Текущее время: Вт сен 15, 2026 06:26
Начать новую тему Ответить на тему  [ Сообщений: 39 ]  На страницу Пред.  1, 2, 3  След.
 Заголовок сообщения: трабла
СообщениеДобавлено: Сб апр 02, 2005 10:30
Sat Nov 06 04:39:32 2004 : STATUS ALARM : PPP Interface Up : Interface - ppp-0
Sat Nov 06 04:39:32 2004 : STATUS ALARM: PPP Event: NCP Got secondary DNS address: 195.34.32.116
Sat Nov 06 04:39:32 2004 : STATUS ALARM: PPP Event: NCP Got primary DNS address: 212.188.4.10
Sat Nov 06 04:39:32 2004 : STATUS ALARM: PPP Event: NCP Got IP address: 83.237.102.30
Sat Nov 06 04:39:32 2004 : STATUS ALARM: PPP Authorization Successful : Interface - ppp-0
Sat Nov 06 04:39:32 2004 : STATUS ALARM: PPP Event: CHAP Authentication Sucessful
Sat Nov 06 04:39:31 2004 : STATUS ALARM: PPP Event: LCP: Config Req packet Received.
Sat Nov 06 04:39:31 2004 : STATUS ALARM: PPP Event: LCP: Sending Config Req.
Sat Nov 06 04:39:31 2004 : STATUS ALARM: PPPoE Event: Receive PADS Packet
Sat Nov 06 04:39:31 2004 : STATUS ALARM : PPPoE Up : Interface - ppp-0
Sat Nov 06 04:39:31 2004 : STATUS ALARM: PPPoE Event: Receive PADO Packet
Sat Nov 06 04:39:31 2004 : STATUS ALARM: PPPoE Event: Send PADR Packet
Sat Nov 06 04:39:31 2004 : STATUS ALARM: PPPoE Event: Send PADI Packet
Sat Nov 06 04:39:31 2004 : STATUS ALARM: PPPoE Event: Send PADT Packet
Sat Nov 06 04:06:54 2004 : STATUS ALARM: PPPoE Event: Send PADT Packet
Sat Nov 06 04:06:54 2004 : MAJOR ALARM : Failed To Get IP Address : Interface - ppp-0
Sat Nov 06 04:06:54 2004 : WARNING : PPP Authorization Failed : Interface - ppp-0
Sat Nov 06 04:06:54 2004 : STATUS ALARM: PPP Event: LCP: Sending Terminate Ack.
Sat Nov 06 04:06:54 2004 : STATUS ALARM: PPP Event: LCP: Terminate Req received.
Sat Nov 06 04:06:54 2004 : STATUS ALARM: PPP Event: LCP: Sending Terminate Req.
Sat Nov 06 04:06:54 2004 : STATUS ALARM: PPP Event: CHAP Authentication Fail
Sat Nov 06 04:06:52 2004 : STATUS ALARM: PPP Event: LCP: Config Req packet Received.
Sat Nov 06 04:06:52 2004 : STATUS ALARM: PPP Event: LCP: Sending Config Req.
Sat Nov 06 04:06:52 2004 : STATUS ALARM: PPPoE Event: Receive PADS Packet
Sat Nov 06 04:06:52 2004 : STATUS ALARM : PPPoE Up : Interface - ppp-0
Sat Nov 06 04:06:51 2004 : STATUS ALARM: PPPoE Event: Receive PADO Packet
Sat Nov 06 04:06:51 2004 : STATUS ALARM: PPPoE Event: Send PADR Packet
Sat Nov 06 04:06:51 2004 : STATUS ALARM: PPPoE Event: Send PADI Packet
Sat Nov 06 04:06:51 2004 : STATUS ALARM: PPPoE Event: Send PADT Packet
Sat Nov 06 04:06:51 2004 : WARNING : PPP Interface Down : Interface - ppp-0
Sat Nov 06 04:06:51 2004 : STATUS ALARM: PPP Event: LCP: Sending Terminate Ack.
Sat Nov 06 04:06:51 2004 : STATUS ALARM: PPP Event: LCP: Terminate Req received.
Fri Nov 05 04:06:50 2004 : STATUS ALARM : PPP Interface Up : Interface - ppp-0
Fri Nov 05 04:06:50 2004 : STATUS ALARM: PPP Event: NCP Got secondary DNS address: 195.34.32.116
Fri Nov 05 04:06:50 2004 : STATUS ALARM: PPP Event: NCP Got primary DNS address: 212.188.4.10
Fri Nov 05 04:06:50 2004 : STATUS ALARM: PPP Event: NCP Got IP address: 83.237.102.34
Fri Nov 05 04:06:50 2004 : STATUS ALARM: PPP Authorization Successful : Interface - ppp-0
Fri Nov 05 04:06:50 2004 : STATUS ALARM: PPP Event: CHAP Authentication Sucessful
Fri Nov 05 04:06:50 2004 : STATUS ALARM: PPP Event: LCP: Config Req packet Received.
Fri Nov 05 04:06:50 2004 : STATUS ALARM: PPP Event: LCP: Sending Config Req.
Fri Nov 05 04:06:50 2004 : STATUS ALARM: PPPoE Event: Receive PADS Packet
Fri Nov 05 04:06:50 2004 : STATUS ALARM : PPPoE Up : Interface - ppp-0
Fri Nov 05 04:06:50 2004 : STATUS ALARM: PPPoE Event: Receive PADO Packet
Fri Nov 05 04:06:50 2004 : STATUS ALARM: PPPoE Event: Send PADR Packet
Fri Nov 05 04:06:50 2004 : STATUS ALARM: PPPoE Event: Send PADI Packet
Fri Nov 05 04:06:50 2004 : STATUS ALARM: PPPoE Event: Send PADT Packet
Fri Nov 05 04:04:30 2004 : STATUS ALARM: PPPoE Event: Send PADT Packet
Fri Nov 05 04:04:30 2004 : MAJOR ALARM : Failed To Get IP Address : Interface - ppp-0
Fri Nov 05 04:04:30 2004 : WARNING : PPP Interface Down : Interface - ppp-0
Fri Nov 05 04:04:30 2004 : WARNING : PPP Authorization Failed : Interface - ppp-0
Fri Nov 05 04:04:30 2004 : STATUS ALARM: PPP Event: LCP: Sending Terminate Ack.
Fri Nov 05 04:04:30 2004 : STATUS ALARM: PPP Event: LCP: Terminate Req received.
Fri Nov 05 04:04:30 2004 : STATUS ALARM: PPP Event: LCP: Sending Terminate Req.
Fri Nov 05 04:04:30 2004 : STATUS ALARM: PPP Event: CHAP Authentication Fail
Fri Nov 05 04:04:30 2004 : STATUS ALARM: PPP Event: LCP: Config Req packet Received.
Fri Nov 05 04:04:30 2004 : STATUS ALARM: PPP Event: LCP: Sending Config Req.
Fri Nov 05 04:04:30 2004 : STATUS ALARM: PPPoE Event: Receive PADS Packet
Fri Nov 05 04:04:30 2004 : STATUS ALARM : PPPoE Up : Interface - ppp-0
Fri Nov 05 04:04:30 2004 : STATUS ALARM: PPPoE Event: Receive PADO Packet
Fri Nov 05 04:04:30 2004 : STATUS ALARM: PPPoE Event: Send PADR Packet
Fri Nov 05 04:04:30 2004 : STATUS ALARM: PPPoE Event: Send PADI Packet
Fri Nov 05 04:04:29 2004 : STATUS ALARM : ATM VC Up : Interface - aal5-0, PortId=7, Vpi=1, Vci=50
Fri Nov 05 04:04:29 2004 : STATUS ALARM: PPPoE Event: Send PADI Packet
Fri Nov 05 04:04:29 2004 : STATUS ALARM: PPPoE Event: Send PADT Packet
Fri Nov 05 04:04:29 2004 : STATUS ALARM : ATM Interface Up : Interface - atm-0
Fri Nov 05 04:04:29 2004 : STATUS ALARM : DSL Interface Up
Fri Nov 05 04:01:16 2004 : WARNING : ATM VC Down : Interface - aal5-0, PortId=7, Vpi=1, Vci=50
Fri Nov 05 04:01:16 2004 : WARNING : PPPoE Down : Interface - ppp-0
Fri Nov 05 04:01:16 2004 : WARNING : PPP Interface Down : Interface - ppp-0
Fri Nov 05 04:01:16 2004 : STATUS ALARM: PPP Event: LCP: Sending Terminate Req.
Fri Nov 05 04:01:16 2004 : STATUS ALARM: PPPoE Event: Send PADT Packet
Fri Nov 05 04:01:16 2004 : MAJOR ALARM : ATM Interface Down : Interface - atm-0
Fri Nov 05 04:01:16 2004 : MAJOR ALARM : DSL Interface Down
Thu Nov 04 17:19:32 2004 : STATUS ALARM : PPP Interface Up : Interface - ppp-0
Thu Nov 04 17:19:32 2004 : STATUS ALARM: PPP Event: NCP Got secondary DNS address: 195.34.32.116
Thu Nov 04 17:19:32 2004 : STATUS ALARM: PPP Event: NCP Got primary DNS address: 212.188.4.10
Thu Nov 04 17:19:32 2004 : STATUS ALARM: PPP Event: NCP Got IP address: 83.237.102.32
Thu Nov 04 17:19:32 2004 : STATUS ALARM: PPP Authorization Successful : Interface - ppp-0
Thu Nov 04 17:19:32 2004 : STATUS ALARM: PPP Event: CHAP Authentication Sucessful
Thu Nov 04 17:19:32 2004 : STATUS ALARM: PPP Event: LCP: Config Req packet Received.
Thu Nov 04 17:19:32 2004 : STATUS ALARM: PPP Event: LCP: Sending Config Req.
Thu Nov 04 17:19:32 2004 : STATUS ALARM: PPPoE Event: Receive PADS Packet
Thu Nov 04 17:19:32 2004 : STATUS ALARM : PPPoE Up : Interface - ppp-0
Thu Nov 04 17:19:32 2004 : STATUS ALARM: PPPoE Event: Receive PADO Packet
Thu Nov 04 17:19:32 2004 : STATUS ALARM: PPPoE Event: Send PADR Packet
Thu Nov 04 17:19:32 2004 : STATUS ALARM: PPPoE Event: Send PADI Packet
Thu Nov 04 17:19:32 2004 : STATUS ALARM: PPPoE Event: Send PADT Packet
Thu Nov 04 16:52:44 2004 : STATUS ALARM: PPPoE Event: Send PADT Packet
Thu Nov 04 16:52:44 2004 : MAJOR ALARM : Failed To Get IP Address : Interface - ppp-0
Thu Nov 04 16:52:44 2004 : WARNING : PPP Authorization Failed : Interface - ppp-0
Thu Nov 04 16:52:44 2004 : STATUS ALARM: PPP Event: LCP: Sending Terminate Ack.
Thu Nov 04 16:52:44 2004 : STATUS ALARM: PPP Event: LCP: Terminate Req received.
Thu Nov 04 16:52:44 2004 : STATUS ALARM: PPP Event: LCP: Sending Terminate Req.
Thu Nov 04 16:52:44 2004 : STATUS ALARM: PPP Event: CHAP Authentication Fail
Thu Nov 04 16:52:44 2004 : STATUS ALARM: PPP Event: LCP: Config Req packet Received.
Thu Nov 04 16:52:44 2004 : STATUS ALARM: PPP Event: LCP: Sending Config Req.
Thu Nov 04 16:52:44 2004 : STATUS ALARM: PPPoE Event: Receive PADS Packet
Thu Nov 04 16:52:44 2004 : STATUS ALARM : PPPoE Up : Interface - ppp-0
Имеем DSL-500G h/w C1 f/w B15 + стрим 1024/256. Отваливается раз-два в сутки. Сам не поднимается.
Welcome to Titanium
D-Link Corp., Software Release R2.01.B15(021206a/T93.3.44)
Copyright (c) 2001-2002 by D-Link Corp.
login: ____
password:
Login Successful
$get ppp global
PPP Inactivity Timeout : 0          Ignore WAN to LAN traffic : False
$modify ppp global ?
Parameter                         Description
[ pppsesstimer <decvalue> ]        PPP session timer (min)
[ ignorewantolan true|false ]      Ignore WAN to LAN traffic for PPP timer
$modify ppp global
А где, собсна maxlcpecho???? Вообще что бы сделать, чтобы стало удобнее?
СообщениеДобавлено: Сб апр 02, 2005 18:41
Выбираете, что лично Вам ближе и нужнее :-))):
а) если нужна надёжная работа осла, но готовы потерпеть отваливание сессий - тогда оставайтесь на прошивке B15. Подвисание сессий на ней не лечится.
б) если готовы к некоторому падению производительности осла (или, по крайней мере, к некоторому геморрою по оптимизации), но вопрос сессий важен - прошиваете B9 (она, как ни странно, новее B15) и устанавливаете maxlcpecho (в B15 такого параметра нет) больше, чем в 1.
Успехов!
Виктор Денисов aka Plukh
СообщениеДобавлено: Сб апр 02, 2005 22:49
Ребят, а как быть с 500T? Как сделать так, чтоб при загруженном канале сессии не рвались? :o
СообщениеДобавлено: Сб апр 02, 2005 23:24
Успехов!
Что есть осел и о какой оптимизации идет речь?
СообщениеДобавлено: Вс апр 03, 2005 01:09
Осёл - он же eMule. Клиент для файлообменной сети ED2K, доступный здесь. Как и большинство p2p-приложений, он оказывает большую нагрузку на домашние маршрутизаторы, особенно нижнего ценового диапазона, такие как DLink и ему подобные. Соответственно, есть мнение, что прошивка B9, по каким-то непонятным причинам, хуже работает с ослом, чем B15. Поскольку Стрим так и так раз в сутки рвёт связь, то многие используют B15, заранее зная, что раз в сутки надо будет его отребутить. Хотя я, к примеру, после некоторого "тюнинга" заставил осла нормально работать и с B9 - по крайней мере, нормально для своих требований ;-).
СообщениеДобавлено: Вс апр 03, 2005 18:27
У меня с новой прошивкой сплошные проблемы. Достаточно отметить периодическое зависание модема, чего с другими прошивками не было ни разу.
По сему остался на прошивке B15, и приходится раз в сутки перезагружать модем.
СообщениеДобавлено: Вт апр 05, 2005 20:34
я подумал и решил оставить B15. а d-link, я полагаю прошивку исправить желанием не горит :?
СообщениеДобавлено: Ср апр 06, 2005 10:02
Позвольте, исправлять что?
СообщениеДобавлено: Ср апр 06, 2005 13:49
Исправить то, чтобы в B15 корректно работали режимы постоянного и on-demand pppoe при роутинге со стримом. on-demand - вообще не работает :(
Если прошивка B9 новее B15 и вы рекомендруете ставить именно ее, то об этом следует написать где-нибудь, потому что для меня не логично что 9 больше 15, для вас, надеюсь, тоже.
СообщениеДобавлено: Ср апр 06, 2005 15:56
B9 - это исправление всех ошибок всех предыдущих прошивок.
B15 - вообще очень старая прошивка.
 Заголовок сообщения: Это не проблема прошивки
СообщениеДобавлено: Ср апр 06, 2005 16:49
Это сто пудов не проблема прошивки. (я имею ввиду вообще тему топика)
У меня эта проблема началась тоглько тогда, когда я перешёл на нео 25. т.е. ровно 1-го апреля.
Звонил в суппорт мту, там сказали что мой модем почему-то постоянно пытается разорвать соединение. Но не сказали почему. Надо их помучать ещё немного, и тогда может быть они решат как исправить эту ошибку.
 Заголовок сообщения: Re: Это не проблема прошивки
СообщениеДобавлено: Ср апр 06, 2005 20:21
Такая же пробла, после того, как перешёл на Нео25, стал переодически обрывать сессии. Потом вообще срывал, что я даже в Инет зайти не мог. В общем, как всегда, МТУшника несли чушь по мопеду и по моей линии, но после того, как я третий раз позвонил и потребовал, чтоб они вручную у себя выставили модуляцию T1413 на моём канале, конект стал нормальным. Те главное позвонить им и попросить грамотного оператора - спеца :) Удачи. 8)
СообщениеДобавлено: Ср апр 06, 2005 20:31
Vendor ID: 0039
Revision Number: T93.3.44
Serial Number:
Local Tx Power: 11.12 dB
Remote Tx Power: 14.18 dB
Local Line Atten.: 26.0 dB
Remote Line Atten.: 7.0 dB
Local SNR Margin: 42.0 dB
Remote SNR Margin: 31.0 dB
Self Test: Passed
DSL Standard: T1.413
Trellis Coding: Enable
Framing Structure: Framing-3
У меня вот эти параметры. Визуально вроде бы что-то изменилось с того времени как всё нормально было, но что не могу понять.
Прокоментируйте плиз. Может какой-нить теллис кодинг отключть надо? или frame structure?
СообщениеДобавлено: Чт апр 07, 2005 14:59
ИМХО это не связанно с тарифом. (я не менял тариф и происходит тоже самое).
сейчас поставил f/w B9 и maxlcpecho=5 - посмотрю что будет.
СообщениеДобавлено: Пн апр 11, 2005 12:00
Господа, скажите пожалуйста у кого какая модуляция стоит. Я точно не помню, но они по-мойму изменили модуляцию мне и из за этого стало глючить. Раньше у меня была G.dmt, а сейчас T1413 или как её там!
PS: А какой командой поставить время на модеме, чтобы он у меня 1970 год не показывал?
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 82
