Текущее время: Пн ноя 02, 2026 11:59
Начать новую тему Ответить на тему  [ Сообщений: 36 ]  На страницу Пред.  1, 2, 3  След.
СообщениеДобавлено: Пн июн 15, 2009 10:45
обновитесь до прошивки http://ftp.dlink.ru/pub/Router/DIR-615/ ... Beta05.bin
СообщениеДобавлено: Пн июн 15, 2009 11:12
Ок, спасибо ща посмотрим)
СообщениеДобавлено: Пн июн 15, 2009 11:36
Кароче ывсё то же самое что и на бета 2.
[INFO] Mon Jun 15 14:33:06 2009 PPP network down
[INFO] Mon Jun 15 14:33:06 2009 PPTP tunnel ID 0x9C54 has been closed
[INFO] Mon Jun 15 14:33:03 2009 PPTP ALG rejected packet from 81.20.169.75:1723 to 10.8.249.206:25388
[INFO] Mon Jun 15 14:32:36 2009 Above message repeated 6 times
[INFO] Mon Jun 15 14:32:36 2009 PPP network up with IP Address 81.20.175.163
[INFO] Mon Jun 15 14:32:36 2009 MSCHAP authentication successful.
[INFO] Mon Jun 15 14:32:36 2009 MSCHAP authentication details were sent to authenticator.
[INFO] Mon Jun 15 14:32:36 2009 MSCHAP authentication challenge received from peer.
[INFO] Mon Jun 15 14:32:36 2009 LCP sets local options: ACCM: 00000000, ACFC: 0, PFC: 0, MRU: 1462
[INFO] Mon Jun 15 14:32:36 2009 PPTP ALG rejected packet from 81.20.169.75:1723 to 10.8.249.206:25388
[INFO] Mon Jun 15 14:32:36 2009 LCP sets remote auth: C223
[INFO] Mon Jun 15 14:32:36 2009 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 0, PFC: 0, MRU: 1460
[INFO] Mon Jun 15 14:32:36 2009 PPTP connected to server "RR-08-02" with ID 0x9C54
[INFO] Mon Jun 15 14:32:36 2009 The PPTP transmit window is 100
[INFO] Mon Jun 15 14:32:36 2009 Attempting to establish a PPTP connection.
[INFO] Mon Jun 15 14:32:24 2009 Log viewed by IP address 192.168.0.2
[INFO] Mon Jun 15 14:32:06 2009 PPP network down
[INFO] Mon Jun 15 14:32:06 2009 PPTP tunnel ID 0xEA9C has been closed
[INFO] Mon Jun 15 14:32:04 2009 Log viewed by IP address 192.168.0.2
[INFO] Mon Jun 15 14:32:03 2009 PPTP ALG rejected packet from 81.20.169.75:1723 to 10.8.249.206:25387
[INFO] Mon Jun 15 14:32:02 2009 DNS relay ALG rejected packet from 81.20.175.170:4102 to 81.20.169.10:53
[INFO] Mon Jun 15 14:32:02 2009 Dropped packet from 81.20.175.170 to 81.20.169.10 (IP protocol 17) as unable to create new session
[INFO] Mon Jun 15 14:31:59 2009 Stored configuration to non-volatile memory
[INFO] Mon Jun 15 14:31:58 2009 primary: Unlock AP setup
Тока не отмалчивайтесь Суппорт!!!
Если нет шансов нормально запустить ВПН с динамическим адресом и с подключением круглосуточно. так и скажите. "извините, сырая прошивка для россии" И всё ёмаё...
Чо мы тут копошимся как олени.
Если есть реальное решение проблемы то ткните пальцем.
СообщениеДобавлено: Пн июн 15, 2009 12:58
при этом если использовать динамический ДАШЦП клиент и поднимать ВПН с компа, то работает.
СообщениеДобавлено: Пн июн 15, 2009 13:05
Шанс есть, у меня-то работает.:(
Support скажите есть вообще прошивка (может старая какая) чтоб не падало соединение РРТР для россии? более пока ничего не надо.
на 26 падала к утру, при выключеном компе, помогал тока выкл/вкл.
До магаза дорога будет где то через полчаса. не решится, да и пох)
Сменю на асуса.
СообщениеДобавлено: Пн июн 15, 2009 13:07
DrCrimson
У тебя че? Россия РРТР дуал акцесс. Динамический адрес?
У меня так тока на 26 работает.
СообщениеДобавлено: Пн июн 15, 2009 13:08
дуал аксесс, dhcp.
СообщениеДобавлено: Пн июн 15, 2009 13:13
В смысле дашцп от провайдера получаешь, правильно?
Россия дуал акцесс или просто Дуал Акцесс?
поключение Олвейс ОН, и склонирован мак.
Ещё у меня пров требует снимать галку "требуется шифрование данных иначе отключаться" в настройках впн на компе.
СообщениеДобавлено: Пн июн 15, 2009 13:32
Да все, тоже самое, за исключением того что мак не клонирован. Роутер получат от провайдера адрес, подключается по pptp (russia dual), прописан маршрут до локалки. Шифрование не используется.
СообщениеДобавлено: Пн июн 15, 2009 13:51
Мак пробовал не клонировать - та же тема. до локалки ничего не прописываю. прописываю вручную настройки для прова и всё. больше вообще ничего не трогаю, ребут раз в 30 сек.
СообщениеДобавлено: Пн июн 15, 2009 18:16
Спрыгнул на другого производителя. посмотрим мож реально в прове проблема. Ппока работает, всё видно будет утром.
СообщениеДобавлено: Пн июн 15, 2009 23:44
кстати а это как понимать?
об какой версии идет речь, если роутер не поддерживает MSCHAP а поддержка только MSCHAP v2, нда чем дальше чем якобы новее прошивки тем дерьмовее, лучше бы туже 2.26 довели до ума в плане падений РРТР и перезагрузок под нагрузкой торрента, а не это говно (извиняюсь за выражение, но правда уже достало) штамповали, то блин WiFi выдает тонны ошибок то еще какая беда ( кстати мне так и не ответили тогда по этому поводу, чтож такого добавили в прошивку что такая ерунда началась с WiFi твориться кроме как задать встречный вопрос про адаптеры и на этом все закончилось) когда же наконец я соизволю его это недоразумение под названием роутер долбануть об стенку и чтоб больше на него даже не смотреть, вот в данный момент сижу на Асусе RT-N15 и никаких проблем ... (есть еще и также нормально работающий DI 804 HV, но вот WiFi жаль у него нет)
зы за время использования этого недоразумения по имени DIR 615 понял одно, оно сие чудо абсолютно фактически не работоспособно при подключении РРТР, при этом на статике с ним нет проблем думаю с любой прошивкой и также в версии прошивки 2.26 была такая хорошая функция как переключение его в точку доступа, вот нафига спрашивается эту функцию убрали зато дерьмовый шейпинг добавили и раздули за счет этого размер прошивки на 300 Кб как будто у него мозги резиновые. вообщем у собратьев по несчастью прошу прощения за резкие высказывания но достало оно ...
СообщениеДобавлено: Вт июн 16, 2009 09:22
Кароче итог. На асусе с утра так же не было инета. Выяснилось что косяк в сетевухе. Сетевуха кстати тож длинк. То есть если бы остался на 26 прошивке, то можно было бы жить наверное. Но т.к. полноценной тех поддержки по телу нет, да ещё и просят залить откровенно сырые беты, больше я к длинку не притронусь.
А взял wl520gc работает и не тупит. Вот ещё DD-wr прошью, вапще счастие будет.
СообщениеДобавлено: Вт июн 16, 2009 17:29
Найдена причина. Если на роутере стоит галочка скрывать SSID, то после перезагрузки компа, винда хоть и цепляется к сети по вайфаю, инета не получает и роутер по айпишнику не пингуется. Выяснено естесственно на асусе уже. Вполне возможно что и на 615м ДИРе то же самое.
ИТОГ: на прошивке 26, в Челябинске РРТР соединение с тригором не рвётся до суток (более не проверял), остальные 27 беты рвут в течение 30 сек.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 47
cron
