Текущее время: Ср сен 30, 2026 09:03
 Заголовок сообщения: 3028 untagget vlan на member port
СообщениеДобавлено: Пт июл 17, 2009 10:55
DES-3028:4#sh vlan po 10
Command: show vlan ports 10
Port 10
VLAN ID  Untagged  Tagged  Forbidden  Dynamic
DES-3028:4#sh vlan
Command: show vlan
VID             : 1           VLAN Name       : default
VLAN Type       : Static      Advertisement   : Enabled
Member Ports    : 25
Static Ports    : 25
Current Tagged Ports   :
Current Untagged Ports : 25
Static Tagged Ports    :
Static Untagged Ports  : 25
Forbidden Ports        :
VID             : 362         VLAN Name       : 362
VLAN Type       : Static      Advertisement   : Disabled
Member Ports    : 1-6,8-9,11-28
Static Ports    : 1-6,8-9,11-28
Current Tagged Ports   : 25
Current Untagged Ports : 1-6,8-9,11-24,26-28
Static Tagged Ports    : 25
Static Untagged Ports  : 1-6,8-9,11-24,26-28
Forbidden Ports        :
VID             : 931         VLAN Name       : 931
Member Ports    : 25
Static Ports    : 25
Forbidden Ports        :
VID             : 999         VLAN Name       : 999
Member Ports    : 7,25
Static Ports    : 7,25
Current Untagged Ports : 7
Static Untagged Ports  : 7
Forbidden Ports        :
Total Entries  : 4
DES-3028:4#
DES-3028:4#show igmp_snooping multicast_vlan
Command: show igmp_snooping multicast_vlan
Muticast Vlan Global State : Enabled
VID          : 998     VLAN Name: v998
Member Ports        : 1-24
Tagged Member Ports :
Source Ports        : 25-28
Status       : Enabled
Replace Source IP   : None
DES-3028:4#sh gvrp
Command: show gvrp
Global GVRP  : Disabled
Port    PVID      GVRP     Ingress Checking      Acceptable Frame Type
1       362     Disabled        Enabled          All Frames
2       362     Disabled        Enabled          All Frames
3       362     Disabled        Enabled          All Frames
4       362     Disabled        Enabled          All Frames
5       362     Disabled        Enabled          All Frames
6       362     Disabled        Enabled          All Frames
7       999     Disabled        Enabled          All Frames
8       362     Disabled        Enabled          All Frames
9       362     Disabled        Enabled          All Frames
10      998     Disabled        Enabled          All Frames
11      362     Disabled        Enabled          All Frames
12      362     Disabled        Enabled          All Frames
13      362     Disabled        Enabled          All Frames
14      362     Disabled        Enabled          All Frames
15      362     Disabled        Enabled          All Frames
16      362     Disabled        Enabled          All Frames
17      362     Disabled        Enabled          All Frames
18      362     Disabled        Enabled          All Frames
19      362     Disabled        Enabled          All Frames
20      362     Disabled        Enabled          All Frames
21      362     Disabled        Enabled          All Frames
22      362     Disabled        Enabled          All Frames
23      362     Disabled        Enabled          All Frames
24      362     Disabled        Enabled          All Frames
25      1       Disabled        Enabled          All Frames
26      362     Disabled        Enabled          All Frames
27      362     Disabled        Enabled          All Frames
28      362     Disabled        Enabled          All Frames
Total Entries  : 28
DES-3028:4#conf vlan 362 add untag 10
Command: config vlan 362 add untagged 10
Untagged ports overlapped!
Fail!
DES-3028:4#
помогло только удаление мембер-порта 10 из мультикаст-влана, после чего результативно влан добавил на порт untag .
Boot PROM Version : Build 1.00-B04
Firmware Version : Build 2.30.B04
Hardware Version : A1
Для нас это критичная бага, ибо из биллинга порты "переключаются" в нужные вланы.[/code]
DXS-3400, DES-3200, DES-1210/ME
СообщениеДобавлено: Пт июл 17, 2009 11:05
воспроизвели так:
с 7 порта удалили все вланы, но порт все еще в member
pvid у порта 1
ребутаем свитч
pvid у порта уже почему-то 998
вланов на порту нет
Добавить на порт untag vlan не могу пока не снесу порт из multicast vlan
СообщениеДобавлено: Пт июл 17, 2009 16:45
Выслал Вам прошивку с исправлением
СообщениеДобавлено: Пт июл 17, 2009 17:00
Так и есть.
Оперативно - честно, не ожидал :)
