Текущее время: Сб июл 04, 2026 09:32
 Заголовок сообщения: DSL-2500U_BRU_D - потеря соединения
СообщениеДобавлено: Вс май 31, 2009 10:28
ЮТК, Таганрог, Ростовская область.
При закачке файла с внутреннего ресурса на скорости ~840Кб/сек
падает внешнее PPPoE соединение
System Log
Date/Time Facility Severity Message
May 31 10:25:32 user warn dnsprobe[789]: dns query failed
May 31 10:25:34 user warn dnsprobe[789]: dns query failed
May 31 10:35:36 user warn dnsprobe[789]: dns query failed
May 31 10:35:38 user warn dnsprobe[789]: dns query failed
May 31 10:35:40 user warn dnsprobe[789]: dns query failed
May 31 10:45:43 user warn dnsprobe[789]: dns query failed
May 31 10:45:45 user warn dnsprobe[789]: dns query failed
May 31 10:45:47 user warn dnsprobe[789]: dns query failed
May 31 10:55:48 user warn dnsprobe[789]: dns query failed
May 31 10:55:50 user warn dnsprobe[789]: dns query failed
May 31 10:55:52 user warn dnsprobe[789]: dns query failed
May 31 11:03:24 daemon info pppd[385]: LCP terminated by peer
May 31 11:03:25 daemon info pppd[385]: Connect time 4951380.0 minutes.
May 31 11:03:25 daemon info pppd[385]: Sent 1144168 bytes, received 5882439 bytes.
May 31 11:03:25 daemon warn pppd[385]: Couldn't increase MRU to 1500
May 31 11:03:29 daemon notice pppd[385]: Connection terminated....
May 31 11:03:34 daemon info pppd[385]: Sent PADT
May 31 11:03:39 daemon info pppd[385]: Sent PADT
May 31 11:03:49 daemon info pppd[385]: Sent PADT
May 31 11:04:01 daemon info pppd[385]: PPP session is 20160
May 31 11:04:01 daemon info pppd[385]: Using interface ppp0_0_35_1
May 31 11:04:02 daemon notice pppd[385]: Connect: ppp_0_0_35_1 <--> nas_0_0_35
May 31 11:04:02 daemon warn pppd[385]: Couldn't increase MRU to 1500
May 31 11:04:06 daemon warn pppd[385]: Couldn't increase MRU to 1500
May 31 11:04:36 daemon warn pppd[385]: LCP: timeout sending Config-Requests
May 31 11:04:37 daemon notice pppd[385]: Connection terminated....
May 31 11:04:41 daemon info pppd[385]: Sent PADT
May 31 11:04:46 daemon info pppd[385]: Sent PADT
May 31 11:05:29 daemon warn pppd[385]: Timeout waiting for PADS packets
May 31 11:05:29 daemon err pppd[385]: Unable to complete PPPoE Discovery
May 31 11:05:32 daemon info pppd[385]: Sent PADT
May 31 11:05:32 daemon info pppd[385]: PPP session is 19174
May 31 11:05:32 daemon info pppd[385]: Using interface ppp0_0_35_1
May 31 11:05:32 daemon notice pppd[385]: Connect: ppp_0_0_35_1 <--> nas_0_0_35
May 31 11:05:32 daemon warn pppd[385]: Couldn't increase MRU to 1500
May 31 11:05:33 daemon info pppd[385]: Remote message: % Sessions limit exceeded.
May 31 11:05:33 daemon err pppd[385]: PAP authentication failed
May 31 11:05:33 daemon warn pppd[385]: Couldn't increase MRU to 1500
May 31 11:05:33 daemon notice pppd[385]: Connection terminated....
May 31 11:05:36 daemon info pppd[385]: Sent PADT
May 31 11:05:41 daemon info pppd[385]: Sent PADT
May 31 11:05:51 daemon info pppd[385]: Sent PADT
May 31 11:05:54 user warn dnsprobe[789]: dns query failed
May 31 11:05:56 user warn dnsprobe[789]: dns query failed
May 31 11:05:58 user warn dnsprobe[789]: dns query failed
May 31 11:06:11 daemon warn pppd[385]: Timeout waiting for PADO packets
May 31 11:06:11 daemon err pppd[385]: Unable to complete PPPoE Discovery
May 31 11:06:14 daemon info pppd[385]: Sent PADT
May 31 11:06:19 daemon info pppd[385]: Sent PADT
May 31 11:06:29 daemon info pppd[385]: Sent PADT
May 31 11:06:49 daemon warn pppd[385]: Timeout waiting for PADO packets
May 31 11:06:49 daemon err pppd[385]: Unable to complete PPPoE Discovery
May 31 11:06:52 daemon info pppd[385]: Sent PADT
May 31 11:06:57 daemon info pppd[385]: Sent PADT
May 31 11:07:07 daemon info pppd[385]: Sent PADT
Потом через какое то время соедение восстанавливается
May 31 11:11:24 daemon info pppd[385]: Sent PADT
May 31 11:11:24 daemon info pppd[385]: PPP session is 3712
May 31 11:11:24 daemon info pppd[385]: Using interface ppp0_0_35_1
May 31 11:11:25 daemon notice pppd[385]: Connect: ppp_0_0_35_1 <--> nas_0_0_35
May 31 11:11:25 daemon warn pppd[385]: Couldn't increase MRU to 1500
May 31 11:11:25 daemon notice pppd[385]: PAP authentication succeeded
May 31 11:11:25 daemon notice pppd[385]: peer from calling number 00:30:88:02:46:9B authorized
May 31 11:11:25 daemon notice pppd[385]: local IP address 172.19.9.255
May 31 11:11:25 daemon notice pppd[385]: remote IP address 172.19.0.1
May 31 11:11:25 daemon notice pppd[385]: primary DNS address 93.178.96.12
May 31 11:11:25 daemon notice pppd[385]: secondary DNS address 93.178.96.10
May 31 11:11:33 user debug syslog: route add default gw 172.19.0.1 dev ppp_0_0_35_1 2>/dev/null
May 31 11:11:34 user debug syslog: route add -net 10.253.0.0 netmask 255.255.255.0 metric 1 gw 10.253.178.1 2>/dev/null
May 31 11:11:34 user debug syslog: echo route add -net 10.253.0.0 netmask 255.255.255.0 metric 1 gw 10.253.178.1 2>/dev/null >> /var/StaticRoute
May 31 11:11:35 user debug syslog: iptables -A FORWARD -o ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
May 31 11:11:35 user debug syslog: iptables -A FORWARD -i ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
May 31 11:11:36 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
May 31 11:11:37 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
May 31 11:16:01 user warn dnsprobe[789]: dns query failed
May 31 11:16:03 user warn dnsprobe[789]: dns query failed
May 31 11:16:05 user warn dnsprobe[789]: dns query failed
Как решить эту проблему? может какие настройки прописать в модеме?
плюс ошибки dns query failed через каждые 10 минут в логе идут
Параметры линии
Statistics -- ADSL
Mode: G.DMT
Type: Fast
Line Coding: Trellis On
Status: No Defect
Link Power State: L0
Downstream Upstream
SNR Margin (dB): 14.3 12.0
Attenuation (dB): 12.0 6.5
Output Power (dBm): 12.5 17.8
Attainable Rate (Kbps): 10464 1120
Rate (Kbps): 8128 896
K (number of bytes in DMT frame): 255 29
R (number of check bytes in RS code word): 0 0
S (RS code word size in DMT frame): 1 1
D (interleaver depth): 1 1
Delay (msec): 0 0
Super Frames: 1435233 1435232
Super Frame Errors: 3 8
RS Words: 0 0
RS Correctable Errors: 0 0
RS Uncorrectable Errors: 0 N/A
HEC Errors: 1 3
OCD Errors: 0 0
LCD Errors: 0 0
Total Cells: 467724126 0
Data Cells: 8598733 0
Bit Errors: 0 0
Total ES: 3 0
Total SES: 0 0
Total UAS: 50 0
DSL-2500U/BRU/D fw.1.40
СообщениеДобавлено: Вс май 31, 2009 14:24
Я по вашей ошике dns query failed отписался в viewtopic.php?t=94661. Даю ссылку, что бы не повторяться. :)
DSL-2500U/BRU/D
СообщениеДобавлено: Вс май 31, 2009 23:25
Да, спасибо! А вот вышеописанная проблема осталась:
Jun 1 00:15:44 daemon info pppd[397]: Sent PADT
Jun 1 00:15:49 daemon info pppd[397]: Sent PADT
Jun 1 00:15:59 daemon info pppd[397]: Sent PADT
Jun 1 00:16:19 daemon warn pppd[397]: Timeout waiting for PADO packets
Jun 1 00:16:19 daemon err pppd[397]: Unable to complete PPPoE Discovery
тут еще файл качается на макс оборотах :)
Jun 1 00:16:22 daemon info pppd[397]: Sent PADT
Jun 1 00:16:27 daemon info pppd[397]: Sent PADT
Jun 1 00:16:37 daemon info pppd[397]: Sent PADT
Jun 1 00:16:57 daemon warn pppd[397]: Timeout waiting for PADO packets
Jun 1 00:16:57 daemon err pppd[397]: Unable to complete PPPoE Discovery
а тут уже файл скачался походу и модем поднимает линк
Jun 1 00:17:00 daemon info pppd[397]: Sent PADT
Jun 1 00:17:05 daemon info pppd[397]: Sent PADT
Jun 1 00:17:15 daemon info pppd[397]: Sent PADT
Jun 1 00:17:15 daemon info pppd[397]: PPP session is 5302
Jun 1 00:17:15 daemon info pppd[397]: Using interface ppp0_0_35_1
Jun 1 00:17:15 daemon notice pppd[397]: Connect: ppp_0_0_35_1 <--> nas_0_0_35
Jun 1 00:17:15 daemon warn pppd[397]: Couldn't increase MRU to 1500
Jun 1 00:17:15 daemon notice pppd[397]: PAP authentication succeeded
Jun 1 00:17:15 daemon notice pppd[397]: peer from calling number 00:30:88:02:46:9B authorized
Jun 1 00:17:16 daemon notice pppd[397]: local IP address 172.19.0.72
Jun 1 00:17:16 daemon notice pppd[397]: remote IP address 172.19.0.1
Jun 1 00:17:16 daemon notice pppd[397]: primary DNS address 93.178.96.12
Jun 1 00:17:16 daemon notice pppd[397]: secondary DNS address 93.178.96.10
Jun 1 00:17:24 user debug syslog: route add default gw 172.19.0.1 dev ppp_0_0_35_1 2>/dev/null
Jun 1 00:17:24 user debug syslog: route add -net 10.253.0.0 netmask 255.255.255.0 metric 1 gw 10.253.178.1 2>/dev/null
Jun 1 00:17:24 user debug syslog: echo route add -net 10.253.0.0 netmask 255.255.255.0 metric 1 gw 10.253.178.1 2>/dev/null >> /var/StaticRoute
Jun 1 00:17:25 user debug syslog: iptables -A FORWARD -o ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jun 1 00:17:25 user debug syslog: iptables -A FORWARD -i ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jun 1 00:17:25 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Jun 1 00:17:25 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
СообщениеДобавлено: Пн июн 01, 2009 07:53
Ваш модем рвет соединение, т.к. не дожидается ответа от сервера. В вашей ситуации надо либо увеличивать таймаут соединения (стандартными средствами модема вы это сделать не сможете только телнетом ), либо снижать скорость на "качалке". Стандартно в таких случаях рекомендуется еще проверить линию.
DSL-2500U/BRU/D
СообщениеДобавлено: Пн июн 01, 2009 08:51
Ну на "качалке" я и уменьшаю, но об этом нужно постоянно помнить и задумываться.... а если качать одновременно несколько файлов то вычислять суммарную скорость и опять же тормозить эти закачки....
Это всё происходит на соединении MER с внутренним ресурсом провайдера (Медиазона ЮТК Ростовская область)
Вот как бы сделать чтоб или приоритет этого соедниия был меньше PPPoE или чтоб скорость его была меньше ширины канала если проблема в этом ?
СообщениеДобавлено: Пн июн 01, 2009 09:00
Ну эта задача не для этой железки :) Разве что QoSом поиграться. Но провайдер дожен тоже его у себя настроить, а шейпера тут и в помине нет.
DSL-2500U/BRU/D
СообщениеДобавлено: Пн июн 01, 2009 17:30
Да в инструкции провайдера по подключению Интернета QoS вообще выключен... так что сушим весла... :(
СообщениеДобавлено: Ср июн 03, 2009 08:41
Может кто подскажет из сотрудников Длинк как QoS настроить, и вообще работает ли он в модеме для входящего трафика, и решиться ли в итоге вышеуказанная проблема?
СообщениеДобавлено: Ср июн 03, 2009 13:34
АУУУУ !!!
Неужели никто помочь не может ????????????
СообщениеДобавлено: Чт июн 04, 2009 06:18
Кстати такая же фигня происходит на Zyxel p660rt_ee....
только логов там не предусмотрено в нем...а то бы выложил
СообщениеДобавлено: Чт июн 04, 2009 07:57
Тут по этому вопросу уже поднималась тема. Точно не помню, но официально было заявлено, что для входящего трафика QoS на этой железке нет. Эта задача провайдера. Более того, если провайдер у себя не настроит, то и QoS на исходящий трафик бесполезен. Вам в любом случае надо либо "накрывать поляну" :wink: провайдеру, либо менять модем на что либо более серьезное.
DSL-2500U/BRU/D
СообщениеДобавлено: Чт июн 04, 2009 08:21
ясно, хреново...
А более серьезное из недорогово это что?
cron
