Текущее время: Ср сен 23, 2026 12:33
 Заголовок сообщения: des3828 PIM SM И 100% загрузка проца
СообщениеДобавлено: Пн окт 05, 2009 18:58
# PIMSM
enable pim
config pim cbsr hash_masklen 30
config pim cbsr bootstrap_period 60
config pim register_probe_time 5
config pim register_suppression_time 60
config pim last_hop_spt_threshold 0
config pim rp_spt_threshold 0
config pim crp holdtime 150 priority 192
config pim crp wildcard_prefix_cnt 0
config pim ipif System state disable hello 30 jp_interval 60 mode dm dr_priority 1
config pim cbsr ipif System priority -1
config pim ipif vlan410 state disable hello 30 jp_interval 60 mode dm dr_priority 1
config pim cbsr ipif vlan410 priority -1
config pim ipif vlan13 state disable hello 30 jp_interval 60 mode sm dr_priority 1
config pim cbsr ipif vlan13 priority -1
config pim ipif vlan14 state disable hello 30 jp_interval 60 mode sm dr_priority 1
config pim cbsr ipif vlan14 priority -1
config pim ipif vlan12 state disable hello 30 jp_interval 60 mode sm dr_priority 1
config pim cbsr ipif vlan12 priority -1
config pim ipif vlan2 state disable hello 30 jp_interval 60 mode dm dr_priority 1
config pim cbsr ipif vlan2 priority -1
config pim ipif vlan3 state disable hello 30 jp_interval 60 mode dm dr_priority 1
config pim cbsr ipif vlan3 priority -1
config pim ipif vlan5 state disable hello 30 jp_interval 60 mode dm dr_priority 1
config pim cbsr ipif vlan5 priority -1
config pim ipif vlan51 state disable hello 30 jp_interval 60 mode dm dr_priority 1
config pim cbsr ipif vlan51 priority -1
config pim ipif vlan100 state disable hello 30 jp_interval 60 mode dm dr_priority 1
config pim cbsr ipif vlan100 priority -1
config pim ipif vlan256 state enable hello 30 jp_interval 60 mode sm dr_priority 1
config pim cbsr ipif vlan256 priority -1
create pim static_rp group 224.0.0.0/4 rp 10.76.254.74
create pim register_checksum_include_data rp_address 0.0.0.0
Версия
Boot PROM Version Build 0.00.010
Firmware Version Build 4.50.B23
Как только включаешь PIM, начинается 100% загрузка проца...
куда копать?
СообщениеДобавлено: Пн окт 05, 2009 23:46
У Вас TTL приходящих на свитч Multicast пакетов случайно не 0 или 1?
СообщениеДобавлено: Вт окт 06, 2009 09:35
дело в том, что мы получаем поток из вне..., когда на это место ставим циску, то все нормально. Могу организовать доступ на этот коммутатор.
СообщениеДобавлено: Вт окт 06, 2009 10:44
Пришлите, пожалуйста, полный конфигурационный файл для анализа настроек.
Бигаров Руслан.
СообщениеДобавлено: Вт окт 06, 2009 10:47
Отправил в почту
СообщениеДобавлено: Чт окт 08, 2009 14:07
UP
СообщениеДобавлено: Чт окт 08, 2009 14:33
У Вас в конфигурации не хватает следующих настроек:
enable igmp_snooping
config igmp_snooping 12seg state enable
config igmp_snooping 13seg state enable
config igmp_snooping 14seg state enable
config igmp_snooping 256seg state enable
config igmp ipif vlan12 version 2 state enable
config igmp ipif vlan13 version 2 state enable
config igmp ipif vlan14 version 2 state enable
config pim ipif vlan12 state enable mode sm
config pim ipif vlan13 state enable mode sm
config pim ipif vlan14 state enable mode sm
Бигаров Руслан.
СообщениеДобавлено: Пн окт 12, 2009 11:09
Не очень это помогло, все равно загрузка 100% иногда падает до 75%.... что смотреть дальше?
СообщениеДобавлено: Пн окт 12, 2009 14:54
Всё-таки посмотрите TTL пакетов.
СообщениеДобавлено: Пн окт 12, 2009 16:45
от30 до 54
СообщениеДобавлено: Пн окт 12, 2009 22:31
Укажите пожалуйста в личку Ваш телефон.
СообщениеДобавлено: Вт окт 13, 2009 18:00
отправил
