Текущее время: Вт сен 29, 2026 14:06
 Заголовок сообщения: DES3028: Безумный UP/DOWN портов
СообщениеДобавлено: Вт ноя 03, 2009 22:47
Помоему тема поднималась, но не помню чем закончилась.
Boot PROM Version  : Build 1.00.B06
Firmware Version   : Build 2.40.B07
И так в течении всего uptime абонента на порту
1950  2009-11-03 22:40:36 Port 3 link up, 10Mbps  FULL duplex
1949  2009-11-03 22:40:34 Port 3 link down
1948  2009-11-03 22:40:34 Port 3 link up, 100Mbps  FULL duplex
1947  2009-11-03 22:40:32 Port 3 link down
1946  2009-11-03 22:40:31 Port 3 link up, 100Mbps  FULL duplex
1945  2009-11-03 22:40:29 Port 3 link down
1944  2009-11-03 22:40:29 Port 3 link up, 100Mbps  FULL duplex
1943  2009-11-03 22:40:27 Port 3 link down
1942  2009-11-03 22:40:26 Port 3 link up, 100Mbps  FULL duplex
1941  2009-11-03 22:40:24 Port 3 link down
1940  2009-11-03 22:40:23 Port 3 link up, 100Mbps  FULL duplex
1939  2009-11-03 22:40:22 Port 3 link down
1938  2009-11-03 22:40:21 Port 3 link up, 100Mbps  FULL duplex
1937  2009-11-03 22:40:19 Port 3 link down
1936  2009-11-03 22:40:19 Port 3 link up, 100Mbps  FULL duplex
1935  2009-11-03 22:40:17 Port 3 link down
1934  2009-11-03 22:40:16 Port 3 link up, 100Mbps  FULL duplex
1933  2009-11-03 22:40:14 Port 3 link down
1932  2009-11-03 22:40:14 Port 3 link up, 100Mbps  FULL duplex
1931  2009-11-03 22:40:12 Port 3 link down
1930  2009-11-03 22:40:11 Port 3 link up, 100Mbps  FULL duplex
1929  2009-11-03 22:40:09 Port 3 link down
1928  2009-11-03 22:40:09 Port 3 link up, 100Mbps  FULL duplex
1927  2009-11-03 22:40:07 Port 3 link down
1926  2009-11-03 22:40:06 Port 3 link up, 100Mbps  FULL duplex
1925  2009-11-03 22:40:04 Port 3 link down
1924  2009-11-03 22:40:04 Port 3 link up, 100Mbps  FULL duplex
1923  2009-11-03 22:40:02 Port 3 link down
1922  2009-11-03 22:40:01 Port 3 link up, 100Mbps  FULL duplex
#cable_diag ports 3
Command: cable_diag ports 3
 Perform Cable Diagnostics ...
 Port   Type      Link Status          Test Result          Cable Length (M)
  3      FE        Link Up       OK                                92
#show fdb port 3
Command: show fdb port 3
VID  VLAN Name                        MAC Address       Port Type
118  v118                             00-19-DB-CE-A2-F0  3   Dynamic
Total Entries  : 1
Сразу скажу: кабель нормальный, пробовал заменять несколько ситуация не изменялась.
У клиента обычный комп с обычным софтом, (сетевая встроенная) как и у тысяч других.
Ситуация встречается примерно на каждом 5м коммутаторе.
С одной стороны, жалоб со стороны клиента нет, с другой напрягают такие сообщения в логе.
СообщениеДобавлено: Вт ноя 03, 2009 23:33
Закончилось тем, что сказали не обращать на это внимание :)
LiveComm
СообщениеДобавлено: Ср ноя 04, 2009 00:08
Может дело не в коммутаторе а в сетевой карточке у клиента ?
СообщениеДобавлено: Ср ноя 04, 2009 07:15
Мне кажется, что эти икания порта связывали как раз с производителями сетевых карт (чипсетов). Мне кажется - потому что не могу найти, где я что-то такое тут читал. Но что-то такое определенно было.
не важно, из какого места растут золотые руки
СообщениеДобавлено: Ср ноя 04, 2009 10:49
Роутеров, сказили что не которые роутеры типа Длинк 804 так себя ведут, и можно не обращать на это внимаение. Хотя это неправильный подход к решениею проблемы, потому как некоторые сетевухи после смерти начинают себя вести аналогично.
СообщениеДобавлено: Ср ноя 04, 2009 12:05
В том то и дело... более того, кто знает... может после таких "иканий" и порт на коммутаторе выгорит, а вот это будет совсем не приятно.
СообщениеДобавлено: Ср ноя 04, 2009 12:07
Может быть, но на 3526 такого не замечали....
СообщениеДобавлено: Ср ноя 04, 2009 13:30
на самом деле и на 3526 такое встречается.
LiveComm
СообщениеДобавлено: Ср ноя 04, 2009 13:50
По моим наблюдениям встречается на:
3526
3028G
3028
3052
3828
3010G
ES3528
Не зависит от модели свича и производителя.
СообщениеДобавлено: Чт ноя 05, 2009 00:06
Проблема именно в сетевых карт и похоже это на их стороне не лечится. К выходу из строя порта не приводит.
СообщениеДобавлено: Чт ноя 05, 2009 06:52
Подтверждаю "икание" портов на:
3526
3550
3028
3028G
3052
3010G
СообщениеДобавлено: Чт ноя 05, 2009 09:28
Проблема может быть в избыточном "твикании" абонентом своей системы. Видел комп, где установлены две ОС. При загрузке одной - все работает как положено. А вот при загрузке другой как раз и наблюдается вышеописанная ситуация. При это у абонента появляется сообщение "Сетевой кабель не подключен", затем через секунду подключение устанавливается, еще через секунду все начинается сначала :)
СообщениеДобавлено: Чт ноя 05, 2009 13:01
xcme - встречали такое при коряво установившихся драйверах неизвестного происхождения... переустановка на скачанные с сайта производителя решила проблему :)
Это текст, который можно добавлять к размещаемым вами сообщениям. Длина его ограничена 255 символами.
СообщениеДобавлено: Ср ноя 18, 2009 15:08
Забавный лог на 3028. Обратите внимание на последовательность событий. Грешу на кабель в данном случае :)
26148 2009-11-18 11:43:50 Port 23 link down
26147 2009-11-18 11:43:48 Port 23 link down
26146 2009-11-18 11:43:46 Port 23 link up, 100Mbps  FULL duplex
26145 2009-11-18 11:43:44 Port 23 link up, 100Mbps  FULL duplex
26144 2009-11-18 11:43:42 Port 23 link up, 100Mbps  FULL duplex
26143 2009-11-18 11:43:40 Port 23 link up, 100Mbps  FULL duplex
26142 2009-11-18 11:43:38 Port 23 link down
26141 2009-11-18 11:43:36 Port 23 link up, 100Mbps  FULL duplex
26140 2009-11-18 11:43:34 Port 23 link up, 100Mbps  FULL duplex
26139 2009-11-18 11:43:32 Port 23 link up, 100Mbps  FULL duplex
26138 2009-11-18 11:43:30 Port 23 link up, 100Mbps  FULL duplex
26137 2009-11-18 11:43:28 Port 23 link up, 100Mbps  FULL duplex
26136 2009-11-18 11:43:26 Port 23 link down
26135 2009-11-18 11:43:24 Port 23 link up, 100Mbps  FULL duplex
26134 2009-11-18 11:43:22 Port 23 link up, 100Mbps  FULL duplex
26133 2009-11-18 11:43:20 Port 23 link up, 100Mbps  FULL duplex
26132 2009-11-18 11:43:18 Port 23 link up, 100Mbps  FULL duplex
26131 2009-11-18 11:43:16 Port 23 link down
26130 2009-11-18 11:43:14 Port 23 link up, 100Mbps  FULL duplex
26129 2009-11-18 11:43:12 Port 23 link up, 100Mbps  FULL duplex
26128 2009-11-18 11:43:10 Port 23 link up, 100Mbps  FULL duplex
26127 2009-11-18 11:43:08 Port 23 link up, 100Mbps  FULL duplex
СообщениеДобавлено: Пн ноя 23, 2009 21:48
Вполне возможно.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 70
