Текущее время: Сб сен 26, 2026 23:29
СообщениеДобавлено: Пн май 19, 2008 08:59
Добрый день,
при создании IPSec соединения в логах выдаёт вот это...
2008-05-16
21:12:13 Info IPSEC
01802708
ike_sa_destroyed
ike_sa_killed
rev=1 ike_sa= Initiator SPI ESP=0x2e7afad4, AH=0x64d53dee, IPComp=0x91d06da
2008-05-16
21:12:13 Warning IPSEC
01802022
ike_sa_failed
no_ike_sa
rev=2 statusmsg="Timeout" local_peer=81.211.120.10 ID No Id remote_peer=213.247.151.169 ID No Id initiator_spi=ESP=0x2e7afad4, AH=0x64d53dee, IPComp=0x91d06dab
2008-05-16
01802715
event_on_ike_sa
rev=1 side=Responder msg="failed" int_severity=6
2008-05-16
21:12:13 Warning RULE
06000051 Default_Rule ICMP wan
195.239.11.230
81.211.120.10
ruleset_drop_packet
drop
rev=1 ipdatalen=36 icmptype=DEST_UNREACH unreach=HOST_UNREACH
2008-05-16
21:12:12 Info CONN
00600001 lan_to_IPSec ICMP lan
office1 192.168.2.2
192.168.111.10
conn_open
rev=1 conn=open connsrcid=512 conndestid=512
2008-05-16
21:11:58 Notice SYSTEM
03202001
startup_echo
rev=1 delay=15 corever=2.12.00.44-1877 build="Apr 27 2007" uptime=2161 cfgfile="core.cfg" cfgver=27 previous_shutdown="2008-05-16 21:11:36: Activating configuration changes"
2008-05-16
21:11:52 Notice SYSTEM
03204001
accept_configuration
using_new_config
rev=1 username=admin userdb=AdminUsers client_ip=192.168.2.2 config_system=HTTP
2008-05-16
03200607
bidir_ok
rev=1 cfgver=27
2008-05-16
21:11:48 Notice SYSTEM
03202001
startup_echo
rev=1 delay=5 corever=2.12.00.44-1877 build="Apr 27 2007" uptime=2151 cfgfile="core.cfg" cfgver=27 previous_shutdown="2008-05-16 21:11:36: Activating configuration changes"
2008-05-16
21:11:44 Info IPSEC
01802708
ike_sa_destroyed
ike_sa_killed
rev=1 ike_sa= Initiator SPI ESP=0x69c54135, AH=0x751d7912, IPComp=0x1e683b5
2008-05-16
21:11:44 Warning IPSEC
01802022
ike_sa_failed
no_ike_sa
rev=2 statusmsg="No proposal chosen" local_peer=81.211.120.10 ID No Id remote_peer=213.247.151.169 ID No Id initiator_spi=ESP=0x69c54135, AH=0x751d7912, IPComp=0x1
2008-05-16
01802715
event_on_ike_sa
2008-05-16
01800107
ike_invalid_proposal
rev=1 local_ip=81.211.120.10 remote_ip=213.247.151.169 cookies=69c54135751d79121e683b53bbf9249f reason="Could not find acceptable proposal"
2008-05-16
21:11:44 Notice IPSEC
01802300
rule_selection_failed
rev=1 info=Peer IP address mismatch int_severity=6
2008-05-16
21:11:44 Info IPSEC
01803001
failed_to_select_policy_rule
rev=1
2008-05-16
01802715
event_on_ike_sa
2008-05-16
21:11:43 Info IPSEC
01800317
peer_is_dead
IPsec_tunnel_disabled
rev=1 peer=213.247.169.151
2008-05-16
21:11:43 Info IPSEC
01802708
ike_sa_destroyed
ike_sa_killed
Bad logmsg: [2008-05-16 21:11:43] <6>FW: IPSEC: prio=1 id=01802708 rev=1 event=ike_sa_destroyed action=ike_sa_killed ike_sa= Initiator SPI ESP=0xcc8c5c3f, AH=0xc08552ec Responder SPI
2008-05-16
21:11:43 Warning IPSEC
01802022
ike_sa_failed
no_ike_sa
rev=2 statusmsg="Timeout" local_peer=127.0.0.1 ID 81.211.120.10 remote_peer=213.247.169.151 ID No Id initiator_spi=ESP=0xcc8c5c3f, AH=0xc08552ec
2008-05-16
01802715
event_on_ike_sa
rev=1 side=Initiator msg="failed" int_severity=6
2008-05-16
21:11:43 Notice SYSTEM
03202000
startup_normal
rev=1 corever=2.12.00.44-1877 build="Apr 27 2007" uptime=2146 cfgfile="core.cfg" cfgver=27 previous_shutdown="2008-05-16 21:11:36: Activating configuration
подскажите пожалуйста что может это значить..
СообщениеДобавлено: Пн май 19, 2008 09:43
Причин может быть много, по настройки ISA я вам ничего подсказать не могу, разве что попробуйте провести диагностику по этому документу http://www.mediafire.com/?7tjyngmnmzv
СообщениеДобавлено: Вт июн 23, 2009 08:13
to rsalnikov
Удалось решить поставленную задачу? Та-же проблема... Очень нужна помошь в решении такой-же проблемы...
