Текущее время: Чт сен 10, 2026 10:33
 Заголовок сообщения: DG-104SH F/W b41 + AlterPSS
СообщениеДобавлено: Вт апр 12, 2005 11:52
Доброго времени уважаемые!
имеем DG-104SH F/W b41, H/W C2
в такой конфигурации:
Welcome to VoIP Gateway system!!!
username:
password:
ggdbg>show h323
h323 display_name = 'DG-104SH'
h323 h323_ID = 'DEFAULT_H323_ID'
h323 h245_term_type = 40
h323 endpoint_reg_type = terminal
h323 rtp_port_base = 16384
h323 rtp_tos = 8
h323 ras_tos = 4
h323 h225h245_tos = 4
h323 fast_start = on
h323 t38 = off
h323 t38_req_initiater = callee
h323 gk_mode = manual
h323 gk_addr = 192.168.26.3 Port: 1719
h323 gk_identifier = 'PSS'
h323 keepalive_to_gk = off
h323 keepalive_interval = 120
h323 gk_max_fails = 3
h323 gk_rsp_timeout = 5
h323 no_ans_callfwd_time = 10
h323 aliases (E.164) =
1
2
3
4
при попытке позвонить голосом имеем:
ggdbg>spy hsmu 0
ggdbg>000028292 HSMU: Enter call_profile->capabilities
000028292 HSMU: Coding Profile Bit 6 ignored, no 'voice' usage.
000028292 HSMU: Exit call_profile->capabilities.
000028292 HSMU 0: Process outgoing H.323 Fast Start call.
000028292 Dialing DEST = TEL:88792222222 (using GateKeeper)
000028292 SOURCE = NAME:DEFAULT_H323_ID,TEL:4
000028292 USER_TO_USER = CID_NAME:tcid3, CID_NUM:4 SETUP
000028292 hsmup_open_rtp_sockets: nw_open(RTP1), port=16384, call_num=0
000028292 hsmup_open_rtp_sockets: nw_open(RTCP2), call_num=0, port=16385
000028292 HSMU 0: set timer for 50000 in state hsmup_state_h225_wait_alerting
000028343 HSMU 0: cmControlStateFastStart
000028343 HSMU 0: Chan 0o cmEvChannelSetRTCPAddress_msg IP = 192.168.26.3, Port
= 16465
000028343 HSMU 0: Chan 0o cmEvChannelSetAddress_msg IP = 192.168.26.3, Port = 16
464
000028343 HSMU 0: Chan 0o - cmChannelStateConnected "g729"
local RTCP = 0, remote RTCP =16465, RTP = 192.168.26.3:16464
000028343 HSMU 0: Chan 0i cmEvChannelSetRTCPAddress_msg IP = 192.168.26.3, Port
= 16465
000028343 HSMU 0: Chan 0i - cmChannelStateConnected "g729"
local RTCP = 0, remote RTCP =16465, RTP = 0.0.0.0:0
000028343 HSMU 0: FS Chan 0i - offering channel "g729"
000028343 HSMU 0: FS Chan 0i: Opened RTP socket = 1, cmChannel = 16384
000028343 HSMU 0: Chan 0i: Opened RTCP socket = 2, port 16385
000028343 HSMU 0: abort timer in state hsmup_state_h225_wait_alerting
000028343 HSMU 0: set timer for 2000 in state hsmup_state_fast_start_alerting_in
fo
000028365 HSMU 0: abort timer in state hsmup_state_fast_start_alerting_info
000029409 HSMU 0: set timer for 300 in state hsmup_state_fast_start_wait_complet
e
000029409 HSMU 0: abort timer in state hsmup_state_fast_start_wait_complete
000029409 HSMU 0: VOICE CONNECTED, coding=g729AnnexA, FAST START mode, originati
ng
000029409 HSMU 0: set timer for 30000 in state hsmup_state_voice_connected
000029416 HSMU 0: abort timer in state hsmup_state_voice_connected
000029416 HSMU 0: set timer for 10000 in state hsmup_state_fax_channel
000029416 HSMU 0: abort timer in state hsmup_state_fax_channel
000029416 HSMU 0: H.323 release (IF)
000029471 HSMU 0: voice rtp open=0, rtcp open=0, nw_close(voice socked RTP1, RTC
P2)
000029471 HSMU 0: nw_close(inchan local RTCP2, RTP1)
000029471 HSMU 0: nw_close(inchan local RTCP65535, RTP65535)
000029471 HSMU 0: nw_close(outchan local RTCP65535)
Логи AlterPSS:
12:32:58: 0000 H = Create Incoming channel - 192.168.26.110:7328
12:32:58: 0000 H >> Setup, DisplayInfo: DG-104SH, User: , DialPhone: 88792222222, UserPhone: 4
12:32:58: 0000 H Resolved time for call 36000
12:32:58: 0000 H Find Plan Number for USER user, number of dest - 2
12:32:58: 0000 HH = Create Outgoing channel 1.1.1.1:1720
12:32:58: 0000 HH SetParam, IP - 192.168.26.110:16384, Transit: 'full proxy'
12:32:58: 0000 HH Voice Capability: G729 - 2,
12:32:58: 0000 HH << Setup, DisplayInfo: AlterPSS, User: , DialPhone: 78792222222, UserPhone: 89285555555
12:32:58: 0000 HH SetParam, IP - 1.1.1.1:18442, Transit: 'full proxy'
12:32:58: 0000 HH CallProceeding
12:32:59: 0000 HH << Progress
12:32:59: 0000 HH Alerting
12:33:08: 0000 HH Connect, DisplayInfo:
12:33:09: 0000 HH CallEnd: User - 'user', Number - 88792222222 (78792222222), Duration - 0 sec, Cause - 38
12:33:09: 0000 -H ReleaseComplete
т.е.: звоним, идет алертинг, затем на удаленной стороне поднимают трубку. На моей стороне короткие гудки.
подскажите, где грабли?
P.S. IP адреса внешнего шлюза изменены намеренно, b41 - из фака, т.к. нужно использовать факс
P.P.S. при прозвоне програмным терминалом или Cisco ATAшкой - все в порядке, звонок проходит
 Заголовок сообщения: Re: DG-104SH F/W b41 + AlterPSS
СообщениеДобавлено: Вт апр 12, 2005 11:54
Модератор
Модератор
username:
password:
ggdbg>show h323
h323 rtp_tos = 8
h323 ras_tos = 4
h323 t38 = off
1
2
3
4
ggdbg>spy hsmu 0
= 16465
464
= 16465
fo
e
ng
P2)
Логи AlterPSS:
Попробуйте пока отключить фаст старт и факс
Виктор Колосов
СообщениеДобавлено: Вт апр 12, 2005 12:23
Отключил.
он теперь кладет трубку как только начинается алертинг
username:
password:
ggdbg>show h323
h323 rtp_tos = 8
h323 ras_tos = 4
h323 fast_start = off
h323 t38 = off
h323 keepalive_to_gk = on
h323 keepalive_interval = 5
1
2
3
4
ggdbg>spy hsmu 0
ggdbg>000022145 HSMU: Enter call_profile->capabilities
000022145 HSMU: Coding Profile Bit 6 ignored, no 'voice' usage.
000022145 HSMU: Exit call_profile->capabilities.
000022145 HSMU 3: Process outgoing H.323 call.
000022145 Dialing DEST = TEL:89286303486 (using GateKeeper)
000022145 SOURCE = NAME:DEFAULT_H323_ID,TEL:4
000022145 USER_TO_USER = CID_NAME:tcid3, CID_NUM:4 SETUP
000022145 HSMU 3: set timer for 50000 in state hsmup_state_h225_wait_alerting
000022261 HSMU 3: abort timer in state hsmup_state_h225_wait_alerting
000022261 HSMU 3: H.323 release (IF)
000022315 HSMU 3: voice rtp open=0, rtcp open=0, nw_close(voice socked RTP0, RTC
P0)
000022315 HSMU 3: nw_close(inchan local RTCP65535, RTP65535)
000022315 HSMU 3: nw_close(outchan local RTCP65535)
СообщениеДобавлено: Вт апр 12, 2005 16:17
IP-PBX member
в destination table прописан адрес ГК как например на этом рисунке???
http://www.ksv.ru/Hardware/D-Link/DG-102SH/PIC/5.png
Даешь связистов без брака!
AB4790-RIPE
СообщениеДобавлено: Вт апр 12, 2005 16:18
IP-PBX member
фаст старт я бы наоборот включил
у меня через full proxy gnugk без проблем работает.
AB4790-RIPE
СообщениеДобавлено: Ср апр 13, 2005 12:51
Прописал,
не помогло.
Еще один момент: звонки изредка проходят нормально, причем совершенно безсистемно, звонок то проходит нормально, то нет.
СообщениеДобавлено: Ср апр 13, 2005 14:40
IP-PBX member
прописаны ли номера и имена на tcid?
AB4790-RIPE
