Текущее время: Вс сен 27, 2026 03:59
 Заголовок сообщения: Нужен ликбез по роутеру dir100!
СообщениеДобавлено: Ср окт 14, 2009 11:46
Имеется этот девайс, настройка касательно раздела "Setup" ясна, непонятны следующие моменты:
а. Port Forwarding:
1. Public port - что это за порты;
2. Private port - что это за порты;
b. Application Rules - как работают эти правила?
3. Trigger port - что это за порты;
4. Firewall port - что это за порты;
с. Что дает механизм DMZ?
Если это возможно, то поясните вышеприведенные моменты на конкретном примере.
Спасибо.
СообщениеДобавлено: Ср окт 14, 2009 11:53
Port Forwarding
Port Forwarding can be used to open a port or range of ports to a device on your network . To use them, click the checkbox to Enable the entry, select a pre-defined service from the Application Name drop down menu, select a computer from the Computer Name drop down menu, and click Save Settings. The Application, Computer, and Ports can also be filled in manually if your Application or Computer is not listed in the drop down menus.
Name - The name for the service being provided by the device on your LAN that uses the ports being opened.
IP Address - The server computer on the LAN network that the specified ports will be opened to.
Application Name - This contains a list of pre-defined services.
Computer Name - This contains a list of the devices on your network which have obtained an IP Address from the router.
Public Port (Start - End) - The port number that users on the Internet will use to access the defined service.
Traffic Type - The protocol used by the service the device on your LAN is providing.
Application Rules
Some applications require multiple connections, such as Internet gaming, video conferencing, Internet telephony and others. These applications have difficulties working through NAT (Network Address Translation). If you need to run applications that require multiple connections, specify the port normally associated with an application in the "Trigger Port" field, select the protocol type as TCP (Transmission Control Protocol) or UDP (User Datagram Protocol), then enter the public ports associated with the trigger port in the Firewall Port field to open them for inbound traffic. There are already defined well-known applications in the Application Name drop down menu.
Name - This is the name referencing the application.
Trigger Port - This is the port used to trigger the application. It can be either a single port or a range of ports.
Traffic Type - This is the protocol used to trigger the application.
Firewall Port - This is the port number on the WAN side that will be used to access the application. You may define a single port or a range of ports. You can use a comma to add multiple ports or port ranges.
Traffic Type - This is the protocol used for the application.
DMZ
DMZ means "Demilitarized Zone." If an application has trouble working from behind the router, you can expose one computer to the Internet and run the application on that computer.
Note: Putting a computer in the DMZ may expose that computer to a variety of security risks. Use of this option is only recommended as a last resort.
Enabled DMZ Host - The DMZ capability can be active or inactive, according to this selection.
DMZ IP Address - Specify the IP address of the computer on the LAN that you want to have unrestricted Internet communication.
(c) веб-интерфейс DIR-100, кнопочка "HELP" в меню
прежде чем орать "кАзлы" - прочтите, наконец, инструкцию.... (c)
СообщениеДобавлено: Ср окт 14, 2009 12:17
а в графе указания адреса, к которому будет применено правило, можно указать не один адрес, а всю внутреннюю сеть, и какой формат при этом?
СообщениеДобавлено: Ср окт 14, 2009 12:23
в графе "адрес" указывается АДРЕС того компа в сети, которому надо перебросить поступивший "снаружи" запрос соединения на указанный "внешний" порт (или диапазон портов). То же касается и DMZ, только там пробрасываются запросы на соединение на любой порт (0-65535). А "всю внутреннюю сеть" указать нельзя (читаем описание) , да и зачем?
СообщениеДобавлено: Чт окт 15, 2009 11:09
Есть FAQ по портфорвардингу: http://dlink.ru/ru/faq/68/275.html
СообщениеДобавлено: Вт окт 20, 2009 10:32
По этой ссылке есть поисания проброса портов при их равном занчении, в случае, когда необходимо несколько внешних портов привязать на один внутренний, не описаны, если это вообще возможно?
Не понятно, например, почему при описании в разделе порт форвардинг порта, используемого торрентом, мю-торрент работает, при таком же описании для ДС++ - этого оказывается не достаточно, нужно еще эти порты прописать в разделе "Апликатион рулез", после чего начинается полноценная работа ДС клиента, хотя обе программы работают по принципу П2П...
Из особенностей работы ДС сервера в нашей сети: большинство хабов должны подключаться через разные порты, однако в самом клиенте в настройках соединениях есть возможность указать только один порт при перенаправлении, поэтому и есть необходимость перенаправлять несколько внешних портов на один внутренний.
СообщениеДобавлено: Вт окт 20, 2009 12:36
А что такое "дс-сервер" ? "дц-хаб" - знаем, а что такое "ДЦ-сервер" ? :)
ps В клиенте на вкладке "избранные хабы" адрес каждого хаба вбивать в виде ip:port (ну или при "быстрое подключение" тоже вводить не "адрес", а "адрес:порт") - пробовали? :D
весьма помогает хоть немного читать документацию (от дц-клиента, роутер тут ни при чём) , знаете ли....
Последний раз редактировалось alex444 Вт окт 20, 2009 14:23, всего редактировалось 1 раз.
СообщениеДобавлено: Вт окт 20, 2009 13:21
Привязать несколько внешних портов к одному внутреннему можно.
Насчет торрент-клиента, если вы внимательно читали - то в FAQ рассмотрено 2 варианта настройки с UPnP и с портфорвардингом.
Да и принцип построения P2P сетей торрента и DC разные и никакого отношения к роутеру не имеют.
СообщениеДобавлено: Вт окт 20, 2009 19:06
происал для каждого отдельного юзера свой порт в порт форвардинге и правил на приложение, - вопрос с перенаправлением нескольких портов - неактуален, т.к. хабы позволяют подключаться через разные порты...
ДС++ работает нормально, только не работает поиск, вот в чем проблема, т.е. файл листы скачиваются нормально, файлы тоже качаются, только в один поток, с одного пользователя, поиск не работает.
В чем может быть проблема?
СообщениеДобавлено: Вт окт 20, 2009 19:22
saprovec писал(а):
ДС++ работает нормально, только не работает поиск, вот в чем проблема, т.е. В чем может быть проблема?
как настроен DC-клиент? указал в его настройках для входящих соединений режим "брандмауэр с ручным перенаправлением портов" ? в настройках "исходящие соединения" поставил "прямое соединение" ?
СообщениеДобавлено: Вт окт 20, 2009 20:51
да, конечно!
в настройках входящего соединения "бранд. с ручным..." указан: внешний айпи, порт 411.
исходящее соединения - прямое.
все как по ссылке, описывающей порт форвардиннг для дс на сайте длинка.
в пассивном режиме работает поиск файлов и альтернативных источников,
в активном, как описано выше, - работает только загрузка с одного пользователя, поиск не работает!
СообщениеДобавлено: Вт окт 20, 2009 21:07
saprovec писал(а):
да, конечно!
ЗАЧЕМ 411 ? "как в faq" - так там на этой http://dlink.ru/up/uploads_img/5/Router ... xxx_01.jpg картинке вовсе не 411-й порт, . Короче, скрины настройки порт-форварда и правил приложений в роутере и настроек соединения в DC-клиенте - в студию
ps Вы у себя, случаем, хаба не подняли? (тогда б я ещё понял проброс 411 порта на локальный компьютер), а так - пользуйте порты > 1000
СообщениеДобавлено: Вт окт 20, 2009 22:41
Разобрался уже.
Нужно было открыть протокол ЮДП, как выяснилось для служебной информации при операции поиска или поиска альтернативных источников...
Вообщем добавил еще такое же правило но для ЮДП.
касательно порта 411, то работает нормально, выбрал его потому как в хаб листе были по дефолту адреса хабов с этим портом...
для двух других компов выбрал порты 1090 и 1091.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 43
