Текущее время: Вс ноя 01, 2026 00:26
 Заголовок сообщения: DIR-615 и TCP SYN Flooding
СообщениеДобавлено: Вт май 05, 2009 19:31
Проблема в следующем. От маршрутника постоянно идут TCP SYN Flooding
May/5/2009 22:24:49   [FW] **TCP SYN Flooding** IP/TCP 94.31.191.122:27961->94.31.191.156:445
May/5/2009 22:24:49   [FW] **TCP SYN Flooding** IP/TCP 94.31.191.122:21595->94.31.191.156:445
May/5/2009 22:24:49   [FW] **TCP SYN Flooding** IP/TCP 94.31.191.122:25217->94.31.191.156:445
May/5/2009 22:24:49   [FW] **TCP SYN Flooding** IP/TCP 94.31.191.122:40769->94.31.191.156:445
May/5/2009 22:24:49   [FW] **TCP SYN Flooding** IP/TCP 94.31.191.122:58711->94.31.191.156:445
May/5/2009 22:24:49   [FW] **TCP SYN Flooding** IP/TCP 94.31.191.122:43325->94.31.191.156:445
May/5/2009 22:24:49   [FW] **TCP SYN Flooding** IP/TCP 94.31.191.122:19573->94.31.191.156:445
May/5/2009 22:24:49   [FW] **TCP SYN Flooding** IP/TCP 94.31.191.122:34787->94.31.191.156:445
May/5/2009 22:24:49   [FW] **TCP SYN Flooding** IP/TCP 94.31.191.122:43807->94.31.191.156:445
May/5/2009 22:24:49   [FW] **TCP SYN Flooding** IP/TCP 94.31.191.122:6667->94.31.191.156:445
May/5/2009 22:24:47   [FW] **TCP SYN Flooding** IP/TCP 94.31.191.122:24460->94.31.191.162:445
May/5/2009 22:24:47   [FW] **TCP SYN Flooding** IP/TCP 94.31.191.122:42538->94.31.191.162:445
May/5/2009 22:24:47   [FW] **TCP SYN Flooding** IP/TCP 94.31.191.122:52654->94.31.191.162:445
May/5/2009 22:24:47   [FW] **TCP SYN Flooding** IP/TCP 94.31.191.122:51586->94.31.191.162:445
May/5/2009 22:24:47   [FW] **TCP SYN Flooding** IP/TCP 94.31.191.122:60158->94.31.191.162:445
May/5/2009 22:24:47   [FW] **TCP SYN Flooding** IP/TCP 94.31.191.122:33816->94.31.191.162:445
May/5/2009 22:24:47   [FW] **TCP SYN Flooding** IP/TCP 94.31.191.122:19346->94.31.191.162:445
May/5/2009 22:24:47   [FW] **TCP SYN Flooding** IP/TCP 94.31.191.122:46222->94.31.191.162:445
May/5/2009 22:24:47   [FW] **TCP SYN Flooding** IP/TCP 94.31.191.122:26130->94.31.191.162:445
Также идет на порт 135, 139.
Прошивка последняя официальная 2,26.
Подскажите как решить проблему. Так как ничего не помогает.
Возможно ли, что это железная, а не программная проблема?
Проблема именно с маршрутником, так как тоже самое идет при отключенном компьютере.
СообщениеДобавлено: Ср май 06, 2009 18:56
Может техподдержка даст ответ на проблему.
СообщениеДобавлено: Ср май 06, 2009 21:04
Это ужасный Kido к тебе рвется, а роутер не пускает, радуйся.
СообщениеДобавлено: Чт май 07, 2009 06:56
Данное снято не с самого роутера, а с роутера который близко к нему подключем. И если не заметили, то это идет от маршрутника к другим машинам. И KIDO тут не причем.
СообщениеДобавлено: Чт май 07, 2009 09:37
>KIDO тут не причем.
Хорошо, пусть будет Randon. Таких червей (атакующих 445 порт) много. Но это уже не модно.
Кстати, Kido умеет проникать еще через авторан и почту - одного фаервола мало.
