Текущее время: Вс апр 12, 2026 02:34
СообщениеДобавлено: Пт дек 04, 2009 04:21
Есть такая проблема. После того, как теряется соединение с ppp сервером, DSL-2500U/BRU/D восстанавливает связь, но не добавляет маршрут по умолчанию.
Лог
Dec  1 22:43:07 gw  -- MARK --
Dec  1 23:43:08 gw  -- MARK --
Dec  2 00:43:08 gw  -- MARK --
Dec  2 00:58:36 gw  pppd[248]: LCP terminated by peer
Dec  2 00:58:37 gw  pppd[248]: Connect time 5217170.5 minutes.
Dec  2 00:58:37 gw  pppd[248]: Sent 3998177832 bytes, received 3407423930 bytes.
Dec  2 00:58:38 gw  pppd[248]: Couldn't increase MRU to 1500
Dec  2 00:58:42 gw  pppd[248]: Connection terminated....
Dec  2 00:58:48 gw  pppd[248]: Sent PADT
Dec  2 00:58:48 gw  pppd[248]: PPP session is 43851
Dec  2 00:58:49 gw  pppd[248]: Using interface ppp0_1_32_1
Dec  2 00:58:49 gw  pppd[248]: Connect: ppp_0_1_32_1 <--> nas_0_1_32
Dec  2 00:58:49 gw  pppd[248]: Couldn't increase MRU to 1500
Dec  2 00:58:50 gw  pppd[248]: PAP authentication succeeded
Dec  2 00:58:50 gw  pppd[248]: peer from calling number 00:24:14:A1:D7:78 authorized
Dec  2 00:58:51 gw  pppd[248]: local  IP address 10.228.109.53
Dec  2 00:58:51 gw  pppd[248]: remote IP address 10.16.254.20
Dec  2 00:58:51 gw  pppd[248]: primary   DNS address 89.232.109.74
Dec  2 00:58:51 gw  pppd[248]: secondary DNS address 78.138.135.10
Dec  2 00:58:54 gw  syslog: dns query failed
Dec  2 00:58:59 XXX syslog: last message repeated 2 times
Dec  2 00:59:00 gw  syslog: dns query failed
Dec  2 00:59:05 XXX syslog: last message repeated 2 times
Dec  2 00:59:39 gw  syslog: dns query failed
Dec  2 00:59:43 XXX syslog: last message repeated 2 times
Dec  2 00:59:45 gw  syslog: dns query failed
Dec  2 00:59:49 XXX syslog: last message repeated 2 times
и т.д.
Лог, с pppd, переведённым в режим дебага
Dec  3 06:54:46 gw  -- MARK --
Dec  3 07:54:46 gw  -- MARK --
Dec  3 08:54:46 gw  -- MARK --
Dec  3 08:55:13 gw  pppd[248]: rcvd [LCP TermReq id=0x2]
Dec  3 08:55:13 gw  pppd[248]: LCP terminated by peer
Dec  3 08:55:14 gw  pppd[248]: Connect time 5219101.9 minutes.
Dec  3 08:55:14 gw  pppd[248]: Sent 223497803 bytes, received 785408663 bytes.
Dec  3 08:55:15 gw  pppd[248]: Script /etc/ppp/ip-down started (pid 937)
Dec  3 08:55:15 gw  pppd[248]: Couldn't increase MRU to 1500
Dec  3 08:55:15 gw  pppd[248]: sent [LCP TermAck id=0x2]
Dec  3 08:55:15 gw  pppd[248]: rcvd [LCP TermReq id=0x3]
Dec  3 08:55:15 gw  pppd[248]: sent [LCP TermAck id=0x3]
Dec  3 08:55:19 gw  pppd[248]: Connection terminated....
Dec  3 08:55:23 gw  pppd[248]: Script /etc/ppp/ip-down finished (pid 937), status = 0x0
Dec  3 08:55:24 gw  pppd[248]: Sent PADT
Dec  3 08:55:24 gw  pppd[248]: PADS: Service-Name: ''
Dec  3 08:55:24 gw  pppd[248]: PPP session is 51362
Dec  3 08:55:25 gw  pppd[248]: using channel 2
Dec  3 08:55:25 gw  pppd[248]: Using interface ppp0_1_32_1
Dec  3 08:55:25 gw  pppd[248]: Connect: ppp_0_1_32_1 <--> nas_0_1_32
Dec  3 08:55:25 gw  pppd[248]: Couldn't increase MRU to 1500
Dec  3 08:55:25 gw  pppd[248]: sent [LCP ConfReq id=0x2 <magic 0x8a8bf4ef>]
Dec  3 08:55:25 gw  pppd[248]: rcvd [LCP ConfReq id=0x1 <mru 1492> <auth pap> <magic 0xe1f379f8>]
Dec  3 08:55:25 gw  pppd[248]: sent [LCP ConfAck id=0x1 <mru 1492> <auth pap> <magic 0xe1f379f8>]
Dec  3 08:55:25 gw  pppd[248]: rcvd [LCP ConfAck id=0x2 <magic 0x8a8bf4ef>]
Dec  3 08:55:25 gw  pppd[248]: sent [LCP EchoReq id=0x0 magic=0x8a8bf4ef]
Dec  3 08:55:25 gw  pppd[248]: sent [PAP AuthReq id=0x2 user="M092028" password=<hidden>]
Dec  3 08:55:25 gw  pppd[248]: rcvd [LCP EchoRep id=0x0 magic=0xe1f379f8]
Dec  3 08:55:25 gw  pppd[248]: rcvd [PAP AuthAck id=0x2 ""]
Dec  3 08:55:25 gw  pppd[248]: PAP authentication succeeded
Dec  3 08:55:25 gw  pppd[248]: peer from calling number 00:24:14:A1:D7:78 authorized
Dec  3 08:55:25 gw  pppd[248]: sent [IPCP ConfReq id=0x3 <addr 10.228.109.53> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
Dec  3 08:55:25 gw  pppd[248]: rcvd [IPCP ConfReq id=0x1 <addr 10.16.254.20>]
Dec  3 08:55:25 gw  pppd[248]: sent [IPCP ConfAck id=0x1 <addr 10.16.254.20>]
Dec  3 08:55:25 gw  pppd[248]: rcvd [IPCP ConfNak id=0x3 <ms-dns1 89.232.109.74> <ms-dns3 78.138.135.10>]
Dec  3 08:55:25 gw  pppd[248]: sent [IPCP ConfReq id=0x4 <addr 10.228.109.53> <ms-dns1 89.232.109.74> <ms-dns3 78.138.135.10>]
Dec  3 08:55:26 gw  pppd[248]: rcvd [IPCP ConfAck id=0x4 <addr 10.228.109.53> <ms-dns1 89.232.109.74> <ms-dns3 78.138.135.10>]
Dec  3 08:55:27 gw  pppd[248]: local  IP address 10.228.109.53
Dec  3 08:55:27 gw  pppd[248]: remote IP address 10.16.254.20
Dec  3 08:55:27 gw  pppd[248]: primary   DNS address 89.232.109.74
Dec  3 08:55:27 gw  pppd[248]: secondary DNS address 78.138.135.10
Dec  3 08:55:33 gw  pppd[248]: Script /etc/ppp/ip-up started (pid 955)
Dec  3 08:55:37 gw  pppd[248]: Script /etc/ppp/ip-up finished (pid 955), status = 0x0
Dec  3 08:55:40 gw  syslog: dns query failed
Dec  3 08:55:44 XXX syslog: last message repeated 2 times
Dec  3 08:55:46 gw  syslog: dns query failed
Dec  3 08:55:50 XXX syslog: last message repeated 2 times
Dec  3 08:56:24 gw  syslog: dns query failed
Dec  3 08:56:28 XXX syslog: last message repeated 2 times
Dec  3 08:56:30 gw  syslog: dns query failed
Dec  3 08:56:34 XXX syslog: last message repeated 2 times
и т.д.
В нормальном случае (например, после включения-выключения питания) лог выглядит следующим образом
Dec  3 11:59:11 gw  BCM96345  started: BusyBox v1.00 (2008.03.26-07:52+0000)
Dec  3 11:59:11 gw  kernel: klogd started: BusyBox v1.00 (2008.03.26-07:52+0000)
Dec  3 11:59:11 gw  kernel: Linux version 2.6.8.1 (jenny@BS5) (gcc version 3.4.2) #1 Wed Mar 26 15:51:26 CST 2008
Dec  3 11:59:11 gw  kernel: Serial flash device: name S25FL016A, id 0x0114, size 2048KB
Dec  3 11:59:11 gw  kernel: 96332 prom init
Dec  3 11:59:11 gw  kernel: CPU revision is: 00029010
Dec  3 11:59:11 gw  kernel: Determined physical RAM map:
Dec  3 11:59:11 gw  kernel:  memory: 007a0000 @ 00000000 (usable)
Dec  3 11:59:11 gw  kernel: On node 0 totalpages: 1952
Dec  3 11:59:11 gw  kernel:   DMA zone: 1952 pages, LIFO batch:1
Dec  3 11:59:11 gw  kernel:   Normal zone: 0 pages, LIFO batch:1
Dec  3 11:59:11 gw  kernel:   HighMem zone: 0 pages, LIFO batch:1
Dec  3 11:59:11 gw  kernel: Built 1 zonelists
Dec  3 11:59:11 gw  kernel: Kernel command line: root=31:0 ro noinitrd console=ttyS0,115200
Dec  3 11:59:11 gw  kernel: brcm mips: enabling icache and dcache...
Dec  3 11:59:11 gw  kernel: Primary instruction cache 16kB, physically tagged, 2-way, linesize 16 bytes.
Dec  3 11:59:11 gw  kernel: Primary data cache 8kB 2-way, linesize 16 bytes.
Dec  3 11:59:11 gw  kernel: PID hash table entries: 32 (order 5: 256 bytes)
Dec  3 11:59:11 gw  kernel: Using 120.000 MHz high precision timer.
Dec  3 11:59:11 gw  kernel: Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Dec  3 11:59:11 gw  kernel: Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Dec  3 11:59:11 gw  kernel: Memory: 5688k/7808k available (1510k kernel code, 2100k reserved, 225k data, 76k init, 0k highmem)
Dec  3 11:59:11 gw  kernel: Calibrating delay loop... 239.20 BogoMIPS
Dec  3 11:59:11 gw  kernel: Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Dec  3 11:59:11 gw  kernel: Checking for 'wait' instruction...  unavailable.
Dec  3 11:59:11 gw  kernel: NET: Registered protocol family 16
Dec  3 11:59:11 gw  kernel: Total Flash size: 2048K with 32 sectors
Dec  3 11:59:11 gw  kernel: File system address: 0xbfc10100
Dec  3 11:59:11 gw  kernel: Can't analyze prologue code at 80188344
Dec  3 11:59:11 gw  kernel: Initializing Cryptographic API
Dec  3 11:59:11 gw  kernel: PPP generic driver version 2.4.2
Dec  3 11:59:11 gw  kernel: PPP Deflate Compression module registered
Dec  3 11:59:11 gw  kernel: PPP BSD Compression module registered
Dec  3 11:59:11 gw  kernel: MPPE/MPPC encryption/compression module registered
Dec  3 11:59:11 gw  kernel: NET: Registered protocol family 24
Dec  3 11:59:11 gw  kernel: Using noop io scheduler
Dec  3 11:59:11 gw  kernel: bcm963xx_mtd driver v1.0
Dec  3 11:59:11 gw  kernel: brcmboard: brcm_board_init entry
Dec  3 11:59:11 gw  kernel: ======= GPIO CONFIG_BCM96338 inited ========
Dec  3 11:59:11 gw  kernel: Serial: BCM63XX driver $Revision: 3.00 $
Dec  3 11:59:11 gw  kernel: ttyS0 at MMIO 0xfffe0300 (irq = 10) is a BCM63XX
Dec  3 11:59:11 gw  kernel: IP: routing cache hash table of 512 buckets, 4Kbytes
Dec  3 11:59:11 gw  kernel: TCP: Hash tables configured (established 512 bind 1024)
Dec  3 11:59:11 gw  kernel: ip_conntrack version 2.1 (61 buckets, 0 max) - 376 bytes per conntrack
Dec  3 11:59:11 gw  kernel: ip_tables: (C) 2000-2002 Netfilter core team
Dec  3 11:59:11 gw  kernel: Initializing IPsec netlink socket
Dec  3 11:59:11 gw  kernel: NET: Registered protocol family 17
Dec  3 11:59:11 gw  kernel: NET: Registered protocol family 15
Dec  3 11:59:11 gw  kernel: Ebtables v2.0 registered
Dec  3 11:59:11 gw  kernel: NET: Registered protocol family 8
Dec  3 11:59:11 gw  kernel: NET: Registered protocol family 20
Dec  3 11:59:11 gw  kernel: 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
Dec  3 11:59:11 gw  kernel: All bugs added by David S. Miller <davem@redhat.com>
Dec  3 11:59:11 gw  kernel: VFS: Mounted root (squashfs filesystem) readonly.
Dec  3 11:59:11 gw  kernel: Freeing unused kernel memory: 76k freed
Dec  3 11:59:11 gw  kernel: Algorithmics/MIPS FPU Emulator v1.5
Dec  3 11:59:11 gw  kernel: atmapi: module license 'Proprietary' taints kernel.
Dec  3 11:59:11 gw  kernel: adsl: adsl_init entry
Dec  3 11:59:11 gw  kernel: blaadd: blaa_detect entry
Dec  3 11:59:11 gw  kernel: Broadcom BCMPROCFS v1.0 initialized
Dec  3 11:59:11 gw  kernel: Broadcom BCM6338A2 Ethernet Network Device v0.3 Mar 26 2008 15:50:38
Dec  3 11:59:11 gw  kernel: Config Internal PHY Through MDIO
Dec  3 11:59:11 gw  kernel: BCM63xx_ENET: 100 MB Full-Duplex (auto-neg)
Dec  3 11:59:11 gw  kernel: eth0: MAC Address: 00:21:91:5A:15:38
Dec  3 11:59:11 gw  kernel: eth0 Link UP.
Dec  3 11:59:11 gw  kernel: BcmAdsl_Initialize=0xC00733F8, g_pFnNotifyCallback=0xC008BC64
Dec  3 11:59:11 gw  kernel: AnnexCParam=0x7FFF7EB8 AnnexAParam=0x00003983 adsl2=0x00000001
Dec  3 11:59:11 gw  kernel: pSdramPHY=0xA07FFFF8, 0x1B77C5 0xDEBDBEFF
Dec  3 11:59:11 gw  kernel: AdslCoreHwReset: AdslOemDataAddr = 0xA07FD3D4
Dec  3 11:59:11 gw  kernel: dgasp: kerSysRegisterDyingGaspHandler: dsl0 registered
Dec  3 11:59:11 gw  kernel: ATM proc init !!!
Dec  3 11:59:11 gw  kernel: ip_conntrack_pptp version 2.1 loaded
Dec  3 11:59:11 gw  kernel: ip_nat_pptp version 2.0 loaded
Dec  3 11:59:11 gw  kernel: device eth0 entered promiscuous mode
Dec  3 11:59:11 gw  kernel: br0: port 1(eth0) entering learning state
Dec  3 11:59:11 gw  kernel: br0: topology change detected, propagating
Dec  3 11:59:11 gw  kernel: br0: port 1(eth0) entering forwarding state
Dec  3 11:59:11 gw  kernel: device nas_0_1_32 entered promiscuous mode
Dec  3 11:59:11 gw  kernel: br0: port 2(nas_0_1_32) entering learning state
Dec  3 11:59:11 gw  kernel: br0: port 2(nas_0_1_32) entering forwarding state
Dec  3 11:59:11 gw  syslog: sntp -s 1.ru.pool.ntp.org -s 0.ru.pool.ntp.org -t "Moscow, St. Petersburg, Volgograd" &
Dec  3 11:59:12 gw  syslog: echo > /var/hosts
Dec  3 11:59:12 gw  kernel:
Dec  3 11:59:12 gw  kernel: ioctl, p_name=diapd
Dec  3 11:59:13 gw  syslog: pppd  plugin pppoe  nas_0_1_32 nodetach user 'M092028' password ********* interface_name 0_1_32_1 usepeerdns refuse-eap persist lcp-echo-interval 30 holdoff 3 lcp-echo-failure 3 maxfail 0 nomppc nomppe  mtu 1492 &
Dec  3 11:59:13 gw  kernel: ADSL G.994 training
Dec  3 11:59:15 gw  syslog: dns query failed
Dec  3 11:59:16 gw  pppd[244]: Plugin pppoe loaded.
Dec  3 11:59:16 gw  pppd[244]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.3
Dec  3 11:59:16 gw  pppd[244]: Plugin pppoe called.
Dec  3 11:59:16 gw  pppd[244]: pppd 2.4.3 started by admin, uid 0
Dec  3 11:59:17 gw  syslog: dns query failed
Dec  3 11:59:21 XXX syslog: last message repeated 2 times
Dec  3 11:59:22 gw  kernel: ADSL G.992 started
Dec  3 11:59:23 gw  syslog: dns query failed
Dec  3 11:59:25 gw  syslog: dns query failed
Dec  3 11:59:27 gw  kernel: ADSL G.992 channel analysis
Dec  3 11:59:33 gw  kernel: ADSL G.992 message exchange
Dec  3 11:59:33 gw  kernel: ADSL link up, interleaved, us=1018, ds=11998
Dec  3 11:59:33 gw  kernel: ATM Soft SAR: ATM link connected.
Dec  3 11:59:35 gw  syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.16.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Dec  3 11:59:36 gw  pppd[244]: PPP session is 51511
Dec  3 11:59:36 gw  pppd[244]: Using interface ppp0_1_32_1
Dec  3 11:59:36 gw  pppd[244]: Connect: ppp_0_1_32_1 <--> nas_0_1_32
Dec  3 11:59:36 gw  pppd[244]: Couldn't increase MRU to 1500
Dec  3 11:59:37 gw  pppd[244]: Remote message: Authentication failed
Dec  3 11:59:37 gw  pppd[244]: PAP authentication failed
Dec  3 11:59:37 gw  pppd[244]: Couldn't increase MRU to 1500
Dec  3 11:59:37 gw  pppd[244]: Connection terminated....
Dec  3 11:59:40 gw  pppd[244]: Sent PADT
Dec  3 11:59:40 gw  pppd[244]: PPP session is 51558
Dec  3 11:59:40 gw  pppd[244]: Using interface ppp0_1_32_1
Dec  3 11:59:40 gw  pppd[244]: Connect: ppp_0_1_32_1 <--> nas_0_1_32
Dec  3 11:59:40 gw  pppd[244]: Couldn't increase MRU to 1500
Dec  3 11:59:40 gw  pppd[244]: Remote message: Authentication failed
Dec  3 11:59:40 gw  pppd[244]: PAP authentication failed
Dec  3 11:59:40 gw  pppd[244]: Connection terminated....
Dec  3 11:59:43 gw  pppd[244]: Sent PADT
Dec  3 11:59:43 gw  pppd[244]: PPP session is 51589
Dec  3 11:59:43 gw  pppd[244]: Using interface ppp0_1_32_1
Dec  3 11:59:43 gw  pppd[244]: Connect: ppp_0_1_32_1 <--> nas_0_1_32
Dec  3 11:59:43 gw  pppd[244]: Couldn't increase MRU to 1500
Dec  3 11:59:43 gw  pppd[244]: Remote message: Authentication failed
Dec  3 11:59:43 gw  pppd[244]: PAP authentication failed
Dec  3 11:59:43 gw  pppd[244]: Connection terminated....
Dec  3 11:59:47 gw  pppd[244]: Sent PADT
Dec  3 11:59:47 gw  pppd[244]: PPP session is 51639
Dec  3 11:59:47 gw  pppd[244]: Using interface ppp0_1_32_1
Dec  3 11:59:47 gw  pppd[244]: Connect: ppp_0_1_32_1 <--> nas_0_1_32
Dec  3 11:59:47 gw  pppd[244]: Couldn't increase MRU to 1500
Dec  3 11:59:47 gw  pppd[244]: PAP authentication succeeded
Dec  3 11:59:47 gw  pppd[244]: peer from calling number 00:24:14:A1:D7:78 authorized
Dec  3 11:59:47 gw  pppd[244]: local  IP address 10.228.109.53
Dec  3 11:59:47 gw  pppd[244]: remote IP address 10.16.254.20
Dec  3 11:59:47 gw  pppd[244]: primary   DNS address 89.232.109.74
Dec  3 11:59:47 gw  pppd[244]: secondary DNS address 78.138.135.10
Dec  3 11:59:49 gw  syslog: route add default gw 10.16.254.20 2>/dev/null
Dec  3 11:59:49 gw  syslog: iptables -A FORWARD -o ppp_0_1_32_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Dec  3 11:59:49 gw  syslog: iptables -A FORWARD -i ppp_0_1_32_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Dec  3 11:59:49 gw  syslog: echo > /proc/net/ip_conntrack
Dec  3 11:59:49 gw  syslog: echo "1000" > /proc/sys/net/ipv4/ip_conntrack_max
Dec  3 11:59:49 gw  syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.16.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Dec  3 11:59:49 gw  syslog: iptables -t nat -D POSTROUTING -o ppp_0_1_32_1 -s 192.168.16.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Dec  3 11:59:49 gw  syslog: iptables -t nat -A POSTROUTING -o ppp_0_1_32_1 -s 192.168.16.0/255.255.255.0 -j MASQUERADE
Dec  3 11:59:50 gw  syslog: kill -9 238
Dec  3 11:59:50 gw  syslog: echo > /var/hosts
Dec  3 12:28:54 gw  kernel: AdslCoreEcUpdTmr: timeMs=1800120 ecUpdMask=0x40000
Dec  3 12:59:11 gw  -- MARK --
Dec  3 13:59:12 gw  -- MARK --
Dec  3 14:59:12 gw  -- MARK --
т.е. в "плохом" случае не появляются строки, выделенные группами из трёх дефисов.
Прочёл полностью темы "Вопросы по RU_1.40_07152008 для DSL-2500U/BRU/D" и "Важно!!! РЕШЕНА проблема! KEEP ALIVE PATCH для 2500U/BRU/D" и так понял, что решения до сих пор нет.
Как поправить? Куда смотреть? В чём проблема?
Если эта проблема решена в какой-либо из прошивок, то в какой? В описаниях прошивок в теме "Новая версия прошивки для DSL-2500U/BRU/D (H/W: D1, D2, D3)" упоминания о такой проблеме не нашёл.
Модем DSL-2500U/BRU/D, H/W ver. D2, F/W ver. RU_1.20.
Последний раз редактировалось Trolzen Пт дек 11, 2009 06:53, всего редактировалось 1 раз.
СообщениеДобавлено: Пт дек 04, 2009 09:59
У вас очень старая прошивка, обновите её.
Должно решить проблему.
DSL-2500U/BRU/D1 | F/W 1.58 | Укртелеком ОГО! - 10
СообщениеДобавлено: Пт дек 04, 2009 11:04
Проблема была решена.
Обновите прошивку до последней версии.
ftp://ftp.dlink.ru/pub/ADSL/DSL-2500U_B ... 122009.zip
СообщениеДобавлено: Пт дек 04, 2009 11:54
Насчет самой последней прошивки имейте ввиду viewtopic.php?p=586588#586588
СообщениеДобавлено: Пт дек 04, 2009 13:23
А можно узнать, в чём конкретно была проблема и как она была решена? Если в результате вот этого
Список изменений:
1. Обновлен PPP клиент (до pppd 2.4.3).
то у меня в моей старой прошивке вот так:
# pppd --version
pppd version 2.4.3
На сайте pppd написано, что в версии 2.4.3 были баги при работе в persist-режиме, но они были поправлены только в 2.4.4 (ссылка)
What was new in ppp-2.4.4.
* Lots of bugs fixed, particularly in the area of demand-dialled and
persistent connections.
И ещё один вопрос. Можно как-нибудь сохранить текущую прошивку, чтобы в крайнем случае можно было на неё откатиться? Прошивки RU_1.20 нигде нет.
СообщениеДобавлено: Вт дек 08, 2009 06:48
Вопросы всё ещё актуальны. Пока, если следовать логике, последняя прошивка мне не поможет. Или я не прав?
Перепрошивать без чёткой уверенности не хотелось бы, т.к. это всё-таки риск чего-нибудь накосячить и испортить устройство.
СообщениеДобавлено: Вт дек 08, 2009 10:40
Ну, в крайнем случае, прошивку 1.20 мы вам найдём...
СообщениеДобавлено: Чт дек 10, 2009 22:00
По-прежнему жду комментария от техподдержки на свой вопрос
СообщениеДобавлено: Чт дек 17, 2009 14:13
ап
СообщениеДобавлено: Чт дек 17, 2009 16:46
Аналогичная проблема, но похоже поддержка длинка не знает как с этим бороться :(
Укртелекомовские ОГОшники их похоже не интересуют
Купил 2540 бруд, тот вообще на любых прошивках тупит и не восстанавливает сессию
Взял попробывать 2500 - та же история, немного получше ведет себя веб интерфейс ( в 2540 тормоза спустя 5 минут после старта, а через час вообще висяк)
Сегодна утром перепрошил 2500 самопальной прошивкой с Keep alive patch`ем, отпишусь завтра как отработал реконнект
А вообще жалею что взял это ....
Р.S. Хм, только сейчас заметил что тему поднял человек из Казани
Значит не только проблемы с Укртелекомом
Поддержка, ау... Сделайте наконец нормальный софт, чтоб модем летал и не падал от торрентов и прочих ослов :!:
СообщениеДобавлено: Чт дек 17, 2009 22:36
alx30721, а пробовали шить официальную 1.53?
Да-да, проблемы не только у пользователей Укртелекома. Проблема давнишняя, судя по темам, которые я указал, уже больше года. Прочитал все 32 страницы в каждой, надеясь, что найду ответ, почему он (модем) так работает, и облом-с...
СообщениеДобавлено: Пн дек 21, 2009 11:33
по-прежнему жду ответа на свои вопросы: viewtopic.php?p=588678#588678
СообщениеДобавлено: Пн дек 21, 2009 18:50
Пробывал, не помогло
Наиболее стабильно и неплохо модем работает на последней бете 1.53, но биллинговый разрыв не переживает
Правда, смотрю бетка уже превратилась в финал 1.54
Шить не буду
возвращаю длинк и беру zyxel p660 ru2
Устал бороться :(
кстати, у зюхеля последняя и единственная прошивка 2007 года. :o
вот так надо работать господа длинковцы, а не проводить "экскременты" над бедными пользователями.
Я свое согласие быть бета тестером не давал :evil:
СообщениеДобавлено: Пн дек 28, 2009 09:05
Вопросы всё ещё актуальны. Или я что-то сверхсложное спрашиваю, на что невозможно дать ответ?
СообщениеДобавлено: Ср дек 30, 2009 06:58
ап
