Текущее время: Чт июн 11, 2026 22:01
Начать новую тему Ответить на тему  [ Сообщений: 31 ]  На страницу 1, 2, 3  След.
 Заголовок сообщения: 2500U/BRU/D и прошивка RU_1.50_03042009
СообщениеДобавлено: Ср мар 11, 2009 16:13
Jan 1 00:00:36     user     warn     kernel: adsl: adsl_init entry
Jan 1 00:00:36    user    warn    kernel: blaadd: blaa_detect entry
Jan 1 00:00:36    user    info    kernel: Broadcom BCMPROCFS v1.0 initialized
Jan 1 00:00:36    user    warn    kernel: Broadcom BCM6338A2 Ethernet Network Device v0.3 Mar 4 2009 21:09:19
Jan 1 00:00:36    user    warn    kernel: Config Internal PHY Through MDIO
Jan 1 00:00:36    user    info    kernel: BCM63xx_ENET: 100 MB Full-Duplex (auto-neg)
Jan 1 00:00:36    user    warn    kernel: eth0: MAC Address: 00:1E:58:47:2B:CF
Jan 1 00:00:36    user    crit    kernel: eth0 Link UP.
Jan 1 00:00:36    user    warn    kernel: BcmAdsl_Initialize=0xC0068A08, g_pFnNotifyCallback=0xC00816D4
Jan 1 00:00:36    user    warn    kernel: AnnexCParam=0x7FFF7EB8 AnnexAParam=0x00000980 adsl2=0x00000000
Jan 1 00:00:36    user    warn    kernel: pSdramPHY=0xA07FFFF8, 0x1B77EF 0xDEADBEEF
Jan 1 00:00:36    user    warn    kernel: AdslCoreHwReset: AdslOemDataAddr = 0xA07EF96C
Jan 1 00:00:36    user    warn    kernel: dgasp: kerSysRegisterDyingGaspHandler: dsl0 registered
Jan 1 00:00:36    user    warn    kernel: ATM proc init !!!
Jan 1 00:00:36    user    crit    kernel: ADSL G.994 training
Jan 1 00:00:36    user    warn    kernel: ip_tables: (C) 2000-2002 Netfilter core team
Jan 1 00:00:36    user    warn    kernel: ip_conntrack version 2.1 (61 buckets, 0 max) - 376 bytes per conntrack
Jan 1 00:00:36    user    warn    kernel: ip_conntrack_pptp version 2.1 loaded
Jan 1 00:00:36    user    warn    kernel: ip_nat_pptp version 2.0 loaded
Jan 1 00:00:36    user    warn    kernel: unregistering helper for port 5060
Jan 1 00:00:36    user    crit    kernel: ADSL G.992 started
Jan 1 00:00:36    user    info    kernel: device eth0 entered promiscuous mode
Jan 1 00:00:36    user    info    kernel: br0: port 1(eth0) entering learning state
Jan 1 00:00:36    user    info    kernel: br0: topology change detected, propagating
Jan 1 00:00:36    user    info    kernel: br0: port 1(eth0) entering forwarding state
Jan 1 00:00:36    user    info    kernel: device nas_0_1_32 entered promiscuous mode
Jan 1 00:00:36    user    info    kernel: br0: port 2(nas_0_1_32) entering learning state
Jan 1 00:00:36    user    info    kernel: br0: port 2(nas_0_1_32) entering forwarding state
Jan 1 00:00:37    user    debug    syslog: pppd -c 0.1.32.1 -i nas_0_1_32 -u az003258@dsl.ukrtel.net -p ******** -f 0 -k &
Jan 1 00:00:37    user    crit    kernel: ADSL G.992 channel analysis
Jan 1 00:00:38    daemon    notice    pppd[277]: pppd 2.4.1 started by admin, uid 0
Jan 1 00:00:44    user    crit    kernel: ADSL G.992 message exchange
Jan 1 00:00:45    user    crit    kernel: ADSL link up, interleaved, us=1244, ds=2463
Jan 1 00:00:45    user    warn    kernel: ADSL2/ADSL2+ connection
Jan 1 00:00:45    user    warn    kernel: ATM Soft SAR: ATM link connected.
Jan 1 00:00:46    user    debug    syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Jan 1 00:00:47    daemon    notice    pppd[277]: PPP: Start to connect ...
Jan 1 00:01:13    daemon    notice    pppd[277]: PPP: Start to connect ...
Jan 1 00:01:39    daemon    notice    pppd[277]: PPP: Start to connect ...
Jan 1 00:02:05    daemon    notice    pppd[277]: PPP: Start to connect ...
Jan 1 00:02:31    daemon    notice    pppd[277]: PPP: Start to connect ...
Jan 1 00:02:57    daemon    notice    pppd[277]: PPP: Start to connect ...
Jan 1 00:03:23    daemon    notice    pppd[277]: PPP: Start to connect ...
Без предположений и комментариев. Нет слов... Вернулся на RU_1.40_12252008
 Заголовок сообщения: Re: 2500U/BRU/D и прошивка RU_1.50_03042009
СообщениеДобавлено: Ср мар 11, 2009 16:27
    Jan 1 00:00:37 user debug syslog: pppd -c 0.0.35.1 -i nas_0_0_35 -u test -p **** -f 0 -k -m 00900b07a760/0001 &
    Jan 1 00:00:38 daemon notice pppd[290]: pppd 2.4.1 started by admin, uid 0
    Jan 1 00:00:39 user crit kernel: ADSL G.992 started
    Jan 1 00:00:43 user crit kernel: ADSL G.992 channel analysis
    Jan 1 00:00:49 user crit kernel: ADSL G.992 message exchange
    Jan 1 00:00:49 user crit kernel: ADSL link up, interleaved, us=1065, ds=23629
    Jan 1 00:00:49 user warn kernel: ADSL2/ADSL2+ connection
    Jan 1 00:00:49 user warn kernel: ATM Soft SAR: ATM link connected.
    Jan 1 00:00:51 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
    Jan 1 00:00:52 daemon notice pppd[290]: PPP: Start to connect ...
    Jan 1 00:00:52 daemon crit pppd[290]: PPP server detected.
    Jan 1 00:00:52 daemon crit pppd[290]: PPP session established.
    Jan 1 00:00:56 daemon crit pppd[290]: PPP LCP UP.
    Jan 1 00:00:56 daemon crit pppd[290]: Received valid IP address from server. Connection UP.
    Jan 1 00:00:56 user debug syslog: route add default gw 192.168.201.200 2>/dev/null
    Jan 1 00:00:56 user debug syslog: iptables -A FORWARD -o ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
    Jan 1 00:00:57 user debug syslog: iptables -A FORWARD -i ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
    Jan 1 00:00:57 user debug syslog: echo > /proc/net/ip_conntrack
    Jan 1 00:00:57 user debug syslog: echo "600" > /proc/sys/net/ipv4/ip_conntrack_max
    Jan 1 00:00:57 user debug syslog: echo 2000 > /proc/sys/net/ipv4/netfilter/ip_conntrack_generic_timeout
    Jan 1 00:00:57 user debug syslog: echo 600 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_established
    Jan 1 00:00:57 user debug syslog: echo 1400 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_fin_wait
    Jan 1 00:00:57 user debug syslog: echo 2000 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_time_wait
    Jan 1 00:00:57 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
    Jan 1 00:00:57 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
    Jan 1 00:00:57 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
    Jan 1 00:00:57 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 192.168.100.1 2>/dev/null
    Jan 1 00:00:57 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 192.168.100.1
    Jan 1 00:00:57 user debug syslog: /bin/dnsprobe &
    Jan 1 00:00:58 user notice dnsprobe[470]: dnsprobe started!
СообщениеДобавлено: Ср мар 11, 2009 16:59
Тоже прошил только что RU_DSL-2500U_BRU_D_1.50_03042009
Завелось все с первого раза, без проблем. UPnP потестил - работает нормально.
DSL-2500U/BRU/D1 | F/W 1.58 | Укртелеком ОГО! - 10
СообщениеДобавлено: Ср мар 11, 2009 18:47
Прошил еще раз. Все заработало, пока без проблем. Что это было, неизвестно.
СообщениеДобавлено: Чт мар 12, 2009 00:49
Заметил особенность. При использовании DMZ, UPnP не работает ( для остальных машин). Т.е. формально все происходит правильно, и даже правила появляются в iptables, но порты все равно остаются закрытыми.
СообщениеДобавлено: Чт мар 12, 2009 16:19
Прошивки RU_DSL-2500U_BRU_D_1.50_02162009 и RU_DSL-2500U_BRU_D_1.50_03042009 выдают следующее:
Test the connection to your DSL service provider
Test ADSL Synchronization: PASS Help
Test ATM OAM F5 segment ping: FAIL Help
Test ATM OAM F5 end-to-end ping: FAIL Help
Откатился обратно на RU_DSL-2500U_BRU_D_1.40_12252008
Test ATM OAM F5 segment ping: PASS Help
Test ATM OAM F5 end-to-end ping: PASS Help
от такэ
DSL-2500U/BRU/D | F/W 1.55 | Vegatele.com
Последний раз редактировалось Halk Чт мар 12, 2009 21:02, всего редактировалось 1 раз.
СообщениеДобавлено: Чт мар 12, 2009 16:59
После перепрошивки, нужно загрузить конфиг по умолчанию, который прилагается в архиве с прошивкой. После настроить соединение заново. Еще помогают галочку Bridge PPPoE Frames Between WAN and Local Ports а также Enable WAN Service и для некоторых провайдеров Enable IGMP Multicast но только после загрузки дефолтного конфига и настройки соединения заново.
СообщениеДобавлено: Чт мар 12, 2009 17:38
Я вообще этот конфиг не грузил, а сбросил модем после перепрошивки через веб-интерфейс.
СообщениеДобавлено: Чт мар 12, 2009 19:14
сделал по вашему совету, настройки ввёл вручную ничего не изменилось.
Откатился на 1.40
СообщениеДобавлено: Чт мар 12, 2009 22:22
Странно. А если оставить только Bridge PPPoE Frames Between WAN and Local Ports и Enable WAN Service, а Enable IGMP Multicast не включать? Кстати, у меня провайдер тоже Вегателеком.
СообщениеДобавлено: Чт мар 12, 2009 23:54
Попробовал, тоже не помогло.
Test ATM OAM F5 segment ping: F4/F5 FAIL Help
Test ATM OAM F5 end-to-end ping: F4/F5 FAIL Help
Предыдущие прошивки были без этой проблемы. Подожду другую версию.
СообщениеДобавлено: Пт мар 13, 2009 00:19
Так а интернет работает? У меня тоже там пишет Fail, как-то побоку оно
СообщениеДобавлено: Пт мар 13, 2009 01:16
Инет работает и скорость не страдает, но иногда такое впечатление что начинает затупливать. Например некоторые сайты не полностью загружаются, какое-то время тупят потом догружается остальное, с F\W 1.40 на этих же сайтах такого не заметил.
Вот из-за этих ощущений я и полез в модем посмотреть что да как там
СообщениеДобавлено: Пт мар 13, 2009 04:35
прошилось всё нормально, только увеличился ping и тормозит связь
СообщениеДобавлено: Пт мар 13, 2009 10:11
от такэ
С нашими IPDSLAM (DAS-32xx Rev.B) такие проблемы не наблюдаются, ATM OAM F5 проходит нормально:
Test your ENET Connection: PASS Help
Для пользователя данная проблема не является критической, но запрос сделаю. Для этого необходимо знать, какой DSLAM у Вашего провайдера?
