Текущее время: Вт сен 29, 2026 12:34
 Заголовок сообщения: заливка скрипта через telnet
СообщениеДобавлено: Пт окт 16, 2009 09:53
вообще мне нужно заливать скрипт через telnet
делаю так:
#!/bin/sh
empty -f -i in -o out telnet ip
empty -w -i out -o in "serName:" "login\n"
empty -w -i out -o in "assWord:" "pass\n"
empty -s -o in "delete access_profile profile_id 1\n"
empty -s -o in "delete access_profile profile_id 2\n"
empty -s -o in "delete access_profile profile_id 3\n"
empty -s -o in "delete access_profile profile_id 4\n"
empty -s -o in "delete access_profile profile_id 5\n"
empty -s -o in "delete access_profile profile_id 6\n"
empty -s -o in "delete access_profile profile_id 7\n"
empty -s -o in "delete access_profile profile_id 8\n"
empty -s -o in "delete access_profile profile_id 9\n"
empty -s -o in "delete access_profile profile_id 10\n"
empty -s -o in "creat access_profile profile_id 1 profile_name prof-1 ethernet source_mac ffffffffffff\n"
empty -s -o in "creat access_profile profile_id 2 profile_name prof-2 ethernet source_mac ffffffffffff\n"
empty -s -o in "creat access_profile profile_id 3 profile_name prof-3 ethernet source_mac ffffffffffff\n"
empty -s -o in "creat access_profile profile_id 4 profile_name prof-4 ethernet source_mac ffffffffffff\n"
empty -s -o in "creat access_profile profile_id 5 profile_name prof-5 ethernet source_mac ffffffffffff\n"
empty -s -o in "creat access_profile profile_id 6 profile_name prof-6 ethernet source_mac ffffffffffff\n"
empty -s -o in "creat access_profile profile_id 7 profile_name prof-7 ethernet source_mac ffffffffffff\n"
empty -s -o in "creat access_profile profile_id 8 profile_name prof-8 ethernet source_mac ffffffffffff\n"
empty -s -o in "creat access_profile profile_id 9 profile_name prof-9 ethernet source_mac ffffffffffff\n"
empty -s -o in "creat access_profile profile_id 10 profile_name prof-10 ethernet source_mac ffffffffffff\n"
empty -s -o in "config access_profile profile_id 1 add access_id auto_assign ethernet source_mac  port 1-10 permit\n"
empty -s -o in "config access_profile profile_id 1 add access_id auto_assign ethernet source_mac 00:E0:7D:E5:5A:55 port 1-10 permit\n"
empty -s -o in "config access_profile profile_id 1 add access_id auto_assign ethernet source_mac 00:0B:6A:C4:30:48 port 1-10 permit\n"
empty -s -o in "config access_profile profile_id 1 add access_id auto_assign ethernet source_mac 00:0B:6A:A9:AE:3B port 1-10 permit\n"
empty -s -o in "config access_profile profile_id 1 add access_id auto_assign ethernet source_mac 00:14:85:19:22:9C port 1-10 permit\n"
empty -s -o in "config access_profile profile_id 1 add access_id auto_assign ethernet source_mac 00:1D:60:76:35:54 port 1-10 permit\n"
empty -s -o in "config access_profile profile_id 1 add access_id auto_assign ethernet source_mac 00:1F:C6:5C:D0:FC port 1-10 permit\n"
empty -s -o in "config access_profile profile_id 1 add access_id auto_assign ethernet source_mac 00:04:61:49:85:AD port 1-10 permit\n"
empty -s -o in "config access_profile profile_id 1 add access_id auto_assign ethernet source_mac 00:E0:4D:0C:9F:B9 port 1-10 permit\n"
empty -s -o in "config access_profile profile_id 1 add access_id auto_assign ethernet source_mac 00:15:E9:3C:E8:5B port 1-10 permit\n"
empty -s -o in "config access_profile profile_id 1 add access_id auto_assign ethernet source_mac 00:04:61:A0:C2:45 port 1-10 permit\n"
empty -s -o in "config access_profile profile_id 1 add access_id auto_assign ethernet source_mac 00:24:8C:CE:11:01 port 1-10 permit\n"
empty -s -o in "config access_profile profile_id 1 add access_id auto_assign ethernet source_mac 00:1B:FC:B0:D6:56 port 1-10 permit\n"
... (около 700 правил)
empty -s -o in "config access_profile profile_id 7 add access_id auto_assign ethernet source_mac 00:02:44:AF:08:E3 port 1-10 permit\n"
empty -s -o in "config access_profile profile_id 7 add access_id auto_assign ethernet source_mac 00:0B:6A:B2:8E:5E port 1-10 permit\n"
empty -s -o in "config access_profile profile_id 7 add access_id auto_assign ethernet source_mac 00:E0:91:34:FB:BC port 1-10 permit\n"
empty -s -o in "config access_profile profile_id 7 add access_id auto_assign ethernet source_mac 00:19:DB:F4:C4:6E port 1-10 permit\n"
empty -s -o in "config access_profile profile_id 7 add access_id auto_assign ethernet source_mac 00:13:D3:37:9A:94 port 1-10 permit\n"
empty -s -o in "config access_profile profile_id 7 add access_id auto_assign ethernet source_mac 00:0E:A6:BB:D9:37 port 1-10 permit\n"
empty -s -o in "config access_profile profile_id 7 add access_id auto_assign ethernet source_mac 00:19:DB:B1:5E:43 port 1-10 permit\n"
empty -s -o in "logout\n"
так вот заливается от 12 до 150 правил и на этом все.
СообщениеДобавлено: Пт окт 16, 2009 09:59
я разбиваю большие заливки по 15 и запускаю их батничком через sleep=1
СообщениеДобавлено: Пт окт 16, 2009 10:08
хотелось бы нормальной работы с большим количеством
СообщениеДобавлено: Пт окт 16, 2009 10:29
А загрузка инкриментного конфига для данной задачи не годится?
Бигаров Руслан.
СообщениеДобавлено: Пт окт 16, 2009 10:30
при загрузке конфига перезагрузка свича требуется ?
СообщениеДобавлено: Пт окт 16, 2009 10:56
мы поьзуем загрузку инкрементного конфига. работает гораздо лучше. Кстати даже загрузка полного конфига перезагрузки свича не требует. Единственная проблема 3526 находится при этом в ауте порядка 2 минут, а вот 3028 всего несколько секунд.
СообщениеДобавлено: Пт окт 16, 2009 11:12
помойму лучше всё-таки батничек на кроне, свич себя при этом чуствует хорошо, не ругается, конфиг наполняется нормально.
СообщениеДобавлено: Пт окт 16, 2009 12:24
А чем лучше?
СообщениеДобавлено: Пт окт 16, 2009 12:34
comtel-b.ru писал(а):
А чем лучше?
Такого нет:
СообщениеДобавлено: Пт окт 16, 2009 14:11
написал через php class telnet-а работает медленноооо... но работает. 1-2 правила в секунду.
хочется быстрее.
СообщениеДобавлено: Пт окт 16, 2009 14:40
Вот вам в подарок перловский скрипт, работает быстро:
use Net::Telnet ();
$t = new Net::Telnet (Host => "[host]", Timeout => 5, Port => [port]) or die "Can't open connection";
$username = "admin";
$passwd = "ia_krevedko";
$t->print("$username");
$t->print("$passwd");
$t->print("conf ports 12 st en");
$t->print("conf ports 13 st dis");
$t->print("exit");
$t->print("logout");
exit;
Для работы скрипта необходима библиотека NET::Telnet
СообщениеДобавлено: Пт окт 16, 2009 15:12
А чем лучше?
Такого нет:
Ну так такое - когда полный конфиг.
СообщениеДобавлено: Пт окт 16, 2009 15:16
ну тогда уж заодно waitfor использовать надо или cmd - вместо.
иначе получится "быстро и непонятно" (для свитча) :)
/nixx
СообщениеДобавлено: Сб окт 17, 2009 01:46
чтож придётся сослатся на когдато написаную тут мной тему .
viewtopic.php?t=41670
почти 3 года в данном режиме быстро непренуждённо и без лишних глюков.
Люблю писать с ошибками.....
D-Link User: DGS-3627G, DGS-3324SR, DES-3526, DES-1024D, DES-1016D, DWL-2100AP, DEM-310GT,DEM-330, DCS-950.
