Текущее время: Чт окт 01, 2026 16:53
Начать новую тему Ответить на тему  [ Сообщений: 26 ]  На страницу 1, 2  След.
СообщениеДобавлено: Пт апр 15, 2005 23:25
Столкнулся с такой проблемой.
У меня АДСЛ по Стриму. Мой DSL-G604T отлично работает в режиме моста, но не устанавливает соединения в режиме маршрутизатора (ПППоЕ).
Последние логи следующие:
Apr 15 23:18:50> Bridge Module is stopping and is set at State = 5
Apr 15 23:18:51> Bridge Created: br0
Apr 15 23:18:51> Bridge Interface Added: nas0
Apr 15 23:18:51> Bridge Interface Added: tiwlan0
Apr 15 23:18:52> Bridge Interface Added: eth0
Apr 15 23:18:52> Add Bridge Iface Error: 1
Apr 15 23:18:52> Duplicate Bridge Iface: tiwlan0
Apr 16 00:11:58> Valid Configuration Tree
Apr 16 00:11:58> Bridge Module is stopping and is set at State = 5
Apr 16 00:11:59> Bridge Created: br0
Apr 16 00:12:00> Bridge Interface Added: tiwlan0
Apr 16 00:12:00> Bridge Interface Added: eth0
Apr 16 00:12:00> Add Bridge Iface Error: 1
Apr 16 00:12:00> Duplicate Bridge Iface: tiwlan0
Apr 16 00:12:01> pppd 2.4.1 started by root, uid 0
Apr 16 00:12:09> System Call Error
Apr 16 00:12:09> Tag error: TAG_HOST_UNIQ
Apr 16 00:12:09> Failed to negotiate PPPoE connection: 25
Apr 16 00:12:09> pppd 2.4.1 started by root, uid 0
Apr 16 00:12:10> Failed to negotiate PPPoE connection: 25
Apr 16 00:12:10> System Call Error
Apr 16 00:12:12> pppd 2.4.1 started by root, uid 0
Apr 16 00:12:14> Failed to negotiate PPPoE connection: 4
Apr 16 00:19:10> Bridge Module is stopping and is set at State = 5
Apr 16 00:19:10> Bridge Created: br0
Apr 16 00:19:10> Bridge Interface Added: nas0
Apr 16 00:19:11> Bridge Interface Added: tiwlan0
Apr 16 00:19:11> Bridge Interface Added: eth0
Apr 16 00:19:11> Add Bridge Iface Error: 1
Apr 16 00:19:11> Duplicate Bridge Iface: tiwlan0
Версия прошивки V1.00B02T02.RU.20041014
В чем может быть дело?
СообщениеДобавлено: Сб апр 16, 2005 00:23
Начиная с октябрьской прошивки применяется DSP v.1,
буквально на днях решил еще раз попробовать на своей
линии эту версию DSP, до этого пользовался прошивками в
которых DSP v.3, т.к. у меня сразу отказалась работать DSP
v.1, так вот, поимел точно такую же проблему, в режиме
моста все хорошо, а в режиме роутера не устанавливается
pppoe соединение, то на авторизацию ругается, то на
Transport endpoint is not connected, возвращаю прошивку
с DSP v.3 и все становится нормально... Я все это к чему,
может попробовать найти августовскую прошивку, в которой
DSP v.3 и вам попробовать?
СообщениеДобавлено: Сб апр 16, 2005 10:22
Спасибо за ответ. А где ее взять? Я, честно говоря, не очень опытный в этих делах, не испорчу я модем?
СообщениеДобавлено: Сб апр 16, 2005 11:13
Только что звонил в Стрим, они сказали, что Длинковское оборудование они не сертифицировали и нормальную работу не гарантируют, хотя в принципе все должно быть ОК :( .
Дело, мол, в настройках рутера или компьютера. Либо, еще вариант решения - создать локальную сеть. На форуме можно где-нибудь об этом почитать?
А у меня в этой связи еще вопрос :idea: (может быть, дилетантский). Если один компьютер работает в режиме моста, может ли второй (ноутбук, через Wi-Fi) одновременно также работать в режиме моста через тот же аппарат?
СообщениеДобавлено: Сб апр 16, 2005 11:45
Только что звонил в Стрим, они сказали, что Длинковское оборудование они не сертифицировали и нормальную работу не гарантируют, хотя в принципе все должно быть ОК.
они сказали: с их стороны проблем и ограничений нет.
они об ICS (например http://mdforum.dynu.com/article282.html)- поищите в поисковиках, на этом форуме нет.
в вашем случае это невозможно.
 Заголовок сообщения: Похоже, что дело в настройках.
СообщениеДобавлено: Сб апр 16, 2005 16:28
У меня V1.00B02T02.RU.20041207 и прекрасно работает в режиме маршрутизатора.
Правда, в целях безопасности WI-FI я изменил IP-адреса WLAN, отключил DHCP и DNS (IP, гейт и DNS на компах прописал жестко). Но и до этого все работало на ура более месяца.
СообщениеДобавлено: Сб апр 16, 2005 16:32
Принципиально должен, но стрим точно запрещает двойную авторизацию, поэтому для стрима так нельзя.
У меня стрим и G604T работает в режиме роутера вполне спокойно обслуживая декстоп по шнурку и ноутбук по wi-fi (кстати, в целях безопастности рекомендуется сразу включать авторизацию).
СообщениеДобавлено: Сб апр 16, 2005 17:22
Ничего не понимаю, сейчас еще раз попробовал подключиться в режиме маршрутизатора и все, вроде, заработало.
Посмотрим, сколько протянет :D
СообщениеДобавлено: Сб апр 16, 2005 22:22
на разных АТС разное оборудование
не только по этому, VPI и VCI не меняются
Ничего не понимаю, сейчас еще раз попробовал подключиться в режиме маршрутизатора и все, вроде, заработало. Посмотрим, сколько протянет
протянет, пока не поменяете модуляцию в настройках. Значит у вас просто долго цепляется. Если за 10 минут не зацепится, то выключите питание и включится снова. Есть вероятность, что сможет подсоединиться. У меня бывает после изменения настроек он входит в клинч и не соединятется пока не выключу питание.
СообщениеДобавлено: Сб апр 16, 2005 22:27
Вчера поставил шефу 604T не прошивал, всё работает сеть + Wi-Fi!
DHCP и DNS сразу отрубил, с ними проблемы особенно с DNS....
СообщениеДобавлено: Вс апр 17, 2005 18:17
Долго не протянуло. Опять работаю в режиме моста :(
К тому же обнаружил, что периодически пропадает сигнал Wi-Fi.
Интересно, это все следствие моей неопытности или качества аппарата?
СообщениеДобавлено: Пн апр 18, 2005 00:41
То же самое... :(
Купил вчера новый G604T, прошивка стоит V1.00B02T02.RU.20041014
Как мост работает отлично, а вот как маршрутизатор... В общем-то, почитав форум, склоняюсь к тому, что это из-за прошивки.
Но самое обидное, что прошивку тоже поменять не получается! Скачал итальянскую, европейскую и русскую. Запускаю все по инструкции, загружаю kernel, "please wait", страница начинает обновляться - никаких надписей или картинок о том, что все прошло успешно, веб-интерфейс перестает быть доступен и не грузится. При этом модем отлично работает, "статус" резво мигает, сетка определяется, но сделать ничего не могу, пока не отсоединю от него питание. Как отсоединяю и вставляю обратно - веб начинает снова работать, но прошивка остается старая... Что же делать? :(
Коннекчусь через wireless, может в этом дело? :(
СообщениеДобавлено: Пн апр 18, 2005 09:43
Dr.Hell писал(а):
То же самое... :(
В этом
СообщениеДобавлено: Пн апр 18, 2005 10:36
Viktor Platov писал(а):
Dr.Hell писал(а):
То же самое... :(
В этом
А я коннекчусь нормально, но все равно ничего не получается. Мне не ответите?
СообщениеДобавлено: Пн апр 18, 2005 16:45
Вчера просто сил уже не было пробовать подключать его через LAN. Проблема с обновлением прошивки была в этом. :)
_dpol, живем! =) Скачал вот отсюда прошивку, поставил и все заработало.
Сейчас буду искать какую-нибудь посвежее... Интересно, почему русский firmware глючит... А обновлять не собираются?
Просто старанно, локализуют хороший модем, перепрошивают заведомо глючным ПО на фирме, а люди это покупают и долго парятся. Не попрядок...
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 58
