Текущее время: Чт окт 01, 2026 00:13
 Заголовок сообщения: DGS-3627 snmp не работат.
СообщениеДобавлено: Чт июл 09, 2009 04:20
# SNMPv3
delete snmp community public
delete snmp community private
delete snmp user initial
delete snmp group initial
delete snmp group ReadGroup
delete snmp group WriteGroup
delete snmp view restricted all
delete snmp view CommunityView all
config snmp engineID 800000ab03001e58d62c00
create snmp view restricted 1.3.6.1.2.1.1 view_type included
create snmp view restricted 1.3.6.1.2.1.11 view_type included
create snmp view restricted 1.3.6.1.6.3.10.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.11.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.15.1.1 view_type included
create snmp view CommunityView 1 view_type included
create snmp view CommunityView 1.3.6.1.6.3 view_type excluded
create snmp view CommunityView 1.3.6.1.6.3.1 view_type included
create snmp group public v1 read_view CommunityView notify_view CommunityView
create snmp group public v2c read_view CommunityView notify_view CommunityView
create snmp group initial v3 noauth_nopriv read_view restricted notify_view restricted
create snmp group private v1 read_view CommunityView write_view CommunityView notify_view CommunityV
iew
create snmp group private v2c read_view CommunityView write_view CommunityView notify_view Community
View
create snmp group ReadGroup v1 read_view CommunityView notify_view CommunityView
create snmp group ReadGroup v2c read_view CommunityView notify_view CommunityView
create snmp group WriteGroup v1 read_view CommunityView write_view CommunityView notify_view Communi
tyView
create snmp group WriteGroup v2c read_view CommunityView write_view CommunityView notify_view Commun
ityView
create snmp community private view CommunityView read_write
create snmp community public view CommunityView read_only
create snmp user initial initial
# MANAGEMENT
enable snmp traps
enable snmp authenticate_traps
enable snmp
enable snmp linkchange_traps
config snmp system_name D-Link DGS3627
config snmp system_location Kem
config snmp system_contact 1
disable rmon
config snmp linkchange_traps ports 1-27 enable
Хотя в него воткнуты несколько des3526 и они нормально работают по SNMP.
 Заголовок сообщения: Re: DGS-3627 snmp не работат.
СообщениеДобавлено: Чт июл 09, 2009 09:35
Приведите, пожалуйста, пример команды, которая не работает, а, также, укажите есть ли пинг до коммутатора с компьютера, с которого посылаете эту команду.
СообщениеДобавлено: Чт июл 09, 2009 10:35
monitoring# snmpwalk -v2c -c public 192.168.0.2
Timeout: No Response from 192.168.0.2
ICMP ping есть.
СообщениеДобавлено: Чт июл 09, 2009 10:48
На тестовом стенде с указанными выше настройками работает корректно. Пришлите, пожалуйста, конфигурационный файл устройства с топологией сети мне на почту, я протестирую.
Последний раз редактировалось Denis Evgraphov Пт июл 10, 2009 09:55, всего редактировалось 1 раз.
СообщениеДобавлено: Чт июл 09, 2009 13:35
Та же ситуация, DGS-3627G
СообщениеДобавлено: Чт июл 09, 2009 13:45
А версия прошивки у Вас какая?
СообщениеДобавлено: Чт июл 09, 2009 23:22
Build 2.40-B55
СообщениеДобавлено: Пт июл 10, 2009 09:23
Выслал Вам прошивку, с ней при выше указанной конфигурации на тестовом стенде подтвердить проблему не могу.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 87
