Текущее время: Ср сен 30, 2026 13:24
СообщениеДобавлено: Ср авг 26, 2009 16:05
Добрый день,
Уже перепробовал много вариантов, но выдача нужного IP с привязкой к порту комутатора DES-3526 так и не заработала.
Вот лог DHCP сервера:
DHCPDISCOVER from 12:12:12:12:12:12 via vlan601: network test: no free leases
Lease for 10.80.70.241 is connected to interface0/2 (add 1 to port number!), VLAN 601 on switch 0:1c:f0:17:ae:dc
Lease for 10.80.70.241 raw option-82 info is CID: 0.4.2.89.0.2 AID: 1.6.0.1c.f0.17.ae.dc port: 2;
DHCPOFFER on 10.80.70.241 to 12:12:12:12:12:12 (COMP) via vlan601
DHCPREQUEST for 10.80.70.241 (10.80.70.1) from 12:12:12:12:12:12 via vlan601: lease 10.80.70.241 unavailable.
DHCPNAK on 10.80.70.241 to 12:12:12:12:12:12 via vlan601
Конфиг isc-dhcp:
lease-file-name "/var/db/dhcpd/dhcpd.leases";
default-lease-time 600;
max-lease-time 7200;
authoritative;
ddns-update-style none;
log-facility local7;
class "port-2"
match if binary-to-ascii (10, 8, "", suffix( option agent.circuit-id, 1)) = "2";
shared-network test {
subnet 10.80.70.0 netmask 255.255.255.0 {
pool { range 10.80.70.241; allow members of "port-2";
if exists agent.circuit-id
log ( info, concat( "Lease for ", binary-to-ascii (10, 8, ".", leased-address), " is connected to interface", binary-to-ascii (10, 8, "/", suffix ( option agent.circuit-id, 2)), " (add 1 to port number!), VLAN ", binary-to-ascii (10, 16, "", substring( option agent.circuit-id, 2, 2)), " on switch ", binary-to-ascii(16, 8, ":", substring( option agent.remote-id, 2, 6))));
log ( info, concat( "Lease for ", binary-to-ascii (10, 8, ".", leased-address), " raw option-82 info is CID: ", binary-to-ascii (10, 8, ".", option agent.circuit-id), " AID: ", binary-to-ascii(16, 8, ".", option agent.remote-id), " port: ", binary-to-ascii (10, 8, "", suffix( option agent.circuit-id, 1)), ";"));
Помогите плз, а то не знаю уже куда копать, в гугле встречал аналогичные проблемы, но конкретных ответов так и не увидел.
СообщениеДобавлено: Ср авг 26, 2009 16:25
версия прошивки?
куски кофига отвечающие за дхцп и вланы в студию
СообщениеДобавлено: Ср авг 26, 2009 16:36
Firmware: 5.01.B52
# IPBIND
config address_binding ip_mac ports 1-2 state enable
config address_binding ip_mac ports 1-2 allow_zeroip enable
disable address_binding acl_mode
disable address_binding trap_log
enable address_binding dhcp_snoop
config address_binding dhcp_snoop max_entry ports 1-26 limit 5
# VLAN
disable asymmetric_vlan
config vlan default delete 1-26
config vlan default add untagged 3-26
config vlan default add forbidden 1-2
config vlan default advertisement enable
create vlan test tag 601
config vlan test add tagged 25
config vlan test add untagged 1-2
config vlan test advertisement disable
disable gvrp
config gvrp 1-2 state disable ingress_checking enable acceptable_frame admit_all pvid 601
config gvrp 3-26 state disable ingress_checking enable acceptable_frame admit_all pvid 1
enable dhcp_relay
config dhcp_relay hops 4 time 90
config dhcp_relay option_82 state enable
config dhcp_relay option_82 check disable
config dhcp_relay option_82 policy keep
config dhcp_relay option_82 remote_id default
config dhcp_relay option_60 state disable
config dhcp_relay option_60 default mode drop
config dhcp_relay option_61 state disable
config dhcp_relay option_61 default drop
# DHCP_LOCAL_RELAY
enable dhcp_local_relay
config dhcp_local_relay vlan vlanid 601 state enable
СообщениеДобавлено: Ср авг 26, 2009 16:50
Либо
либо
Вы определитесь, это избыточная настройка.
И не для всех подходит настройка:
лучше
config dhcp_relay hops 4 time 0
И если Вы используете DHCP Relay, то где настройка для сервера DHCP!?
Бигаров Руслан.
СообщениеДобавлено: Ср авг 26, 2009 17:07
Bigarov Ruslan писал(а):
Либо
либо
Если отключаю опцию dhcp_local_relay или убираю vlan, то не приходит option82.
лучше
спс, поменял.
свитч используется как DHCP relay, а в качестве dhcp сервера - isc-dhcp, конфиг привел в самом первом посту.
СообщениеДобавлено: Ср авг 26, 2009 17:20
config dhcp_relay add ipif System <ipaddr DHCP Server>
Бигаров Руслан.
СообщениеДобавлено: Чт авг 27, 2009 08:31
Выключаю dhcp_local_relay, добавляю IP dhcp сервера, option82 не приходит, смотрел через tcpdump.
вот конфиг dhcp со свича:
# DHCP_RELAY
enable dhcp_relay
config dhcp_relay add ipif System 10.80.70.1
# DHCP_LOCAL_RELAY
disable dhcp_local_relay
cхема:
<comp>---untag-vlan601---<des3526>---trunk-tag-vlan601---<dhcpserver>
management - vlan1.
СообщениеДобавлено: Чт авг 27, 2009 09:22
При использовании dhcp_relay клиент и сервер должны быть в разных виланах.
Если Вы хотите чтобы они находились в одном вилане, то отключите dhcp_relay и включите dhcp_local_relay.
Вся настройка в этом случае будет выглядеть так:
disable dhcp_relay
config dhcp_local_relay vlan 601 state enable
Последний раз редактировалось Alexandr Zaitsev Чт авг 27, 2009 09:23, всего редактировалось 1 раз.
СообщениеДобавлено: Чт авг 27, 2009 09:23
проверь видно ли вообще dhcp сервер со свитча, пинг в помощь. (дада, у свитча есть команда пинг 8))
2Александр - Ну по всей видимости они в разных, раз он указал внизу про влан1
правда я не уверен что влан 1 доходит до дхцп :)
и кстате где DHCP FORWARD в # IPBIND у порта клиента ? :)
СообщениеДобавлено: Чт авг 27, 2009 09:43
Ipif System пингует DHCP Server?
Бигаров Руслан.
СообщениеДобавлено: Чт авг 27, 2009 09:45
disable dhcp_relay
Сделал как вы сказали, option82 приходит.
но проблема в самом первом посту так и осталась.
СообщениеДобавлено: Чт авг 27, 2009 10:00
ipif (10.90.90.90) не видит dhcp сервер, т.к. vlan1 & vlan601 приходят на 2 разных сервера.
сам сервер видит dhcp запросы, отвечает, но когда привязываешь запросы абонента к порту свича - ошибка, no free lease.
СообщениеДобавлено: Чт авг 27, 2009 15:41
Слушатель
Проблема в том, что dhcp сервер не может правильно обработать опцию 82?
Посмотрите на nag.ru, там приводились примеры как правильно настроить isc-dhcpd
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 73
