Текущее время: Вс сен 27, 2026 08:49
 Заголовок сообщения: ACL лист
СообщениеДобавлено: Ср окт 14, 2009 13:07
create access_profile profile_id 1 ip source_ip_mask 255.255.255.0 destination_ip_mask 255.255.0.0
config access_profile profile_id 1 add access_id auto_assign ip source_ip 192.168.0.0 destination_ip 192.168.0.0 port 1-12 permit rx_rate no_limit
create access_profile profile_id 2 ip source_ip_mask 255.255.252.0 destination_ip_mask 255.255.252.0
config access_profile profile_id 2 add access_id 1 ip source_ip 192.168.0.0 destination_ip 192.168.0.0 port 1-12 permit rx_rate no_limit
create access_profile profile_id 3 ip source_ip_mask 255.255.0.0 destination_ip_mask 255.255.255.255 tcp dst_port_mask 0xFFFF
config access_profile profile_id 3 add access_id auto_assign ip source_ip 192.168.0.0 destination_ip 192.168.0.3 tcp dst_port 80 port 1-12 permit rx_rate no_limit
config access_profile profile_id 3 add access_id auto_assign ip source_ip 192.168.0.0 destination_ip 192.168.0.3 tcp dst_port 25 port 1-12 permit rx_rate no_limit
create access_profile profile_id 4 ip source_ip_mask 255.255.0.0 destination_ip_mask 255.255.255.255 udp dst_port_mask 0xFFFF
config access_profile profile_id 4 add access_id auto_assign ip source_ip 192.168.0.0 destination_ip 192.168.0.2 udp dst_port 53 port 1-12 permit rx_rate no_limit
create access_profile profile_id 5 ip source_ip_mask 255.255.0.0 destination_ip_mask 255.255.255.255 icmp
config access_profile profile_id 5 add access_id 1 ip source_ip 192.168.0.0 destination_ip 192.168.0.2 icmp port 1-12 permit rx_rate no_limit
config access_profile profile_id 5 add access_id auto_assign ip source_ip 192.168.0.0 destination_ip 192.168.0.3 icmp port 1-12 permit rx_rate no_limit
create access_profile profile_id 6 ip source_ip_mask 255.255.0.0 destination_ip_mask 255.255.255.252
config access_profile profile_id 6 add access_id 1 ip source_ip 192.168.0.0 destination_ip 192.168.0.12 port 1-12 permit rx_rate no_limit
create access_profile profile_id 13 ip source_ip_mask 255.255.0.0 destination_ip_mask 255.255.252.0
config access_profile profile_id 13 add access_id 1 ip source_ip 192.168.0.0 destination_ip 192.168.0.0 port 1-12 deny
create access_profile profile_id 14 ip source_ip_mask 255.255.252.0 destination_ip_mask 255.255.0.0
config access_profile profile_id 14 add access_id 1 ip source_ip 192.168.0.0 destination_ip 192.168.0.0 port 1-12 deny
есть правила которые разрешают доступ к к подсетям с маской 255.255.0.0 с подсетей с маской 255.255.255.252
Куда мне добавить еще правило которое будет позволять доступ к подсетям с маской 255.255.0.0 с подсети 192.168.100.0?
СообщениеДобавлено: Ср окт 14, 2009 13:28
то, что запрещено - не может быть разрешено
то, что разрешено - не может быть запрещено
выстраивайте ваши правила согласно этому принципу
СообщениеДобавлено: Ср окт 14, 2009 13:42
добавил. Не помагает :-(
config access_profile profile_id 1 add access_id 1 ip source_ip 192.168.100.0 destination_ip 192.168.0.0 port 1-12 permit rx_rate no_limit
СообщениеДобавлено: Ср окт 14, 2009 15:19
Нужно учитывать что проверка пакетов происходит от наименьшего ID до максимального до первого совпадения.
Бигаров Руслан.
СообщениеДобавлено: Ср окт 14, 2009 15:28
config access_profile profile_id 1 add access_id 2 ip source_ip 192.168.0.0 destination_ip 192.168.0.0 port 1-12 permit rx_rate no_limit
config access_profile profile_id 1 add access_id 3 ip source_ip 192.168.0.0 destination_ip 192.168.100.0 port 1-12 permit rx_rate no_limit
create access_profile profile_id 7 ip source_ip_mask 255.255.0.0 destination_ip_mask 255.255.252.0
config access_profile profile_id 7 add access_id 10 ip source_ip 192.168.0.0 destination_ip 192.168.0.0 port 1-12 deny
create access_profile profile_id 8 ip source_ip_mask 255.255.252.0 destination_ip_mask 255.255.0.0
config access_profile profile_id 8 add access_id 10 ip source_ip 192.168.0.0 destination_ip 192.168.0.0 port 1-12 deny
Вот добавил правила. Но все равно с 192.168.100.1 нет доступа к подсетям 192.168.0-3 :-(
СообщениеДобавлено: Ср окт 14, 2009 17:50
логики нет.
3 правило первого профиля бессмысленно. под него ничего не подаёт. всё попадёт под 2 правило.
аналогично - второй профиль бессмысленный. под него тоже ничего не попадёт. всё уйдёт по второму правилу в первом профиле.
LiveComm
СообщениеДобавлено: Чт окт 15, 2009 12:19
Cогласен с svsh1990. Во-вторых, пожалуйста, уточните какие подсети у Вас в сети, т.е. только 192.168.100.0/24 и 192.168.0.0/22 или 192.168.0.0/16, а также какие ограничения Вы хотите наложить на пакеты из данных подсетей, т.е., пожалуйста, опишите более подробно задачу, которую Вы хотите решить.
Бигаров Руслан.
