Текущее время: Вс сен 27, 2026 12:01
Начать новую тему Ответить на тему  [ Сообщений: 29 ]  На страницу Пред.  1, 2
СообщениеДобавлено: Чт фев 19, 2009 19:50
У меня тоже самое в логах, притом ни каких торентов нету, просто открываю nnm.ru или rambler.ru и сессия обрывается загрувив только половину странички..
СообщениеДобавлено: Чт фев 19, 2009 21:36
[Thu Feb 19 23:15:26 2009]:[PPP] Got Secondary DNS address 87.224.213.1
[Thu Feb 19 23:15:26 2009]:[PPP] Got Primary DNS address 87.224.197.1
[Thu Feb 19 23:15:26 2009]:[PPP] Got local IP 94.31.198.121
[Thu Feb 19 23:15:26 2009]:[PPP] Got gateway IP 172.30.0.1
[Thu Feb 19 23:15:26 2009]:[PPP] ipcp up
[Thu Feb 19 23:15:26 2009]:[PPP] start lcp stage
[Thu Feb 19 23:15:26 2009]:[PPTP] pptp start up
[Thu Feb 19 23:15:24 2009]:[PPTP] pptp close
[Thu Feb 19 23:15:22 2009]:[PPP] ipcp down
[Thu Feb 19 23:12:26 2009]:[DHCPD] broadcasting packet to client
[Thu Feb 19 23:12:26 2009]:[DHCPD] sending ACK to 192.168.5.100
[Thu Feb 19 23:12:26 2009]:[DHCPD] received REQUEST
[Thu Feb 19 23:12:22 2009]:[PPP] Got Secondary DNS address 87.224.213.1
[Thu Feb 19 23:12:22 2009]:[PPP] Got Primary DNS address 87.224.197.1
[Thu Feb 19 23:12:22 2009]:[PPP] Got local IP 94.31.198.121
[Thu Feb 19 23:12:22 2009]:[PPP] Got gateway IP 172.30.0.1
[Thu Feb 19 23:12:22 2009]:[PPP] ipcp up
[Thu Feb 19 23:12:22 2009]:[PPP] start lcp stage
[Thu Feb 19 23:12:22 2009]:[PPTP] pptp start up
[Thu Feb 19 23:12:16 2009]:[PPTP] pptp close
[Thu Feb 19 23:12:16 2009]:[PPP] ipcp down
[Thu Feb 19 22:30:02 2009]:[DHCPD] unicasting packet to client ciaddr
[Thu Feb 19 22:30:02 2009]:[DHCPD] received INFORM
[Thu Feb 19 21:07:22 2009]:[DHCPD] unicasting packet to client ciaddr
[Thu Feb 19 21:07:22 2009]:[DHCPD] received INFORM
[Thu Feb 19 19:06:09 2009]:[DHCPD] unicasting packet to client ciaddr
[Thu Feb 19 19:06:09 2009]:[DHCPD] received INFORM
[Thu Feb 19 19:05:04 2009]:[DHCPD] broadcasting packet to client
[Thu Feb 19 19:05:04 2009]:[DHCPD] sending ACK to 192.168.5.100
[Thu Feb 19 19:05:04 2009]:[DHCPD] received REQUEST
[Thu Feb 19 19:01:30 2009]:[DHCPD] unicasting packet to client ciaddr
[Thu Feb 19 19:01:30 2009]:[DHCPD] received INFORM
[Thu Feb 19 19:00:28 2009]:[DHCPD] unicasting packet to client ciaddr
[Thu Feb 19 19:00:28 2009]:[DHCPD] sending ACK to 192.168.5.100
[Thu Feb 19 19:00:28 2009]:[DHCPD] received REQUEST
[Thu Feb 19 19:00:26 2009]:[DHCPD] broadcasting packet to client
[Thu Feb 19 19:00:26 2009]:[DHCPD] sending ACK to 192.168.5.100
[Thu Feb 19 19:00:26 2009]:[DHCPD] received REQUEST
[Thu Feb 19 18:54:20 2009]:[DHCPD] unicasting packet to client ciaddr
[Thu Feb 19 18:54:20 2009]:[DHCPD] received INFORM
И так перезагрузок небыло, тоесть небыло system start в логах.
Произошло следующее. Сетевая карта сообщила, что отключилась и подключилась опять. После того как зашел на маршрутник увидел что он в сети, но связи с интернетом небыло, через какое то время он сам переподключился и связь восстановилась.
Нагрузка не более 100 сессий, от 40 до 70 в среднем.
Но главное, что удивительно, он долго держался прежде чем отвалился.
В DC++ качает не более 5 человек, скорость разная, от мегабайта в секунду, до нескольких килобайт.
Прошивка 202и10
У провайдера с впн все в порядке, крайне редко бывают проблемы с впн. Следователь разорвать он мог только по своей инициативе.
Если будет нужен сниф, скажите только чем снять и как.
Еще вопрос, может он себя так вести из-за syn flood атак?
СообщениеДобавлено: Пт фев 27, 2009 15:10
И у меня тож самое ( Обновление сделал...
СообщениеДобавлено: Пт фев 27, 2009 15:15
Такой происходит только при использовании P2P програм?
СообщениеДобавлено: Пт фев 27, 2009 15:29
Выкинул я DIR100 :)
СообщениеДобавлено: Вс мар 15, 2009 12:14
В общем на последней прошивке он все равно перегружается.
Бывает держит и 1000 сессий, а бывает и на 100 перегружается. Почему он это делает определить не удается но видно что он это делает, причем после этого он еще и виснит.
Зайти на него можно, а дальше никуда. Никаких адресов не пингует.
Блин надо DIR-655 покупать, но он подорожал зараза.
с 3000 до 5500 рублей взлетел.
В общем поработайте с ним и может сваяете ему нормальную прошивку.
СообщениеДобавлено: Вс мар 15, 2009 20:45
Тут проверка показала следующее после того как произошло это
Mar/15/2009 22:42:30   [PPP] Got Secondary DNS address 87.224.213.1
Mar/15/2009 22:42:30   [PPP] Got Primary DNS address 87.224.197.1
Mar/15/2009 22:42:30   [PPP] Got local IP 94.31.191.121
Mar/15/2009 22:42:30   [PPP] Got gateway IP 172.30.0.1
Mar/15/2009 22:42:30   [PPP] ipcp up
Mar/15/2009 22:42:30   [PPP] start lcp stage
Mar/15/2009 22:42:12   [PPTP] pptp start up
Mar/15/2009 22:42:10   [PPTP] pptp close
Mar/15/2009 22:42:09   [PPP] start lcp stage
Mar/15/2009 22:42:09   [PPTP] pptp start up
Mar/15/2009 22:42:05   [PPTP] pptp close
Mar/15/2009 22:42:05   [PPP] ipcp down
связь не восстанавливается, только если отключить и подключить VPN.
СообщениеДобавлено: Пн мар 16, 2009 10:06
Это тут не причем. По пводу перезагрузок, это происходит под нагрузкой или без? Вы используете dual access pptp? Сколько маршрутов прописано?
СообщениеДобавлено: Пн мар 16, 2009 10:41
Подтверждаю периодические перезагрузки на прошивке dir100_v202_en_b10.bin. Подключение dual access pptp. Маршрутов прописано 3. Основную нагрузку создает DC++, кстати стоит ограничение до 2 Мбит. Перезагрузки нечастые и безсистемные, видимо когда возрастает количество скачивающих.
DIR-100B1 FW: v2.03(EN),
DAP-1360B1 FW: v2.12
СообщениеДобавлено: Пн мар 16, 2009 11:50
Да dual access pptp оператор KABiNET екатеринбург.
Никаких маршрутов нет.
Все идет через VPN, без него до внутрисетевых ресурсов провайдера не добраться.
Стоят и FTP и DC++, при этом не сказать что много скачивающих.
Бывает не больше 5, ну и торрент на раздачи, но с него не более 20 килобайт/сек. Скорость аплоада не больше 1,5Мбайт/сек.
А можно сделать так, чтоб он процессор не напрягал.
Чтобы поднял VPN и поменьше думал куда, что отправить.
Максимум включается два компьютера. Постоянно работает один, второй время от времени. На первом висит ftp, dc++, utorrent. Ну и в интернет я чаще с него хожу.
P.S
Прописал 4-е маршрута на ИП сети провайдера.
И один на всю сеть 0.0.0.0 mask 255.255.255.255. Посмотрим может это поможет. Может он думать меньше будет. (Хотя есть сомнения в этом предприятии).
СообщениеДобавлено: Пн мар 16, 2009 13:44
И что это за ошибка такая
Mar/16/2009 15:33:52   [DHCPD] error on dhcpd_rcv
Mar/16/2009 15:03:52   [DHCPD] error on dhcpd_rcv
Появилась после настройки маршрутизации.
Шлюз по VPN 94.31.191.1
Настройки маршрутизации. (для примера)
WAN
Destination 94.31.128.0
Subnet Mask 255.255.128.0
Gateway 94.31.191.1
Последний раз редактировалось Gromila Ср мар 18, 2009 12:58, всего редактировалось 1 раз.
СообщениеДобавлено: Ср мар 18, 2009 09:22
Кстати, если уж будете повышать стабильность прошивки, исправьте попутно еще два "бага":
1. Setup -> Internet Setup -> Manual Connection Options (Internet Connection Setup Wizard) есть кнопка "Duplicate MAC address from the customer end", при нажатии меняется на "Clone MAC Address", а должно быть, наверное, что-то вроде "Restore MAC address". Мелочь, но сбивает с толку.
2.Этот уже где-то описывали на форуме. На странице Maintence -> FirmWare Update в самом низу читаем Fireware Upgrade Notification Options (а должно быть, наверное, Firmware Upgrade Notification Options).
Зараннее спасибо. Идеальная прошивка уже совсем близко :)
СообщениеДобавлено: Ср мар 18, 2009 12:57
И так, предварительные, но не окончательные итоги заставить этот маршрутизатор меньше думать.
Прописал статические маршруты.
Dir-100 стал держит более 1000 сессий без перезагрузок.
Пока вроде перестал отключать сетевой кабель LAN.
Уже два дня без перезагрузок при активных в среднем 500 сессиях.
Пока с меня не нагружали канал, когда на клиента приходится до 1Мб/с.
Посмотрим когда пойдет такая нагрузка как он себя будет вести.
При этом при таком количестве сессий я могу боле-менее ходить в интернет.
То есть статические маршруты, предварительно заставили его меньше думать процессором, а больше заниматься своими прямыми обязанностями.
А именно поддержкой VPN соединения и выдачей трафика в LAN порты.
Отправил ИП 4-е диапазона адресов на шлюз провайдера и 0.0.0.0 туда же.
Будем смотреть что будет дальше.
СообщениеДобавлено: Чт мар 19, 2009 16:51
И так могу сказать следующее, нагрузку после прописки
статических маршрутов стабильность возросла.
Перезагрузок не наблюдается даже под нагрузкой.
Нет отключения порта LAN. Тоесть винда больше не говорит, что кабель не подключен.
В общем похоже проблема теоретически решена, осталось еще неделю потестировать. И можно сказать, проблема была в том, что он слишком много думает, после прописки он ориентируется на них, а не думает что куда отправить.
Но ошибка [DHCPD] error on dhcpd_rcv не пропадает, периодически возникает вновь.
