Текущее время: Ср ноя 11, 2026 01:11
СообщениеДобавлено: Пн июл 20, 2009 13:44
Помогите поднять VPN Через нат провайдера.
Имеем:
DI-804 c серым IP
(Firmware Version: V1.44, Fri, Nov 24 2006)
DFL - 800 белый IP
Firmware Version: 2.20.01.05-4840
Feb 8 2008
Настройки DI-804
VPN : Enabl
Max.tun: 2
Tunnel Name: gate61
Aggressive Mode: Disable
Local Subnet 192.168.61.0
Local Netmask 255.255.255.0
Remote Subnet 192.168.1.0
Remote Netmask 255.255.255.0
Remote Gateway 83.xxx.xxx.xxx
Preshare Key 1234567890
IPSec NAT Traversal Enable
Auto-reconnect Enable
Remote ID Type IP
Local ID Type IP
IKE Proporsal: Group2, 3DES, MD5, 28800 sec
IPSec Proporsal: DH None, ESP,3des,MD5, 3600 sec
Настройки DFL-800
Local Network: lannet
Remote Network:all-nets
Remote Endpoint: (None)
Encapsulation Mode: Tunnel
IKE Config Mode: None
Algorithms
IKE Algorithms:Medium
IKE Life Time seconds 28880
IPsec Algorithms: Medium
IPsec Life Time seconds 3660
IPsec Life Time kilobytes 0
Authentication
Pre-shared Key:1234567890
Local ID Type: Auto
XAutch: off
Routing
Dynamically add route to the remote network when a tunnel is established
Automatically pick the address of a local interface that corresponds to the local net
Main
DH Group 2
Aggressive off
Perfect Forward Secrecy NONE
Security Association:Per Net
NAT Traversa
On if supported and NATed
Dead Peer Detection off
Automatically add route for remote network: ON
В логах DFL
2009-07-20
14:38:30 Info IPSEC
1802708
ike_sa_destroyed
ike_sa_killed
ike_sa=" Initiator SPI ESP=0x03396744, AH=0xd3c6f9fc, IPComp=0x827a322"
2009-07-20
14:38:30 Warning IPSEC
1802022
ike_sa_failed
no_ike_sa
statusmsg="No proposal chosen" local_peer="83.xxx.xxx.xxx ID No Id" remote_peer="77.66.163.145 ID No Id" initiator_spi="ESP=0x03396744, AH=0xd3c6f9fc, IPComp=0x827a322f"
2009-07-20
1802715
event_on_ike_sa
side=Responder msg="failed" int_severity=6
2009-07-20
1800107
ike_invalid_proposal
local_ip=83.xxx.xxx.xxx remote_ip=77.66.163.145 cookies=03396744d3c6f9fc827a322f9ae7e839 reason="Could not find acceptable proposal"
2009-07-20
14:38:30 Notice IPSEC
1802300
rule_selection_failed
info="Peer IP address mismatch" int_severity=6
2009-07-20
14:38:30 Info IPSEC
1803001
failed_to_select_policy_rule
2009-07-20
1802715
event_on_ike_sa
В логах DI
14:47:45 IKED re-TX : INIT to 83.xxx.xxx.xxx
14:47:45 Receive IKE INFO : 83.xxx.xx.xxx --> 77.66.163.145
14:47:55 IKED re-TX : INIT to 83.xxx.xxx.xxx
14:47:55 Receive IKE INFO : 83.xxx.xxx.xxx --> 77.66.163.145
14:48:15 IKED re-TX : INIT to 83.xxx.xxx.xxx
14:48:15 Receive IKE INFO : 83.xxx.xxx.xxx --> 77.66.163.145
14:48:16 Send IKE (INFO) : delete 77.66.163.145 -> 83.xxx.xxx.xxx phase 1
14:48:16 IKE phase1 (ISAKMP SA) remove : 77.66.163.145 <-> 83.xxx.xxx.xxx
Тунель не понднимается
Что у меня в настройках не так? чего не докрутил?
СообщениеДобавлено: Пн июл 20, 2009 15:57
обновление прошивкм на 804 до Firmware Version: V1.51b10, Fri, Mar 27 2009
не решает проблему
СообщениеДобавлено: Пн июл 20, 2009 16:22
Меня смущает для начала это несоответствие:
На DFL:
На DI-804:
IPSec Proporsal: DH None, ESP,3des,MD5, [b]3600[/b] sec
IKE Proporsal: Group2, 3DES, MD5, [b]28800[/b] sec
И прошивку для DFL обновите до последней 2.25
СообщениеДобавлено: Пн июл 20, 2009 18:44
3600
и
28800
соответственно
СообщениеДобавлено: Пн июл 20, 2009 19:07
прошивку DFL обновил
картина всё таже и так же
СообщениеДобавлено: Пн июл 20, 2009 21:15
А почему на DFL Remote Endpoint: (None) ?
СообщениеДобавлено: Пн июл 20, 2009 21:19
динамический от того и ноне - здесь этот параметр обсуждался где-то ранее
СообщениеДобавлено: Пн июл 20, 2009 21:38
А вы замените его на что-нибудь поприличнее, например all-nets.
А None означает, что второго конца туннеля у вас нет. Вообще.
СообщениеДобавлено: Пн июл 20, 2009 21:42
ага пытаюсь поменять - вот тока после обновления не сохраняет конфигурацию... :( бьюсьтеперь и с этим...
СообщениеДобавлено: Пн июл 20, 2009 23:06
800-тый перепрошил на раннюю версию.
на ди804 заново пересоздал правила.. с нуля...
помогло - стал ругаться на ике кешь.
вылечилось созданием короткого ключа до 8-ми символов.
до этого длина была в 22 символа - не понимали друг друга....
тему закрываем
СообщениеДобавлено: Вт июл 21, 2009 13:35
Во первых при динимическом IPSec Automatically add route for remote network: надо отключать, впротивном случае у вас интерфейс IPSec станет маршрутом по умолчанию.
Во вторых, в DFL есть механизм ikesnoop доступный по ssh или консоли, задействуйте его и приведите вывод сюда.
СообщениеДобавлено: Ср июл 22, 2009 20:45
то что вчера запустилось сегодня в ночь на отрез отказалось работать.
конфигурация не менялась.
всего 3 тунеля. последний динамический.
через некоторое время всё опять восстановилось
запрошенный вывод прилагается
вывод идёт в основном от соединения с di-lb604...с которым вроде всё нормально было
Ike snooping is active; snooping address *
2009-07-22 02:09:23: IkeSnoop: Received IKE packet from 85.175.133.31:500
Exchange type : Informational
Payloads:
HASH (Hash)
D (Delete)
Payloads:
HASH (Hash)
D (Delete)
2009-07-22 02:09:26: IkeSnoop: Received IKE packet from 85.175.133.31:500
Exchange type : Identity Protection (main mode)
Payloads:
SA (Security Association)
2009-07-22 02:09:26: IkeSnoop: Sending IKE packet to 85.175.133.31:500
Payloads:
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
Payloads:
KE (Key Exchange)
NONCE (Nonce)
Payloads:
KE (Key Exchange)
NONCE (Nonce)
Payloads:
ID (Identification)
HASH (Hash)
Payloads:
ID (Identification)
HASH (Hash)
2009-07-22 02:09:27: IkeSnoop: Received IKE packet from 85.175.133.31:500
Exchange type : Quick mode
Payloads:
HASH (Hash)
NONCE (Nonce)
KE (Key Exchange)
ID (Identification)
ID (Identification)
2009-07-22 02:09:27: IkeSnoop: Sending IKE packet to 85.175.133.31:500
Payloads:
HASH (Hash)
NONCE (Nonce)
KE (Key Exchange)
ID (Identification)
ID (Identification)
Payloads:
HASH (Hash)
2009-07-22 02:12:18: IkeSnoop: Received IKE packet from 85.175.133.31:500
Payloads:
HASH (Hash)
D (Delete)
Payloads:
HASH (Hash)
D (Delete)
2009-07-22 02:12:21: IkeSnoop: Received IKE packet from 85.175.133.31:500
Payloads:
2009-07-22 02:12:21: IkeSnoop: Sending IKE packet to 85.175.133.31:500
Payloads:
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
Payloads:
KE (Key Exchange)
NONCE (Nonce)
Payloads:
KE (Key Exchange)
NONCE (Nonce)
Payloads:
ID (Identification)
HASH (Hash)
Payloads:
ID (Identification)
HASH (Hash)
2009-07-22 02:12:22: IkeSnoop: Received IKE packet from 85.175.133.31:500
Payloads:
HASH (Hash)
NONCE (Nonce)
KE (Key Exchange)
ID (Identification)
ID (Identification)
2009-07-22 02:12:22: IkeSnoop: Sending IKE packet to 85.175.133.31:500
Payloads:
HASH (Hash)
NONCE (Nonce)
KE (Key Exchange)
ID (Identification)
ID (Identification)
Payloads:
HASH (Hash)
2009-07-22 02:15:13: IkeSnoop: Received IKE packet from 85.175.133.31:500
Payloads:
HASH (Hash)
D (Delete)
Payloads:
HASH (Hash)
D (Delete)
2009-07-22 02:15:16: IkeSnoop: Received IKE packet from 85.175.133.31:500
Payloads:
2009-07-22 02:15:16: IkeSnoop: Sending IKE packet to 85.175.133.31:500
Payloads:
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
VID (Vendor ID)
Payloads:
KE (Key Exchange)
NONCE (Nonce)
Payloads:
KE (Key Exchange)
NONCE (Nonce)
2009-07-22 02:15:17: IkeSnoop: Received IKE packet from 85.175.133.31:500
Payloads:
ID (Identification)
HASH (Hash)
2009-07-22 02:15:17: IkeSnoop: Sending IKE packet to 85.175.133.31:500
Payloads:
ID (Identification)
HASH (Hash)
Payloads:
HASH (Hash)
NONCE (Nonce)
KE (Key Exchange)
ID (Identification)
ID (Identification)
Payloads:
HASH (Hash)
NONCE (Nonce)
KE (Key Exchange)
ID (Identification)
ID (Identification)
Payloads:
HASH (Hash)
