64713 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:58 2004 UPnP renew entry 255.255.255.255 <-> 95.25.188.150:61034 <-> 192.168.0.199:61034 UDP timeout:0 'Teredo'
[INFO] Sat Jan 31 21:56:58 2004 Blocked incoming UDP packet from 84.50.163.172:34081 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:58 2004 Blocked incoming UDP packet from 78.231.100.215:50490 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:58 2004 Blocked incoming TCP connection request from 89.112.68.56:54820 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:58 2004 Blocked incoming TCP connection request from 95.54.129.192:19309 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:58 2004 Blocked incoming TCP connection request from 89.112.68.56:55078 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:57 2004 Blocked incoming TCP connection request from 61.246.38.186:4543 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:57 2004 Allowed configuration authentication by IP address 192.168.0.199
[INFO] Sat Jan 31 21:56:57 2004 Blocked incoming UDP packet from 94.223.196.140:6924 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:57 2004 Blocked incoming TCP connection request from 92.124.8.164:49110 to 95.25.188.150:23456
[INFO] Sat Jan 31 21:56:56 2004 Blocked incoming TCP connection request from 84.228.105.242:64713 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:56 2004 Blocked incoming TCP connection request from 95.71.135.64:54007 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:55 2004 Blocked incoming TCP connection request from 95.69.136.31:63795 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:55 2004 Blocked incoming TCP connection request from 89.112.68.56:55078 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:55 2004 Blocked incoming TCP connection request from 89.112.68.56:54820 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:55 2004 Blocked incoming TCP connection request from 95.54.129.192:19309 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:54 2004 Blocked incoming TCP connection request from 61.246.38.186:4543 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:54 2004 Blocked incoming TCP connection request from 193.22.84.18:50700 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:53 2004 Blocked incoming TCP connection request from 95.71.135.64:54007 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:52 2004 Blocked incoming TCP connection request from 95.134.241.241:53322 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:50 2004 Blocked incoming TCP connection request from 193.22.84.18:50700 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:49 2004 Blocked incoming TCP connection request from 95.69.136.31:63795 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:46 2004 Blocked incoming TCP connection request from 95.134.241.241:53322 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:46 2004 Blocked incoming TCP connection request from 95.69.136.31:63795 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:45 2004 Blocked incoming UDP packet from 81.157.59.233:56646 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:45 2004 Blocked incoming UDP packet from 209.226.186.17:52256 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:45 2004 Blocked incoming TCP connection request from 92.124.8.164:49110 to 95.25.188.150:23456
[INFO] Sat Jan 31 21:56:45 2004 Blocked incoming TCP connection request from 95.84.141.68:1960 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:44 2004 Blocked incoming TCP connection request from 89.179.14.180:4845 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:43 2004 Blocked incoming TCP connection request from 95.134.241.241:53322 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:43 2004 Blocked incoming UDP packet from 83.31.138.254:25118 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:42 2004 Blocked incoming UDP packet from 109.196.77.197:59402 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:40 2004 Blocked incoming TCP connection request from 62.176.15.18:3086 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:39 2004 Blocked incoming UDP packet from 89.2.68.29:8346 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:39 2004 Blocked incoming TCP connection request from 92.124.8.164:49110 to 95.25.188.150:23456
[INFO] Sat Jan 31 21:56:39 2004 Blocked incoming TCP connection request from 95.84.141.68:1960 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:38 2004 Blocked incoming TCP connection request from 89.179.14.180:4845 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:37 2004 Blocked incoming TCP connection request from 79.39.217.37:55164 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:36 2004 Blocked incoming TCP connection request from 91.12.42.116:62358 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:36 2004 Blocked incoming TCP connection request from 95.84.141.68:1960 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:36 2004 Blocked incoming TCP connection request from 92.124.8.164:49110 to 95.25.188.150:23456
[INFO] Sat Jan 31 21:56:35 2004 Blocked incoming TCP connection request from 178.93.133.252:35710 to 95.25.188.150:61253
[INFO] Sat Jan 31 21:56:35 2004 Blocked incoming TCP connection request from 89.179.14.180:4845 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:34 2004 Blocked incoming TCP connection request from 64.184.226.121:25582 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:34 2004 Blocked incoming TCP connection request from 62.176.15.18:3086 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:32 2004 Blocked incoming TCP connection request from 83.237.242.203:60186 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:32 2004 Blocked incoming TCP connection request from 62.176.15.18:3086 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:31 2004 Blocked incoming UDP packet from 195.58.243.77:40788 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:31 2004 Blocked incoming UDP packet from 186.14.97.120:7260 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:31 2004 Blocked incoming TCP connection request from 79.39.217.37:55164 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:30 2004 Blocked incoming UDP packet from 89.105.151.82:1025 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:30 2004 Blocked incoming TCP connection request from 91.12.42.116:62358 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:29 2004 Blocked incoming TCP connection request from 94.232.76.68:4600 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:29 2004 Blocked incoming TCP connection request from 178.49.252.119:24782 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:29 2004 Blocked incoming TCP connection request from 64.184.226.121:25582 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:28 2004 Blocked incoming TCP connection request from 79.39.217.37:55164 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:27 2004 Blocked incoming TCP connection request from 91.12.42.116:62358 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:26 2004 Blocked incoming TCP connection request from 95.25.95.203:46957 to 95.25.188.150:445
[INFO] Sat Jan 31 21:56:26 2004 Blocked incoming TCP connection request from 83.237.242.203:60186 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:26 2004 Blocked incoming TCP connection request from 64.184.226.121:25582 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:24 2004 Blocked incoming UDP packet from 109.105.163.149:21837 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:23 2004 Blocked incoming TCP connection request from 94.232.76.68:4600 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:23 2004 Blocked incoming TCP connection request from 178.49.252.119:24782 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:22 2004 Blocked incoming packet from 95.27.94.35 to 95.25.188.150 (IP protocol 41)
[INFO] Sat Jan 31 21:56:22 2004 Blocked incoming UDP packet from 77.108.211.78:20066 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:21 2004 UPnP renew entry 255.255.255.255 <-> 95.25.188.150:61034 <-> 192.168.0.199:61034 UDP timeout:0 'Teredo'
[INFO] Sat Jan 31 21:56:20 2004 Blocked incoming TCP connection request from 94.232.76.68:4600 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:20 2004 Blocked incoming TCP connection request from 178.49.252.119:24782 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:20 2004 Blocked incoming TCP connection request from 80.70.22.122:3867 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:19 2004 Blocked incoming UDP packet from 84.228.105.242:49450 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:19 2004 Blocked incoming packet from 95.27.94.35 to 95.25.188.150 (IP protocol 41)
[INFO] Sat Jan 31 21:56:17 2004 Blocked incoming UDP packet from 79.39.217.37:45682 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:16 2004 Blocked incoming UDP packet from 77.108.211.78:20066 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:14 2004 Blocked incoming TCP connection request from 80.70.22.122:3867 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:13 2004 Blocked incoming UDP packet from 77.108.211.78:20066 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:12 2004 Blocked incoming UDP packet from 81.214.166.52:38989 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:11 2004 Blocked incoming TCP connection request from 178.93.133.252:35710 to 95.25.188.150:61253
[INFO] Sat Jan 31 21:56:11 2004 Blocked incoming UDP packet from 79.39.217.37:45682 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:11 2004 Blocked incoming UDP packet from 77.108.211.78:20066 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:11 2004 Above message repeated 1 times
[INFO] Sat Jan 31 21:56:11 2004 Blocked incoming UDP packet from 94.68.66.39:34204 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:11 2004 Blocked incoming TCP connection request from 80.70.22.122:3867 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:10 2004 Blocked incoming packet from 213.199.162.208 to 95.25.188.150 (IP protocol 41)
[INFO] Sat Jan 31 21:56:09 2004 Blocked incoming UDP packet from 74.115.0.24:27466 to 95.25.188.150:11336
[INFO] Sat Jan 31 21:56:09 2004 Blocked incoming UDP packet from 93.157.47.1:62565 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:08 2004 Blocked incoming UDP packet from 79.39.217.37:45682 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:08 2004 Blocked incoming packet from 213.199.162.206 to 95.25.188.150 (IP protocol 41)
[INFO] Sat Jan 31 21:56:08 2004 Blocked incoming TCP connection request from 88.84.200.157:2827 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:08 2004 Blocked incoming UDP packet from 79.120.120.13:21836 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:07 2004 Blocked incoming UDP packet from 79.39.217.37:45682 to 95.25.188.150:33738
[INFO] Sat Jan 31 21:56:07 2004 Above message repeated 1 times
[INFO] Sat Jan 31 21:56:06 2004 Blocked incoming packet from 213.199.162.208 to 95.25.188.150 (IP protocol 41)
Фаервол корбины отключен, настройки фаервола роутера не трогал.
Думаю что из-за того что роутеру приходится блочить кучу входящих запросов, он и подвисает.... Как с этим бороться? где-то читал что может помочь прямой айпишник...
СообщениеДобавлено: Чт янв 28, 2010 16:38
Up, тут техподдержка вообще есть?)
СообщениеДобавлено: Пт янв 29, 2010 17:38
клево... :(
СообщениеДобавлено: Вт фев 09, 2010 17:12
у тебя походу такая же проблема как и у меня
viewtopic.php?t=117918&highlight=DIR-655
тут дело не в блокированных пакетов.
просто как я вижу ты включил торрент.
а потом роутер завис.
тоже самое и у меня.
удалось как-то решить ?
я пока никак не решил :( повезу в сервис
СообщениеДобавлено: Вт фев 09, 2010 17:15
viewtopic.php?t=105074&highlight=DIR-655
вот тут тоже люди с похожими проблемами
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 73
