Текущее время: Вт июн 23, 2026 20:32
 Заголовок сообщения: проблемма с ДНС DSL-2540
СообщениеДобавлено: Ср июн 24, 2009 00:00
Удаленый доступ через интернет работает. Но не могу зайти ни на одну страничку с той машины. Лог модема
BoardID: DSL-2540U
Software Version: RU_1.00
Bootloader (CFE) Version: 1.0.37-12.1
This information reflects the current status of your DSL connection.
Line Rate - Upstream (Kbps): 1021
Line Rate - Downstream (Kbps): 8000
LAN IPv4 Address: 192.168.2.11
MAC Address: 00-21-91-cd-6e-aa
Default Gateway: 83.239.153.35
Primary DNS Server: 83.239.131.8
Secondary DNS Server: 83.239.128.30
Date/Time Facility Severity Message
1st day 00:00:22 user debug kernel: HighMem zone: 0 pages, LIFO batch:1
1st day 00:00:22 user warn kernel: Built 1 zonelists
1st day 00:00:22 user warn kernel: Kernel command line: root=31:0 ro noinitrd console=ttyS0,115200
1st day 00:00:22 user warn kernel: brcm mips: enabling icache and dcache...
1st day 00:00:22 user warn kernel: Primary instruction cache 16kB, physically tagged, 2-way, linesize 16 bytes.
1st day 00:00:22 user warn kernel: Primary data cache 8kB 2-way, linesize 16 bytes.
1st day 00:00:22 user warn kernel: PID hash table entries: 32 (order 5: 256 bytes)
1st day 00:00:22 user warn kernel: Using 120.000 MHz high precision timer.
1st day 00:00:22 user warn kernel: Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
1st day 00:00:22 user warn kernel: Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
1st day 00:00:22 user info kernel: Memory: 5992k/7808k available (1308k kernel code, 1796k reserved, 191k data, 68k init, 0k highmem)
1st day 00:00:22 user warn kernel: KLOB Pool 1 Initialized: 1048576 bytes <0x80600000 ... 0x80700000>
1st day 00:00:22 user warn kernel: Calibrating delay loop... 239.20 BogoMIPS
1st day 00:00:22 user warn kernel: Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
1st day 00:00:22 user warn kernel: Checking for 'wait' instruction... unavailable.
1st day 00:00:22 user info kernel: NET: Registered protocol family 16
1st day 00:00:22 user warn kernel: Total Flash size: 2048K with 35 sectors
1st day 00:00:22 user warn kernel: File system address: 0xbfc10100
1st day 00:00:22 user warn kernel: Blk# BlkOff Blks MemLen Partition Name
1st day 00:00:22 user warn kernel: 0 1408 1 1024 NVRAM
1st day 00:00:22 user warn kernel: 33 40960 1 24576 Config 2
1st day 00:00:22 user warn kernel: 34 32768 1 8192 Scratch PAD
1st day 00:00:22 user warn kernel: 34 40960 1 24576 Config 1
1st day 00:00:22 user warn kernel: Can't analyze prologue code at 801559d4
1st day 00:00:22 user info kernel: PPP generic driver version 2.4.2
1st day 00:00:22 user info kernel: NET: Registered protocol family 24
1st day 00:00:22 user warn kernel: Using noop io scheduler
1st day 00:00:22 user warn kernel: bcm963xx_mtd driver v1.0
1st day 00:00:22 user warn kernel: brcmboard: brcm_board_init entry
1st day 00:00:22 user info kernel: Serial: BCM63XX driver $Revision: 3.00 $
1st day 00:00:22 user warn kernel: ttyS0 at MMIO 0xfffe0300 (irq = 10) is a BCM63XX
1st day 00:00:22 user info kernel: IP: routing cache hash table of 512 buckets, 4Kbytes
1st day 00:00:22 user info kernel: TCP: Hash tables configured (established 512 bind 1024)
1st day 00:00:22 user info kernel: NET: Registered protocol family 17
1st day 00:00:22 user notice kernel: Ebtables v2.0 registered
1st day 00:00:22 user info kernel: NET: Registered protocol family 8
1st day 00:00:22 user info kernel: NET: Registered protocol family 20
1st day 00:00:22 user info kernel: 802.1Q VLAN Support v1.8 Ben Greear
1st day 00:00:22 user info kernel: All bugs added by David S. Miller
1st day 00:00:22 user warn kernel: VFS: Mounted root (squashfs filesystem) readonly.
1st day 00:00:22 user info kernel: Freeing unused kernel memory: 68k freed
1st day 00:00:22 user warn kernel: Algorithmics/MIPS FPU Emulator v1.5
1st day 00:00:22 user warn kernel: atmapi: module license 'Proprietary' taints kernel.
1st day 00:00:22 user warn kernel: adsl: adsl_init entry
1st day 00:00:22 user warn kernel: blaadd: blaa_detect entry
1st day 00:00:22 user info kernel: Broadcom BCMPROCFS v1.0 initialized
1st day 00:00:22 user warn kernel: Broadcom BCM6338A2 Ethernet Network Device v0.3 Aug 6 2008 03:45:55
1st day 00:00:22 user warn kernel: Config Ethernet Switch Through MDIO Pseudo PHY Interface
1st day 00:00:22 user warn kernel: ethsw: found bcm5325e!
1st day 00:00:22 user warn kernel: dgasp: kerSysRegisterDyingGaspHandler: eth0 registered
1st day 00:00:22 user warn kernel: eth0: MAC Address: 00:21:91:CD:6E:AA
1st day 00:00:22 user warn kernel: BcmAdsl_Initialize=0xC00643E8, g_pFnNotifyCallback=0xC007EFE4
1st day 00:00:22 user warn kernel: AnnexCParam=0x7FFF7EB8 AnnexAParam=0x00000980 adsl2=0x00000000
1st day 00:00:22 user warn kernel: pSdramPHY=0xA07FFFF8, 0x1B7745 0xDEADBEEF
1st day 00:00:22 user crit kernel: eth0 Link UP.
1st day 00:00:22 user warn kernel: AdslCoreHwReset: AdslOemDataAddr = 0xA07FBB64
1st day 00:00:22 user warn kernel: dgasp: kerSysRegisterDyingGaspHandler: dsl0 registered
1st day 00:00:22 user warn kernel: ATM proc init !!!
1st day 00:00:22 user warn kernel: ip_tables: (C) 2000-2002 Netfilter core team
1st day 00:00:22 user warn kernel: ip_conntrack version 2.1 (61 buckets, 0 max) - 384 bytes per conntrack
1st day 00:00:22 user warn kernel: ip_ct_h323: init success
1st day 00:00:22 user warn kernel: ip_nat_h323: init success
1st day 00:00:22 user warn kernel: BRCM NAT Caching v1.0 Nov 20 2007 10:22:27
1st day 00:00:22 user warn kernel: BRCM NAT Cache: Hooking hit function @ c005d088
1st day 00:00:22 user warn kernel: ip_conntrack_rtsp v0.01 loading
1st day 00:00:22 user warn kernel: ip_nat_rtsp v0.01 loading
1st day 00:00:22 user crit kernel: ADSL G.994 training
1st day 00:00:22 user info kernel: device eth0 entered promiscuous mode
1st day 00:00:22 user info kernel: br0: port 1(eth0) entering learning state
1st day 00:00:22 user info kernel: br0: topology change detected, propagating
1st day 00:00:22 user info kernel: br0: port 1(eth0) entering forwarding state
1st day 00:00:22 user info kernel: device eth0 left promiscuous mode
1st day 00:00:22 user info kernel: br0: port 1(eth0) entering disabled state
1st day 00:00:22 user crit kernel: ADSL G.992 started
1st day 00:00:22 user warn kernel: eth0.2: MAC Address: 00:21:91:CD:6E:AA
1st day 00:00:22 user warn kernel: eth0.3: MAC Address: 00:21:91:CD:6E:AA
1st day 00:00:22 user warn kernel: eth0.4: MAC Address: 00:21:91:CD:6E:AA
1st day 00:00:22 user warn kernel: eth0.5: MAC Address: 00:21:91:CD:6E:AA
1st day 00:00:22 user info kernel: miscuous mode
1st day 00:00:22 user info kernel: br0: port 1(eth0.2) entering learning state
1st day 00:00:22 user info kernel: br0: port 1(eth0.2) entering forwarding state
1st day 00:00:22 user info kernel: device eth0.3 entered promiscuous mode
1st day 00:00:22 user info kernel: br0: port 2(eth0.3) entering learning state
1st day 00:00:22 user info kernel: br0: port 2(eth0.3) entering forwarding state
1st day 00:00:22 user info kernel: device eth0.4 entered promiscuous mode
1st day 00:00:22 user info kernel: br0: port 3(eth0.4) entering learning state
1st day 00:00:22 user info kernel: br0: port 3(eth0.4) entering forwarding state
1st day 00:00:22 user info kernel: device eth0.5 entered promiscuous mode
1st day 00:00:22 user info kernel: br0: port 4(eth0.5) entering learning state
1st day 00:00:22 user info kernel: br0: port 4(eth0.5) entering forwarding state
1st day 00:00:23 user debug syslog: pppd keepalive -c 0.8.35.1 -i nas_0_8_35 -u dslpp****** -p ********** -f 0 -m ***********/e222 &
1st day 00:00:24 daemon notice pppd[338]: pppd 2.4.1 started by admin, uid 0
1st day 00:00:24 user info kernel: br0: port 1(eth0.2) entering disabled state
1st day 00:00:24 user crit kernel: ADSL G.992 channel analysis
1st day 00:00:31 user crit kernel: ADSL G.992 message exchange
1st day 00:00:32 user crit kernel: ADSL link up, interleaved, us=1021, ds=8000
1st day 00:00:32 user warn kernel: ATM Soft SAR: ATM link connected.
1st day 00:00:33 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.2.11 -p udp --dport 53 -j DNAT --to 128.9.0.107
1st day 00:00:34 daemon notice pppd[338]: PPP: Start to connect ...
1st day 00:00:35 daemon crit pppd[338]: PPP server detected.
1st day 00:00:38 daemon notice pppd[338]: PPP: Start to connect ...
1st day 00:00:39 daemon crit pppd[338]: PPP server detected.
1st day 00:00:39 daemon crit pppd[338]: PPP session established.
1st day 00:00:39 daemon crit pppd[338]: PPP LCP UP.
1st day 00:00:39 daemon err pppd[338]: User name and password authentication failed.
1st day 00:00:40 user debug syslog: iptables -t nat -A PREROUTING -i br0 -p tcp --dport 80 -j DNAT --to 192.168.2.11
1st day 00:00:40 user debug syslog: iptables -t nat -I PREROUTING -i br0 -p udp --dport 53 -j DNAT --to 192.168.2.11
1st day 00:00:40 user debug syslog: /bin/dnsspoof 192.168.2.11 &
1st day 00:00:42 daemon notice pppd[338]: PPP: Start to connect ...
1st day 00:00:43 daemon crit pppd[338]: PPP server detected.
1st day 00:00:46 daemon notice pppd[338]: PPP: Start to connect ...
1st day 00:00:47 daemon crit pppd[338]: PPP server detected.
1st day 00:00:47 daemon crit pppd[338]: PPP session established.
1st day 00:00:49 daemon crit pppd[338]: PPP LCP UP.
1st day 00:00:50 daemon crit pppd[338]: Received valid IP address from server. Connection UP.
1st day 00:00:51 user debug syslog: route add default gw 83.239.153.35 2>/dev/null
1st day 00:00:52 user debug syslog: iptables -A FORWARD -o ppp_0_8_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
1st day 00:00:52 user debug syslog: iptables -A FORWARD -i ppp_0_8_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
1st day 00:00:52 user debug syslog: echo > /proc/net/ip_conntrack
1st day 00:00:52 user debug syslog: echo "1000" > /proc/sys/net/ipv4/ip_conntrack_max
1st day 00:00:52 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.2.11 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
1st day 00:00:52 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_8_35_1 -s 192.168.2.0/255.255.255.0 -j MASQUERADE 2>/dev/null
1st day 00:00:52 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_8_35_1 -s 192.168.2.0/255.255.255.0 -j MASQUERADE
1st day 00:00:52 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.2.11 -p udp --dport 53 -j DNAT --to 83.239.131.8 2>/dev/null
1st day 00:00:53 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.2.11 -p udp --dport 53 -j DNAT --to 83.239.131.8
1st day 00:00:53 user debug syslog: /bin/dnsprobe &
1st day 00:00:53 user notice dnsprobe[804]: dnsprobe started!
1st day 00:00:56 user debug syslog: ifconfig ppp_0_8_35_1 mtu 1492
1st day 00:08:30 user debug syslog: ethctl eth0 vport query 2>/var/vcfgerr
1st day 00:08:30 user debug syslog: rm /var/vcfgerr
1st day 00:08:35 user debug syslog: ethctl eth0 vport query 2>/var/vcfgerr
1st day 00:08:35 user debug syslog: rm /var/vcfgerr
1st day 00:08:40 user debug syslog: brctl delif br0 eth0.2 2>/dev/null
1st day 00:08:40 user info kernel: device eth0.2 left promiscuous mode
1st day 00:08:40 user info kernel: br0: port 1(eth0.2) entering disabled state
1st day 00:08:40 user debug syslog: sendarp -s br0 -d br0
1st day 00:08:40 user debug syslog: ifconfig eth0.2 up 2>/dev/null
1st day 00:08:40 user debug syslog: ifconfig eth0.2 down 2>/dev/null
1st day 00:08:41 user debug syslog: sendarp -s br0 -d br0
1st day 00:08:41 user debug syslog: ifconfig eth0.2 down 2>/dev/null
1st day 00:08:41 user debug syslog: brctl delif br0 eth0.3 2>/dev/null
1st day 00:08:41 user info kernel: device eth0.3 left promiscuous mode
1st day 00:08:41 user info kernel: br0: port 2(eth0.3) entering disabled state
1st day 00:08:41 user debug syslog: ifconfig eth0.3 up 2>/dev/null
1st day 00:08:41 user debug syslog: ifconfig eth0.3 down 2>/dev/null
1st day 00:08:41 user debug syslog: brctl delif br0 eth0.4 2>/dev/null
1st day 00:08:41 user info kernel: device eth0.4 left promiscuous mode
1st day 00:08:41 user info kernel: br0: port 3(eth0.4) entering disabled state
1st day 00:08:41 user debug syslog: ifconfig eth0.4 up 2>/dev/null
1st day 00:08:41 user debug syslog: ifconfig eth0.4 down 2>/dev/null
1st day 00:08:42 user debug syslog: ifconfig eth0.4 down 2>/dev/null
1st day 00:08:42 user debug syslog: brctl delif br0 eth0.5 2>/dev/null
1st day 00:08:42 user info kernel: device eth0.5 left promiscuous mode
1st day 00:08:42 user info kernel: br0: port 4(eth0.5) entering disabled state
1st day 00:08:42 user debug syslog: sendarp -s br0 -d br0
1st day 00:08:42 user debug syslog: ifconfig eth0.5 up 2>/dev/null
1st day 00:08:42 user debug syslog: ifconfig eth0.5 down 2>/dev/null
1st day 00:08:42 user debug syslog: rmmod vnet
1st day 00:08:43 user debug syslog: ifconfig eth0 up 2>/dev/null
1st day 00:08:43 user debug syslog: brctl addif br0 eth0 2>/dev/null
1st day 00:08:43 user info kernel: device eth0 entered promiscuous mode
1st day 00:08:43 user info kernel: br0: port 1(eth0) entering learning state
1st day 00:08:43 user info kernel: br0: topology change detected, propagating
1st day 00:08:43 user info kernel: br0: port 1(eth0) entering forwarding state
1st day 00:08:43 user debug syslog: sendarp -s br0 -d br0
1st day 00:08:47 user debug syslog: ethctl eth0 vport query 2>/var/vcfgerr
1st day 00:08:48 user debug syslog: rm /var/vcfgerr
1st day 00:08:48 user debug syslog: sendarp -s br0 -d br0
1st day 00:08:48 user debug syslog: ifconfig eth0 up 2>/dev/null
1st day 00:08:48 user debug syslog: ethctl eth0 vport query 2>/var/vcfgerr
C:\Documents and Settings\Maxim>tracert 217.69.128.41
Трассировка маршрута к 217.69.128.41 с максимальным числом прыжков 30
1 <1 мс <1 мс <1 мс 192.168.2.11
2 65 ms 21 ms 55 ms 83.239.153.35
3 23 ms 21 ms 21 ms 83.239.151.241
4 21 ms 21 ms 23 ms 83.239.129.70
5 23 ms 21 ms 21 ms 217.150.49.22
6 78 ms 46 ms 46 ms 212.44.128.149
7 50 ms 49 ms 46 ms 194.186.157.50
8 48 ms 50 ms 55 ms 195.239.8.10
9 46 ms 45 ms 46 ms 217.69.128.41
Трассировка завершена.
C:\Documents and Settings\Maxim>tracert mail.ru
Не удается разрешить системное имя узла mail.ru.
при вводе любого ip адресса в браузере заходит на веб интерфейс модема
Destination Gateway Subnet Mask Flag Metric Service Interface
83.239.153.35 0.0.0.0 255.255.255.255 UH 0 pppoe_0_8_35_1 ppp_0_8_35_1
192.168.2.0 0.0.0.0 255.255.255.0 U 0 br0
0.0.0.0 83.239.153.35 0.0.0.0 UG 0 pppoe_0_8_35_1 ppp_0_8_35_1
Последний раз редактировалось wandera Ср июн 24, 2009 23:09, всего редактировалось 1 раз.
СообщениеДобавлено: Ср июн 24, 2009 22:14
Опеределил когда возникает проблемма. Когда в модеме пробрасовываю порты, начинаеться такая котовасия. причем в параметрах кроме ip server есть еще и ip host. ЗАЧЕМ ХОСТ-то?
СообщениеДобавлено: Вт июн 30, 2009 09:30
up
СообщениеДобавлено: Ср июл 01, 2009 15:05
Ты при настройке неверно задал пароль и у тебя просто нет выхода в Интернет. Вариант второй - кончились деньги на счете.
