Текущее время: Вт окт 06, 2026 14:02
 Заголовок сообщения: DIR-655 Access denied to LAN system with MAC address ?
СообщениеДобавлено: Пт ноя 13, 2009 00:35
Имеется DIR-655
Hardware Version: A3
Firmware Version : 1.30WW, 2009/10/12
Как можно интерпретировать следующий кусок лога?
MAC Filtering включен.
[INFO] Fri Nov 13 00:11:11 2009 Access denied to LAN system with MAC address 000D3AFED306
[INFO] Fri Nov 13 00:11:07 2009 Above message repeated 23 times
[INFO] Fri Nov 13 00:11:07 2009 Access denied to LAN system with MAC address 000D3AFED303
[INFO] Fri Nov 13 00:11:07 2009 Access denied to wireless system with MAC address 000D3AFED302
[INFO] Fri Nov 13 00:11:07 2009 Above message repeated 2 times
[INFO] Fri Nov 13 00:11:07 2009 Access denied to LAN system with MAC address 000D3AFED301
[INFO] Fri Nov 13 00:11:07 2009 Access denied to LAN system with MAC address 000D3AFED300
[INFO] Fri Nov 13 00:10:55 2009 Access denied to LAN system with MAC address 000D3AFED206
[INFO] Fri Nov 13 00:10:52 2009 Above message repeated 23 times
[INFO] Fri Nov 13 00:10:51 2009 Access denied to LAN system with MAC address 000D3AFED203
[INFO] Fri Nov 13 00:10:51 2009 Access denied to wireless system with MAC address 000D3AFED202
[INFO] Fri Nov 13 00:10:51 2009 Above message repeated 2 times
[INFO] Fri Nov 13 00:10:51 2009 Access denied to LAN system with MAC address 000D3AFED201
[INFO] Fri Nov 13 00:10:51 2009 Access denied to LAN system with MAC address 000D3AFED200
СообщениеДобавлено: Пт ноя 13, 2009 10:12
А что тут непонятного, с этими МАКами в сеть не пускает. :)
DI-524 (2.06Patch08RU) - Divo PPPoE
DIR-300 (1.05_b09) - OnLime IPoE
DIR-655 (1.37WW) (в запасе)
DIR-825 - OnLime IPoE
DIR-140L (1.02b02WW) + DIR-806A (2.5.22) + DES-1008A - OnLime IPoE
СообщениеДобавлено: Пт ноя 13, 2009 14:01
Это лишь бы написать чего-нибудь? 8)
Непонятно в чем отличие "Access denied to LAN system" от "Access denied to wireless system" - по LAN у меня подключен один компьютер никакого отношения к приведенным в логе MAC address не имеющий.
СообщениеДобавлено: Пт ноя 13, 2009 14:08
лишь бы написать что-нибудь:... есть такой вирус - запрашивает на фейковый мак ип-адрес и начинает "какать" в сеть и в интернет. Не оно? :) а у Вас, похоже, просто генерация фейк-маков подряд.. - невооружённым же взглядом видно.
прежде чем орать "кАзлы" - прочтите, наконец, инструкцию.... (c)
СообщениеДобавлено: Пт ноя 13, 2009 18:47
А можно понять с какого интерфейса запрос идет?
У меня стационарный комп по LAN подключен и два ноута по wifi цепляются.
СообщениеДобавлено: Пт ноя 13, 2009 19:35
Можно чисто экспериментальным путем, отключением всех компов на минут 10-15, а потом включать по-одному, а далее уже понятно...
DIR-655 и DWA-556
Мысли, написанные с грамматическими ошибками, невозможно воспринимать как умные 8)
СообщениеДобавлено: Пт ноя 13, 2009 23:35
Дело в том, что такие записи всего пару раз отловил - постоянно нет ничего криминального. Просканировал компы DrWEB и Outpost Firewall - ничего не нашло :D
Попробовал законектится по wifi и проводу с девайсами, для которых не разрешен MAC - в логе соответственно и пишет:
Access denied to wireless system with MAC address 001DFD643E72
Access denied to LAN system with MAC address 002219D91A8A
В связи с этим непонятны записи в вышеприведенном логе, когда такое дело происходит одновременно :shock:
На стационарном компе нет беспроводных интерфейсов, а ноутбуки работают только по wifi - поэтому все выглядит весьма странно (если не предполагать ошибок логирования :) )
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 115
