Текущее время: Пн июн 15, 2026 06:08
СообщениеДобавлено: Вс сен 27, 2009 20:42
Прошивка 227RUB07Beta06 (2.26 - та же история, только хуже еще)
- постоянные отвалы, провайдер Уфанет (PPTP Russia)
Не зависит от того запущен torrent или нет. Периодичность работы без отвала в среднем от 15 минут до 12 часов.
Shaping и QOS - выключено.
[INFO] Sun Sep 27 22:58:40 2009 Blocked incoming UDP packet from 94.41.62.45:48790 to 94.41.16.86:45752
[INFO] Sun Sep 27 22:58:39 2009 Blocked incoming TCP packet from 10.161.201.13:47053 to 94.41.16.86:59824 as SYN:ACK received but there is no active connection
[INFO] Sun Sep 27 22:58:36 2009 Above message repeated 1 times
[INFO] Sun Sep 27 22:58:07 2009 Blocked incoming UDP packet from 172.27.20.1:44978 to 94.41.16.86:45752
[INFO] Sun Sep 27 22:57:58 2009 PPP network up with IP Address 94.41.16.86
[INFO] Sun Sep 27 22:57:58 2009 LCP sets local options: ACCM: 00000000, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Sun Sep 27 22:57:58 2009 LCP sets remote auth: C223
[INFO] Sun Sep 27 22:57:58 2009 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 0, PFC: 0, MRU: 1460
[INFO] Sun Sep 27 22:57:58 2009 PPTP connected to server "drs28.ufanet.ru" with ID 0xFAC0
[INFO] Sun Sep 27 22:57:58 2009 The PPTP transmit window is 16
[INFO] Sun Sep 27 22:57:58 2009 Attempting to establish a PPTP connection.
[INFO] Sun Sep 27 22:57:28 2009 PPTP tunnel ID 0x2970 has been closed
[INFO] Sun Sep 27 22:57:28 2009 PPTP received a tunnel clear down request from the application, the tunnel will now be closed.
[INFO] Sun Sep 27 22:57:28 2009 PPP network down
[INFO] Sun Sep 27 22:57:28 2009 LCP sets remote auth: 00000000
[INFO] Sun Sep 27 22:57:28 2009 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Sun Sep 27 22:57:28 2009 LCP sets local options: ACCM: 00000000, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Sun Sep 27 22:57:27 2009 PPP network down
[INFO] Sun Sep 27 22:57:27 2009 Blocked incoming TCP connection request from 10.49.163.191:3780 to 92.50.166.224:45752
[INFO] Sun Sep 27 22:57:27 2009 Blocked incoming TCP connection request from 92.50.166.224:59203 to 92.50.166.224:45752
[INFO] Sun Sep 27 22:57:26 2009 Blocked incoming TCP connection request from 172.27.4.104:2841 to 92.50.166.224:45752
[INFO] Sun Sep 27 22:57:26 2009 Blocked incoming TCP connection request from 94.41.141.69:2146 to 92.50.166.224:45752
[INFO] Sun Sep 27 22:57:26 2009 Blocked incoming TCP connection request from 172.27.71.209:1213 to 92.50.166.224:45752
 Заголовок сообщения: еще просьба
СообщениеДобавлено: Вс сен 27, 2009 21:16
Выложите пожалуйста прошивку
DIR615B2_FW227RUB07Beta05.bin
:!: с ней стабильнее работало (отвалы с интервалом 6 часов...неделя) :!:
перепрошился в новую (думал отвалы уйдут :evil: ), та версия не сохранилась у меня
СообщениеДобавлено: Вс сен 27, 2009 21:22
Попробуй вот эту:
http://belozersk.narod.ru/files/D-Link/ ... 7RUB07.bin
СообщениеДобавлено: Вс сен 27, 2009 21:28
спасибо, седня-завтра проверю.
ЗЫ всетки старую (227B07Beta05) хотелось бы тоже в архив себе, стабильнее была...
СообщениеДобавлено: Вс сен 27, 2009 22:31
у меня тоже самое, всё перепробовал, ничего не помогает, надо видимо пробывать менять на ASUS в магазине
ДАЙТЕ СРОЧНО НОРМАЛЬНУЮ ПРОШИВКУ
[WARN]   Mon Sep 28 05:37:53 2009   The remote PPTP access concentrator is slow to respond. There may be connectivity problems.
СообщениеДобавлено: Вт сен 29, 2009 08:32
Ну как, помогло?
Стоит прошивать?
СообщениеДобавлено: Вт сен 29, 2009 19:05
mdemid писал(а):
Ну как, помогло?
Стоит прошивать?
Мне помогло, сейчас например 22 часа без отвалов уже пашет.
Одновременно торренты с внешки и локала, серфинг - все ок.
отвалы все же бывают, но их "не видно" в прогах (не видно ошибок типа "не удается отобразить страницу"), просто скорость в 0 падает и быстро восстанавливается
режим - Russia PPTP;
Traffic Sharping, QOS - отключено
СообщениеДобавлено: Вт сен 29, 2009 20:14
ну это не показатель, у меня вот как получается, данные со статистики провайдера VPN сессии
29-09-2009 21:14:34 29-09-2009 22:01:55 47м
29-09-2009 18:48:37 29-09-2009 21:14:24 2ч 25м
29-09-2009 18:08:57 29-09-2009 18:48:30 39м
28-09-2009 22:38:58 29-09-2009 18:08:23 19ч 29м
28-09-2009 15:45:26 28-09-2009 22:38:44 6ч 53м
28-09-2009 07:36:47 28-09-2009 15:44:53 8ч 8м
28-09-2009 02:06:37 28-09-2009 07:36:43 5ч 30м
28-09-2009 01:45:51 28-09-2009 02:04:54 19м
28-09-2009 01:26:27 28-09-2009 01:45:13 18м
27-09-2009 22:44:47 28-09-2009 01:25:35 2ч 40м
27-09-2009 09:09:09 27-09-2009 22:43:49 13ч 34м
27-09-2009 00:52:29 27-09-2009 09:08:09 8ч 15м
26-09-2009 23:40:45 27-09-2009 00:51:50 1ч 11м
26-09-2009 20:12:06 26-09-2009 23:40:07 3ч 28м
26-09-2009 18:50:18 26-09-2009 20:11:28 1ч 21м
26-09-2009 18:12:31 26-09-2009 18:50:15 37м
26-09-2009 18:06:20 26-09-2009 18:11:42 5м
26-09-2009 17:51:11 26-09-2009 18:06:13 15м
26-09-2009 15:26:25 26-09-2009 17:51:04 2ч 24м
26-09-2009 15:03:45 26-09-2009 15:25:54 22м
26-09-2009 13:34:30 26-09-2009 15:03:15 1ч 28м
26-09-2009 12:23:19 26-09-2009 13:00:36 37м
24-09-2009 23:08:28 25-09-2009 22:26:32 23ч 18м
24-09-2009 22:23:52 24-09-2009 23:07:51 43м
24-09-2009 21:45:48 24-09-2009 22:23:26 37м
24-09-2009 08:44:58 24-09-2009 21:43:03 12ч 58м
СообщениеДобавлено: Ср сен 30, 2009 08:56
у вас ест ьвозможность сделать сниф на последней прошивке? Эт оускорит решение проблемы.
СообщениеДобавлено: Ср сен 30, 2009 09:49
говорите что сделать и как, сделаю
СообщениеДобавлено: Ср сен 30, 2009 10:09
AndreTM писал(а):
А для 655 такая есть? Тоже на Уфанете так же плющит...
И что за это прошивка? Официальная, русская или что?
DIR655A4_FW134WWB08Beta
СообщениеДобавлено: Ср сен 30, 2009 10:13
fire1990 писал(а):
mdemid писал(а):
Ну как, помогло?
Стоит прошивать?
У меня тоже Уфанет и 655... Но вчера 29 тоже также вдруг поперло... может дело у нас с уфанетом? Надеюсь Вы в курсе, что глюки на этих роутерах практически одинаковые...
Я выходил из положения уменьшением MTU до 1100-1200 - разрывы становились гораздо реже, но переставала нормально работать статическая маршрутизация, а вчера вот плюнул и вернул на 1400 и через полчаса всё поперло... А может чисто по времени что-то совпало.
СообщениеДобавлено: Ср сен 30, 2009 19:34
Я значение MTU как только не менял - не помогает, а если прошить бетой (ftp://ftp.dlink.ru/pub/Router/DIR-615/F ... Beta06.bin) или последней "типа стабильной" (ftp://ftp.dlink.ru/pub/Router/DIR-615/F ... 6RUB06.bin) - вообще (_!_) задница, рвет по-черному, еще бывает и поднять потом соединение не может. (повторюсь режим PPTP Russia)
Я не говорю что на текущей прошивке у меня сейчас не рвет - рвет, но реже намного и "безболезненно" как-то...
ЗЫ думаю руки кривые у программистов, прошивку испанскую вытащили на доделку (мыслей своих нет?). Перевести с английского на русский или убрать не нужное в русской версии "Espaniol" тоже не в состоянии? Скиньте исходник - помогу с техническим переводом. Диагностировать косяки по многочисленным заявлениям на форуме тоже не в состоянии - тайваньские парни?, а в России - только сбыт + техподдержка сидит.
 Заголовок сообщения: Русская прошивка версия 3.02
СообщениеДобавлено: Чт окт 01, 2009 11:48
Русская прошивка версия 3.02 - она существует, для HW версии C1
Похоже косяк конкретный с железом, раз ревизию пришлось сменить
Или мы увидим нормально переведенную бескосячную прошивку для своих ревизий?
СообщениеДобавлено: Пт окт 09, 2009 12:19
Недолго продолжалась беззаботная работа роутера... :evil:
На роутере при режиме PPTP горит красная лампочка - попыток подключения не делает, кнопку Connect жать бесполезно
В режиме Russia PPTP выдает подключено (лампа зеленая), все как и раньше - везде IP прописаны (шлюз и прочие настройки у провайдера не изменились), но не пингуется ни один сайт ни с компа ни с роутера
Перепрошивал новой бетой и старыми прошивками - то же самое.
Сброс делал кнопкой, настройки руками вбивал - не помогает.
Что делать?
Сейчас этот форум просматривают: Google [Bot] и гости: 14
