Текущее время: Чт окт 29, 2026 23:06
Начать новую тему Ответить на тему  [ Сообщений: 164 ]  На страницу Пред.  1, 2, 3, 4, 5 ... 11  След.
СообщениеДобавлено: Чт апр 09, 2009 11:35
здесь в 22:10:55 сессия была отключена и далее не восстановилась.
Date/Time Facility Severity Message
Apr 8 21:27:28 user warn dnsprobe[630]: dns query failed
Apr 8 21:33:50 syslog info -- MARK --
Apr 8 21:34:14 user warn dnsprobe[630]: dns query failed
Apr 8 21:35:18 user warn dnsprobe[630]: dns query failed
Apr 8 21:36:01 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=88.252.82.134 DST=85.173.68.56 LEN=60 TOS=0x00 PREC=0x00 TTL=54 ID=23048 DF PROTO=TCP SPT=4696 DPT=23 WINDOW=5808 RES=0x00 SYN URGP=0
Apr 8 21:36:53 user warn dnsprobe[630]: dns query failed
Apr 8 21:36:55 user warn dnsprobe[630]: dns query failed
Apr 8 21:37:27 user warn dnsprobe[630]: dns query failed
Apr 8 21:38:00 user warn dnsprobe[630]: dns query failed
Apr 8 21:38:02 user warn dnsprobe[630]: dns query failed
Apr 8 21:39:37 user warn dnsprobe[630]: dns query failed
Apr 8 21:42:14 user warn dnsprobe[630]: dns query failed
Apr 8 21:42:47 user warn dnsprobe[630]: dns query failed
Apr 8 21:45:25 user warn dnsprobe[630]: dns query failed
Apr 8 21:46:07 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=85.173.18.101 DST=85.173.68.56 LEN=48 TOS=0x00 PREC=0x00 TTL=117 ID=42879 DF PROTO=TCP SPT=2261 DPT=445 WINDOW=64800 RES=0x00 SYN URGP=0
Apr 8 21:46:29 user warn dnsprobe[630]: dns query failed
Apr 8 21:47:02 user warn dnsprobe[630]: dns query failed
Apr 8 21:48:06 user warn dnsprobe[630]: dns query failed
Apr 8 21:50:12 user warn dnsprobe[630]: dns query failed
Apr 8 21:53:51 user warn dnsprobe[630]: dns query failed
Apr 8 21:53:53 user warn dnsprobe[630]: dns query failed
Apr 8 21:53:55 user warn dnsprobe[630]: dns query failed
Apr 8 21:53:55 user notice dnsprobe[630]: Primary DNS server Is Down... Switching To Secondary DNS server
Apr 8 21:54:26 user notice dnsprobe[630]: Switching Back To Primary DNS server
Apr 8 21:57:02 user warn dnsprobe[630]: dns query failed
Apr 8 21:57:43 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=85.121.248.236 DST=85.173.68.56 LEN=64 TOS=0x00 PREC=0x00 TTL=32 ID=44550 DF PROTO=TCP SPT=2107 DPT=135 WINDOW=53760 RES=0x00 SYN URGP=0
Apr 8 21:58:06 user warn dnsprobe[630]: dns query failed
Apr 8 21:59:41 user warn dnsprobe[630]: dns query failed
Apr 8 22:00:45 user warn dnsprobe[630]: dns query failed
Apr 8 22:01:49 user warn dnsprobe[630]: dns query failed
Apr 8 22:01:52 user warn dnsprobe[630]: dns query failed
Apr 8 22:02:25 user warn dnsprobe[630]: dns query failed
Apr 8 22:03:29 user warn dnsprobe[630]: dns query failed
Apr 8 22:04:02 user warn dnsprobe[630]: dns query failed
Apr 8 22:04:04 user warn dnsprobe[630]: dns query failed
Apr 8 22:05:08 user warn dnsprobe[630]: dns query failed
Apr 8 22:06:26 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=85.180.30.175 DST=85.173.68.56 LEN=64 TOS=0x00 PREC=0x00 TTL=37 ID=50273 DF PROTO=TCP SPT=3751 DPT=135 WINDOW=53760 RES=0x00 SYN URGP=0
Apr 8 22:06:43 user warn dnsprobe[630]: dns query failed
Apr 8 22:07:16 user warn dnsprobe[630]: dns query failed
Apr 8 22:08:19 user warn dnsprobe[630]: dns query failed
Apr 8 22:08:21 user warn dnsprobe[630]: dns query failed
Apr 8 22:08:23 user warn dnsprobe[630]: dns query failed
Apr 8 22:08:23 user notice dnsprobe[630]: Primary DNS server Is Down... Switching To Secondary DNS server
Apr 8 22:08:55 user warn dnsprobe[630]: dns query failed
Apr 8 22:08:57 user warn dnsprobe[630]: dns query failed
Apr 8 22:08:59 user warn dnsprobe[630]: dns query failed
Apr 8 22:09:31 user warn dnsprobe[630]: dns query failed
Apr 8 22:09:33 user warn dnsprobe[630]: dns query failed
Apr 8 22:09:34 user notice dnsprobe[630]: Switching Back To Primary DNS server
Apr 8 22:10:07 user warn dnsprobe[630]: dns query failed
Apr 8 22:10:09 user warn dnsprobe[630]: dns query failed
Apr 8 22:10:11 user warn dnsprobe[630]: dns query failed
Apr 8 22:10:11 user notice dnsprobe[630]: Primary DNS server Is Down... Switching To Secondary DNS server
Apr 8 22:10:34 syslog info -- MARK --
Apr 8 22:10:43 user warn dnsprobe[630]: dns query failed
Apr 8 22:10:45 user warn dnsprobe[630]: dns query failed
Apr 8 22:10:46 user notice dnsprobe[630]: Switching Back To Primary DNS server
Apr 8 22:10:55 daemon crit pppd[274]: Clear IP addresses. Connection DOWN.
Apr 8 22:10:55 daemon crit pppd[274]: Clear IP addresses. PPP connection DOWN.
Apr 8 22:11:01 daemon notice pppd[274]: PPP: Start to connect ...
Apr 8 22:11:01 daemon crit pppd[274]: PPP server detected.
Apr 8 22:11:04 daemon notice pppd[274]: PPP: Start to connect ...
Apr 8 22:11:04 daemon crit pppd[274]: PPP server detected.
Apr 8 22:11:07 daemon notice pppd[274]: PPP: Start to connect ...
Apr 8 22:11:07 daemon crit pppd[274]: PPP server detected.
Apr 8 22:11:10 daemon notice pppd[274]: PPP: Start to connect ...
Apr 8 22:11:11 daemon crit pppd[274]: PPP server detected.
Apr 8 22:11:11 daemon crit pppd[274]: PPP session established.
Apr 8 22:11:12 daemon crit pppd[274]: PPP LCP UP.
Apr 8 22:11:18 user warn dnsprobe[630]: dns query failed
Apr 8 22:11:20 user warn dnsprobe[630]: dns query failed
Apr 8 22:11:22 user warn dnsprobe[630]: dns query failed
Apr 8 22:11:22 user notice dnsprobe[630]: Primary DNS server Is Down... Switching To Secondary DNS server
Apr 8 22:11:42 daemon err pppd[274]: User name and password authentication failed.
Apr 8 22:11:46 daemon notice pppd[274]: PPP: Start to connect ...
Apr 8 22:11:46 daemon crit pppd[274]: PPP server detected.
Apr 8 22:11:49 daemon notice pppd[274]: PPP: Start to connect ...
Apr 8 22:11:49 daemon crit pppd[274]: PPP server detected.
Apr 8 22:11:49 daemon crit pppd[274]: PPP session established.
Apr 8 22:11:54 user warn dnsprobe[630]: dns query failed
Apr 8 22:11:56 user warn dnsprobe[630]: dns query failed
Apr 8 22:11:58 user warn dnsprobe[630]: dns query failed
Apr 8 22:12:01 daemon notice pppd[274]: PPP: Start to connect ...
Apr 8 22:12:01 daemon crit pppd[274]: PPP server detected.
Apr 8 22:12:04 daemon notice pppd[274]: PPP: Start to connect ...
Apr 8 22:12:04 daemon crit pppd[274]: PPP server detected.
Apr 8 22:12:04 daemon crit pppd[274]: PPP session established.
Apr 8 22:12:16 daemon notice pppd[274]: PPP: Start to connect ...
Apr 8 22:12:16 daemon crit pppd[274]: PPP server detected.
Apr 8 22:12:16 daemon crit pppd[274]: PPP session established.
Apr 8 22:12:28 daemon notice pppd[274]: PPP: Start to connect ...
Apr 8 22:12:28 daemon crit pppd[274]: PPP server detected.
Apr 8 22:12:30 user warn dnsprobe[630]: dns query failed
Apr 8 22:12:31 daemon notice pppd[274]: PPP: Start to connect ...
Apr 8 22:12:31 daemon crit pppd[274]: PPP server detected.
Apr 8 22:12:31 daemon crit pppd[274]: PPP session established.
Apr 8 22:12:32 user warn dnsprobe[630]: dns query failed
Apr 8 22:12:34 user warn dnsprobe[630]: dns query failed
dsl-2540u_RU ЮТК Волгоград
СообщениеДобавлено: Чт апр 09, 2009 11:50
tundra37 писал(а):
Проблема с биллингом(а не снятием статистики) существует не только у вашего провайдера. Проблема именно провайдера и на D-Link не надо ее сваливать. Народ ее решает через скрипты/программы автоматической перезагрузки. Для какой-то модели делали прошивку, но по-моему тема заглохла. Провайдер быстро ее тоже решать не будет, т.к. это выльется в большую КОПЕЕЧКУ. Втюхали им кривое оборудование и что прикажете делать ?
Биллинг (англ. billing — составление счёта) — в некоторых видах бизнеса, в частности в телекоммуникациях — автоматизированная система учёта предоставленных услуг, их тарификации и выставления счетов для оплаты.
Стати́стика — отрасль знаний , в которой излагаются общие вопросы сбора, измерения и анализа массовых статистических (количественных или качественных) данных. (можно отнести и к сбору и анализу трафика)
моё мнение, что биллинг и снятие статистики -- это одно и тоже
СообщениеДобавлено: Чт апр 09, 2009 14:36
Дело не в смысле. Просто на форумах по ADSL-модемам термин биллинг употребляется. А у тебя неправильный подход. Всегда надо посмотреть что до этого было. И про dns probe failed и про разрыв при биллинге исписано тонны байт :-) А ты начинаешь изобретать велосипед. У нашего провайдера нет разрыва при биллинге - значит проблема решаема? Какой ценой - это уже другой вопрос. Я так подозреваю, что раздали глючные DSLAM в глухие углы нашей области, а себе(нам) поставили получше.
Последний раз редактировалось tundra37 Чт апр 09, 2009 15:20, всего редактировалось 1 раз.
СообщениеДобавлено: Чт апр 09, 2009 14:41
Если ты такой умный и термины все знаешь, может нам глупым посоветуешь как убрать данную проблему? А если ты такой же чайник как и все, то и не выеживайся!
СообщениеДобавлено: Чт апр 09, 2009 14:54
tundra37 писал(а):
Проблема с биллингом(а не снятием статистики) существует не только у вашего провайдера. Проблема именно провайдера и на D-Link не надо ее сваливать. Провайдер быстро ее тоже решать не будет, т.к. это выльется в большую КОПЕЕЧКУ. Втюхали им кривое оборудование и что прикажете делать ?
Извините, если не восстанавливается соединение после обрыва со стороны провайдера это проблема провайдера? С чего бы? Почему-то например на Acorp'ах и некоторых др. модемах соединение без проблем поднимается.
СообщениеДобавлено: Чт апр 09, 2009 15:14
To: tundra37
на dlink в этой теме никто и не сваливает
я лишь хочу чтобы dlink и ЮТК разобрались в данной проблеме, которая встречается у многих.
И совместными усилиями наладили работу оборудования. Возможно что прошивку на наш модем напишут либо настройки оборудования ЮТК сделают.
Повторюсь ---2 года работало отлично всё. но с января месяца начались эти проблемы.
На счёт слова "статистика" --его употребляет и наш провайдер также как и слово биллинг. поэтому для меня разницы нет. И то как употребляют слово БИЛЛИНГ в этом форуме мне честно говоря наплевать. смысл у этих слов одинаковый. Я подстраиваться не собираюсь. Хоть ты его называй биллингом хоть статистикой ---проблема от этого не решится.
а всякие батники и скрипты --- это всё чушь. Сессия восстанавливается только при выкл-вкл модема.
представь, едешь на своём авто, вдруг резкий тормоз, машина сама останавливается чтобы наш спидометр сделал биллинг? нормально? и чтобы она ехала дальше, надо откинуть клемму с аккумулятора, либо придумать устройство которое само бы снимала клемму с аккумулятора---автоматизировать процесс.
СообщениеДобавлено: Чт апр 09, 2009 15:49
Ну тогда напишу точнее - это проблема "роста". Сколько появилось новых моделей D-Link и сколько Акорп ? Завтра провайдеры сменят свое железо на "нормальное" и где будет Акорп ? Слишком уж все быстро меняется, а у нас еще и делают все через одно место...
Сегодня прочел : "Диск ДВД-Караоке BBK c русскими народными песнями, страна производитель .... :roll: Китай"
СообщениеДобавлено: Пт апр 10, 2009 13:09
Чтобы решить проблему, надо знать причину. Мы пока знаем "косвенную причину" - режим роутера. Я с подачи других умников считал, что дело в реализации протокола PPPoE, забыв что есть и другие причины. Советую взглянуть сюда (пост #14)
http://www.wl500g.info/showthread.php?p=120973
Т.ч. надо рыть много и глубоко и думаю сотрудники D-Link это и делают. А вот некоторые товарищи считают, что все можно исправить в две строчки.
На половину OFFTOPIC
Тут кстати подумал, Акорп вот хорошо работает. Ну и что же наши прилавки им не завалены ? Неужели какой-то злой дядька мешает ?
Придется жить по реалиям, а не по хотению.
СообщениеДобавлено: Пт апр 10, 2009 15:10
To supervisor82, Hunter34
Пожалуйста, попробуйте проделать следующее:
Зайдите на модем по telnet, авторизуйтесь и выполните две команды:
echo 10240 > /proc/sys/net/ipv4/ipfrag_low_thresh
echo 22000 > /proc/sys/net/ipv4/ipfrag_high_thresh
После чего, не перезагружая модем (т.к. после перезагрузки настройки будут сброшены), оставьте его работать на некоторое время и понаблюдайте - сохранится ли проблема?
О результате напишите.
dsl-2500u_SYN_attack_issue.jpg [ 39.67 KiB | Просмотров: 4942 ]
СообщениеДобавлено: Пт апр 10, 2009 15:47
To: Alexander Gorelik
спасибо, что занимаетесь решением нашей проблемы.
команды запустил, о результатах отпишусь.
СообщениеДобавлено: Пт апр 10, 2009 17:13
Команду не запустил. Модем пережил "разрыв". Когда повиснет, запущу. Так сказать, чтоб не портить статистику.
СообщениеДобавлено: Пт апр 10, 2009 22:56
Добавил настройки в модем. Ждем 8 часов.
СообщениеДобавлено: Сб апр 11, 2009 07:16
Счастье (с)
Apr 11 07:53:32 daemon crit pppd[315]: Clear IP addresses. Connection DOWN.
Apr 11 07:53:32 daemon crit pppd[315]: Clear IP addresses. PPP connection DOWN.
Apr 11 07:53:38 daemon notice pppd[315]: PPP: Start to connect ...
Apr 11 07:53:38 daemon crit pppd[315]: PPP server detected.
Apr 11 07:53:41 daemon notice pppd[315]: PPP: Start to connect ...
Apr 11 07:53:42 daemon crit pppd[315]: PPP server detected.
Apr 11 07:53:42 daemon crit pppd[315]: PPP session established.
Apr 11 07:53:42 daemon crit pppd[315]: PPP LCP UP.
Apr 11 07:53:43 daemon crit pppd[315]: Received valid IP address from server. Connection UP.
Наблюдаем дальше.
СообщениеДобавлено: Сб апр 11, 2009 09:33
у меня 2 реконнекта пережил уже после ввода команды.
10.04.2009, 21:51:53, DAEMON, CRITICAL, pppd[274]: Clear IP addresses. Connection DOWN.
10.04.2009, 21:51:53, DAEMON, CRITICAL, pppd[274]: Clear IP addresses. PPP connection DOWN.
10.04.2009, 21:51:59, DAEMON, NOTICE, pppd[274]: PPP: Start to connect ...
10.04.2009, 21:51:59, DAEMON, CRITICAL, pppd[274]: PPP server detected.
10.04.2009, 21:52:02, DAEMON, NOTICE, pppd[274]: PPP: Start to connect ...
10.04.2009, 21:52:02, DAEMON, CRITICAL, pppd[274]: PPP server detected.
10.04.2009, 21:52:05, DAEMON, NOTICE, pppd[274]: PPP: Start to connect ...
10.04.2009, 21:52:05, DAEMON, CRITICAL, pppd[274]: PPP session established.
10.04.2009, 21:52:05, DAEMON, CRITICAL, pppd[274]: PPP LCP UP.
10.04.2009, 21:52:06, DAEMON, CRITICAL, pppd[274]: Received valid IP address from server. Connection UP.
наблюдаем дальше
СообщениеДобавлено: Сб апр 11, 2009 13:16
после двух удачных реконнектов на 3-ий завис
11.04.2009, 13:37:24, USER, ALERT, kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=85.115.102.156 DST=85.173.68.56 LEN=48 TOS=0x00 PREC=0x20 TTL=116 ID=21480 DF PROTO=TCP SPT=65146 DPT=40183 WINDOW=8192 RES=0x00 SYN URGP=0
11.04.2009, 13:47:24, USER, ALERT, kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=85.173.65.94 DST=85.173.68.56 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=60719 DF PROTO=TCP SPT=24154 DPT=445 WINDOW=64240 RES=0x00 SYN URGP=0
11.04.2009, 13:51:37, SYSLOG, INFO, -- MARK --
11.04.2009, 13:51:59, USER, WARNING, dnsprobe[602]: dns query failed
11.04.2009, 13:52:01, USER, WARNING, dnsprobe[602]: dns query failed
11.04.2009, 13:52:03, USER, WARNING, dnsprobe[602]: dns query failed
11.04.2009, 13:52:03, USER, NOTICE, dnsprobe[602]: Primary DNS server Is Down... Switching To Secondary DNS server
11.04.2009, 13:52:21, DAEMON, CRITICAL, pppd[274]: Clear IP addresses. Connection DOWN.
11.04.2009, 13:52:21, DAEMON, CRITICAL, pppd[274]: Clear IP addresses. PPP connection DOWN.
11.04.2009, 13:52:27, DAEMON, NOTICE, pppd[274]: PPP: Start to connect ...
11.04.2009, 13:52:27, DAEMON, CRITICAL, pppd[274]: PPP server detected.
11.04.2009, 13:52:30, DAEMON, NOTICE, pppd[274]: PPP: Start to connect ...
11.04.2009, 13:52:30, DAEMON, CRITICAL, pppd[274]: PPP server detected.
11.04.2009, 13:52:30, DAEMON, CRITICAL, pppd[274]: PPP session established.
11.04.2009, 13:52:35, USER, WARNING, dnsprobe[602]: dns query failed
11.04.2009, 13:52:37, USER, WARNING, dnsprobe[602]: dns query failed
11.04.2009, 13:52:39, USER, WARNING, dnsprobe[602]: dns query failed
11.04.2009, 13:52:42, DAEMON, NOTICE, pppd[274]: PPP: Start to connect ...
11.04.2009, 13:52:42, DAEMON, CRITICAL, pppd[274]: PPP server detected.
11.04.2009, 13:52:45, DAEMON, NOTICE, pppd[274]: PPP: Start to connect ...
11.04.2009, 13:52:46, DAEMON, CRITICAL, pppd[274]: PPP server detected.
11.04.2009, 14:03:29, DAEMON, NOTICE, pppd[274]: PPP: Start to connect ...
11.04.2009, 14:03:29, DAEMON, CRITICAL, pppd[274]: PPP server detected.
11.04.2009, 14:03:32, DAEMON, NOTICE, pppd[274]: PPP: Start to connect ...
11.04.2009, 14:03:32, DAEMON, INFO, pppd[274]: Exit.
11.04.2009, 14:03:59, USER, WARNING, dnsprobe[602]: dns query failed
11.04.2009, 14:04:01, USER, WARNING, dnsprobe[602]: dns query failed
11.04.2009, 14:04:03, USER, WARNING, dnsprobe[602]: dns query failed
11.04.2009, 14:04:35, USER, WARNING, dnsprobe[602]: dns query failed
11.04.2009, 14:04:37, USER, WARNING, dnsprobe[602]: dns query failed
11.04.2009, 14:04:39, USER, WARNING, dnsprobe[602]: dns query failed
Последний раз редактировалось supervisor82 Пн апр 13, 2009 09:14, всего редактировалось 1 раз.
