Текущее время: Чт окт 22, 2026 11:23
СообщениеДобавлено: Чт сен 03, 2009 05:03
Помогите пожалуйста, что делать!
Проблема следующая:
Не могу попасть через гипертерминал на DSLAM rev. B1. До этого стояла на нем прошивка R2.44
Подключаюсь консольником- устройство не обнаруживается, пока его не влючишь/выключишь. Потом проходит загрузка и на фазе инициализации зависает.
Listing:
DSLAM Bootloader
Bootloader Release: R2.1n_4M Date: Jul 21 2008
Initializing IPDSLAM Memories............. Success
Press F1 to enter Interactive Mode, 'Enter' to skip .... 5 seconds left
Press i to force upgrade image, 'Enter' to skip .... 5 seconds left
Transfering Control to BootTftp binary
Flash Present In System.......
MANUF skip tftping
All the files are in Flash, No TFTP required
Mxu shall come up in normal mode
All the files have been successfully received.....
Active copy of Ctrl Plane Bin was found in flash
Unzipping the Control Plane....................................................
Transferring Control to Ctrl Plane Binary...
Free Memory available in SDRAM-A is 0xa71b8
System coming up in normal mode...
Locking Control Plane Text Start: 0x4923000 End: 0x4f7e868
FlashPresent = 1
u8ColumbiaIdSel = 18
u32FlashSize = 4194304
PCB Board version: 40
total memory Free in SDRAM A = 684472
Allocatiing System Memory fom SDRAM-E
total memory Free in SDRAM E = 196608
total memory Free in SDRAM D = 0
total memory Free in SDRAM B = 316468
Flash scanning in progress
CdbNvm:- Configuration Size is 1939236
CdbNvm:- NVM CFG1 size 262032
CdbNvm:- Device not Opened before Ioctl
The uncompress location for data plane is 0x400b000
Cin:- DataPlane present in NVRAM
Cin- Uncompressing Dataplane
Uncompressing "DP.bin.gz" (384665->840232) ...... Done
Locking Text Area DP Text Start: 0x4818000 CP Text End : 0x4f7e868
CfgInit: System Coming up from Default Configuration
Initializing DataPlane
DataPlane Initialized successfully
Cin:- Factory Default File received from NVRAM
The DSL binary file to be opened is dsl_10_330000003C00000D.bin.gz
The DSL bin size is 265892
Loading The system.....
Loading system over.....
Initializing system.....
Пробовал перепрошить - выбираю: F1, i, y и виснет....
Listing:
DSLAM Bootloader
Press 'P/p' to perform POST, 'Enter' to skip .... 5 seconds left
POST not performed..................Continuing
Press y to confirm the upgrade operation, 'Enter' to skip .... 5 seconds left
Primary Ethernet Interface for TFTP :- eth-0
Secondary Ethernet Interface for TFTP :- eth-1
Кнопкой RESET в дефаулт тоже не скидывается :(
P.S: настройки гиперки- как и рекомендуется: 9600 и т.д
СообщениеДобавлено: Чт сен 03, 2009 09:42
Здравствуйте,
Если на DSLAM стояла прошивка 2.44 - до какой версии Вы хотите обновить устройство?
2.44 - это последний официальный релиз для DAS3 rev.B
Новее пока ничего нет.
С уважением, Давыдов Денис.
СообщениеДобавлено: Пт сен 04, 2009 08:20
Davydov Denis писал(а):
Здравствуйте,
Да я знаю, Денис, что это последняя.
Но проблема в том, что я вообще не могу никаким образом попасть на DSLAM. Гиперка виснет в процессе загрузки, а reset не работает (в дефаулт не могу скинуть)
СообщениеДобавлено: Пт сен 04, 2009 08:41
А, и еще:
Я тут посмотрел соседнюю темку viewtopic.php?t=97729&postdays=0&postorder=asc&start=0 там вроде симптомы схожи с моими. Так вот, у меня диод ERROR тоже горит, правда зеленым светом...
СообщениеДобавлено: Пт сен 04, 2009 09:18
De[Vol]S>ys™ писал(а):
А, и еще:
Здравствуйте,
Обратитесь в наше представительство в Иркутске.
