Текущее время: Вт окт 06, 2026 14:40
СообщениеДобавлено: Пт июл 03, 2009 09:49
Необходимо чтобы с сервера DHCP раздавались адреса по VLAN'ам схема примерно следуещего характера
DHCP (ISC-DHCP Vlan default) - DGS-3627G(Vlan default) -- DGS-1216T(Vlan160 1-8 untagged 15 tagged, Vlan170 9, 15 tagged ) -- DGS-1216T (1-14 untagged 15 tagged)
dhcp.conf
option domain-name "lvovka.ru";
option domain-name-servers 192.168.10.2;
authoritative;
default-lease-time 21600;
max-lease-time 72000;
ddns-update-style none;
log-facility local7;
local-address 172.18.0.252;
ignore client-updates;
if exists agent.circuit-id
    log (info, concat ("Lease for ", binary-to-ascii (10, 8, ".", leased-adress)
       ," option-82 info is CID: ", binary-to-ascii (10, 8, ".", option agent.circuit-id)
       ," RID ", binary-to-ascii (16, 8, ":", option agent.remote-id)
       ," MAC ", binary-to-ascii (16, 8, ":", suffix (hardware, 6))
       ," || ", binary-to-ascii (16, 8, ":", substring (hardware, 1, 6))));
class "vlan160"
    match if binary-to-ascii (10, 16, "", substring (option agent.circuit-id, 2, 2)) = "160";
class "vlan170"
    match if ( binary-to-ascii (10, 16, "", substring (option agent.circuit-id, 2, 2))) = "170";
shared-network "lvovka.ru" {
    subnet 172.18.0.0 netmask 255.255.255.0 { not authoritative; }
    subnet 172.18.160.0 netmask 255.255.255.0 {
        option subnet-mask 255.255.255.0;
   option routers 172.18.160.254;
   pool {
       range 172.18.160.1 172.18.160.253;
       allow members of "vlan160";
    subnet 172.18.170.0 netmask 255.255.255.0 {
   option routers 172.18.170.254;
   pool {
       range 172.18.170.1 172.18.170.253;
DGS-3627G
DGS-3627G:5#show vlan
Command: show vlan
VID             : 1          VLAN
VLAN Type       : Static     Advertisement : Enabled
Member Ports    : 16,22-24
Static Ports    : 16,22-24
Current Tagged Ports  : 16
Current Untagged Ports: 22-24
Static Tagged Ports   : 16
Static Untagged Ports : 22-24
Forbidden Ports       :
VID             : 160        VLAN Name     : vlan160
VLAN Type       : Static     Advertisement : Disabled
Member Ports    : 16
Static Ports    : 16
Forbidden Ports       :
VID             : 170        VLAN Name     : vlan170
Member Ports    : 16
Static Ports    : 16
Forbidden Ports       :
DGS-3627G:5#show dhcp_relay
Command: show dhcp_relay
DHCP/Bootp Relay Status         : Enable
DHCP/Bootp Hops Count Limit     : 5
DHCP/Bootp Relay Time Threshold : 0 second(s)
DHCP Relay Agent Information Option 82 State  : Enable
DHCP Relay Agent Information Option 82 Check  : Disabled
DHCP Relay Agent Information Option 82 Policy : Replace
Interface    Server 1        Server 2        Server 3        Server 4
System       172.18.0.252
Суть в том что на DHCP не приходит запрос на получение адреса. DHCP собран с опцией USE_SOCKETS. Если кто может помочь разобраться пишите.
СообщениеДобавлено: Пт июл 03, 2009 10:40
У Вас неправильная настройка DHCP Relay, по вашей настройке получается, что только клиенты подключённые к ipif System(VLAN не знаю, нет вывода "sh ipif"), могут получить динамически настройки от DHCP Server-а(172.18.0.252) и то, если коммутатор имеет связь с ним.
P.S.: Интерфейс ipif System не должен быть задействован ни для чего кроме как для управления коммутатором!
Бигаров Руслан.
СообщениеДобавлено: Пт июл 03, 2009 12:05
Вот вам вывод команды!
Command: show ipif
IP Interface                : eth2
VLAN Name                   : vlan160
Interface Admin state       : Enabled
IPv4 Address                : 172.18.160.254/24 (Manual)  Primary
Proxy ARP                   : Disabled   (Local : Disabled)
IP MTU                      : 1500
IP Interface                : eth3
VLAN Name                   : vlan170
IPv4 Address                : 172.18.170.254/24 (Manual)  Primary
IP MTU                      : 1500
IP Interface                : System
VLAN Name                   : default
IPv4 Address                : 172.18.0.254/24 (Manual)  Primary
IP MTU                      : 1500
 Total Entries   : 3
СообщениеДобавлено: Пт июл 03, 2009 12:19
Все заработало спасибо за ответ)))
СообщениеДобавлено: Пт июл 03, 2009 13:00
Рад слышать.
Бигаров Руслан.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 51
