Текущее время: Ср апр 08, 2026 10:57
СообщениеДобавлено: Сб авг 01, 2009 12:53
Пытаюсь поднять впн поверх MER
Все настройки правильные. Помогите плз понять в чём проблема:
Jan 1 00:01:21     daemon     notice     pppd[955]: pppd 2.4.4 started by admin, uid 0
Jan 1 00:01:21    daemon    info    pppd[955]: Using interface ppp0
Jan 1 00:01:21    daemon    notice    pppd[955]: Connect: ppp0 <--> /dev/ttyp0
Jan 1 00:01:21    daemon    notice    pptp[960]: anon log[main:pptp.c:276]: The synchronous pptp option is NOT activated
Jan 1 00:01:21    daemon    notice    pptp[962]: anon log[ctrlp_rep:pptp_ctrl.c:251]: Sent control packet type is 1 'Start-Control-Connection-Request'
Jan 1 00:01:21    daemon    notice    pptp[962]: anon log[ctrlp_disp:pptp_ctrl.c:738]: Received Start Control Connection Reply
Jan 1 00:01:21    daemon    notice    pptp[962]: anon log[ctrlp_disp:pptp_ctrl.c:772]: Client connection established.
Jan 1 00:01:22    daemon    warn    pppd[955]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
Jan 1 00:01:22    daemon    notice    pptp[962]: anon log[ctrlp_rep:pptp_ctrl.c:251]: Sent control packet type is 7 'Outgoing-Call-Request'
Jan 1 00:01:22    daemon    notice    pptp[962]: anon log[ctrlp_disp:pptp_ctrl.c:857]: Received Outgoing Call Reply.
Jan 1 00:01:22    daemon    notice    pptp[962]: anon log[ctrlp_disp:pptp_ctrl.c:896]: Outgoing call established (call ID 0, peer's call ID 27509).
Jan 1 00:01:42    daemon    notice    pptp[962]: anon log[ctrlp_disp:pptp_ctrl.c:928]: Call disconnect notification received (call id 0)
Jan 1 00:01:42    daemon    notice    pptp[962]: anon log[ctrlp_error:pptp_ctrl.c:199]: Result code is 1 'Lost Carrier'. Error code is 0, Cause code is 256
Jan 1 00:01:42    daemon    notice    pptp[962]: anon log[call_callback:pptp_callmgr.c:78]: Closing connection (call state)
Jan 1 00:01:42    daemon    notice    pptp[962]: anon log[ctrlp_disp:pptp_ctrl.c:787]: Received Stop Control Connection Request.
Jan 1 00:01:42    daemon    notice    pptp[962]: anon log[ctrlp_rep:pptp_ctrl.c:251]: Sent control packet type is 4 'Stop-Control-Connection-Reply'
Jan 1 00:01:42    daemon    notice    pppd[955]: Modem hangup
Jan 1 00:01:42    daemon    notice    pppd[955]: Connection terminated.
СообщениеДобавлено: Сб авг 01, 2009 13:36
С предыдущей прошивкой впн поднимался, но была проблема с дефолтным шлюзом, который оставался прежним.
Jan 1 00:01:21 daemon notice pppd[933]: pppd 2.4.3 started by admin, uid 0
Jan 1 00:01:21 daemon info pppd[933]: Using interface ppp0
Jan 1 00:01:21 daemon notice pppd[933]: Connect: ppp0 <--> /dev/ttyp0
Jan 1 00:01:22 daemon notice pptp[937]: anon log[main:pptp.c:276]: The synchronous pptp option is NOT activated
Jan 1 00:01:22 daemon notice pptp[940]: anon log[ctrlp_rep:pptp_ctrl.c:251]: Sent control packet type is 1 'Start-Control-Connection-Request'
Jan 1 00:01:22 daemon notice pptp[940]: anon log[ctrlp_disp:pptp_ctrl.c:738]: Received Start Control Connection Reply
Jan 1 00:01:22 daemon notice pptp[940]: anon log[ctrlp_disp:pptp_ctrl.c:772]: Client connection established.
Jan 1 00:01:22 daemon warn pppd[933]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
Jan 1 00:01:23 daemon notice pptp[940]: anon log[ctrlp_rep:pptp_ctrl.c:251]: Sent control packet type is 7 'Outgoing-Call-Request'
Jan 1 00:01:23 daemon notice pptp[940]: anon log[ctrlp_disp:pptp_ctrl.c:857]: Received Outgoing Call Reply.
Jan 1 00:01:23 daemon notice pptp[940]: anon log[ctrlp_disp:pptp_ctrl.c:896]: Outgoing call established (call ID 0, peer's call ID 2127).
Jan 1 00:01:23 daemon warn pppd[933]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
Jan 1 00:01:23 daemon info pppd[933]: CHAP authentication succeeded
Jan 1 00:01:23 daemon notice pppd[933]: local IP address 10.128.31.109
Jan 1 00:01:23 daemon notice pppd[933]: remote IP address 93.125.5.137
Jan 1 00:02:23 daemon notice pptp[940]: anon log[logecho:pptp_ctrl.c:676]: Echo Reply received.
СообщениеДобавлено: Вт авг 04, 2009 09:33
Что используется в качестве PPTP-сервера? Используете ли MPPE шифрование?
СообщениеДобавлено: Вт авг 04, 2009 12:15
Настройки, предоставленные провайдером:
Адрес VPN сервера
и
В окне «Дополнительные параметры безопасности» выставляпем:
- Шифрование данных: ставим «необязательное (подключиться даже без шифрования)»;
- Разрешить следующие протоколы: оставляем галку только на «Протоколе проверки пароля (CHAP)». Нажимаем «ОК».
СообщениеДобавлено: Вт авг 18, 2009 10:18
Что за манера не отвечать на вопрос если не знаете ответа? Что здесь, что в "техподдержке регионального офиса". Если поднять впн нельзя - так и скажите. Сплошные уходы от ответа и размусоливание.
СообщениеДобавлено: Вт авг 25, 2009 08:53
Извините за ожидание, был в отпуске. Проблема известна и разработчик занимается её решением. Частично уже есть результат, я выслал Вам по e-mail тестовую версию прошивки.
СообщениеДобавлено: Вт авг 25, 2009 09:52
Спасибо, сегодня вечером опробую :)
СообщениеДобавлено: Чт авг 27, 2009 14:52
Здравствуйте, у меня аналогичная проблема. Можно и мне прислать новую прошивку.
Заранее спасибо
СообщениеДобавлено: Чт авг 27, 2009 16:22
Заранее спасибо
Отправлено.
Когда появится решение проблемы, я сообщу дополнительно в данной теме форума.
СообщениеДобавлено: Пт авг 28, 2009 14:10
Камрады, Pnevmoslon и YuriT, ну как новая прошивка, работает?
Уважаемый Alexander Gorelik, вышлите, please, мне тоже эту прошиву. Я так понимаю, что у меня аналогичная проблема: viewtopic.php?t=108543
СообщениеДобавлено: Пт авг 28, 2009 14:53
Отправлено.
СообщениеДобавлено: Пт авг 28, 2009 19:45
такая же проблема, не поднимает pptp, поделитесь прошивкой, а также напишите её версию. спасибо
СообщениеДобавлено: Пт авг 28, 2009 21:23
а также можно ли использовать принтер xerox workcenter 3119?
какие критерии для принтеров?
СообщениеДобавлено: Сб авг 29, 2009 09:22
мне не помогла. соединение устанавливается, но рвётся через каждые 0.9 минуты
СообщениеДобавлено: Вт сен 01, 2009 16:45
Пытаюсь поднять VPN + Bridge. Ошибка вроде такая же как и у топикстатретра. Можно и мне её выслать?
