Текущее время: Чт июл 16, 2026 19:06
Начать новую тему Ответить на тему  [ Сообщений: 241 ]  На страницу 1, 2, 3, 4, 5 ... 17  След.
 Заголовок сообщения: DNS-323 BETA firmware 1.8 !!!
СообщениеДобавлено: Пт май 15, 2009 22:18
NOTE: Do NOT take these changes for face value. These are not finalized changes and more will and can be added.
v1.08
1. Now Supports Scandisk.
2. Extended the email Sender's address limitation to 63 chars.
3. Now Support System Logging/FTP Logging.
4. Supports Yahoo! Widget.
5. FTP Server support Hebrew codepage.
6. Re-added EXT3 Support.
7. User can assign volume for storing BT's torrents.
8. Add Email Alert: Send email when rebuild is done.
9. Add Email Alert: Send email when harddrives go into degraded mode.
10. Now Capable of sending logs by email.
11. Support Apkg: new applications can be modulized and be installed to disk.
12. Add email notification when BT is done downloading.
13. Save Quota settting to Configuration file.
14. FTP Server supports FXP.
15. UPnP AV support wav streaming to XBox 360, PS3, DSM-520, DSM-510 and etc.
16. Support Bonjour.
17. Fix FTP Server: unable to work by using other port than 21 no matter with or without SSL/TLS.
18. Fix Unable to send out an email with some authenticated mail server.
19. iTunes Server is capable of update more than 50,000 songs.
20. Display BT download status on Widget.
21. BT can be uninstalled if it is installed via Apkg.
22. Changes DST GUI design.
23. Fix Disk formatting counter imprecise and always hanged at 94% issue.
24. Add Disk formatting error code returned capability.
25. Add Ability to specify Passive port ranges for FTP.
26. Add the ability to set the FTP server to ONLY accept SSL/TLS connections and reject regular non-authenticated connections.
27. Add the Ability to control the devices LED status of On or Off. Some users are complaining about the brightness of the BLUE LED when the device is placed in their home.
28. Add the possibility to turn off the hard drive after more than 30 minutes (1 hour, 2 hours, etc.) in Power Management Settings.
29. Add the ability to manually configure your SMTP mail server port. ISP's are no longer using port 25 and are now using unique ports. Also should be able to select authenticated for authenticated mail servers.
30. Change fan speed design, Shut off fan at desired temp (ability to check always on low, Add always on ).
31. Improve download URL length limit : extends to 235 chars
32. Add Ajax Download bar similar to BT Page(no refresh required).
33. Add Support for: OGG, FLAC, MKV, APE, IFO, ISO, AAC, DIVX, M4A.
34. Add support for spaces in filenames when using UPnP AV.
35. Improve filename length support in UPnP AV.
36. Add Ability to stream m2ts, .iso files.
37. Improve UPnP AV : If it runs across a Corrupt file then it just skip's it instead of stopping the scan all together.
38. Add More Indepth Network information on status page, (Current Rx/Tx, Device Uptime).
39. Add NFS Server.
40. Add Support for 2TB HDD.
41. Add Samba Share mode and User mode auto switching to fix Vista login issue.
42. Support Auto Power Recovery(For HW C1 only).
43. Replace existing iTunes server (mt-daapd) with new released software, Firefly by Apkg.
44. Fix Incremental Backup setting gone while checking on Edit page.
45. Fix Display invalid quota value in Windows.
46. Fix When SMTP server set to Hinet, it failed to work when email account has dot.
47. Email Alert counter delayed for 1mins.
48. Fix Invalid Username crashing web server.
49. DDNS: Different providers support.(Add no-ip)
Последний раз редактировалось maxim_fr Пт май 15, 2009 23:14, всего редактировалось 1 раз.
СообщениеДобавлено: Пт май 15, 2009 22:20
А глюки с кулером пофиксили?
СообщениеДобавлено: Пт май 15, 2009 22:24
описание (Release Notes) http://forums.dlink.com/index.php?topic=5485.0
Скачка http://forums.dlink.com/index.php?topic=5486.0 или прямо с ftp://ftp.dlink.com/Multimedia/dns323/Beta/Firmware/dns323_firmware_108_beta.zip
Другие полезности: http://forums.dlink.com/index.php?board=251.0
СообщениеДобавлено: Пт май 15, 2009 22:25
Вот сейчас зашью и узнаем... В списке, как видишь (см. пункт 30), о кулере много чего ))
СообщениеДобавлено: Пт май 15, 2009 22:45
Прошился. Работает. Прошивка была собрана СЕГОДНЯ
Firmware Date : 05/15/2009
Первые впечатления:
1. много изменений в интерфейсе
2. перестала работать отправка сообщений на gmail
похоже упал веб-интерфейс - буду перегружаться
СообщениеДобавлено: Сб май 16, 2009 00:55
много вкусностей, особенно:
СообщениеДобавлено: Сб май 16, 2009 01:22
Упал веб-интерфейс минут на 20, потом загрузился таки.
Впечатления за 5 минут :-)
На самом внешних изменений мало. В торренте ничего не добавилось.
Появился скандиск...без кнопочки "стоп". При запуске отрубил папку...прально вообчем то, но а если нужно остановить.
Еще через 15 минут снова упал веб-интерфейс. А потом еще неск.раз.
И четого то скрябает винтами постоянно, раньше такого не было.
Страшновато...стало за информацию. Пожалуй вернусь на предыдущую прошивку пока.
Мне кажется сыровато...
3xDFL-210, 1xDFL-800, 1x3110 HotSpot
СообщениеДобавлено: Сб май 16, 2009 01:31
фича не заработала у меня, точнее Install failed. Please check file
хотя с фтп родного брал apkg*.*.
СообщениеДобавлено: Сб май 16, 2009 01:38
После нескольких переключений между режимами "конфигурация" и "приложения", в веб-интерфейсе стали пропадать кнопочки, в частности исчез Торрент.
Доступ к сетевой(SMB) папке пропадал время от времени...
СообщениеДобавлено: Сб май 16, 2009 01:45
После возвращения прошивки к версии 1.07..."бобик" не ожил в течении 15 минут, подожду еще.
СообщениеДобавлено: Сб май 16, 2009 02:02
Сдох таки... arp -a 192.168.0.254 mac 00-00-00-00-00-00. Соот-но доступа нет.
Как вернуть к жизни? Товарищи из тех.поддержки помогайте. :?
СообщениеДобавлено: Сб май 16, 2009 02:52
Вообщем помогла иголочка и запуск девйса без винтов. Прошивка осталась 1.07, вернул сетевые настройки. Потом подоткнул винты, включил и порядок...фууу... :)
СообщениеДобавлено: Сб май 16, 2009 09:07
Странно, но у меня ничего не падало. Torrent я не ставил, не нужен. А вот поддержку NFS с удовольствием загрузил - все работает.
А вот sacn disk у меня не запускается. Пишет ошибку
Hard Drive(s) Scanning Failure
И UPnP работает вроде нормально, видно и MKV и M2TS файлы, и popcorn прекрасно их хавает и показывает. Правда похоже не вся инфа по файлу передается, т.к. popcorn по кнопке info t выдает данные о размере файла. Если по NFS зацепиться, то все показывает.
СообщениеДобавлено: Сб май 16, 2009 12:52
У меня сначала тоже не работал. Потом я плюнул на всё, сбросил 323ий на все дефолты и переформатил винты уже в EXT3 (они у меня пустые т.к. я их пару дней как проапгрейдил на 1.5терабайтники)... и после этого всё заработало. Скан _пустого_ EXT3 винта 1.5ТБ на 7200 длится почти час.
Думаю, два варианта: или прошивка требует форматирования, или у тебя мешали отмонтировать том процесы запущенные из fun_plug, причем поскольку версия ядра так и не поменялась то скорее второе :)
СообщениеДобавлено: Сб май 16, 2009 14:26
1. Поставли NFS. Что писать в настройке HOST ?
2. Исчезли пользователи ALL. Как вообще открыть теперь безымянный доступ по самбе?
